[U-Boot-Users] dataflash problem
I'm using u-boot 1.1.3 with an AT91 board, however I'm having problems with the dataflash support:
U-Boot downloaded successfully
U-Boot 1.1.3 (Oct 9 2005 - 21:49:00)
U-Boot code: 21F00000 -> 21F149B8 BSS: -> 21F19290 RAM Configuration: Bank #0: 20000000 32 MB Atmel: Flash: 0 kB DataFlash:AT45DB161 Nb pages: 4096 Page Size: 528 Size= 2162688 bytes Logical address: 0xC0000000 Area 0: C0000000 to C0007FFF (RO) Area 1: C0008000 to C001FFFF (RO) Area 2: C0020000 to C0027FFF Area 3: C0028000 to C020FFFF *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial U-Boot> flinfo DataFlash:AT45DB161 Nb pages: 4096 Page Size: 528 Size= 2162688 bytes Logical address: 0xC0000000 Area 0: C0000000 to C0007FFF (RO) Area 1: C0008000 to C001FFFF (RO) Area 2: C0020000 to C0027FFF Area 3: C0028000 to C020FFFF
Bank # 1: Atmel: Unknown Chip Type U-Boot> md C0020000 c0020000:Error Timeout -F- Data Abort detected
To me, this seems like u-boot is not honouring that C0000000 should be mapped to the dataflash, instead it wants to read the physical memory at C0000000 which is obviously non existing on this platform.
the "about the "Atmel: Flash: 0 kB" message is normal, since I'm having no NAND and using the atmel developed loader.bin for booting u-boot.
SPI support also seems to be okay, since it recognizes the exact type of my dataflash device..
Can you give some hints how to start finding out what is causing this problem?
Best regards, Zoli
Here is my at91rm9200dk.h:
/* ARM asynchronous clock */ #define AT91C_MAIN_CLOCK 179712000 /* from 18.432 MHz crystal (18432000 / 4 * 39) */ #define AT91C_MASTER_CLOCK 59904000 /* peripheral clock (AT91C_MASTER_CLOCK / 3) */ /* #define AT91C_MASTER_CLOCK 44928000 */ /* peripheral clock (AT91C_MASTER_CLOCK / 4) */
#define AT91_SLOW_CLOCK 32768 /* slow clock */
#define CONFIG_ARM920T 1 /* This is an ARM920T Core */ #define CONFIG_AT91RM9200 1 /* It's an Atmel AT91RM9200 SoC */ #define CONFIG_AT91RM9200DK 1 /* on an AT91RM9200DK Board */ #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ #define USE_920T_MMU 1
#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1
#ifndef CONFIG_SKIP_LOWLEVEL_INIT #define CFG_USE_MAIN_OSCILLATOR 1 /* flash */ #define MC_PUIA_VAL 0x00000000 #define MC_PUP_VAL 0x00000000 #define MC_PUER_VAL 0x00000000 #define MC_ASR_VAL 0x00000000 #define MC_AASR_VAL 0x00000000 #define EBI_CFGR_VAL 0x00000000 #define SMC2_CSR_VAL 0x00003284 /* 16bit, 2 TDF, 4 WS */
/* clocks */ #define PLLAR_VAL 0x20263E04 /* 179.712000 MHz for PCK */ #define PLLBR_VAL 0x10483E0E /* 48.054857 MHz (divider by 2 for USB) */ #define MCKR_VAL 0x00000202 /* PCK/3 = MCK Master Clock = 59.904000MHz from PLLA */
/* sdram */ #define PIOC_ASR_VAL 0xFFFF0000 /* Configure PIOC as peripheral (D16/D31) */ #define PIOC_BSR_VAL 0x00000000 #define PIOC_PDR_VAL 0xFFFF0000 #define EBI_CSA_VAL 0x00000002 /* CS1=SDRAM */ #define SDRC_CR_VAL 0x2188c155 /* set up the SDRAM */ #define SDRAM 0x20000000 /* address of the SDRAM */ #define SDRAM1 0x20000080 /* address of the SDRAM */ #define SDRAM_VAL 0x00000000 /* value written to SDRAM */ #define SDRC_MR_VAL 0x00000002 /* Precharge All */ #define SDRC_MR_VAL1 0x00000004 /* refresh */ #define SDRC_MR_VAL2 0x00000003 /* Load Mode Register */ #define SDRC_MR_VAL3 0x00000000 /* Normal Mode */ #define SDRC_TR_VAL 0x000002E0 /* Write refresh rate */ #endif /* CONFIG_SKIP_LOWLEVEL_INIT */ /* * Size of malloc() pool */ #define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) #define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
#define CONFIG_BAUDRATE 115200
/* * Hardware drivers */
/* define one of these to choose the DBGU, USART0 or USART1 as console */ #define CONFIG_DBGU #undef CONFIG_USART0 #undef CONFIG_USART1
#undef CONFIG_HWFLOW /* don't include RTS/CTS flow control support */
#undef CONFIG_MODEM_SUPPORT /* disable modem initialization stuff */ #define CONFIG_BOOTDELAY 3 /* #define CONFIG_ENV_OVERWRITE 1 */
#define CONFIG_COMMANDS \ ((CONFIG_CMD_DFL | \ CFG_CMD_DHCP ) & \ ~(CFG_CMD_BDI | \ CFG_CMD_IMI | \ CFG_CMD_AUTOSCRIPT | \ CFG_CMD_FPGA | \ CFG_CMD_MISC | \ CFG_CMD_LOADS ))
/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ #include <cmd_confdefs.h>
#define CFG_MAX_NAND_DEVICE 0 /* Max number of NAND devices */ #define SECTORSIZE 512
#define ADDR_COLUMN 1 #define ADDR_PAGE 2 #define ADDR_COLUMN_PAGE 3
#define NAND_ChipID_UNKNOWN 0x00 #define NAND_MAX_FLOORS 1 #define NAND_MAX_CHIPS 1
#define AT91_SMART_MEDIA_ALE (1 << 22) /* our ALE is AD22 */ #define AT91_SMART_MEDIA_CLE (1 << 21) /* our CLE is AD21 */
#define NAND_DISABLE_CE(nand) do { *AT91C_PIOC_SODR = AT91C_PIO_PC0;} while(0) #define NAND_ENABLE_CE(nand) do { *AT91C_PIOC_CODR = AT91C_PIO_PC0;} while(0)
#define NAND_WAIT_READY(nand) while (!(*AT91C_PIOC_PDSR & AT91C_PIO_PC2))
#define WRITE_NAND_COMMAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr | AT91_SMART_MEDIA_CLE) = (__u8)(d); } while(0) #define WRITE_NAND_ADDRESS(d, adr) do{ *(volatile __u8 *)((unsigned long)adr | AT91_SMART_MEDIA_ALE) = (__u8)(d); } while(0) #define WRITE_NAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)d; } while(0) #define READ_NAND(adr) ((volatile unsigned char)(*(volatile __u8 *)(unsigned long)adr)) /* the following are NOP's in our implementation */ #define NAND_CTL_CLRALE(nandptr) #define NAND_CTL_SETALE(nandptr) #define NAND_CTL_CLRCLE(nandptr) #define NAND_CTL_SETCLE(nandptr)
#define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM 0x20000000 #define PHYS_SDRAM_SIZE 0x2000000 /* 32 megs */
#define CFG_MEMTEST_START PHYS_SDRAM #define CFG_MEMTEST_END CFG_MEMTEST_START + PHYS_SDRAM_SIZE - (1024*1024)
#define CONFIG_DRIVER_ETHER #define CONFIG_NET_RETRY_COUNT 20
#define CONFIG_HAS_DATAFLASH 1 #define CFG_SPI_WRITE_TOUT (5*CFG_HZ) #define CFG_MAX_DATAFLASH_BANKS 2 #define CFG_MAX_DATAFLASH_PAGES 16384 #define CFG_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* Logical adress for CS0 */ #define CFG_DATAFLASH_LOGIC_ADDR_CS3 0xD0000000 /* Logical adress for CS3 */
#define PHYS_FLASH_1 0x10000000 #define PHYS_FLASH_SIZE 0x200000 /* 2 megs main flash */ #define CFG_FLASH_BASE PHYS_FLASH_1 #define CFG_MAX_FLASH_BANKS 1 #define CFG_MAX_FLASH_SECT 256 #define CFG_FLASH_ERASE_TOUT (2*CFG_HZ) /* Timeout for Flash Erase */#define CFG_FLASH_WRITE_TOUT (2*CFG_HZ) /* Timeout for Flash Write */ #undef CFG_ENV_IS_IN_DATAFLASH
#ifdef CFG_ENV_IS_IN_DATAFLASH #define CFG_ENV_OFFSET 0x20000 #define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CFG_ENV_OFFSET) #define CFG_ENV_SIZE 0x2000 /* 0x8000 */ #else #define CFG_ENV_IS_IN_FLASH 1 #ifdef CONFIG_SKIP_LOWLEVEL_INIT #define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x60000) /* after u-boot.bin */ #define CFG_ENV_SIZE 0x10000 /* sectors are 64K here */ #else #define CFG_ENV_ADDR (PHYS_FLASH_1 + 0xe000) /* between boot.bin and u-boot.bin.gz */ #define CFG_ENV_SIZE 0x2000 /* 0x8000 */ #endif /* CONFIG_SKIP_LOWLEVEL_INIT */ #endif /* CFG_ENV_IS_IN_DATAFLASH */
#define CFG_LOAD_ADDR 0x21000000 /* default load address */
#ifdef CONFIG_SKIP_LOWLEVEL_INIT #define CFG_BOOT_SIZE 0x00 /* 0 KBytes */ #define CFG_U_BOOT_BASE PHYS_FLASH_1 #define CFG_U_BOOT_SIZE 0x60000 /* 384 KBytes */ #else #define CFG_BOOT_SIZE 0x6000 /* 24 KBytes */ #define CFG_U_BOOT_BASE (PHYS_FLASH_1 + 0x10000) #define CFG_U_BOOT_SIZE 0x10000 /* 64 KBytes */ #endif /* CONFIG_SKIP_LOWLEVEL_INIT */
#define CFG_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 }
#define CFG_PROMPT "U-Boot> " /* Monitor Command Prompt */ #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ #define CFG_MAXARGS 16 /* max number of command args */#define CFG_PBSIZE (CFG_CBSIZE +sizeof(CFG_PROMPT)+16) /* Print Buffer Size */
#ifndef __ASSEMBLY__ /*----------------------------------------------------------------------- * Board specific extension for bd_info * * This structure is embedded in the global bd_info (bd_t) structure * and can be used by the board specific code (eg board/...) */
struct bd_info_ext { /* helper variable for board environment handling * * env_crc_valid == 0 => uninitialised * env_crc_valid > 0 => environment crc in flash is valid * env_crc_valid < 0 => environment crc in flash is invalid */ int env_crc_valid; }; #endif
#define CFG_HZ 1000 #define CFG_HZ_CLOCK AT91C_MASTER_CLOCK/2 /* AT91C_TC0_CMR is implicitly set to */ /* AT91C_TC_TIMER_DIV1_CLOCK */
#define CONFIG_STACKSIZE (32*1024) /* regular stack */
#ifdef CONFIG_USE_IRQ #error CONFIG_USE_IRQ not supported #endif
#endif
#define CFG_AUTO_COMPLETE 1
Hello!
Absence of NAND flash uncovers an issue with flash address ranges checking. The problem can be bypassed with either of two methods:
First: hack address ranges checking in common/flash.c:
--- u-boot-1.1.3/common/flash.c 2005-08-14 03:53:35.000000000 +0400 +++ u-boot-1.1.3-new/common/flash.c 2005-09-15 01:15:58.000000000 +0400 @@ -105,6 +105,8 @@ int i;
for (i=0, info=&flash_info[0]; i<CFG_MAX_FLASH_BANKS; ++i, ++info) { + if (info->size == 0) + continue; if (info->flash_id != FLASH_UNKNOWN && addr >= info->start[0] && /* WARNING - The '- 1' is needed if the flash
Second: disable NAND flash by setting CFG_MAX_FLASH_BANKS to 0 in board config.
I'm not sure it is right solution, but it at least looks as working for me :)
thank you for your answer!
in the last few hours I've managed to track down that the error is not in the address range checking, but in at45.c : AT91F_DataFlashRead function. Within that, the AT91F_DataFlashWaitReady function is timeouting resulting that cmd_mem.c:do_mem_cmd continues execution at line 167, where it attemts to read non-existing memory..
I dont really know why is this timeout occuring, since I've written some codes which run natively (without Linux) on the board, and I can access the DataFlash without problems.
regards, Zoli
if (info->flash_id != FLASH_UNKNOWN && addr >= info->start[0] && /* WARNING - The '- 1' is needed if the flashcontinue;
Andrey P. Vasilyev
zoldnap@freemail.hu
