[PATCH v4] bloblist: fix bloblist convention check.
According to recently firmware handsoff spec [1]'s "Register usage at handoff boundary", Transfer List's signature value was changed from 0x40_b10b (3 bytes) to 4a0f_b10b (4 bytes).
As updating of TL's signature, register value of x1/r1 should be:
In aarch32's r1 value should be R1[23:0]: set to the TL signature (4a0f_b10b -> masked range value: 0f_b10b) R1[31:24]: version of the register convention == 1
and
In aarch64's x1 value should be X1[31:0]: set to the TL signature (4a0f_b10b) X1[39:32]: version of the register convention == 1 X1[63:40]: MBZ (See the [2] and [3]).
This patch fix problems: 1. breaking X1 value with updated specification in aarch64 - change of length of signature field.
2. previous error value set in R1 in arm32. - length of signature should be 24, but it uses 32bit signature.
This patch is a breaking change. It works only TF-A is updated.
Link: https://github.com/FirmwareHandoff/firmware_handoff [1] Link: https://github.com/FirmwareHandoff/firmware_handoff/issues/32 [2] Link: https://github.com/FirmwareHandoff/firmware_handoff/commit/5aa7aa1d3a1db7521... [3] Signed-off-by: Levi Yun yeoreum.yun@arm.com --- v4: - Remove FIXME tags on xfterlist.h - Modify commit message
v3: - Restore arch/arm/lib/xferlist.c
v2: - Modify commit message - Remove wrong swaping check in xferlist_from_boot_arg()
common/bloblist.c | 11 ++++++++++- include/bloblist.h | 10 ++++------ 2 files changed, 14 insertions(+), 7 deletions(-)
diff --git a/common/bloblist.c b/common/bloblist.c index 11d6422b69..2008ab4d25 100644 --- a/common/bloblist.c +++ b/common/bloblist.c @@ -576,7 +576,16 @@ int bloblist_maybe_init(void)
int bloblist_check_reg_conv(ulong rfdt, ulong rzero, ulong rsig) { - if (rzero || rsig != (BLOBLIST_MAGIC | BLOBLIST_REGCONV_VER) || + ulong version = BLOBLIST_REGCONV_VER; + ulong sigval; + + sigval = (IS_ENABLED(CONFIG_64BIT)) ? + ((BLOBLIST_MAGIC & ((1UL << BLOBLIST_REGCONV_SHIFT_64) - 1)) | + ((version & BLOBLIST_REGCONV_MASK) << BLOBLIST_REGCONV_SHIFT_64)) : + ((BLOBLIST_MAGIC & ((1UL << BLOBLIST_REGCONV_SHIFT_32) - 1)) | + ((version & BLOBLIST_REGCONV_MASK) << BLOBLIST_REGCONV_SHIFT_32)); + + if (rzero || rsig != sigval || rfdt != (ulong)bloblist_find(BLOBLISTT_CONTROL_FDT, 0)) { gd->bloblist = NULL; /* Reset the gd bloblist pointer */ return -EIO; diff --git a/include/bloblist.h b/include/bloblist.h index 7fbdd622bc..b0706b5637 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -78,12 +78,10 @@ enum { BLOBLIST_VERSION = 1, BLOBLIST_MAGIC = 0x4a0fb10b,
- /* - * FIXME: - * Register convention version should be placed into a higher byte - * https://github.com/FirmwareHandoff/firmware_handoff/issues/32 - */ - BLOBLIST_REGCONV_VER = 1 << 24, + BLOBLIST_REGCONV_SHIFT_64 = 32, + BLOBLIST_REGCONV_SHIFT_32 = 24, + BLOBLIST_REGCONV_MASK = 0xff, + BLOBLIST_REGCONV_VER = 1,
BLOBLIST_BLOB_ALIGN_LOG2 = 3, BLOBLIST_BLOB_ALIGN = 1 << BLOBLIST_BLOB_ALIGN_LOG2, -- LEVI:{C3F47F37-75D8-414A-A8BA-3980EC8A46D7}
Hi Levi,
and
v4:
v3:
v2:
ulong sigval;
* FIXME:
BLOBLIST_REGCONV_VER = 1, BLOBLIST_BLOB_ALIGN_LOG2 = 3, BLOBLIST_BLOB_ALIGN = 1 << BLOBLIST_BLOB_ALIGN_LOG2,
Feel free to add tag:
Reviewed-by: Raymond Mao raymond.mao@linaro.org
Regards, Raymond
On Wed, 10 Jul 2024 at 17:46, Raymond Mao raymond.mao@linaro.org wrote:
Hi Levi,
and
v4:
v3:
v2:
ulong sigval;
I'd argue that this is unnecessary, since the point of passing fdt in a register is to avoid having to search the bloblist for it.
* FIXME:
Feel free to add tag: Reviewed-by: Raymond Mao raymond.mao@linaro.org
Regards, Raymond
Levi Yun
Raymond Mao
