[U-Boot] [PATCH 1/2] Removed CONFIG_NUM_CPUS for 85xx and 86xx Freescale processors.
The number of CPUs are getting detected dynamically by checking the processor SVR value. Also removed CONFIG_NUM_CPUS references from all the platforms with 85xx/86xx processors.
This can help to use the same u-boot image across the platforms.
Also revamped and corrected few Freescale Copyright messages.
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com --- common/cmd_mp.c | 6 +- cpu/mpc85xx/cpu.c | 111 ++++++++++++++++++++++++++--------------- cpu/mpc85xx/mp.c | 6 +- cpu/mpc85xx/release.S | 25 +++++++++- cpu/mpc85xx/speed.c | 4 +- cpu/mpc86xx/cpu.c | 44 ++++++++++++++-- cpu/mpc86xx/cpu_init.c | 2 +- include/asm-ppc/config.h | 41 +++++++++++++++ include/asm-ppc/global_data.h | 4 ++ include/asm-ppc/processor.h | 5 +- include/common.h | 2 + include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P2020DS.h | 1 - include/configs/XPEDITE5170.h | 1 - include/configs/XPEDITE5370.h | 1 - include/configs/sbc8641d.h | 1 - include/e500.h | 6 +-- lib_ppc/board.c | 4 ++ lib_ppc/bootm.c | 2 +- 21 files changed, 197 insertions(+), 72 deletions(-)
diff --git a/common/cmd_mp.c b/common/cmd_mp.c index faa8700..4f2c639 100644 --- a/common/cmd_mp.c +++ b/common/cmd_mp.c @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright (C) 2008-2009 Freescale Semiconductor, Inc. All rights reserved. * * See file CREDITS for list of people who contributed to this * project. @@ -34,9 +34,9 @@ cpu_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) }
cpuid = simple_strtoul(argv[1], NULL, 10); - if (cpuid >= CONFIG_NUM_CPUS) { + if (cpuid >= cpu_numcores()) { printf ("Core num: %lu is out of range[0..%d]\n", - cpuid, CONFIG_NUM_CPUS - 1); + cpuid, cpu_numcores() - 1); return 1; }
diff --git a/cpu/mpc85xx/cpu.c b/cpu/mpc85xx/cpu.c index 28c6119..ff7bff1 100644 --- a/cpu/mpc85xx/cpu.c +++ b/cpu/mpc85xx/cpu.c @@ -1,5 +1,5 @@ /* - * Copyright 2004,2007,2008 Freescale Semiconductor, Inc. + * Copyright(C) 2004,2007-2009 Freescale Semiconductor, Inc. All rights reserved. * (C) Copyright 2002, 2003 Motorola Inc. * Xianghua Xiao (X.Xiao@motorola.com) * @@ -38,37 +38,37 @@ DECLARE_GLOBAL_DATA_PTR;
struct cpu_type cpu_type_list [] = { - CPU_TYPE_ENTRY(8533, 8533), - CPU_TYPE_ENTRY(8533, 8533_E), - CPU_TYPE_ENTRY(8535, 8535), - CPU_TYPE_ENTRY(8535, 8535_E), - CPU_TYPE_ENTRY(8536, 8536), - CPU_TYPE_ENTRY(8536, 8536_E), - CPU_TYPE_ENTRY(8540, 8540), - CPU_TYPE_ENTRY(8541, 8541), - CPU_TYPE_ENTRY(8541, 8541_E), - CPU_TYPE_ENTRY(8543, 8543), - CPU_TYPE_ENTRY(8543, 8543_E), - CPU_TYPE_ENTRY(8544, 8544), - CPU_TYPE_ENTRY(8544, 8544_E), - CPU_TYPE_ENTRY(8545, 8545), - CPU_TYPE_ENTRY(8545, 8545_E), - CPU_TYPE_ENTRY(8547, 8547_E), - CPU_TYPE_ENTRY(8548, 8548), - CPU_TYPE_ENTRY(8548, 8548_E), - CPU_TYPE_ENTRY(8555, 8555), - CPU_TYPE_ENTRY(8555, 8555_E), - CPU_TYPE_ENTRY(8560, 8560), - CPU_TYPE_ENTRY(8567, 8567), - CPU_TYPE_ENTRY(8567, 8567_E), - CPU_TYPE_ENTRY(8568, 8568), - CPU_TYPE_ENTRY(8568, 8568_E), - CPU_TYPE_ENTRY(8569, 8569), - CPU_TYPE_ENTRY(8569, 8569_E), - CPU_TYPE_ENTRY(8572, 8572), - CPU_TYPE_ENTRY(8572, 8572_E), - CPU_TYPE_ENTRY(P2020, P2020), - CPU_TYPE_ENTRY(P2020, P2020_E), + CPU_TYPE_ENTRY(8533, 8533, 1), + CPU_TYPE_ENTRY(8533, 8533_E, 1), + CPU_TYPE_ENTRY(8535, 8535, 1), + CPU_TYPE_ENTRY(8535, 8535_E, 1), + CPU_TYPE_ENTRY(8536, 8536, 1), + CPU_TYPE_ENTRY(8536, 8536_E, 1), + CPU_TYPE_ENTRY(8540, 8540, 1), + CPU_TYPE_ENTRY(8541, 8541, 1), + CPU_TYPE_ENTRY(8541, 8541_E, 1), + CPU_TYPE_ENTRY(8543, 8543, 1), + CPU_TYPE_ENTRY(8543, 8543_E, 1), + CPU_TYPE_ENTRY(8544, 8544, 1), + CPU_TYPE_ENTRY(8544, 8544_E, 1), + CPU_TYPE_ENTRY(8545, 8545, 1), + CPU_TYPE_ENTRY(8545, 8545_E, 1), + CPU_TYPE_ENTRY(8547, 8547_E, 1), + CPU_TYPE_ENTRY(8548, 8548, 1), + CPU_TYPE_ENTRY(8548, 8548_E, 1), + CPU_TYPE_ENTRY(8555, 8555, 1), + CPU_TYPE_ENTRY(8555, 8555_E, 1), + CPU_TYPE_ENTRY(8560, 8560, 1), + CPU_TYPE_ENTRY(8567, 8567, 1), + CPU_TYPE_ENTRY(8567, 8567_E, 1), + CPU_TYPE_ENTRY(8568, 8568, 1), + CPU_TYPE_ENTRY(8568, 8568_E, 1), + CPU_TYPE_ENTRY(8569, 8569, 1), + CPU_TYPE_ENTRY(8569, 8569_E, 1), + CPU_TYPE_ENTRY(8572, 8572, 2), + CPU_TYPE_ENTRY(8572, 8572_E, 2), + CPU_TYPE_ENTRY(P2020, P2020, 2), + CPU_TYPE_ENTRY(P2020, P2020_E, 2), };
struct cpu_type *identify_cpu(u32 ver) @@ -81,6 +81,26 @@ struct cpu_type *identify_cpu(u32 ver) return NULL; }
+int cpu_numcores() { + struct cpu_type *cpu; + cpu = gd->cpu; + return cpu->num_cores; +} + + +int probecpu (void) +{ + uint svr; + uint ver; + + svr = get_svr(); + ver = SVR_SOC_VER(svr); + + gd->cpu = identify_cpu(ver); + + return 0; +} + int checkcpu (void) { sys_info_t sysinfo; @@ -100,22 +120,31 @@ int checkcpu (void) int i;
svr = get_svr(); - ver = SVR_SOC_VER(svr); major = SVR_MAJ(svr); #ifdef CONFIG_MPC8536 major &= 0x7; /* the msb of this nibble is a mfg code */ #endif minor = SVR_MIN(svr);
-#if (CONFIG_NUM_CPUS > 1) - volatile ccsr_pic_t *pic = (void *)(CONFIG_SYS_MPC85xx_PIC_ADDR); - printf("CPU%d: ", pic->whoami); -#else - puts("CPU: "); +#ifndef CONFIG_MP + if (cpu_numcores() > 1) + puts("#############################################\n" + "The system is detected to be MULTICORE,\n" + "but u-boot is built with UNI-CORE\n" + "To enable mutlticore Build set CONFIG_MP\n" + "#############################################\n\n"); #endif
- cpu = identify_cpu(ver); - if (cpu) { + if (cpu_numcores() > 1) { + volatile ccsr_pic_t *pic = (void *)(CONFIG_SYS_MPC85xx_PIC_ADDR); + printf("CPU%d: ", pic->whoami); + } + else + puts("CPU: "); + + cpu = gd->cpu; + + if (cpu->name) { puts(cpu->name);
if (IS_E_PROCESSOR(svr)) @@ -150,7 +179,7 @@ int checkcpu (void) get_sys_info(&sysinfo);
puts("Clock Configuration:"); - for (i = 0; i < CONFIG_NUM_CPUS; i++) { + for (i = 0; i < cpu_numcores(); i++) { if (!(i & 3)) printf ("\n "); printf("CPU%d:%-4s MHz, ", diff --git a/cpu/mpc85xx/mp.c b/cpu/mpc85xx/mp.c index 76f02a4..9f1f9d7 100644 --- a/cpu/mpc85xx/mp.c +++ b/cpu/mpc85xx/mp.c @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor. + * Copyright (C) 2008-2009 Freescale Semiconductor, Inc. All rights reserved. * * See file CREDITS for list of people who contributed to this * project. @@ -157,7 +157,7 @@ static void pq3_mp_up(unsigned long bootpg) out_be32(&gur->devdisr, devdisr);
/* release the hounds */ - up = ((1 << CONFIG_NUM_CPUS) - 1); + up = ((1 << cpu_numcores()) - 1); bpcr = in_be32(&ecm->eebpcr); bpcr |= (up << 24); out_be32(&ecm->eebpcr, bpcr); @@ -167,7 +167,7 @@ static void pq3_mp_up(unsigned long bootpg) /* wait for everyone */ while (timeout) { int i; - for (i = 0; i < CONFIG_NUM_CPUS; i++) { + for (i = 0; i < cpu_numcores(); i++) { if (table[i * NUM_BOOT_ENTRY + BOOT_ENTRY_ADDR_LOWER]) cpu_up_mask |= (1 << i); }; diff --git a/cpu/mpc85xx/release.S b/cpu/mpc85xx/release.S index fbefc2c..e553079 100644 --- a/cpu/mpc85xx/release.S +++ b/cpu/mpc85xx/release.S @@ -1,3 +1,26 @@ +/* + * Copyright (C) 2008-2009 Freescale Semiconductor, Inc. All rights reserved. + * Kumar Gala kumar.gala@freescale.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + #include <config.h> #include <mpc85xx.h> #include <version.h> @@ -203,7 +226,7 @@ __secondary_start_page: .align L1_CACHE_SHIFT .globl __spin_table __spin_table: - .space CONFIG_NUM_CPUS*ENTRY_SIZE + .space CONFIG_MAX_CPUS*ENTRY_SIZE
/* Fill in the empty space. The actual reset vector is * the last word of the page */ diff --git a/cpu/mpc85xx/speed.c b/cpu/mpc85xx/speed.c index 286b6b2..ea7afad 100644 --- a/cpu/mpc85xx/speed.c +++ b/cpu/mpc85xx/speed.c @@ -1,5 +1,5 @@ /* - * Copyright 2004, 2007-2009 Freescale Semiconductor Inc. + * Copyright (C) 2004, 2007-2009 Freescale Semiconductor, Inc. All rights reserved. * (C) Copyright 2003 Motorola Inc. * Xianghua Xiao, (X.Xiao@motorola.com) * @@ -51,7 +51,7 @@ void get_sys_info (sys_info_t * sysInfo) /* Divide before multiply to avoid integer * overflow for processor speeds above 2GHz */ half_freqSystemBus = sysInfo->freqSystemBus/2; - for (i = 0; i < CONFIG_NUM_CPUS; i++) { + for (i = 0; i < cpu_numcores(); i++) { e500_ratio = ((gur->porpllsr) >> (i * 8 + 16)) & 0x3f; sysInfo->freqProcessor[i] = e500_ratio * half_freqSystemBus; } diff --git a/cpu/mpc86xx/cpu.c b/cpu/mpc86xx/cpu.c index bc64286..37fbd3d 100644 --- a/cpu/mpc86xx/cpu.c +++ b/cpu/mpc86xx/cpu.c @@ -1,4 +1,5 @@ /* + * Copyright(C) 2009 Freescale Semiconductor, Inc. * Copyright 2006 Freescale Semiconductor * Jeff Brown * Srikanth Srinivasan (srikanth.srinivasan@freescale.com) @@ -31,10 +32,12 @@ #include <tsec.h> #include <asm/fsl_law.h>
+DECLARE_GLOBAL_DATA_PTR; + struct cpu_type cpu_type_list [] = { - CPU_TYPE_ENTRY(8610, 8610), - CPU_TYPE_ENTRY(8641, 8641), - CPU_TYPE_ENTRY(8641D, 8641D), + CPU_TYPE_ENTRY(8610, 8610, 1), + CPU_TYPE_ENTRY(8641, 8641, 2), + CPU_TYPE_ENTRY(8641D, 8641D, 2), };
struct cpu_type *identify_cpu(u32 ver) @@ -47,6 +50,25 @@ struct cpu_type *identify_cpu(u32 ver) return NULL; }
+int probecpu (void) +{ + uint svr; + uint ver; + + svr = get_svr(); + ver = SVR_SOC_VER(svr); + + gd->cpu = identify_cpu(ver); + + return 0; +} + +int cpu_numcores() { + struct cpu_type *cpu; + cpu = gd->cpu; + return cpu->num_cores; +} + /* * Default board reset function */ @@ -66,9 +88,9 @@ checkcpu(void) uint ver; uint major, minor; char buf1[32], buf2[32]; + struct cpu_type *cpu; volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; volatile ccsr_gur_t *gur = &immap->im_gur; - struct cpu_type *cpu; uint msscr0 = mfspr(MSSCR0);
svr = get_svr(); @@ -76,10 +98,20 @@ checkcpu(void) major = SVR_MAJ(svr); minor = SVR_MIN(svr);
+#ifndef CONFIG_MP + if (cpu_numcores() > 1) + puts("#############################################\n" + "The system is detected to be MULTICORE,\n" + "but u-boot is built with UNI-CORE\n" + "To enable mutlticore Build set CONFIG_MP\n" + "#############################################\n\n"); +#endif + puts("CPU: ");
- cpu = identify_cpu(ver); - if (cpu) { + cpu = gd->cpu; + + if (cpu->name) { puts(cpu->name); } else { puts("Unknown"); diff --git a/cpu/mpc86xx/cpu_init.c b/cpu/mpc86xx/cpu_init.c index 341e815..c8b499c 100644 --- a/cpu/mpc86xx/cpu_init.c +++ b/cpu/mpc86xx/cpu_init.c @@ -129,7 +129,7 @@ void cpu_init_f(void) */ int cpu_init_r(void) { -#if (CONFIG_NUM_CPUS > 1) +#if defined(CONFIG_MP) setup_mp(); #endif return 0; diff --git a/include/asm-ppc/config.h b/include/asm-ppc/config.h index ca143c7..b799a22 100644 --- a/include/asm-ppc/config.h +++ b/include/asm-ppc/config.h @@ -37,4 +37,45 @@ #endif #endif
+#if defined(CONFIG_MPC8533) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8535) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8536) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8540) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8541) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8543) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8544) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8545) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8547) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8548) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8555) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8560) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8567) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8568) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8569) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8572) +#define CONFIG_MAX_CPUS 2 +#elif defined(CONFIG_P2020) +#define CONFIG_MAX_CPUS 2 + +#elif defined(CONFIG_MPC8610) +#define CONFIG_MAX_CPUS 1 +#elif defined(CONFIG_MPC8641) +#define CONFIG_MAX_CPUS 2 +#endif + #endif /* _ASM_CONFIG_H_ */ diff --git a/include/asm-ppc/global_data.h b/include/asm-ppc/global_data.h index 244c161..aa531b9 100644 --- a/include/asm-ppc/global_data.h +++ b/include/asm-ppc/global_data.h @@ -1,4 +1,5 @@ /* + * Copyright (C) 2009 Freescale Semiconductor, Inc. All rights reserved. * (C) Copyright 2002 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * @@ -92,6 +93,9 @@ typedef struct global_data { #if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) u32 lbc_clk; #endif /* CONFIG_MPC85xx || CONFIG_MPC86xx */ +#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) + void *cpu; +#endif #if defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) u32 i2c1_clk; u32 i2c2_clk; diff --git a/include/asm-ppc/processor.h b/include/asm-ppc/processor.h index 65546ad..a060697 100644 --- a/include/asm-ppc/processor.h +++ b/include/asm-ppc/processor.h @@ -1017,13 +1017,14 @@ n: struct cpu_type { char name[15]; u32 soc_ver; + u32 num_cores; };
struct cpu_type *identify_cpu(u32 ver);
#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) -#define CPU_TYPE_ENTRY(n, v) \ - { .name = #n, .soc_ver = SVR_##v, } +#define CPU_TYPE_ENTRY(n, v, nc) \ + { .name = #n, .soc_ver = SVR_##v, .num_cores = (nc), } #else #if defined(CONFIG_MPC83xx) #define CPU_TYPE_ENTRY(x) {#x, SPR_##x} diff --git a/include/common.h b/include/common.h index 6284b8a..ab5b4f8 100644 --- a/include/common.h +++ b/include/common.h @@ -439,6 +439,8 @@ void ppcDWstore(unsigned int *addr, unsigned int *value); #endif
/* $(CPU)/cpu.c */ +int cpu_numcores (void); +int probecpu (void); int checkcpu (void); int checkicache (void); int checkdcache (void); diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 6f1b1a4..d542510 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -34,7 +34,6 @@ #define CONFIG_MPC8572 1 #define CONFIG_MPC8572DS 1 #define CONFIG_MP 1 /* support multiple processors */ -#define CONFIG_NUM_CPUS 2 /* Number of CPUs in the system */
#define CONFIG_FSL_ELBC 1 /* Has Enhanced localbus controller */ #define CONFIG_PCI 1 /* Enable PCI/PCIE */ diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 1091043..45932ef 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -17,7 +17,6 @@ #define CONFIG_MPC86xx 1 /* MPC86xx */ #define CONFIG_MPC8610 1 /* MPC8610 specific */ #define CONFIG_MPC8610HPCD 1 /* MPC8610HPCD board specific */ -#define CONFIG_NUM_CPUS 1 /* Number of CPUs in the system */ #define CONFIG_LINUX_RESET_VEC 0x100 /* Reset vector used by Linux */
#define CONFIG_FSL_DIU_FB 1 /* FSL DIU */ diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 035874b..a878850 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -37,7 +37,6 @@ #define CONFIG_MPC8641 1 /* MPC8641 specific */ #define CONFIG_MPC8641HPCN 1 /* MPC8641HPCN board specific */ #define CONFIG_MP 1 /* support multiple processors */ -#define CONFIG_NUM_CPUS 2 /* Number of CPUs in the system */ #define CONFIG_LINUX_RESET_VEC 0x100 /* Reset vector used by Linux */ /*#define CONFIG_PHYS_64BIT 1*/ /* Place devices in 36-bit space */ #define CONFIG_ADDR_MAP 1 /* Use addr map */ diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index 9306860..0d2475a 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -34,7 +34,6 @@ #define CONFIG_P2020 1 #define CONFIG_P2020DS 1 #define CONFIG_MP 1 /* support multiple processors */ -#define CONFIG_NUM_CPUS 2 /* Number of CPUs in the system */
#define CONFIG_FSL_ELBC 1 /* Has Enhanced localbus controller */ #define CONFIG_PCI 1 /* Enable PCI/PCIE */ diff --git a/include/configs/XPEDITE5170.h b/include/configs/XPEDITE5170.h index 2553293..a572fd0 100644 --- a/include/configs/XPEDITE5170.h +++ b/include/configs/XPEDITE5170.h @@ -34,7 +34,6 @@ #define CONFIG_MPC8641 1 /* MPC8641 specific */ #define CONFIG_XPEDITE5140 1 /* MPC8641HPCN board specific */ #define CONFIG_SYS_BOARD_NAME "XPedite5170" -#define CONFIG_NUM_CPUS 1 /* Number of CPUs in the system */ #define CONFIG_LINUX_RESET_VEC 0x100 /* Reset vector used by Linux */ #define CONFIG_BOARD_EARLY_INIT_R /* Call board_pre_init */ #define CONFIG_RELOC_FIXUP_WORKS /* Fully relocate to SDRAM */ diff --git a/include/configs/XPEDITE5370.h b/include/configs/XPEDITE5370.h index 536e063..422dab3 100644 --- a/include/configs/XPEDITE5370.h +++ b/include/configs/XPEDITE5370.h @@ -36,7 +36,6 @@ #define CONFIG_MPC8572 1 #define CONFIG_XPEDITE5370 1 #define CONFIG_SYS_BOARD_NAME "XPedite5370" -#define CONFIG_NUM_CPUS 2 /* 2 Cores */ #define CONFIG_BOARD_EARLY_INIT_R /* Call board_pre_init */ #define CONFIG_RELOC_FIXUP_WORKS /* Fully relocate to SDRAM */
diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index ef0f627..5376e4a 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -41,7 +41,6 @@ #define CONFIG_MPC8641 1 /* MPC8641 specific */ #define CONFIG_SBC8641D 1 /* SBC8641D board specific */ #define CONFIG_MP 1 /* support multiple processors */ -#define CONFIG_NUM_CPUS 2 /* Number of CPUs in the system */ #define CONFIG_LINUX_RESET_VEC 0x100 /* Reset vector used by Linux */
#ifdef RUN_DIAG diff --git a/include/e500.h b/include/e500.h index 84b580d..f8c8266 100644 --- a/include/e500.h +++ b/include/e500.h @@ -8,13 +8,9 @@
#ifndef __ASSEMBLY__
-#ifndef CONFIG_NUM_CPUS -#define CONFIG_NUM_CPUS 1 -#endif - typedef struct { - unsigned long freqProcessor[CONFIG_NUM_CPUS]; + unsigned long freqProcessor[CONFIG_MAX_CPUS]; unsigned long freqSystemBus; unsigned long freqDDRBus; unsigned long freqLocalBus; diff --git a/lib_ppc/board.c b/lib_ppc/board.c index 155171d..70dfe95 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -291,6 +291,10 @@ init_fnc_t *init_sequence[] = { board_early_init_f, #endif
+#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) + probecpu, +#endif + #if !defined(CONFIG_8xx_CPUCLK_DEFAULT) get_clocks, /* get CPU and bus clocks (etc.) */ #if defined(CONFIG_TQM8xxL) && !defined(CONFIG_TQM866M) \ diff --git a/lib_ppc/bootm.c b/lib_ppc/bootm.c index 0d702bf..dd1fcf1 100644 --- a/lib_ppc/bootm.c +++ b/lib_ppc/bootm.c @@ -170,7 +170,7 @@ void arch_lmb_reserve(struct lmb *lmb)
static void boot_prep_linux(void) { -#if (CONFIG_NUM_CPUS > 1) +#ifdef CONFIG_MP /* if we are MP make sure to flush the dcache() to any changes are made * visibile to all other cores */ flush_dcache();
Dear Poonam Aggrwal,
In message 1248173263-30516-1-git-send-email-poonam.aggrwal@freescale.com you wrote:
Please restrict your line length to 70 characters or less.
+#ifndef CONFIG_MP
- if (cpu_numcores() > 1)
#endif
Please use terse error messages. We don't print prose here.
- if (cpu) {
- if (cpu_numcores() > 1) {
- else
Incorrect brace style.
- for (i = 0; i < cpu_numcores(); i++) {
Only one space before the '<', please.
- uint svr;
- uint ver;
- svr = get_svr();
- gd->cpu = identify_cpu(ver);
- cpu = gd->cpu;
- return cpu->num_cores;
This seems to be identically repeated code. Please factor out into common code.
- Default board reset function
- struct cpu_type *cpu; volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; volatile ccsr_gur_t *gur = &immap->im_gur;
svr = get_svr();
+#ifndef CONFIG_MP
Ditto.
puts("CPU: ");
- if (cpu) {
- cpu = gd->cpu;
- if (cpu->name) { puts(cpu->name); } else {
No braces for one-line statements, please.
Sorry, but this does not scale. Please find a better solution.
- Copyright (C) 2009 Freescale Semiconductor, Inc. All rights reserved.
On which base to you make such a claim?
- (C) Copyright 2002
- Wolfgang Denk, DENX Software Engineering, wd@denx.de.
- void *cpu;
Because you added a sinle variable declaration? Come on, be reasonable...
- u32 num_cores;
- { .name = #n, .soc_ver = SVR_##v, .num_cores = (nc), }
typedef struct {
- unsigned long freqProcessor[CONFIG_MAX_CPUS]; unsigned long freqSystemBus; unsigned long freqDDRBus; unsigned long freqLocalBus;
- probecpu,
No empty line here, please.
is there a better solution? We effectively do things like this in the board CONFIG.h and its just duplicated for every board. Here its just isolated. Just wondering if you had any suggestions (I agree its ugly and if/when we get Kconfig its something that could be put there).
- k
Dear Kumar Gala,
In message D46E33D8-E298-4C7F-BF99-1B0269148AB8@kernel.crashing.org you wrote:
Well, no, sorry, I don't have any clever suggestion.
It would at least be a bit shorter if you used
#if defined(..) || defined(..) || defined(..) ... #define CONFIG_MAX_CPUS 1 #elif defined(..) || defined(..) || defined(..) ... #define CONFIG_MAX_CPUS 2 #else #error #endif
+#ifndef CONFIG_MP
#endif
- if (cpu) {
- else
- uint svr;
- uint ver;
- svr = get_svr();
- cpu = gd->cpu;
Actually the files cpu/mpc86xx/cpu.c cpu/mpc85xx/cpu.c are quite identical. Kumar, Please suggest how should this be taken care. Probably a single file to take care of 85xx and 86xx don't know?
svr = get_svr();
+#ifndef CONFIG_MP
Ditto.
puts("CPU: ");
- if (cpu) {
- cpu = gd->cpu;
rights reserved.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de You can only live once, but if you do it right, once is enough. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Aggrwal Poonam-B10812 Sent: Wednesday, July 22, 2009 3:45 PM To: Wolfgang Denk; Gala Kumar-B11780 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH 1/2] Removed CONFIG_NUM_CPUS for 85xx and86xxFreescale processors.
+#ifndef CONFIG_MP
#endif
- if (cpu) {
- else
- uint svr;
- uint ver;
- svr = get_svr();
- cpu = gd->cpu;
Just a request , I would like to close this as we need to push P2020RDB support quickly. Otherwise should I just go ahead with 85xx for now? Please suggest. Regards Poonam
Detlev Zundel
- uint svr;
- uint ver;
- svr = get_svr();
- cpu = gd->cpu;
We can move the code into cpu/mpc8xxx/cpu.c
- k
- cpu = gd->cpu;
Shouldn't this check CONFIG_MP and return 1 if not set? Otherwise you get a weird mix of MP and UP.
The checks to warn the user of a UP u-boot on an MP chip would have to reference cpu->num_cores directly, or we could add a hard_cpu_numcores(), or similar.
-Scott
-----Original Message----- From: Wood Scott-B07421 Sent: Wednesday, July 29, 2009 2:39 AM To: Aggrwal Poonam-B10812 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH 1/2] Removed CONFIG_NUM_CPUS for 85xx and 86xx Freescale processors.
- cpu = gd->cpu;
This function's intent is to just return the number of cores that the system has. This is more of kind of probong the actual hardware. The CONFIG_MP flag will take care of all the multicore stuff in u-boot.
-Scott
- cpu = gd->cpu;
-Scott
But you have places that call cpu_numcores() and do per-core stuff that don't check CONFIG_MP, as far as I can tell.
-Scott
participants (6)
Kumar Gala
Kumar Gala
Poonam Aggrwal
Scott Wood
