[U-Boot] [PATCH] pxe: Fix pxe boot with FIT image
When FIT image is used, a single image provides kernel, device tree and optionally ramdisk. Argc and argv need to be adjusted to support this.
Signed-off-by: York Sun york.sun@nxp.com --- cmd/pxe.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/cmd/pxe.c b/cmd/pxe.c index 9434a18..0a07f14 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -620,7 +620,7 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) char initrd_str[22]; char mac_str[29] = ""; char ip_str[68] = ""; - int bootm_argc = 3; + int bootm_argc = 2; int len = 0; ulong kernel_addr; void *buf; @@ -652,8 +652,6 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) strcpy(bootm_argv[2], getenv("ramdisk_addr_r")); strcat(bootm_argv[2], ":"); strcat(bootm_argv[2], getenv("filesize")); - } else { - bootm_argv[2] = "-"; }
if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) { @@ -785,8 +783,11 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) if (!bootm_argv[3]) bootm_argv[3] = getenv("fdt_addr");
- if (bootm_argv[3]) + if (bootm_argv[3]) { + if (!bootm_argv[2]) + bootm_argv[2] = "-"; bootm_argc = 4; + }
kernel_addr = genimg_get_kernel_addr(bootm_argv[1]); buf = map_sysmem(kernel_addr, 0);
+Tom
I cannot see this patch in patchwork - Tom do you know if there is anything wrong?
- Simon
int bootm_argc = 3;
} else {
bootm_argv[2] = "-"; } if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) {
if (bootm_argv[3])
if (!bootm_argv[2])
} kernel_addr = genimg_get_kernel_addr(bootm_argv[1]); buf = map_sysmem(kernel_addr, 0);
-- 2.1.0.27.g96db324
Recently I have seen mails not reaching mailing list many times. Not sure if it was our email server issue.
York
-------- Original Message -------- From: Simon Glass sjg@chromium.org Sent: Thursday, August 4, 2016 06:37 PM To: Wenbin Song wenbin.song@nxp.com Subject: Re: [PATCH] pxe: Fix pxe boot with FIT image CC: Bin Meng bmeng.cn@gmail.com,Heiko Schocher hs@denx.de,Przemyslaw Marczak p.marczak@samsung.com,Stefan Roese sr@denx.de,york sun york.sun@nxp.com,U-Boot Mailing List u-boot@lists.denx.de,Mingkai Hu mingkai.hu@nxp.com,Qianyu Gong qianyu.gong@nxp.com,Shaohui Xie shaohui.xie@nxp.com,zhiqian.hou@nxp.com,Tom Rini trini@konsulko.com
+Tom
- Simon
int bootm_argc = 3;
} else {
if (bootm_argv[3])
if (!bootm_argv[2])
What would you advise?
Thanks.
Best Regards Wenbin Song
-----Original Message----- From: Wenbin song [mailto:wenbin.song@nxp.com] Sent: Thursday, August 04, 2016 3:45 PM To: sjg@chromium.org; bmeng.cn@gmail.com; hs@denx.de; p.marczak@samsung.com; sr@denx.de; york sun york.sun@nxp.com; u- boot@lists.denx.de; Mingkai Hu mingkai.hu@nxp.com; Wenbin Song wenbin.song@nxp.com; Qianyu Gong qianyu.gong@nxp.com; Shaohui Xie shaohui.xie@nxp.com; zhiqian.hou@nxp.com Subject: [PATCH] pxe: Fix pxe boot with FIT image
- int bootm_argc = 2; int len = 0; ulong kernel_addr; void *buf;
} else {
if (!bootm_argv[2])
bootm_argc = 4;
Resend if necessary.
In the mean time, get the msg id and open an internal ticket for mail team to track down the log. I did it before and I found the mail wasn't even delivered to the mailing list. But they were not able to find out why.
York
Can you please confirm you tested the other common cases of PXE booting still work with this change? Thanks!
Hi, Tom
Yes, I have tested all kinds of cases.
-----Original Message----- From: Tom Rini [mailto:trini@konsulko.com] Sent: Tuesday, August 30, 2016 8:22 AM To: Wenbin Song wenbin.song@nxp.com Cc: sjg@chromium.org; bmeng.cn@gmail.com; hs@denx.de; p.marczak@samsung.com; sr@denx.de; york sun york.sun@nxp.com; u- boot@lists.denx.de; Mingkai Hu mingkai.hu@nxp.com; Qianyu Gong qianyu.gong@nxp.com; Shaohui Xie shaohui.xie@nxp.com; zhiqian.hou@nxp.com Subject: Re: [U-Boot] [PATCH] pxe: Fix pxe boot with FIT image
-- Tom
participants (5)
Wenbin Song
Wenbin song
york sun
