[U-Boot-Users] [GIT PULL] [ARM] Pleasepullfromgit://www.denx.de/git/u-boot-arm.git
Wolfgang Please pull from git://www.denx.de/git/u-boot-arm.git
This is the apollon port - tested on apollon by Kyungmin Park - MAKEALL tested by Peter Pearse
Signed-off-by: Peter Pearse peter.pearse@arm.com Signed-off-by: Kyungmin Park kmpark@infradead.org
Regards
Peter
--- The following changes since commit 5c740711f0ea5b51414b341b71597c4a0751be74: Jon Loeliger (1): 8610: Move include of config.h earlier.
are found in the git repository at:
Peter Pearse (5): Add apollon board support Merge with git://www.denx.de/git/u-boot.git Correction patch Remove warnings re CONFIG_EXTRA_ENV_SETTINGS Merge with git://www.denx.de/git/u-boot.git
MAKEALL | 1 + Makefile | 5 +- board/apollon/Makefile | 48 +++ board/apollon/apollon.c | 472 +++++++++++++++++++++++++++++++ board/apollon/config.mk | 25 ++ board/apollon/lowlevel_init.S | 337 ++++++++++++++++++++++ board/apollon/mem.c | 235 +++++++++++++++ board/apollon/mem.h | 170 +++++++++++ board/apollon/sys_info.c | 403 ++++++++++++++++++++++++++ board/apollon/u-boot.lds | 63 ++++ common/env_onenand.c | 4 +- include/asm-arm/arch-arm1136/mux.h | 18 ++ include/asm-arm/arch-arm1136/omap2420.h | 33 ++- include/asm-arm/mach-types.h | 13 + include/configs/apollon.h | 238 ++++++++++++++++ 15 files changed, 2058 insertions(+), 7 deletions(-) create mode 100644 board/apollon/Makefile create mode 100644 board/apollon/apollon.c create mode 100644 board/apollon/config.mk create mode 100644 board/apollon/lowlevel_init.S create mode 100644 board/apollon/mem.c create mode 100644 board/apollon/mem.h create mode 100644 board/apollon/sys_info.c create mode 100644 board/apollon/u-boot.lds create mode 100755 include/configs/apollon.h ---
Dear Peter,
Done, thanks.
But please pay more attention to the Coding style. There was C++ comments in include/configs/apollon.h, trailing white space in include/configs/apollon.h, indentation not by TABs in board/apollon/lowlevel_init.S etc. ...
Thanks I'll try harder next time.... Peter
-----Original Message----- From: wd@denx.de [mailto:wd@denx.de] Sent: 09 January 2008 10:37 To: Peter Pearse Cc: u-boot-users@lists.sourceforge.net; Kyungmin Park Subject: Re: [U-Boot-Users] [GIT PULL] [ARM] Pleasepullfromgit://www.denx.de/git/u-boot-arm.git
Dear Peter,
Done, thanks.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "I'm not a god, I was misquoted." - Lister, Red Dwarf
Peter Pearse
Peter Pearse
