[U-Boot] [PATCH v2 1/2] i2c: zynq: Support for 0-length register address
Fixed bug with alen == 0 in 'i2c_write', 'i2c_read' Further minor corrections: - Write 'address' register before 'data' register. - Write 'transfer_size' register before 'address' register.
Signed-off-by: Michael Burr michael.burr@logicpd.com Signed-off-by: Michal Simek michal.simek@xilinx.com
Changes in v2: - Fix incorrect rebase
Changes in v1: - Based on original thread from Michael Burr http://lists.denx.de/pipermail/u-boot/2013-October/165060.html - MS rebase on latest&greatest
drivers/i2c/zynq_i2c.c | 42 +++++++++++++++++++++++------------------- 1 file changed, 23 insertions(+), 19 deletions(-)
diff --git a/drivers/i2c/zynq_i2c.c b/drivers/i2c/zynq_i2c.c index 70a9aea..11ef0f8 100644 --- a/drivers/i2c/zynq_i2c.c +++ b/drivers/i2c/zynq_i2c.c @@ -189,20 +189,22 @@ static int zynq_i2c_read(struct i2c_adapter *adap, u8 dev, uint addr, * Temporarily disable restart (by clearing hold) * It doesn't seem to work. */ - clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_RW | - ZYNQ_I2C_CONTROL_HOLD); + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); writel(0xFF, &zynq_i2c->interrupt_status); - while (alen--) - writel(addr >> (8*alen), &zynq_i2c->data); - writel(dev, &zynq_i2c->address); + if (alen) { + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_RW); + writel(dev, &zynq_i2c->address); + while (alen--) + writel(addr >> (8 * alen), &zynq_i2c->data);
- /* Wait for the address to be sent */ - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { - /* Release the bus */ - clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); - return -ETIMEDOUT; + /* Wait for the address to be sent */ + if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { + /* Release the bus */ + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); + return -ETIMEDOUT; + } + debug("Device acked address\n"); } - debug("Device acked address\n");
setbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_CLR_FIFO | ZYNQ_I2C_CONTROL_RW); @@ -247,17 +249,19 @@ static int zynq_i2c_write(struct i2c_adapter *adap, u8 dev, uint addr, ZYNQ_I2C_CONTROL_HOLD); clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_RW); writel(0xFF, &zynq_i2c->interrupt_status); - while (alen--) - writel(addr >> (8*alen), &zynq_i2c->data); - /* Start the tranfer */ writel(dev, &zynq_i2c->address); - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { - /* Release the bus */ - clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); - return -ETIMEDOUT; + if (alen) { + while (alen--) + writel(addr >> (8 * alen), &zynq_i2c->data); + /* Start the tranfer */ + if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { + /* Release the bus */ + clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); + return -ETIMEDOUT; + } + debug("Device acked address\n"); }
- debug("Device acked address\n"); while (length--) { writel(*(cur_data++), &zynq_i2c->data); if (readl(&zynq_i2c->transfer_size) == ZYNQ_I2C_FIFO_DEPTH) { -- 1.8.2.3
Initialize the second i2c controller.
Signed-off-by: Michael Burr michael.burr@logicpd.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
Changes in v2: None Changes in v1: - Based on original thread from Michael Burr http://lists.denx.de/pipermail/u-boot/2013-October/165017.html Heiko did some changes in this mainline patch "i2c, zynq: convert zynq i2c driver to new multibus/multiadapter framework" (sha1: 0bdffe71fddeaa46768a39305797e4512dee0f15) - MS rebase on latest&greatest
drivers/i2c/zynq_i2c.c | 44 ++++++++++++++++++++++++++----------------- include/configs/zynq-common.h | 6 +++--- 2 files changed, 30 insertions(+), 20 deletions(-)
diff --git a/drivers/i2c/zynq_i2c.c b/drivers/i2c/zynq_i2c.c index 11ef0f8..f1f6513 100644 --- a/drivers/i2c/zynq_i2c.c +++ b/drivers/i2c/zynq_i2c.c @@ -64,19 +64,21 @@ struct zynq_i2c_registers { #define ZYNQ_I2C_FIFO_DEPTH 16 #define ZYNQ_I2C_TRANSFERT_SIZE_MAX 255 /* Controller transfer limit */
-#if defined(CONFIG_ZYNQ_I2C0) -# define ZYNQ_I2C_BASE ZYNQ_I2C_BASEADDR0 -#else -# define ZYNQ_I2C_BASE ZYNQ_I2C_BASEADDR1 -#endif - -static struct zynq_i2c_registers *zynq_i2c = - (struct zynq_i2c_registers *)ZYNQ_I2C_BASE; +static struct zynq_i2c_registers *i2c_select(struct i2c_adapter *adap) +{ + return adap->hwadapnr ? + /* Zynq PS I2C1 */ + (struct zynq_i2c_registers *)ZYNQ_I2C_BASEADDR1 : + /* Zynq PS I2C0 */ + (struct zynq_i2c_registers *)ZYNQ_I2C_BASEADDR0; +}
/* I2C init called by cmd_i2c when doing 'i2c reset'. */ static void zynq_i2c_init(struct i2c_adapter *adap, int requested_speed, int slaveadd) { + struct zynq_i2c_registers *zynq_i2c = i2c_select(adap); + /* 111MHz / ( (3 * 17) * 22 ) = ~100KHz */ writel((16 << ZYNQ_I2C_CONTROL_DIV_B_SHIFT) | (2 << ZYNQ_I2C_CONTROL_DIV_A_SHIFT), &zynq_i2c->control); @@ -87,7 +89,7 @@ static void zynq_i2c_init(struct i2c_adapter *adap, int requested_speed, }
#ifdef DEBUG -static void zynq_i2c_debug_status(void) +static void zynq_i2c_debug_status(struct zynq_i2c_registers *zynq_i2c) { int int_status; int status; @@ -129,7 +131,7 @@ static void zynq_i2c_debug_status(void) #endif
/* Wait for an interrupt */ -static u32 zynq_i2c_wait(u32 mask) +static u32 zynq_i2c_wait(struct zynq_i2c_registers *zynq_i2c, u32 mask) { int timeout, int_status;
@@ -140,7 +142,7 @@ static u32 zynq_i2c_wait(u32 mask) break; } #ifdef DEBUG - zynq_i2c_debug_status(); + zynq_i2c_debug_status(zynq_i2c)); #endif /* Clear interrupt status flags */ writel(int_status & mask, &zynq_i2c->interrupt_status); @@ -154,6 +156,8 @@ static u32 zynq_i2c_wait(u32 mask) */ static int zynq_i2c_probe(struct i2c_adapter *adap, u8 dev) { + struct zynq_i2c_registers *zynq_i2c = i2c_select(adap); + /* Attempt to read a byte */ setbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_CLR_FIFO | ZYNQ_I2C_CONTROL_RW); @@ -162,7 +166,7 @@ static int zynq_i2c_probe(struct i2c_adapter *adap, u8 dev) writel(dev, &zynq_i2c->address); writel(1, &zynq_i2c->transfer_size);
- return (zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP | + return (zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP | ZYNQ_I2C_INTERRUPT_NACK) & ZYNQ_I2C_INTERRUPT_COMP) ? 0 : -ETIMEDOUT; } @@ -177,6 +181,7 @@ static int zynq_i2c_read(struct i2c_adapter *adap, u8 dev, uint addr, u32 status; u32 i = 0; u8 *cur_data = data; + struct zynq_i2c_registers *zynq_i2c = i2c_select(adap);
/* Check the hardware can handle the requested bytes */ if ((length < 0) || (length > ZYNQ_I2C_TRANSFERT_SIZE_MAX)) @@ -198,7 +203,7 @@ static int zynq_i2c_read(struct i2c_adapter *adap, u8 dev, uint addr, writel(addr >> (8 * alen), &zynq_i2c->data);
/* Wait for the address to be sent */ - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { + if (!zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP)) { /* Release the bus */ clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); return -ETIMEDOUT; @@ -214,7 +219,7 @@ static int zynq_i2c_read(struct i2c_adapter *adap, u8 dev, uint addr,
/* Wait for data */ do { - status = zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP | + status = zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP | ZYNQ_I2C_INTERRUPT_DATA); if (!status) { /* Release the bus */ @@ -243,6 +248,7 @@ static int zynq_i2c_write(struct i2c_adapter *adap, u8 dev, uint addr, int alen, u8 *data, int length) { u8 *cur_data = data; + struct zynq_i2c_registers *zynq_i2c = i2c_select(adap);
/* Write the register address */ setbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_CLR_FIFO | @@ -254,7 +260,7 @@ static int zynq_i2c_write(struct i2c_adapter *adap, u8 dev, uint addr, while (alen--) writel(addr >> (8 * alen), &zynq_i2c->data); /* Start the tranfer */ - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { + if (!zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP)) { /* Release the bus */ clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); return -ETIMEDOUT; @@ -265,7 +271,7 @@ static int zynq_i2c_write(struct i2c_adapter *adap, u8 dev, uint addr, while (length--) { writel(*(cur_data++), &zynq_i2c->data); if (readl(&zynq_i2c->transfer_size) == ZYNQ_I2C_FIFO_DEPTH) { - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) { + if (!zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP)) { /* Release the bus */ clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); @@ -277,7 +283,7 @@ static int zynq_i2c_write(struct i2c_adapter *adap, u8 dev, uint addr, /* All done... release the bus */ clrbits_le32(&zynq_i2c->control, ZYNQ_I2C_CONTROL_HOLD); /* Wait for the address and data to be sent */ - if (!zynq_i2c_wait(ZYNQ_I2C_INTERRUPT_COMP)) + if (!zynq_i2c_wait(zynq_i2c, ZYNQ_I2C_INTERRUPT_COMP)) return -ETIMEDOUT; return 0; } @@ -295,3 +301,7 @@ U_BOOT_I2C_ADAP_COMPLETE(zynq_0, zynq_i2c_init, zynq_i2c_probe, zynq_i2c_read, zynq_i2c_write, zynq_i2c_set_bus_speed, CONFIG_SYS_I2C_ZYNQ_SPEED, CONFIG_SYS_I2C_ZYNQ_SLAVE, 0) +U_BOOT_I2C_ADAP_COMPLETE(zynq_1, zynq_i2c_init, zynq_i2c_probe, zynq_i2c_read, + zynq_i2c_write, zynq_i2c_set_bus_speed, + CONFIG_SYS_I2C_ZYNQ_SPEED, CONFIG_SYS_I2C_ZYNQ_SLAVE, + 1) diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index e7a8e9f..04ea81f 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -104,13 +104,13 @@ # define CONFIG_DOS_PARTITION #endif
+#define CONFIG_SYS_I2C_ZYNQ /* I2C */ -#if defined(CONFIG_ZYNQ_I2C0) || defined(CONFIG_ZYNQ_I2C1) +#if defined(CONFIG_SYS_I2C_ZYNQ) # define CONFIG_CMD_I2C # define CONFIG_SYS_I2C -# define CONFIG_SYS_I2C_ZYNQ # define CONFIG_SYS_I2C_ZYNQ_SPEED 100000 -# define CONFIG_SYS_I2C_ZYNQ_SLAVE 1 +# define CONFIG_SYS_I2C_ZYNQ_SLAVE 0 #endif
/* EEPROM */ -- 1.8.2.3
Hello Michal,
Am 22.01.2014 09:46, schrieb Michal Simek:
Signed-off-by: Michael Burrmichael.burr@logicpd.com Signed-off-by: Michal Simekmichal.simek@xilinx.com
Applied to u-boot-i2c.git, thanks!
bye, Heiko
Hello Michal,
Changes in v2:
Changes in v1:
bye, Heiko
Heiko Schocher
Michal Simek
