[PATCH v2 0/3] efi: vars: Implement SPI Flash storage
With this patch series we implement SPI Flash storage for EFI variables.
Changes in v2: - Refactored efi_var_file to move common parts out as requested - Changed ifdefs to use CONFIG_IS_DEFINED - Fixed typos
Shantur Rathore (3): efi_var_file: refactor to move buffer functions efi_vars: Implement SPI Flash store defconfig: rockpro64: Enable SF EFI var store
configs/rockpro64-rk3399_defconfig | 2 + include/efi_variable.h | 26 +++++++ lib/efi_loader/Kconfig | 25 ++++++ lib/efi_loader/Makefile | 3 +- lib/efi_loader/efi_var_common.c | 109 ++++++++++++++++++++++++++ lib/efi_loader/efi_var_file.c | 121 ----------------------------- lib/efi_loader/efi_var_sf.c | 91 ++++++++++++++++++++++ lib/efi_loader/efi_variable.c | 17 +++- 8 files changed, 270 insertions(+), 124 deletions(-) create mode 100644 lib/efi_loader/efi_var_sf.c
Currently efi_var_file.c has functions to store/read EFI variables to/from memory buffer. These functions can be used with other EFI variable stores so move them out to efi_var_common.c
Signed-off-by: Shantur Rathore i@shantur.com ---
(no changes since v1)
include/efi_variable.h | 5 ++ lib/efi_loader/Makefile | 2 +- lib/efi_loader/efi_var_common.c | 109 ++++++++++++++++++++++++++++ lib/efi_loader/efi_var_file.c | 121 -------------------------------- lib/efi_loader/efi_variable.c | 8 ++- 5 files changed, 122 insertions(+), 123 deletions(-)
diff --git a/include/efi_variable.h b/include/efi_variable.h index 805e6c5f1e..bd0a31fc3e 100644 --- a/include/efi_variable.h +++ b/include/efi_variable.h @@ -161,6 +161,11 @@ efi_status_t efi_var_to_file(void); efi_status_t __maybe_unused efi_var_collect(struct efi_var_file **bufp, loff_t *lenp, u32 check_attr_mask);
+/* GUID used by Shim to store the MOK database */ +#define SHIM_LOCK_GUID \ + EFI_GUID(0x605dab50, 0xe046, 0x4300, \ + 0xab, 0xb6, 0x3d, 0xd8, 0x10, 0xdd, 0x8b, 0x23) + /** * efi_var_restore() - restore EFI variables from buffer * diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index 8d31fc61c6..33b1910249 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -66,7 +66,7 @@ obj-y += efi_string.o obj-$(CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2) += efi_unicode_collation.o obj-y += efi_var_common.o obj-y += efi_var_mem.o -obj-y += efi_var_file.o +obj-$(CONFIG_EFI_VARIABLE_FILE_STORE) += efi_var_file.o ifeq ($(CONFIG_EFI_MM_COMM_TEE),y) obj-y += efi_variable_tee.o else diff --git a/lib/efi_loader/efi_var_common.c b/lib/efi_loader/efi_var_common.c index ad50bffd2b..7509c30b5a 100644 --- a/lib/efi_loader/efi_var_common.c +++ b/lib/efi_loader/efi_var_common.c @@ -10,6 +10,7 @@ #include <efi_loader.h> #include <efi_variable.h> #include <stdlib.h> +#include <u-boot/crc.h>
enum efi_secure_mode { EFI_MODE_SETUP, @@ -40,6 +41,7 @@ static const struct efi_auth_var_name_type name_type[] = {
static bool efi_secure_boot; static enum efi_secure_mode efi_secure_mode; +static const efi_guid_t shim_lock_guid = SHIM_LOCK_GUID;
/** * efi_efi_get_variable() - retrieve value of a UEFI variable @@ -417,3 +419,110 @@ void *efi_get_var(const u16 *name, const efi_guid_t *vendor, efi_uintn_t *size)
return buf; } + +efi_status_t __maybe_unused efi_var_collect(struct efi_var_file **bufp, loff_t *lenp, + u32 check_attr_mask) +{ + size_t len = EFI_VAR_BUF_SIZE; + struct efi_var_file *buf; + struct efi_var_entry *var, *old_var; + size_t old_var_name_length = 2; + + *bufp = NULL; /* Avoid double free() */ + buf = calloc(1, len); + if (!buf) + return EFI_OUT_OF_RESOURCES; + var = buf->var; + old_var = var; + for (;;) { + efi_uintn_t data_length, var_name_length; + u8 *data; + efi_status_t ret; + + if ((uintptr_t)buf + len <= + (uintptr_t)var->name + old_var_name_length) + return EFI_BUFFER_TOO_SMALL; + + var_name_length = (uintptr_t)buf + len - (uintptr_t)var->name; + memcpy(var->name, old_var->name, old_var_name_length); + guidcpy(&var->guid, &old_var->guid); + ret = efi_get_next_variable_name_int( + &var_name_length, var->name, &var->guid); + if (ret == EFI_NOT_FOUND) + break; + if (ret != EFI_SUCCESS) { + free(buf); + return ret; + } + old_var_name_length = var_name_length; + old_var = var; + + data = (u8 *)var->name + old_var_name_length; + data_length = (uintptr_t)buf + len - (uintptr_t)data; + ret = efi_get_variable_int(var->name, &var->guid, + &var->attr, &data_length, data, + &var->time); + if (ret != EFI_SUCCESS) { + free(buf); + return ret; + } + if ((var->attr & check_attr_mask) == check_attr_mask) { + var->length = data_length; + var = (struct efi_var_entry *)ALIGN((uintptr_t)data + data_length, 8); + } + } + + buf->reserved = 0; + buf->magic = EFI_VAR_FILE_MAGIC; + len = (uintptr_t)var - (uintptr_t)buf; + buf->crc32 = crc32(0, (u8 *)buf->var, + len - sizeof(struct efi_var_file)); + buf->length = len; + *bufp = buf; + *lenp = len; + + return EFI_SUCCESS; +} + +efi_status_t efi_var_restore(struct efi_var_file *buf, bool safe) +{ + struct efi_var_entry *var, *last_var; + u16 *data; + efi_status_t ret; + + if (buf->reserved || buf->magic != EFI_VAR_FILE_MAGIC || + buf->crc32 != crc32(0, (u8 *)buf->var, + buf->length - sizeof(struct efi_var_file))) { + log_err("Invalid EFI variables file\n"); + return EFI_INVALID_PARAMETER; + } + + last_var = (struct efi_var_entry *)((u8 *)buf + buf->length); + for (var = buf->var; var < last_var; + var = (struct efi_var_entry *) + ALIGN((uintptr_t)data + var->length, 8)) { + + data = var->name + u16_strlen(var->name) + 1; + + /* + * Secure boot related and volatile variables shall only be + * restored from U-Boot's preseed. + */ + if (!safe && + (efi_auth_var_get_type(var->name, &var->guid) != + EFI_AUTH_VAR_NONE || + !guidcmp(&var->guid, &shim_lock_guid) || + !(var->attr & EFI_VARIABLE_NON_VOLATILE))) + continue; + if (!var->length) + continue; + if (efi_var_mem_find(&var->guid, var->name, NULL)) + continue; + ret = efi_var_mem_ins(var->name, &var->guid, var->attr, + var->length, data, 0, NULL, + var->time); + if (ret != EFI_SUCCESS) + log_err("Failed to set EFI variable %ls\n", var->name); + } + return EFI_SUCCESS; +} diff --git a/lib/efi_loader/efi_var_file.c b/lib/efi_loader/efi_var_file.c index d7dba05071..166501a355 100644 --- a/lib/efi_loader/efi_var_file.c +++ b/lib/efi_loader/efi_var_file.c @@ -15,17 +15,9 @@ #include <mapmem.h> #include <efi_loader.h> #include <efi_variable.h> -#include <u-boot/crc.h>
#define PART_STR_LEN 10
-/* GUID used by Shim to store the MOK database */ -#define SHIM_LOCK_GUID \ - EFI_GUID(0x605dab50, 0xe046, 0x4300, \ - 0xab, 0xb6, 0x3d, 0xd8, 0x10, 0xdd, 0x8b, 0x23) - -static const efi_guid_t shim_lock_guid = SHIM_LOCK_GUID; - /** * efi_set_blk_dev_to_system_partition() - select EFI system partition * @@ -53,70 +45,6 @@ static efi_status_t __maybe_unused efi_set_blk_dev_to_system_partition(void) return EFI_SUCCESS; }
-efi_status_t __maybe_unused efi_var_collect(struct efi_var_file **bufp, loff_t *lenp, - u32 check_attr_mask) -{ - size_t len = EFI_VAR_BUF_SIZE; - struct efi_var_file *buf; - struct efi_var_entry *var, *old_var; - size_t old_var_name_length = 2; - - *bufp = NULL; /* Avoid double free() */ - buf = calloc(1, len); - if (!buf) - return EFI_OUT_OF_RESOURCES; - var = buf->var; - old_var = var; - for (;;) { - efi_uintn_t data_length, var_name_length; - u8 *data; - efi_status_t ret; - - if ((uintptr_t)buf + len <= - (uintptr_t)var->name + old_var_name_length) - return EFI_BUFFER_TOO_SMALL; - - var_name_length = (uintptr_t)buf + len - (uintptr_t)var->name; - memcpy(var->name, old_var->name, old_var_name_length); - guidcpy(&var->guid, &old_var->guid); - ret = efi_get_next_variable_name_int( - &var_name_length, var->name, &var->guid); - if (ret == EFI_NOT_FOUND) - break; - if (ret != EFI_SUCCESS) { - free(buf); - return ret; - } - old_var_name_length = var_name_length; - old_var = var; - - data = (u8 *)var->name + old_var_name_length; - data_length = (uintptr_t)buf + len - (uintptr_t)data; - ret = efi_get_variable_int(var->name, &var->guid, - &var->attr, &data_length, data, - &var->time); - if (ret != EFI_SUCCESS) { - free(buf); - return ret; - } - if ((var->attr & check_attr_mask) == check_attr_mask) { - var->length = data_length; - var = (struct efi_var_entry *)ALIGN((uintptr_t)data + data_length, 8); - } - } - - buf->reserved = 0; - buf->magic = EFI_VAR_FILE_MAGIC; - len = (uintptr_t)var - (uintptr_t)buf; - buf->crc32 = crc32(0, (u8 *)buf->var, - len - sizeof(struct efi_var_file)); - buf->length = len; - *bufp = buf; - *lenp = len; - - return EFI_SUCCESS; -} - /** * efi_var_to_file() - save non-volatile variables as file * @@ -126,7 +54,6 @@ efi_status_t __maybe_unused efi_var_collect(struct efi_var_file **bufp, loff_t * */ efi_status_t efi_var_to_file(void) { -#ifdef CONFIG_EFI_VARIABLE_FILE_STORE efi_status_t ret; struct efi_var_file *buf; loff_t len; @@ -150,52 +77,6 @@ error: log_err("Failed to persist EFI variables\n"); free(buf); return ret; -#else - return EFI_SUCCESS; -#endif -} - -efi_status_t efi_var_restore(struct efi_var_file *buf, bool safe) -{ - struct efi_var_entry *var, *last_var; - u16 *data; - efi_status_t ret; - - if (buf->reserved || buf->magic != EFI_VAR_FILE_MAGIC || - buf->crc32 != crc32(0, (u8 *)buf->var, - buf->length - sizeof(struct efi_var_file))) { - log_err("Invalid EFI variables file\n"); - return EFI_INVALID_PARAMETER; - } - - last_var = (struct efi_var_entry *)((u8 *)buf + buf->length); - for (var = buf->var; var < last_var; - var = (struct efi_var_entry *) - ALIGN((uintptr_t)data + var->length, 8)) { - - data = var->name + u16_strlen(var->name) + 1; - - /* - * Secure boot related and volatile variables shall only be - * restored from U-Boot's preseed. - */ - if (!safe && - (efi_auth_var_get_type(var->name, &var->guid) != - EFI_AUTH_VAR_NONE || - !guidcmp(&var->guid, &shim_lock_guid) || - !(var->attr & EFI_VARIABLE_NON_VOLATILE))) - continue; - if (!var->length) - continue; - if (efi_var_mem_find(&var->guid, var->name, NULL)) - continue; - ret = efi_var_mem_ins(var->name, &var->guid, var->attr, - var->length, data, 0, NULL, - var->time); - if (ret != EFI_SUCCESS) - log_err("Failed to set EFI variable %ls\n", var->name); - } - return EFI_SUCCESS; }
/** @@ -214,7 +95,6 @@ efi_status_t efi_var_restore(struct efi_var_file *buf, bool safe) */ efi_status_t efi_var_from_file(void) { -#ifdef CONFIG_EFI_VARIABLE_FILE_STORE struct efi_var_file *buf; loff_t len; efi_status_t ret; @@ -239,6 +119,5 @@ efi_status_t efi_var_from_file(void) log_err("Invalid EFI variables file\n"); error: free(buf); -#endif return EFI_SUCCESS; } diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index be95ed44e6..adc5ac6a80 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -357,8 +357,11 @@ efi_status_t efi_set_variable_int(const u16 *variable_name, * Write non-volatile EFI variables to file * TODO: check if a value change has occured to avoid superfluous writes */ - if (attributes & EFI_VARIABLE_NON_VOLATILE) +#if CONFIG_IS_ENABLED(EFI_VARIABLE_FILE_STORE) + if (attributes & EFI_VARIABLE_NON_VOLATILE) { efi_var_to_file(); + } +#endif
return EFI_SUCCESS; } @@ -466,9 +469,12 @@ efi_status_t efi_init_variables(void) if (ret != EFI_SUCCESS) return ret;
+#if CONFIG_IS_ENABLED(EFI_VARIABLE_FILE_STORE) ret = efi_var_from_file(); if (ret != EFI_SUCCESS) return ret; +#endif + if (IS_ENABLED(CONFIG_EFI_VARIABLES_PRESEED)) { ret = efi_var_restore((struct efi_var_file *) __efi_var_file_begin, true);
The moved functions relate to filling the memory buffer of variables. Wouldn't lib/efi_loader/efi_var_mem.c be more appropriate as target file?
Best regards
Heinrich
- efi_var_restore() - restore EFI variables from buffer
- efi_efi_get_variable() - retrieve value of a UEFI variable
return buf; }
- if (!buf)
- var = buf->var;
- old_var = var;
- for (;;) {
u8 *data;
efi_status_t ret;
break;
free(buf);
return ret;
old_var = var;
&var->time);
free(buf);
return ret;
- *bufp = buf;
- *lenp = len;
- u16 *data;
- efi_status_t ret;
if (!safe &&
continue;
if (!var->length)
continue;
continue;
var->time);
- efi_set_blk_dev_to_system_partition() - select EFI system partition
- if (!buf)
- var = buf->var;
- old_var = var;
- for (;;) {
u8 *data;
efi_status_t ret;
break;
free(buf);
return ret;
old_var = var;
&var->time);
free(buf);
return ret;
- *bufp = buf;
- *lenp = len;
- efi_var_to_file() - save non-volatile variables as file
-#endif -}
u16 *data;
efi_status_t ret;
if (!safe &&
continue;
if (!var->length)
continue;
continue;
var->time);
- if (attributes & EFI_VARIABLE_NON_VOLATILE) { efi_var_to_file();
- if (IS_ENABLED(CONFIG_EFI_VARIABLES_PRESEED)) { ret = efi_var_restore((struct efi_var_file *) __efi_var_file_begin, true);
Hi Heinrich,
On Wed, Nov 29, 2023 at 5:41 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
As I understand, efi_var_mem.c implements an in-memory store of all EFI variables. These functions build a / read from a buffer for writing to an in-secure storage device ( file / SPI flash ). The functions are only used by efi_var_sf and efi_var_file hence in efi_var_common.
Happy to change if you want.
Kind regards, Shantur
Best regards
Heinrich
return buf;
if (!buf)
var = buf->var;
old_var = var;
for (;;) {
u8 *data;
efi_status_t ret;
break;
free(buf);
return ret;
old_var = var;
&var->time);
free(buf);
return ret;
buf->reserved = 0;
buf->length = len;
*bufp = buf;
*lenp = len;
return EFI_SUCCESS;
u16 *data;
efi_status_t ret;
if (!safe &&
continue;
if (!var->length)
continue;
continue;
var->time);
return EFI_SUCCESS;
if (!buf)
var = buf->var;
old_var = var;
for (;;) {
u8 *data;
efi_status_t ret;
break;
free(buf);
return ret;
old_var = var;
&var->time);
free(buf);
return ret;
buf->reserved = 0;
buf->length = len;
*bufp = buf;
*lenp = len;
return EFI_SUCCESS;
return EFI_SUCCESS;
-#endif -}
u16 *data;
efi_status_t ret;
if (!safe &&
continue;
if (!var->length)
continue;
continue;
var->time);
return EFI_SUCCESS;
return EFI_SUCCESS;
Currently U-boot uses ESP as storage for EFI variables. Devices with SPI Flash are used for storing environment with this commit we allow EFI variables to be stored on SPI Flash.
include/efi_variable.h | 21 ++++++++ lib/efi_loader/Kconfig | 25 ++++++++++ lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_var_sf.c | 91 +++++++++++++++++++++++++++++++++++ lib/efi_loader/efi_variable.c | 15 ++++-- 5 files changed, 149 insertions(+), 4 deletions(-) create mode 100644 lib/efi_loader/efi_var_sf.c
diff --git a/include/efi_variable.h b/include/efi_variable.h index bd0a31fc3e..f90bbb0548 100644 --- a/include/efi_variable.h +++ b/include/efi_variable.h @@ -190,6 +190,27 @@ efi_status_t efi_var_restore(struct efi_var_file *buf, bool safe); */ efi_status_t efi_var_from_file(void);
+/** + * efi_var_from_sf() - read variables from SPI Flash + * + * EFI variable buffer is read from SPI Flash at offset defined with + * CONFIG_EFI_VARIABLE_SF_OFFSET of length CONFIG_EFI_VAR_BUF_SIZE + * + * + * Return: status code + */ +efi_status_t efi_var_from_sf(void); + +/** + * efi_var_to_sf() - save non-volatile variables to SPI Flash + * + * EFI variable buffer is saved to SPI Flash at offset defined with + * CONFIG_EFI_VARIABLE_SF_OFFSET of length CONFIG_EFI_VAR_BUF_SIZE. + * + * Return: status code + */ +efi_status_t efi_var_to_sf(void); + /** * efi_var_mem_init() - set-up variable list * diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 2e3935467c..d3200cb3e3 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -54,6 +54,17 @@ config EFI_VARIABLE_FILE_STORE Select this option if you want non-volatile UEFI variables to be stored as file /ubootefi.var on the EFI system partition.
+config EFI_VARIABLE_SF_STORE + bool "Store non-volatile UEFI variables in SPI Flash" + depends on SPI_FLASH + help + Select this option if you want non-volatile UEFI variables to be + stored in SPI Flash. + Define CONFIG_EFI_VARIABLE_SF_OFFSET as offset in SPI Flash to use as + the storage for variables. CONFIG_EFI_VAR_BUF_SIZE defines the space + needed. + + config EFI_MM_COMM_TEE bool "UEFI variables storage service via the trusted world" depends on OPTEE @@ -108,6 +119,20 @@ config EFI_VARIABLE_NO_STORE
endchoice
+config EFI_VARIABLE_SF_OFFSET + hex "EFI variables in SPI flash offset" + depends on EFI_VARIABLE_SF_STORE + help + Offset from the start of the SPI Flash where EFI variables will be stored. + This should be aligned to the sector size of SPI Flash. + +config EFI_VARIABLE_SF_DEVICE_INDEX + int "Device Index for target SPI Flash" + default 0 + help + The index of SPI Flash device used for storing EFI variables. This would be + needed if there are more than 1 SPI Flash devices available to use. + config EFI_VARIABLES_PRESEED bool "Initial values for UEFI variables" depends on !EFI_MM_COMM_TEE diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index 33b1910249..823e0a759f 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -67,6 +67,7 @@ obj-$(CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2) += efi_unicode_collation.o obj-y += efi_var_common.o obj-y += efi_var_mem.o obj-$(CONFIG_EFI_VARIABLE_FILE_STORE) += efi_var_file.o +obj-$(CONFIG_EFI_VARIABLE_SF_STORE) += efi_var_sf.o ifeq ($(CONFIG_EFI_MM_COMM_TEE),y) obj-y += efi_variable_tee.o else diff --git a/lib/efi_loader/efi_var_sf.c b/lib/efi_loader/efi_var_sf.c new file mode 100644 index 0000000000..ecf25929f5 --- /dev/null +++ b/lib/efi_loader/efi_var_sf.c @@ -0,0 +1,91 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * SPI Flash interface for UEFI variables + * + * Copyright (c) 2023, Shantur Rathore + */ + +#define LOG_CATEGORY LOGC_EFI + +#include <efi_loader.h> +#include <efi_variable.h> +#include <spi_flash.h> +#include <dm.h> + +efi_status_t efi_var_to_sf(void) +{ + efi_status_t ret; + struct efi_var_file *buf; + loff_t len; + struct udevice *sfdev; + + ret = efi_var_collect(&buf, &len, EFI_VARIABLE_NON_VOLATILE); + if (len > EFI_VAR_BUF_SIZE) { + log_err("EFI var buffer length more than target SF size"); + ret = EFI_OUT_OF_RESOURCES; + goto error; + } + + log_debug("%s - Got buffer to write buf->len : %d\n", __func__, buf->length); + + if (ret != EFI_SUCCESS) + goto error; + + ret = uclass_get_device(UCLASS_SPI_FLASH, CONFIG_EFI_VARIABLE_SF_DEVICE_INDEX, &sfdev); + if (ret) + goto error; + + ret = spi_flash_erase_dm(sfdev, CONFIG_EFI_VARIABLE_SF_OFFSET, EFI_VAR_BUF_SIZE); + log_debug("%s - Erased SPI Flash offset %lx\n", __func__, CONFIG_EFI_VARIABLE_SF_OFFSET); + if (ret) + goto error; + + ret = spi_flash_write_dm(sfdev, CONFIG_EFI_VARIABLE_SF_OFFSET, len, buf); + log_debug("%s - Wrote buffer to SPI Flash : %ld\n", __func__, ret); + + if (ret) + goto error; + + ret = EFI_SUCCESS; +error: + if (ret) + log_err("Failed to persist EFI variables in SF\n"); + free(buf); + return ret; +} + +efi_status_t efi_var_from_sf(void) +{ + struct efi_var_file *buf; + efi_status_t ret; + struct udevice *sfdev; + + buf = calloc(1, EFI_VAR_BUF_SIZE); + if (!buf) { + log_err("%s - Unable to allocate buffer\n", __func__); + return EFI_OUT_OF_RESOURCES; + } + + ret = uclass_get_device(UCLASS_SPI_FLASH, 0, &sfdev); + if (ret) + goto error; + + ret = spi_flash_read_dm(sfdev, CONFIG_EFI_VARIABLE_SF_OFFSET, + EFI_VAR_BUF_SIZE, buf); + + log_debug("%s - read buffer buf->length: %x\n", __func__, buf->length); + + if (ret || buf->length < sizeof(struct efi_var_file)) { + log_err("%s - buffer read from SPI Flash isn't valid\n", __func__); + goto error; + } + + ret = efi_var_restore(buf, false); + if (ret != EFI_SUCCESS) + log_err("%s - Unable to restore EFI variables from buffer\n"); + + ret = EFI_SUCCESS; +error: + free(buf); + return ret; +} diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index adc5ac6a80..f73fb40061 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -354,14 +354,16 @@ efi_status_t efi_set_variable_int(const u16 *variable_name, ret = EFI_SUCCESS;
/* - * Write non-volatile EFI variables to file + * Write non-volatile EFI variables to file or SPI Flash * TODO: check if a value change has occured to avoid superfluous writes */ -#if CONFIG_IS_ENABLED(EFI_VARIABLE_FILE_STORE) if (attributes & EFI_VARIABLE_NON_VOLATILE) { +#if CONFIG_IS_ENABLED(EFI_VARIABLE_FILE_STORE) efi_var_to_file(); - } +#elif CONFIG_IS_ENABLED(EFI_VARIABLE_SF_STORE) + efi_var_to_sf(); #endif + }
return EFI_SUCCESS; } @@ -471,9 +473,14 @@ efi_status_t efi_init_variables(void)
#if CONFIG_IS_ENABLED(EFI_VARIABLE_FILE_STORE) ret = efi_var_from_file(); +#elif CONFIG_IS_ENABLED(EFI_VARIABLE_SF_STORE) + ret = efi_var_from_sf(); +#else + ret = EFI_SUCCESS; +#endif + if (ret != EFI_SUCCESS) return ret; -#endif
RockPro64 uses SPI Flash for storing env, also use it store EFI variables.
configs/rockpro64-rk3399_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 4cd6b76665..f550f2ae43 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -8,6 +8,8 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 CONFIG_ENV_SIZE=0x8000 CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_EFI_VARIABLE_SF_STORE=y +CONFIG_EFI_VARIABLE_SF_OFFSET=0x7D0000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-rockpro64" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y
Shantur Rathore
