[U-Boot] [PATCH] drivers/gpio/da8xx_gpio.c: Fix build warning
Fix: da8xx_gpio.c: In function 'gpio_toggle_value': da8xx_gpio.c:208:23: warning: variable 'bank' set but not used [-Wunused-but-set-variable]
Signed-off-by: Anatolij Gustschin agust@denx.de --- drivers/gpio/da8xx_gpio.c | 3 --- 1 files changed, 0 insertions(+), 3 deletions(-)
diff --git a/drivers/gpio/da8xx_gpio.c b/drivers/gpio/da8xx_gpio.c index 7a15614..74b58e8 100644 --- a/drivers/gpio/da8xx_gpio.c +++ b/drivers/gpio/da8xx_gpio.c @@ -205,9 +205,6 @@ void gpio_free(int gp)
void gpio_toggle_value(int gp) { - struct davinci_gpio *bank; - - bank = GPIO_BANK(gp); gpio_set_value(gp, !gpio_get_value(gp)); }
Fix: mv_sdhci.c: In function 'mv_sdh_init': mv_sdhci.c:47:22: warning: the comparison will always evaluate as 'true' for the address of 'mv_sdhci_writeb' will never be NULL [-Waddress]
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Lei Wen leiwen@marvell.com Cc: Andy Fleming afleming@freescale.com --- drivers/mmc/mv_sdhci.c | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/mv_sdhci.c b/drivers/mmc/mv_sdhci.c index 1501974..2fe34b6 100644 --- a/drivers/mmc/mv_sdhci.c +++ b/drivers/mmc/mv_sdhci.c @@ -44,8 +44,7 @@ int mv_sdh_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks) host->quirks = quirks; #ifdef CONFIG_MMC_SDHCI_IO_ACCESSORS memset(&mv_ops, 0, sizeof(struct sdhci_ops)); - if (mv_sdhci_writeb != NULL) - mv_ops.write_b = mv_sdhci_writeb; + mv_ops.write_b = mv_sdhci_writeb; host->ops = &mv_ops; #endif if (quirks & SDHCI_QUIRK_REG32_RW)
Hi Anatolij,
host->ops = &mv_ops; #endif if (quirks & SDHCI_QUIRK_REG32_RW) -- 1.7.5.4
Thanks for pointing it out!
Acked-by: Lei Wen leiwen@marvell.com
Applied, thanks!
Andy
Dear Anatolij Gustschin,
Applied, thanks.
Albert, Sandeep, Tom: hope thisis OK with you.
Anatolij Gustschin
Andy Fleming
Lei Wen
