[PATCH 1/1] Azure: copy GRUB to correct build path
The GRUB binaries are expected in $UBOOT_TRAVIS_BUILD_DIR.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- .azure-pipelines.yml | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 98e8a4fe14..924bb9de41 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -294,10 +294,6 @@ jobs: ln -s travis-ci /tmp/uboot-test-hooks/py/`hostname` grub-mkimage --prefix="" -o ~/grub_x86.efi -O i386-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd grub-mkimage --prefix="" -o ~/grub_x64.efi -O x86_64-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd - cp /opt/grub/grubriscv64.efi ~/grub_riscv64.efi - cp /opt/grub/grubriscv32.efi ~/grub_riscv32.efi - cp /opt/grub/grubaa64.efi ~/grub_arm64.efi - cp /opt/grub/grubarm.efi ~/grub_arm.efi if [[ "${TEST_PY_BD}" == "qemu-riscv32_spl" ]]; then wget -O - https://github.com/riscv/opensbi/releases/download/v0.6/opensbi-0.6-rv32-bin... | tar -C /tmp -xJ; export OPENSBI=/tmp/opensbi-0.6-rv32-bin/platform/qemu/virt/firmware/fw_dynamic.bin; @@ -310,6 +306,12 @@ jobs: cd ${WORK_DIR} export UBOOT_TRAVIS_BUILD_DIR=/tmp/${TEST_PY_BD}; tools/buildman/buildman -o ${UBOOT_TRAVIS_BUILD_DIR} -w -E -W -e --board ${TEST_PY_BD} ${OVERRIDE} + cp ~/grub_x86.efi ${UBOOT_TRAVIS_BUILD_DIR}/ + cp ~/grub_x64.efi ${UBOOT_TRAVIS_BUILD_DIR}/ + cp /opt/grub/grubriscv64.efi ${UBOOT_TRAVIS_BUILD_DIR}/grub_riscv64.efi + cp /opt/grub/grubriscv32.efi ${UBOOT_TRAVIS_BUILD_DIR}/grub_riscv32.efi + cp /opt/grub/grubaa64.efi ${UBOOT_TRAVIS_BUILD_DIR}/grub_arm64.efi + cp /opt/grub/grubarm.efi ${UBOOT_TRAVIS_BUILD_DIR}/grub_arm.efi virtualenv -p /usr/bin/python3 /tmp/venv . /tmp/venv/bin/activate pip install -r test/py/requirements.txt -- 2.27.0
