[U-Boot] MMC0: DMA transfer failed
On a mx28evk board I am getting the following using top of tree U-boot:
U-Boot 2012.04-rc1-00001-g037cbfd (Apr 02 2012 - 10:57:48)
Freescale i.MX28 family at 454 MHz DRAM: 128 MiB MMC: MXS MMC: 0 MMC0: DMA transfer failed MMC0: DMA transfer failed MMC0: DMA transfer failed MMC0: DMA transfer failed MMC init failed Using default environment
Is there any patch I am missing?
Thanks,
Fabio Estevam
Dear Fabio Estevam,
No, it means I might just have a good card and I didn't notice this. I really do need to get some crappy (new) cards to track down these issues. Fabio, can you please try debugging this?
Thanks,
Fabio Estevam
Best regards, Marek Vasut
Ok, I am debugging this.
What do you think about the change below?
--- a/drivers/mmc/mxsmmc.c +++ b/drivers/mmc/mxsmmc.c @@ -191,7 +191,7 @@ mxsmmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct else cache_data_count = data_count;
- if (data->flags & MMC_DATA_READ) { + if (data->flags & MMC_DATA_WRITE) { priv->desc->cmd.data = MXS_DMA_DESC_COMMAND_DMA_WRITE; priv->desc->cmd.address = (dma_addr_t)data->dest; } else {
It doesn't fix this issue, but it seems correct.
Dear Fabio Estevam,
No it's not, when you do SD READ, you read the data into the dest buffer.
Hi Fabio,
maybe it is worth to check first if it depends on the data cache, that is now turned on. Add CONFIG_CMD_CACHE to the configuartion file, and try to start mmc with and without dcache.
Best regards, Stefano
Dear Stefano Babic,
Hi Fabio,
The cache should be off on m28evk and so should be on mx28evk.
Fabio Estevam
Stefano Babic
