[U-Boot] [PATCH v3 0/2] add armv7m cache support
This patchset adds armv7m instruction/data caches support & enable it for stm32f7.
Changed in v3: - uint32 replcaed with u32. - multiple read of hardware register replaced with single. - pointers replaced with macros for base address. - register names added as comment for system control block registers.
Changed in v2: - changed strucures for memory mapped cache registers to macros - added lines better readability. - replaced magic numbers with macros.
Vikas Manocha (2): armv7m: add instruction & data cache support stm32f7: enable instruction & data cache
arch/arm/cpu/armv7m/Makefile | 2 +- arch/arm/cpu/armv7m/cache.c | 291 ++++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/armv7m.h | 26 +++- arch/arm/lib/Makefile | 2 + arch/arm/mach-stm32/stm32f7/soc.c | 2 + include/configs/stm32f746-disco.h | 4 +- 6 files changed, 321 insertions(+), 6 deletions(-) create mode 100644 arch/arm/cpu/armv7m/cache.c
This patch adds armv7m instruction & data cache support.
Signed-off-by: Vikas Manocha vikas.manocha@st.com cc: Christophe KERELLO christophe.kerello@st.com ---
arch/arm/cpu/armv7m/Makefile | 2 +- arch/arm/cpu/armv7m/cache.c | 291 ++++++++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/armv7m.h | 26 +++- arch/arm/lib/Makefile | 2 + 4 files changed, 318 insertions(+), 3 deletions(-) create mode 100644 arch/arm/cpu/armv7m/cache.c
diff --git a/arch/arm/cpu/armv7m/Makefile b/arch/arm/cpu/armv7m/Makefile index aff60e8..41efe11 100644 --- a/arch/arm/cpu/armv7m/Makefile +++ b/arch/arm/cpu/armv7m/Makefile @@ -6,4 +6,4 @@ #
extra-y := start.o -obj-y += cpu.o +obj-y += cpu.o cache.o diff --git a/arch/arm/cpu/armv7m/cache.c b/arch/arm/cpu/armv7m/cache.c new file mode 100644 index 0000000..9021525 --- /dev/null +++ b/arch/arm/cpu/armv7m/cache.c @@ -0,0 +1,291 @@ +/* + * (C) Copyright 2017 + * Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/armv7m.h> +#include <asm/io.h> +#include <errno.h> + +/* Cache maintenance operation registers */ + +#define IC_IALLU (V7M_CACHE_MAINT_BASE + 0x00) +#define INVAL_ICACHE_POU 0 +#define IC_IMVALU (V7M_CACHE_MAINT_BASE + 0x08) +#define DC_IMVAC (V7M_CACHE_MAINT_BASE + 0x0C) +#define DC_ISW (V7M_CACHE_MAINT_BASE + 0x10) +#define DC_CMVAU (V7M_CACHE_MAINT_BASE + 0x14) +#define DC_CMVAC (V7M_CACHE_MAINT_BASE + 0x18) +#define DC_CSW (V7M_CACHE_MAINT_BASE + 0x1C) +#define DC_CIMVAC (V7M_CACHE_MAINT_BASE + 0x20) +#define DC_CISW (V7M_CACHE_MAINT_BASE + 0x24) +#define WAYS_SHIFT 30 +#define SETS_SHIFT 5 + +/* armv7m processor feature registers */ + +#define CLIDR (V7M_PROC_FTR_BASE + 0x00) +#define CTR (V7M_PROC_FTR_BASE + 0x04) +#define CCSIDR (V7M_PROC_FTR_BASE + 0x08) +#define MASK_NUM_WAYS GENMASK(12, 3) +#define MASK_NUM_SETS GENMASK(27, 13) +#define CLINE_SIZE_MASK GENMASK(2, 0) +#define NUM_WAYS_SHIFT 3 +#define NUM_SETS_SHIFT 13 +#define CSSELR (V7M_PROC_FTR_BASE + 0x0C) +#define SEL_I_OR_D BIT(0) + +enum cache_type { + DCACHE = 0, + ICACHE, +}; + +/* PoU : Point of Unification, Poc: Point of Coherency */ +enum cache_action { + INVALIDATE_POU, /* for i-cache invalidate by address */ + INVALIDATE_POC, /* for d-cache invalidate by address */ + INVALIDATE_SET_WAY, /* for d-cache invalidate by sets/ways */ + FLUSH_POU, + FLUSH_POC, + FLUSH_SET_WAY, + FLUSH_INVAL_POC, + FLUSH_INVAL_SET_WAY, +}; + +#ifndef CONFIG_SYS_DCACHE_OFF +struct dcache_config { + u32 ways; + u32 sets; +}; + +static void get_cache_ways_sets(struct dcache_config *cache) +{ + u32 cache_size_id = readl(CCSIDR); + cache->ways = (cache_size_id & MASK_NUM_WAYS) >> NUM_WAYS_SHIFT; + cache->sets = (cache_size_id & MASK_NUM_SETS) >> NUM_SETS_SHIFT; +} + +static u32 *get_action_reg_set_ways(enum cache_action action) +{ + switch (action) { + case INVALIDATE_SET_WAY: + return (u32 *)DC_ISW; + case FLUSH_SET_WAY: + return (u32 *)DC_CSW; + case FLUSH_INVAL_SET_WAY: + return (u32 *)DC_CISW; + default: + break; + }; + + return NULL; +} + +static u32 *get_action_reg_range(enum cache_action action) +{ + switch (action) { + case INVALIDATE_POU: + return (u32 *)IC_IMVALU; + case INVALIDATE_POC: + return (u32 *)DC_IMVAC; + case FLUSH_POU: + return (u32 *)DC_CMVAU; + case FLUSH_POC: + return (u32 *)DC_CMVAC; + case FLUSH_INVAL_POC: + return (u32 *)DC_CIMVAC; + default: + break; + } + + return NULL; +} + +static u32 get_cline_size(enum cache_type type) +{ + u32 size; + + if (type == DCACHE) + clrbits_le32(CSSELR, BIT(SEL_I_OR_D)); + else if (type == ICACHE) + setbits_le32(CSSELR, BIT(SEL_I_OR_D)); + dsb(); + + size = readl(CCSIDR) & CLINE_SIZE_MASK; + /* Size enocoded as 2 less than log(no_of_words_in_cache_line) base 2 */ + size = 1 << (size + 2); + debug("cache line size is %d\n", size); + + return size; +} + +static __attribute__((unused)) int action_cache_range(enum cache_action action, + u32 start_addr, int64_t size) +{ + u32 cline_size; + u32 *action_reg; + enum cache_type type; + + action_reg = get_action_reg_range(action); + if (!action_reg) + return -EINVAL; + if (action == INVALIDATE_POU) + type = ICACHE; + else + type = DCACHE; + + /* Cache line size is minium size for the cache action */ + cline_size = get_cline_size(type); + /* Align start address to cache line boundary */ + start_addr &= ~(cline_size - 1); + do { + writel(start_addr, action_reg); + size -= cline_size; + start_addr += cline_size; + } while (size > cline_size); + dsb(); + isb(); + debug("cache action on range done\n"); + + return 0; +} + +static int action_dcache_all(enum cache_action action) +{ + struct dcache_config cache; + u32 *action_reg; + int i, j; + + action_reg = get_action_reg_set_ways(action); + if (!action_reg) + return -EINVAL; + + clrbits_le32(CSSELR, BIT(SEL_I_OR_D)); + dsb(); + + get_cache_ways_sets(&cache); /* Get number of ways & sets */ + debug("cache: ways= %d, sets= %d\n", cache.ways + 1, cache.sets + 1); + for (i = cache.sets; i >= 0; i--) { + for (j = cache.ways; j >= 0; j--) { + writel((j << WAYS_SHIFT) | (i << SETS_SHIFT), + action_reg); + } + } + dsb(); + isb(); + + return 0; +} + +void dcache_enable(void) +{ + if (dcache_status()) /* return if cache already enabled */ + return; + + if (action_dcache_all(INVALIDATE_SET_WAY)) { + printf("ERR: D-cache not enabled\n"); + return; + } + + setbits_le32(&V7M_SCB->ccr, BIT(V7M_CCR_DCACHE)); + dsb(); + isb(); +} + +void dcache_disable(void) +{ + /* if dcache is enabled-> dcache disable & then flush */ + if (dcache_status()) { + if (action_dcache_all(FLUSH_SET_WAY)) { + printf("ERR: D-cahe not flushed\n"); + return; + } + + clrbits_le32(&V7M_SCB->ccr, BIT(V7M_CCR_DCACHE)); + dsb(); + isb(); + } +} + +int dcache_status(void) +{ + return (readl(&V7M_SCB->ccr) & BIT(V7M_CCR_DCACHE)) != 0; +} + +#else +void dcache_enable(void) +{ + return; +} + +void dcache_disable(void) +{ + return; +} + +int dcache_status(void) +{ + return 0; +} +#endif + +#ifndef CONFIG_SYS_ICACHE_OFF + +void invalidate_icache_all(void) +{ + writel(INVAL_ICACHE_POU, IC_IALLU); + dsb(); + isb(); +} + +void icache_enable(void) +{ + if (icache_status()) + return; + + invalidate_icache_all(); + setbits_le32(&V7M_SCB->ccr, BIT(V7M_CCR_ICACHE)); + dsb(); + isb(); +} + +int icache_status(void) +{ + return (readl(&V7M_SCB->ccr) & BIT(V7M_CCR_ICACHE)) != 0; +} + +void icache_disable(void) +{ + isb(); + clrbits_le32(&V7M_SCB->ccr, BIT(V7M_CCR_ICACHE)); + isb(); +} +#else +void icache_enable(void) +{ + return; +} + +void icache_disable(void) +{ + return; +} + +int icache_status(void) +{ + return 0; +} +#endif + +void enable_caches(void) +{ +#ifndef CONFIG_SYS_ICACHE_OFF + icache_enable(); +#endif +#ifndef CONFIG_SYS_DCACHE_OFF + dcache_enable(); +#endif +} diff --git a/arch/arm/include/asm/armv7m.h b/arch/arm/include/asm/armv7m.h index 54d8a2b..ebf0f17 100644 --- a/arch/arm/include/asm/armv7m.h +++ b/arch/arm/include/asm/armv7m.h @@ -16,8 +16,15 @@ .thumb #endif
-#define V7M_SCB_BASE 0xE000ED00 -#define V7M_MPU_BASE 0xE000ED90 +/* armv7m fixed base addresses */ +#define V7M_SCS_BASE 0xE000E000 +#define V7M_NVIC_BASE (V7M_SCS_BASE + 0x0100) +#define V7M_SCB_BASE (V7M_SCS_BASE + 0x0D00) +#define V7M_PROC_FTR_BASE (V7M_SCS_BASE + 0x0D78) +#define V7M_MPU_BASE (V7M_SCS_BASE + 0x0D90) +#define V7M_FPU_BASE (V7M_SCS_BASE + 0x0F30) +#define V7M_CACHE_MAINT_BASE (V7M_SCS_BASE + 0x0F50) +#define V7M_ACCESS_CNTL_BASE (V7M_SCS_BASE + 0x0F90)
#define V7M_SCB_VTOR 0x08
@@ -27,6 +34,18 @@ struct v7m_scb { uint32_t icsr; /* Interrupt Control and State Register */ uint32_t vtor; /* Vector Table Offset Register */ uint32_t aircr; /* App Interrupt and Reset Control Register */ + uint32_t scr; /* offset 0x10: System Control Register */ + uint32_t ccr; /* offset 0x14: Config and Control Register */ + uint32_t shpr1; /* offset 0x18: System Handler Priority Reg 1 */ + uint32_t shpr2; /* offset 0x1c: System Handler Priority Reg 2 */ + uint32_t shpr3; /* offset 0x20: System Handler Priority Reg 3 */ + uint32_t shcrs; /* offset 0x24: System Handler Control State */ + uint32_t cfsr; /* offset 0x28: Configurable Fault Status Reg */ + uint32_t hfsr; /* offset 0x2C: HardFault Status Register */ + uint32_t res; /* offset 0x30: reserved */ + uint32_t mmar; /* offset 0x34: MemManage Fault Address Reg */ + uint32_t bfar; /* offset 0x38: BusFault Address Reg */ + uint32_t afsr; /* offset 0x3C: Auxiliary Fault Status Reg */ }; #define V7M_SCB ((struct v7m_scb *)V7M_SCB_BASE)
@@ -39,6 +58,9 @@ struct v7m_scb {
#define V7M_ICSR_VECTACT_MSK 0xFF
+#define V7M_CCR_DCACHE 16 +#define V7M_CCR_ICACHE 17 + struct v7m_mpu { uint32_t type; /* Type Register */ uint32_t ctrl; /* Control Register */ diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 166fa9e..52b36b3 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -55,8 +55,10 @@ endif
obj-y += cache.o ifndef CONFIG_ARM64 +ifndef CONFIG_CPU_V7M obj-y += cache-cp15.o endif +endif
obj-y += psci-dt.o
Changed in v3:
Changed in v2:
Please address comments on V2 before sending V3 ...
Hi Vikas,
Changed in v3:
Changed in v2:
- (C) Copyright 2017
- Vikas Manocha, ST Micoelectronics, vikas.manocha@st.com.
put this one below common.h
+enum cache_type {
DCACHE = 0,
Do you need the =0 ?
ICACHE,
FLUSH_POU,
FLUSH_POC,
FLUSH_SET_WAY,
FLUSH_INVAL_POC,
Can you add comments for the rest?
u32 ways;
u32 sets;
blank line here
Can you please add a function comment? What does this return?
switch (action) {
Can you drop these casts by using a C structure or by putting thecast in the #define?
case FLUSH_SET_WAY:
default:
break;
return NULL;
switch (action) {
case FLUSH_POU:
case FLUSH_POC:
default:
break;
return NULL;
Why u32? Should it be uint or ulong?
u32 size;
if (type == DCACHE)
dsb();
return size;
Function comment.
Can you use __used ?
u32 cline_size;
u32 *action_reg;
if (!action_reg)
return -EINVAL;
type = ICACHE;
else
type = DCACHE;
do {
size -= cline_size;
dsb();
isb();
Function comment.
Thanks Simon,
On 03/16/2017 03:06 PM, Simon Glass wrote:
Hi Vikas,
Changed in v3:
Changed in v2:
oh yes, ok.
+enum cache_type {
DCACHE = 0,
No :-), thanks.
ICACHE,
FLUSH_POU,
FLUSH_POC,
FLUSH_SET_WAY,
FLUSH_INVAL_POC,
sure.
u32 ways;
u32 sets;
blank line here
ok.
this function returns the io register to perform required cache action like clean or clean & invalidate by sets/ways. The procedure to perform on these io register is same for cleaning & clean/invalidate.
I will add the comment in code.
switch (action) {
C structures was the first choice but they were removed after v1 as per review comment & replaced with #defines. ok for the casting in #defines.
case FLUSH_SET_WAY:
default:
break;
return NULL;
switch (action) {
case FLUSH_POU:
case FLUSH_POC:
default:
break;
return NULL;
armv7m is 32bit arch, cacheline size (32 bytes for cortex M7) can never be more than u32. Please let me know if i am missing something.
u32 size;
if (type == DCACHE)
dsb();
return size;
Function comment.
this function is to perform the required action like invalidate/clean on a range of cache addresses. I will add comment.
I figured these attribute will not be required after using the cache prototypes of common.h like invalidate_dcache_range().
u32 cline_size;
u32 *action_reg;
if (!action_reg)
return -EINVAL;
type = ICACHE;
else
type = DCACHE;
do {
size -= cline_size;
dsb();
isb();
Function comment.
this function is to perform the required action like invalidate/clean on all cached addresses. I will add comment for it.
Cheers, Vikas
Regards, Simon .
It also enables commands for cache enable/disable/status.
Changed in v3: None Changed in v2: None
arch/arm/mach-stm32/stm32f7/soc.c | 2 ++ include/configs/stm32f746-disco.h | 4 +--- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-stm32/stm32f7/soc.c b/arch/arm/mach-stm32/stm32f7/soc.c index 8baee99..ca54603 100644 --- a/arch/arm/mach-stm32/stm32f7/soc.c +++ b/arch/arm/mach-stm32/stm32f7/soc.c @@ -60,6 +60,8 @@ int arch_cpu_init(void) (V7M_MPU_RASR_XN_ENABLE | V7M_MPU_RASR_AP_RW_RW | 0x01 << V7M_MPU_RASR_TEX_SHIFT + | 0x01 << V7M_MPU_RASR_B_SHIFT + | 0x01 << V7M_MPU_RASR_C_SHIFT | V7M_MPU_RASR_SIZE_8MB | V7M_MPU_RASR_EN) , &V7M_MPU->rasr diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index ae3211a..9e9406a 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -14,9 +14,6 @@ #define CONFIG_SYS_INIT_SP_ADDR 0x20050000 #define CONFIG_SYS_TEXT_BASE 0x08000000
-#define CONFIG_SYS_ICACHE_OFF -#define CONFIG_SYS_DCACHE_OFF - /* * Configuration of the external SDRAM memory */ @@ -82,4 +79,5 @@ #define CONFIG_CMDLINE_EDITING
#define CONFIG_CMD_MEM +#define CONFIG_CMD_CACHE #endif /* __CONFIG_H */
Vikas Manocha
