[U-Boot] [PATCH 1/1] nios2 - adjust gbl data off to account for bd_info
* Adjust the GBL_DATA_OFFSET to account for the fact that we'll be using the space between that offset and the start of the malloc region to allocate both a gd structure and a board info structure.
* This fixes a memory corruption bug due to overlap of the malloc region and the bd_info structure.
Signed-off-by: Alex Hornung alex@alexhornung.com --- include/configs/nios2-generic.h | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index 9ba35e8..17017a5 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -131,7 +131,8 @@ #define CONFIG_SYS_MALLOC_BASE (CONFIG_SYS_MONITOR_BASE - \ CONFIG_SYS_MALLOC_LEN) #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_MALLOC_BASE - \ - GENERATED_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE - \ + GENERATED_BD_INFO_SIZE) #define CONFIG_SYS_INIT_SP CONFIG_SYS_GBL_DATA_OFFSET
Hi Alex,
Oh I really want to NAK this, but I think I might be out-voted
in arch/x86/lib/init_helpers.c I do:
bd_t bd_data;
int init_bd_struct_r(void) { gd->bd = &bd_data; memset(gd->bd, 0, sizeof(bd_t));
return 0; }
So the bd struct is in bss
But everyone else (ARM, PPC) seems to do:
addr_sp -= sizeof(bd_t); bd = (bd_t *) addr_sp;
Why?
Well I see that a lot of bd is setup while still running from flash, so bss is not available. But is this really necessary?
And for the sake of one more copy and pointer adjustment, even gd could be moved into bss which would save all the hackish calculations of sticking gd and bd in a magic void below the stack
But maybe that's a battle for another day...
Oh, and Nios is particularly nasty - It has no init_r / init_f so there is no support for relocation - Will there every be an intent to enable relocation for Nios or is it pointless?
Regards,
Graeme
Hi Graeme,
On 21/02/12 10:33, Graeme Russ wrote:
Hi Alex,
bd_t bd_data;
return 0; }
Why?
To be honest I just started using u-boot, and for that matter, just started using Nios2. I just ran across the issue and had to fix it to get u-boot working on my system.
Nonetheless I'd generally agree that less hackery is a better idea, and putting it in BSS is a good option - but reality is, as you point out, that most other platforms don't do that, either. For now I think the above patch should do.
As I mentioned I'm not really involved with u-boot on Nios, so I can't answer that question.
Cheers, Alex
Hi Alex,
On 02/23/2012 07:13 PM, Alex Hornung wrote:
Hi Graeme,
Hi Alex,
[snip]
I agree - as I said, a battle for another day :)
Regards,
Graeme
+cc the nios maintainers ... -mike
Signed-off-by: Alex Hornungalex@alexhornung.com
Dear Alex,
Applied. Thanks.
Best regards, Thomas
Alex Hornung
Graeme Russ
Mike Frysinger
Thomas Chou
