[U-Boot-Users] the ppc405ep u-boot (with jffs2 configure) failed
Hello,
I am a new user, try to get the u-boot(with jffs2) work on a ppc405ep board(32M Ram, 8M flash disk, one serial port, one network port), it will has one partition for u-boot(128k), the rest make one jffs2 partition, the kernel and initrd will locate in this JFFS2 partition.
First I build the u-boot.bin without configure jffs2 support, installed it to 405ep board flash memory, it works well, when turn on power, from serial port, I could get the prompt => and excute the u-boot command like setenv, saveenv.
But after I configure u-boot JFFS2 support in include/configs/PPC405EPVV.h, add 4 lines:
#define CONFIG_COMMANDS ( CFG_CMD_JFFS2 )
#define CFG_JFFS2_FIRST_BANK 0 #define CFG_JFFS2_FIRST_SECTOR 0 #define CFG_JFFS2_NUM_BANKS 1
(the 8M flash memery havs one bank, 64 sector.)
after make compile, I load this jffs2 configured u-boot.bin to flash memory, turn on power, but nothing happened on serial port, no display, no prompt =>, could not type command, it seems u-boot crashed.
I could not figure out how to fix the problem that adding jffs2 support crashed the u-boot.
thanks
Tyler
__________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
So you have at least these two partitions, right?
How many partitions did you configure here, and which sizes do they have?
Tyler Jia
