[U-Boot] [PATCH v2] Add generic FPGA reconfig mailbox API for S10
This patch is v2 for: https://lists.denx.de/pipermail/u-boot/2018-September/342465.html
Ang, Chee Hong (1): arm: socfpga: stratix10: Add generic FPGA reconfig mailbox API for S10
arch/arm/mach-socfpga/include/mach/mailbox_s10.h | 3 +- arch/arm/mach-socfpga/mailbox_s10.c | 48 ++++++++++++++++++++++++ 2 files changed, 50 insertions(+), 1 deletion(-)
Add a generic mailbox API for FPGA reconfig status which can be called by others. This new function accepts 2 different mailbox commands: CONFIG_STATUS or RECONFIG_STATUS.
Signed-off-by: Ang, Chee Hong chee.hong.ang@intel.com --- arch/arm/mach-socfpga/include/mach/mailbox_s10.h | 3 +- arch/arm/mach-socfpga/mailbox_s10.c | 48 ++++++++++++++++++++++++ 2 files changed, 50 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h index 81a609d..660df35 100644 --- a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h +++ b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h @@ -140,5 +140,6 @@ int mbox_qspi_open(void); #endif
int mbox_reset_cold(void); - +int mbox_get_fpga_config_status(u32 cmd); +int mbox_get_fpga_config_status_psci(u32 cmd); #endif /* _MAILBOX_S10_H_ */ diff --git a/arch/arm/mach-socfpga/mailbox_s10.c b/arch/arm/mach-socfpga/mailbox_s10.c index 0d906c3..3c33223 100644 --- a/arch/arm/mach-socfpga/mailbox_s10.c +++ b/arch/arm/mach-socfpga/mailbox_s10.c @@ -342,6 +342,54 @@ int mbox_reset_cold(void) return 0; }
+/* Accepted commands: CONFIG_STATUS or RECONFIG_STATUS */ +static __always_inline int mbox_get_fpga_config_status_common(u32 cmd) +{ + u32 reconfig_status_resp_len; + u32 reconfig_status_resp[RECONFIG_STATUS_RESPONSE_LEN]; + int ret; + + reconfig_status_resp_len = RECONFIG_STATUS_RESPONSE_LEN; + ret = mbox_send_cmd_common(MBOX_ID_UBOOT, cmd, + MBOX_CMD_DIRECT, 0, NULL, 0, + &reconfig_status_resp_len, + reconfig_status_resp); + + if (ret) + return ret; + + /* Check for any error */ + ret = reconfig_status_resp[RECONFIG_STATUS_STATE]; + if (ret && ret != MBOX_CFGSTAT_STATE_CONFIG) + return ret; + + /* Make sure nStatus is not 0 */ + ret = reconfig_status_resp[RECONFIG_STATUS_PIN_STATUS]; + if (!(ret & RCF_PIN_STATUS_NSTATUS)) + return MBOX_CFGSTAT_STATE_ERROR_HARDWARE; + + ret = reconfig_status_resp[RECONFIG_STATUS_SOFTFUNC_STATUS]; + if (ret & RCF_SOFTFUNC_STATUS_SEU_ERROR) + return MBOX_CFGSTAT_STATE_ERROR_HARDWARE; + + if ((ret & RCF_SOFTFUNC_STATUS_CONF_DONE) && + (ret & RCF_SOFTFUNC_STATUS_INIT_DONE) && + !reconfig_status_resp[RECONFIG_STATUS_STATE]) + return 0; /* configuration success */ + + return MBOX_CFGSTAT_STATE_CONFIG; +} + +int mbox_get_fpga_config_status(u32 cmd) +{ + return mbox_get_fpga_config_status_common(cmd); +} + +int __secure mbox_get_fpga_config_status_psci(u32 cmd) +{ + return mbox_get_fpga_config_status_common(cmd); +} + int mbox_send_cmd(u8 id, u32 cmd, u8 is_indirect, u32 len, u32 *arg, u8 urgent, u32 *resp_buf_len, u32 *resp_buf) {
Applied, thanks
