[PATCH v2] arm64: zynqmp: Add support for u-boot.itb generation with ATF
Follow i.MX, Sunxi, RISC-V and Rockchip to generate u-boot.itb which includes U-Boot proper, ATF and DTBs in FIT format. ZynqMP supports FIT for quite a long time but with using out of tree solution. The patch is filling this gap.
Tested on zcu102, zcu104 and zcu100/Ultra96.
zcu100/Ultra96 v2.2 ATF build by: make DEBUG=0 ZYNQMP_CONSOLE=cadence1 RESET_TO_BL31=1 PLAT=zynqmp bl31
Changes in v2: - Exchange u-boot/atf in config section - Use default ATF baseaddr from mainline - Update commit message
Kconfig | 3 +- arch/arm/mach-zynqmp/mkimage_fit_atf.sh | 99 +++++++++++++++++++++++++ include/configs/xilinx_zynqmp.h | 6 +- 3 files changed, 106 insertions(+), 2 deletions(-) create mode 100755 arch/arm/mach-zynqmp/mkimage_fit_atf.sh
diff --git a/Kconfig b/Kconfig index e22417ec4471..7efafffec0a4 100644 --- a/Kconfig +++ b/Kconfig @@ -253,7 +253,7 @@ config BUILD_TARGET default "u-boot-spl.kwb" if ARCH_MVEBU && SPL default "u-boot-elf.srec" if RCAR_GEN3 default "u-boot.itb" if SPL_LOAD_FIT && (ARCH_ROCKCHIP || \ - ARCH_SUNXI || RISCV) + ARCH_SUNXI || RISCV || ARCH_ZYNQMP) default "u-boot.kwb" if KIRKWOOD default "u-boot-with-spl.bin" if ARCH_AT91 && SPL_NAND_SUPPORT default "u-boot-with-spl.imx" if ARCH_MX6 && SPL @@ -481,6 +481,7 @@ config SPL_FIT_GENERATOR depends on SPL_FIT default "board/sunxi/mksunxi_fit_atf.sh" if SPL_LOAD_FIT && ARCH_SUNXI default "arch/arm/mach-rockchip/make_fit_atf.py" if SPL_LOAD_FIT && ARCH_ROCKCHIP + default "arch/arm/mach-zynqmp/mkimage_fit_atf.sh" if SPL_LOAD_FIT && ARCH_ZYNQMP default "arch/riscv/lib/mkimage_fit_opensbi.sh" if SPL_LOAD_FIT && RISCV help Specifies a (platform specific) script file to generate the FIT diff --git a/arch/arm/mach-zynqmp/mkimage_fit_atf.sh b/arch/arm/mach-zynqmp/mkimage_fit_atf.sh new file mode 100755 index 000000000000..c50aba45ca5c --- /dev/null +++ b/arch/arm/mach-zynqmp/mkimage_fit_atf.sh @@ -0,0 +1,99 @@ +#!/bin/sh +# SPDX-License-Identifier: GPL-2.0+ +# +# script to generate FIT image source for Xilinx ZynqMP boards with +# ARM Trusted Firmware and multiple device trees (given on the command line) +# +# usage: $0 <dt_name> [<dt_name> [<dt_name] ...] + +BL33="u-boot-nodtb.bin" +[ -z "$BL31" ] && BL31="bl31.bin" +[ -z "$ATF_LOAD_ADDR" ] && ATF_LOAD_ADDR="0xfffea000" +[ -z "$BL33_LOAD_ADDR" ] && BL33_LOAD_ADDR="0x8000000" + +if [ ! -f $BL31 ]; then + echo "ERROR: BL31 file $BL31 NOT found" >&2 +else + echo "$BL31 size: " >&2 + ls -lct $BL31 | awk '{print $5}' >&2 +fi + + + +cat << __HEADER_EOF +/dts-v1/; + +/ { + description = "Configuration to load ATF before U-Boot"; + + images { + uboot { + description = "U-Boot (64-bit)"; + data = /incbin/("$BL33"); + type = "firmware"; + os = "u-boot"; + arch = "arm64"; + compression = "none"; + load = <$BL33_LOAD_ADDR>; + hash { + algo = "md5"; + }; + }; + atf { + description = "ARM Trusted Firmware"; + data = /incbin/("$BL31"); + type = "firmware"; + os = "arm-trusted-firmware"; + arch = "arm64"; + compression = "none"; + load = <$ATF_LOAD_ADDR>; + entry = <$ATF_LOAD_ADDR>; + hash { + algo = "md5"; + }; + }; +__HEADER_EOF + +cnt=1 +for dtname in $* +do + cat << __FDT_IMAGE_EOF + fdt_$cnt { + description = "$(basename $dtname .dtb)"; + data = /incbin/("$dtname"); + type = "flat_dt"; + arch = "arm64"; + compression = "none"; + hash { + algo = "md5"; + }; + }; +__FDT_IMAGE_EOF +cnt=$((cnt+1)) +done + +cat << __CONF_HEADER_EOF + }; + configurations { + default = "config_1"; + +__CONF_HEADER_EOF + +cnt=1 +for dtname in $* +do +cat << __CONF_SECTION1_EOF + config_$cnt { + description = "$(basename $dtname .dtb)"; + firmware = "atf"; + loadables = "uboot"; + fdt = "fdt_$cnt"; + }; +__CONF_SECTION1_EOF +cnt=$((cnt+1)) +done + +cat << __ITS_EOF + }; +}; +__ITS_EOF diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index ee1ceebf1291..e7eb8dbfcb45 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -243,7 +243,11 @@ # define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0 /* unused */ # define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0 /* unused */ # define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0 /* unused */ -# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +# if defined(CONFIG_SPL_LOAD_FIT) +# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.itb" +# else +# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +# endif #endif
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_DFU)
Changes in v2:
My only complaint here is adding and N'th version of mkimage_fit_atf.sh that varies seemingly only in addresses. Can we not abstract this enough to make it for everyone to use and pass in the needed values?
Changes in v2:
First of all I will be sending v3 because of other things I found.
Adding more folks to this.
I have went through all versions and here is sort of stat:
board/sunxi/mksunxi_fit_atf.sh - firmware is uboot, atf loadables (not standard)
board/theobroma-systems/puma_rk3399/fit_spl_atf.sh - license present atf, uboot, pmufw (only present here)
arch/arm/mach-rockchip/make_fit_atf.py - python (only one) and read addresses from elfs
arch/arm/mach-rockchip/fit_spl_optee.sh - firmware is tee(no ATF)
arch/riscv/lib/mkimage_fit_opensbi.sh - reads stuff from .config and also handles non DT case
arch/arm/mach-imx/mkimage_fit_atf.sh - optee, atf, incorrect dt nodes names
And of course this one.
I think the key point here is to start talk about how this should be done. Language? One is python others are shell scripts.
Should it stop when ATF/TEE is not found?
What file to read to get information from u-boot? .config or include/generated/autoconf.h?
Read information about locations from ELFs?
Should we handle non DT case? Yes?
Move just DT generation to common location and keep VARs, file checking in board/arch scripts?
Thanks, Michal
Changes in v2:
Thanks for looking more here.
I don't have a hard preference here. I think the reason we have one in Python is for ease of working with ELF. Restrictions / issues like that probably mean it would be best to make sure we pick a language that allows for peeking at ELFs but I have not confirmed if we could easily re-do the rockchip python tool in shell by using a standard tool (objdump or similar from binutils, so we'll certainly have it).
For CI it must non-fatally complete, but should also be verbose in that the resulting binary is non-functional.
Honestly? I'd like to start looking at something better if we can here as these are not really user-configurable values, but system values. Some property under a -u-boot.dtsi file?
Sorry, non-DT case in this instance meaning what? We're talking about FIT and FIT uses a DT.
High level, this sounds right. Thanks!
Changes in v2:
I expect that all addresses are just entry points of these elfs It means something like this should be enough. readelf -l bl31.elf | awk '/Entry point/ { print $3 }'
ok.
I still have one ancient branch to get rid of all u-boot,dm* variables from nodes and move them to chosen node where they should be. Can you please elaborate on this more?
With OF_BOARD configurations where DT can be stored somewhere else there could be use cases that you want to have FIT without DT.
I would like to get more feedback from others to agreed how this should be done before anybody invest time for doing it.
Thanks, Michal
Changes in v2:
OK. Then we should probably stick to shell.
ok.
Well, it's been pointed out before, and I agree, that a lot of things we have had historically in CONFIG_xxx symbols are things that just aren't appropriate for Kconfig (users shouldn't change them, putting N default values in Kconfig is ugly, etc). While devicetree-the-in-kernel-file is to describe the hardware, devicetree-the-syntax is something we use for other things (FIT images) and other projects take even farther. So I've been thinking that devicetree-the-syntax seems like a good way to handle this particular problem. Where it all goes, I don't know.
Michal Simek
