[U-Boot] [PATCH] drivers/net/phy: implement fallback mechanism for negative phy adresses
Negative phy-addresses can occour if the caller function was not able to determine a valid phy address (from device-tree for example). In this case we catch this here and search for ANY phy device on the given mdio- bus.
Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com
drivers/net/phy/phy.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 0c8b29d..916b525 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -922,13 +922,14 @@ struct phy_device *phy_connect(struct mii_dev *bus, int addr, #endif { struct phy_device *phydev = NULL; + uint mask = (addr > 0) ? (0x1 << addr) : 0xffffffff;
#ifdef CONFIG_PHY_FIXED phydev = phy_connect_fixed(bus, dev, interface); #endif
if (!phydev) - phydev = phy_find_by_mask(bus, 1 << addr, interface); + phydev = phy_find_by_mask(bus, mask, interface);
if (phydev) phy_connect_dev(phydev, dev);
if (!phydev)
This fallback is only useful if the board has absolutely no description of the phy connected to some MAC. With some drivers, like the MXC_FEC, it is possible to configure a phy-address within the board header.
In days where DM is more and more used, i would suggest having a meaningful device-tree which also describes the connected ethernet-phy.
cheers, Hannes
Please fix subject net: phy: should be fine.
- uint mask = (addr > 0) ? (0x1 << addr) : 0xffffffff;
s/0x1/1/
if (!phydev)
When subject and that stuff above are fixed please add Tested-by: Michal Simek michal.simek@xilinx.com
And then we can remove our code from zynq_gem (phy_dectection()).
Thanks, Michal
Hannes Schmelzer
Hannes Schmelzer
Michal Simek
