[PATCH] Convert CONFIG_SKIP_LOWLEVEL_INIT et al to Kconfig
This converts the following to Kconfig: CONFIG_SKIP_LOWLEVEL_INIT CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these options so that we can clearly disable these options only in SPL in some cases, and both instances in other cases.
Signed-off-by: Tom Rini trini@konsulko.com --- README | 16 ------ arch/Kconfig | 57 +++++++++++++++++++ arch/arm/cpu/arm1136/start.S | 8 +-- arch/arm/cpu/arm720t/start.S | 10 ++-- arch/arm/cpu/arm920t/start.S | 8 +-- arch/arm/cpu/arm926ejs/start.S | 8 +-- arch/arm/cpu/arm946es/start.S | 6 +- arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/start.S | 8 +-- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 6 ++ arch/arm/cpu/pxa/start.S | 6 +- arch/arm/cpu/sa1100/start.S | 4 +- arch/arm/include/asm/arch-am33xx/chilisom.h | 2 +- arch/arm/mach-at91/arm920t/lowlevel_init.S | 4 +- arch/arm/mach-imx/mx7/soc.c | 2 +- arch/arm/mach-imx/syscounter.c | 2 +- arch/arm/mach-mvebu/include/mach/config.h | 4 -- arch/arm/mach-omap2/Kconfig | 1 + arch/arm/mach-omap2/am33xx/Makefile | 2 +- arch/arm/mach-omap2/am33xx/board.c | 6 +- arch/arm/mach-omap2/am33xx/chilisom.c | 4 +- arch/arm/mach-omap2/omap3/board.c | 4 +- arch/arm/mach-omap2/omap3/lowlevel_init.S | 4 +- arch/arm/mach-orion5x/Makefile | 2 +- arch/arm/mach-rockchip/Kconfig | 1 + arch/arm/mach-tegra/Kconfig | 1 + arch/mips/cpu/start.S | 4 +- arch/mips/mach-mtmips/mt7628/lowlevel_init.S | 4 +- arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S | 4 +- arch/nds32/cpu/n1213/ag101/lowlevel_init.S | 4 +- arch/nds32/cpu/n1213/start.S | 2 +- board/bosch/guardian/Makefile | 2 +- board/bosch/guardian/board.c | 2 +- board/eets/pdu001/Makefile | 2 +- board/eets/pdu001/board.c | 4 +- board/freescale/ls1021aqds/README | 5 +- board/freescale/ls1021atwr/README | 5 +- board/grinn/chiliboard/board.c | 6 +- board/qca/ap152/ap152.c | 2 +- board/tcl/sl50/Makefile | 2 +- board/tcl/sl50/board.c | 2 +- board/ti/am335x/Makefile | 2 +- board/ti/am335x/board.c | 2 +- board/ti/am43xx/Makefile | 2 +- board/ti/am43xx/board.c | 2 +- board/tplink/wdr4300/wdr4300.c | 2 +- board/vscom/baltos/Makefile | 2 +- configs/SBx81LIFKW_defconfig | 1 + configs/SBx81LIFXCAT_defconfig | 1 + configs/adp-ae3xx_defconfig | 1 + configs/adp-ag101p_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/am64x_evm_a53_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/am65x_hs_evm_a53_defconfig | 1 + configs/arndale_defconfig | 2 + configs/aspenite_defconfig | 1 + configs/at91sam9260ek_dataflash_cs0_defconfig | 1 + configs/at91sam9260ek_dataflash_cs1_defconfig | 1 + configs/at91sam9260ek_nandflash_defconfig | 1 + configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9g20ek_2mmc_defconfig | 1 + .../at91sam9g20ek_2mmc_nandflash_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs1_defconfig | 1 + configs/at91sam9g20ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/at91sam9xeek_dataflash_cs0_defconfig | 1 + configs/at91sam9xeek_dataflash_cs1_defconfig | 1 + configs/at91sam9xeek_nandflash_defconfig | 1 + configs/axm_defconfig | 2 + configs/bcm7260_defconfig | 1 + configs/bcm7445_defconfig | 1 + configs/bcm963158_ram_defconfig | 1 + configs/bcm968360bg_ram_defconfig | 1 + configs/bcm968380gerg_ram_defconfig | 3 + configs/bcm968580xref_ram_defconfig | 1 + configs/bk4r1_defconfig | 1 + configs/chromebit_mickey_defconfig | 1 + configs/chromebook_bob_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/chromebook_speedy_defconfig | 1 + configs/ci20_mmc_defconfig | 3 + configs/clearfog_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/colibri_vf_defconfig | 1 + configs/comtrend_ar5315u_ram_defconfig | 3 + configs/comtrend_ar5387un_ram_defconfig | 3 + configs/comtrend_ct5361_ram_defconfig | 3 + configs/comtrend_vr3032u_ram_defconfig | 3 + configs/comtrend_wap5813n_ram_defconfig | 3 + configs/controlcenterdc_defconfig | 2 + configs/corvus_defconfig | 2 + configs/d2net_v2_defconfig | 1 + configs/da850evm_defconfig | 2 + configs/da850evm_direct_nor_defconfig | 1 + configs/da850evm_nand_defconfig | 2 + configs/db-88f6720_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/dns325_defconfig | 1 + configs/dockstar_defconfig | 1 + configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 1 + configs/ea-lpc3250devkitv2_defconfig | 1 + configs/elgin-rv1108_defconfig | 1 + configs/ethernut5_defconfig | 1 + configs/evb-px30_defconfig | 1 + configs/evb-px5_defconfig | 1 + configs/evb-rk3036_defconfig | 2 + configs/evb-rk3128_defconfig | 1 + configs/evb-rk3229_defconfig | 3 + configs/evb-rk3288_defconfig | 2 + configs/evb-rk3308_defconfig | 1 + configs/evb-rk3328_defconfig | 1 + configs/evb-rk3399_defconfig | 1 + configs/evb-rk3568_defconfig | 1 + configs/evb-rv1108_defconfig | 1 + configs/ficus-rk3399_defconfig | 1 + configs/firefly-px30_defconfig | 1 + configs/firefly-rk3288_defconfig | 2 + configs/firefly-rk3399_defconfig | 1 + .../gardena-smart-gateway-at91sam_defconfig | 2 + .../gardena-smart-gateway-mt7688_defconfig | 3 + configs/geekbox_defconfig | 1 + configs/goflexhome_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/helios4_defconfig | 1 + configs/highbank_defconfig | 1 + configs/huawei_hg556a_ram_defconfig | 3 + configs/ib62x0_defconfig | 1 + configs/iconnect_defconfig | 1 + configs/imgtec_xilfpga_defconfig | 3 + configs/inetspace_v2_defconfig | 1 + configs/k2e_evm_defconfig | 2 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 2 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 2 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 2 + configs/k2l_hs_evm_defconfig | 1 + configs/khadas-edge-captain-rk3399_defconfig | 1 + configs/khadas-edge-rk3399_defconfig | 1 + configs/khadas-edge-v-rk3399_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + configs/kmnusa_defconfig | 1 + configs/kmsuse2_defconfig | 1 + configs/kylin-rk3036_defconfig | 2 + configs/leez-rk3399_defconfig | 1 + configs/legoev3_defconfig | 1 + configs/linkit-smart-7688_defconfig | 3 + configs/lion-rk3368_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 2 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 2 + configs/ls1021aqds_sdcard_qspi_defconfig | 2 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 2 + configs/ls1021atwr_sdcard_ifc_defconfig | 2 + configs/ls1021atwr_sdcard_qspi_defconfig | 2 + configs/ls1028aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1028aqds_tfa_defconfig | 1 + configs/ls1028aqds_tfa_lpuart_defconfig | 1 + configs/ls1028ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1028ardb_tfa_defconfig | 1 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/lx2160aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160aqds_tfa_defconfig | 1 + configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160ardb_tfa_defconfig | 1 + configs/lx2160ardb_tfa_stmm_defconfig | 1 + configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2162aqds_tfa_defconfig | 1 + .../lx2162aqds_tfa_verified_boot_defconfig | 1 + configs/meesc_dataflash_defconfig | 1 + configs/meesc_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/mt7620_mt7530_rfb_defconfig | 3 + configs/mt7620_rfb_defconfig | 3 + configs/mt7628_rfb_defconfig | 3 + configs/nanopc-t4-rk3399_defconfig | 1 + configs/nanopi-m4-2gb-rk3399_defconfig | 1 + configs/nanopi-m4-rk3399_defconfig | 1 + configs/nanopi-m4b-rk3399_defconfig | 1 + configs/nanopi-neo4-rk3399_defconfig | 1 + configs/nanopi-r2s-rk3328_defconfig | 1 + configs/nanopi-r4s-rk3399_defconfig | 1 + configs/nas220_defconfig | 1 + configs/net2big_v2_defconfig | 1 + configs/netgear_cg3100d_ram_defconfig | 3 + configs/netgear_dgnd3700v2_ram_defconfig | 3 + configs/netspace_lite_v2_defconfig | 1 + configs/netspace_max_v2_defconfig | 1 + configs/netspace_mini_v2_defconfig | 1 + configs/netspace_v2_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/nsa310s_defconfig | 1 + configs/odroid-go2_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + configs/omapl138_lcdk_defconfig | 2 + configs/openrd_base_defconfig | 1 + configs/openrd_client_defconfig | 1 + configs/openrd_ultimate_defconfig | 1 + configs/orangepi-rk3399_defconfig | 1 + configs/origen_defconfig | 2 + configs/pcm052_defconfig | 1 + configs/peach-pi_defconfig | 2 + configs/peach-pit_defconfig | 2 + configs/pg_wcom_expu1_defconfig | 1 + configs/pg_wcom_seli8_defconfig | 1 + configs/phycore-rk3288_defconfig | 1 + configs/pinebook-pro-rk3399_defconfig | 1 + configs/pm9g45_defconfig | 1 + configs/pogo_e02_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/px30-core-ctouch2-px30_defconfig | 1 + configs/px30-core-edimm2.2-px30_defconfig | 1 + configs/roc-cc-rk3308_defconfig | 1 + configs/roc-cc-rk3328_defconfig | 1 + configs/roc-pc-mezzanine-rk3399_defconfig | 1 + configs/roc-pc-rk3399_defconfig | 1 + configs/rock-pi-4-rk3399_defconfig | 1 + configs/rock-pi-4c-rk3399_defconfig | 1 + configs/rock-pi-e-rk3328_defconfig | 1 + configs/rock-pi-n10-rk3399pro_defconfig | 1 + configs/rock-pi-n8-rk3288_defconfig | 2 + configs/rock2_defconfig | 1 + configs/rock64-rk3328_defconfig | 1 + configs/rock960-rk3399_defconfig | 1 + configs/rock_defconfig | 2 + configs/rockpro64-rk3399_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/sagem_f@st1704_ram_defconfig | 3 + configs/sam9x60ek_mmc_defconfig | 1 + configs/sam9x60ek_nandflash_defconfig | 1 + configs/sam9x60ek_qspiflash_defconfig | 1 + configs/sama5d27_giantboard_defconfig | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 1 + configs/sama5d27_som1_ek_mmc_defconfig | 1 + configs/sama5d27_som1_ek_qspiflash_defconfig | 1 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 1 + .../sama5d27_wlsom1_ek_qspiflash_defconfig | 1 + configs/sama5d2_icp_mmc_defconfig | 1 + configs/sama5d2_ptc_ek_mmc_defconfig | 1 + configs/sama5d2_ptc_ek_nandflash_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_qspiflash_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sfr_nb4-ser_ram_defconfig | 3 + configs/sheep-rk3368_defconfig | 1 + configs/sheevaplug_defconfig | 1 + configs/smartweb_defconfig | 2 + configs/smdk5250_defconfig | 2 + configs/smdk5420_defconfig | 2 + configs/smdkv310_defconfig | 2 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/snow_defconfig | 2 + configs/spring_defconfig | 2 + configs/stemmy_defconfig | 1 + configs/stih410-b2260_defconfig | 1 + configs/taurus_defconfig | 2 + configs/ti816x_evm_defconfig | 1 + configs/tinker-rk3288_defconfig | 2 + configs/tinker-s-rk3288_defconfig | 2 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/usb_a9263_dataflash_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + configs/vinco_defconfig | 1 + configs/vocore2_defconfig | 3 + configs/vyasa-rk3288_defconfig | 2 + configs/work_92105_defconfig | 1 + configs/x530_defconfig | 1 + configs/xilinx_zynqmp_r5_defconfig | 1 + configs/zynq_cse_nand_defconfig | 2 + configs/zynq_cse_nor_defconfig | 2 + configs/zynq_cse_qspi_defconfig | 2 + doc/board/AndesTech/adp-ag101p.rst | 4 +- include/configs/SBx81LIFKW.h | 1 - include/configs/SBx81LIFXCAT.h | 1 - include/configs/adp-ae3xx.h | 2 - include/configs/adp-ag101p.h | 2 - include/configs/am43xx_evm.h | 8 --- include/configs/am64x_evm.h | 4 -- include/configs/am65x_evm.h | 4 -- include/configs/aspenite.h | 1 - include/configs/at91-sama5_common.h | 4 -- include/configs/at91sam9260ek.h | 1 - include/configs/at91sam9261ek.h | 2 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 2 - include/configs/at91sam9x5ek.h | 1 - include/configs/bcmstb.h | 1 - include/configs/bk4r1.h | 2 - include/configs/bmips_bcm3380.h | 1 - include/configs/bmips_bcm6318.h | 1 - include/configs/bmips_bcm63268.h | 1 - include/configs/bmips_bcm6328.h | 1 - include/configs/bmips_bcm6338.h | 1 - include/configs/bmips_bcm6348.h | 1 - include/configs/bmips_bcm6358.h | 1 - include/configs/bmips_bcm6362.h | 1 - include/configs/bmips_bcm6368.h | 1 - include/configs/bmips_bcm6838.h | 1 - include/configs/broadcom_bcm963158.h | 2 - include/configs/broadcom_bcm968360bg.h | 2 - include/configs/broadcom_bcm968580xref.h | 2 - include/configs/bur_am335x_common.h | 3 - include/configs/ci20.h | 2 - include/configs/cm_t43.h | 3 - include/configs/colibri_vf.h | 2 - include/configs/controlcenterdc.h | 2 - include/configs/corvus.h | 1 - include/configs/da850evm.h | 1 - include/configs/devkit3250.h | 4 -- include/configs/dns325.h | 1 - include/configs/dockstar.h | 1 - include/configs/ea-lpc3250devkitv2.h | 1 - include/configs/ethernut5.h | 1 - include/configs/exynos-common.h | 2 - .../configs/gardena-smart-gateway-at91sam.h | 5 -- .../configs/gardena-smart-gateway-mt7688.h | 3 - include/configs/goflexhome.h | 1 - include/configs/highbank.h | 1 - include/configs/ib62x0.h | 1 - include/configs/iconnect.h | 1 - include/configs/imgtec_xilfpga.h | 1 - include/configs/integrator-common.h | 1 - include/configs/km/km_arm.h | 2 - include/configs/km/pg-wcom-ls102xa.h | 2 - include/configs/lacie_kw.h | 1 - include/configs/legoev3.h | 1 - include/configs/linkit-smart-7688.h | 3 - include/configs/ls1012a_common.h | 2 - include/configs/ls1021aqds.h | 2 - include/configs/ls1021atwr.h | 1 - include/configs/ls1028a_common.h | 2 - include/configs/ls1043a_common.h | 2 - include/configs/ls1043aqds.h | 2 - include/configs/ls1046a_common.h | 2 - include/configs/ls1046aqds.h | 2 - include/configs/ls1088a_common.h | 2 - include/configs/ls2080a_common.h | 2 - include/configs/lsxl.h | 2 - include/configs/lx2160a_common.h | 2 - include/configs/meesc.h | 1 - include/configs/mt7620.h | 3 - include/configs/mt7628.h | 3 - include/configs/mv-plug-common.h | 1 - include/configs/mx7_common.h | 5 -- include/configs/nas220.h | 1 - include/configs/nokia_rx51.h | 2 - include/configs/nsa310s.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/openrd.h | 1 - include/configs/pcm052.h | 2 - include/configs/pm9261.h | 2 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/pogo_e02.h | 1 - include/configs/px30_common.h | 1 - include/configs/rk3036_common.h | 1 - include/configs/rk3128_common.h | 1 - include/configs/rk3188_common.h | 1 - include/configs/rk322x_common.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/rk3308_common.h | 1 - include/configs/rk3328_common.h | 1 - include/configs/rk3368_common.h | 1 - include/configs/rk3399_common.h | 1 - include/configs/rk3568_common.h | 1 - include/configs/rpi.h | 4 -- include/configs/rv1108_common.h | 1 - include/configs/sam9x60ek.h | 1 - include/configs/siemens-am33x-common.h | 3 - include/configs/smartweb.h | 1 - include/configs/smdkv310.h | 1 - include/configs/snapper9260.h | 1 - include/configs/snapper9g45.h | 1 - include/configs/stemmy.h | 1 - include/configs/stih410-b2260.h | 2 - include/configs/taurus.h | 2 - include/configs/tegra-common-post.h | 3 - include/configs/ti814x_evm.h | 3 - include/configs/ti816x_evm.h | 3 - include/configs/ti_am335x_common.h | 3 - include/configs/ti_armv7_keystone2.h | 1 - include/configs/usb_a9263.h | 2 - include/configs/vf610twr.h | 2 - include/configs/vocore2.h | 3 - include/configs/work_92105.h | 4 -- include/configs/xilinx_zynqmp_r5.h | 2 - include/configs/zynq_cse.h | 2 - scripts/config_whitelist.txt | 2 - 457 files changed, 514 insertions(+), 311 deletions(-)
diff --git a/README b/README index 1c1db9809878..d810fd08ffbf 100644 --- a/README +++ b/README @@ -2876,22 +2876,6 @@ Low Level (hardware related) configuration options: This only takes effect if the memory commands are activated globally (CONFIG_CMD_MEMORY).
-- CONFIG_SKIP_LOWLEVEL_INIT - [ARM, NDS32, MIPS, RISC-V only] If this variable is defined, then certain - low level initializations (like setting up the memory - controller) are omitted and/or U-Boot does not - relocate itself into RAM. - - Normally this variable MUST NOT be defined. The only - exception is when U-Boot is loaded (to RAM) by some - other boot loader or by a debugger which performs - these initializations itself. - -- CONFIG_SKIP_LOWLEVEL_INIT_ONLY - [ARM926EJ-S only] This allows just the call to lowlevel_init() - to be skipped. The normal CP15 init (such as enabling the - instruction cache) is still performed. - - CONFIG_SPL_BUILD Set when the currently-running compilation is for an artifact that will end up in the SPL (as opposed to the TPL or U-Boot diff --git a/arch/Kconfig b/arch/Kconfig index b6f9e177b645..55e8372c9a24 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -326,6 +326,63 @@ config SYS_DISABLE_DCACHE_OPS Note that, its up to the individual architectures to implement this functionality.
+config SKIP_LOWLEVEL_INIT + bool "Skip the calls to certain low level initialization functions" + depends on ARM || NDS32 || MIPS || RISCV + help + If enabled, then certain low level initializations (like setting up + the memory controller) are omitted and/or U-Boot does not relocate + itself into RAM. + Normally this variable MUST NOT be defined. The only exception is + when U-Boot is loaded (to RAM) by some other boot loader or by a + debugger which performs these initializations itself. + +config SPL_SKIP_LOWLEVEL_INIT + bool "Skip the calls to certain low level initialization functions" + depends on SPL && (ARM || NDS32 || MIPS || RISCV) + help + If enabled, then certain low level initializations (like setting up + the memory controller) are omitted and/or U-Boot does not relocate + itself into RAM. + Normally this variable MUST NOT be defined. The only exception is + when U-Boot is loaded (to RAM) by some other boot loader or by a + debugger which performs these initializations itself. + +config TPL_SKIP_LOWLEVEL_INIT + bool "Skip the calls to certain low level initialization functions" + depends on SPL && ARM + help + If enabled, then certain low level initializations (like setting up + the memory controller) are omitted and/or U-Boot does not relocate + itself into RAM. + Normally this variable MUST NOT be defined. The only exception is + when U-Boot is loaded (to RAM) by some other boot loader or by a + debugger which performs these initializations itself. + +config SKIP_LOWLEVEL_INIT_ONLY + bool "Skip the call to lowlevel_init during early boot ONLY" + depends on ARM + help + This allows just the call to lowlevel_init() to be skipped. The + normal CP15 init (such as enabling the instruction cache) is still + performed. + +config SPL_SKIP_LOWLEVEL_INIT_ONLY + bool "Skip the call to lowlevel_init during early boot ONLY" + depends on SPL && ARM + help + This allows just the call to lowlevel_init() to be skipped. The + normal CP15 init (such as enabling the instruction cache) is still + performed. + +config TPL_SKIP_LOWLEVEL_INIT_ONLY + bool "Skip the call to lowlevel_init during early boot ONLY" + depends on TPL && ARM + help + This allows just the call to lowlevel_init() to be skipped. The + normal CP15 init (such as enabling the instruction cache) is still + performed. + source "arch/arc/Kconfig" source "arch/arm/Kconfig" source "arch/m68k/Kconfig" diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index da7278e59fa7..4bc27f637366 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -39,7 +39,7 @@ reset: msr cpsr,r0
/* the mask ROM code should have PLL and others stable */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) bl cpu_init_crit #endif
@@ -62,7 +62,7 @@ c_runtime_cpu_setup: * ************************************************************************* */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) cpu_init_crit: /* * flush v4 I/D caches @@ -81,7 +81,7 @@ cpu_init_crit: orr r0, r0, #0x00001000 @ set bit 12 (I) I-Cache mcr p15, 0, r0, c1, c0, 0
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT_ONLY +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT_ONLY) /* * Jump to board specific initialization... The Mask ROM will have already initialized * basic memory. Go here to bump up clock rate and handle wake up conditions. @@ -91,4 +91,4 @@ cpu_init_crit: mov lr, ip /* restore link */ #endif mov pc, lr /* back to my caller */ -#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ +#endif /* !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */ diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index ecb4e44fd8d4..9ad1f031429c 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -37,8 +37,8 @@ reset: * we do sys-critical inits only at reboot, * not when booting from ram! */ -#if !defined(CONFIG_SKIP_LOWLEVEL_INIT) && \ - !defined(CONFIG_SKIP_LOWLEVEL_INIT_ONLY) +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) && \ + !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT_ONLY) bl cpu_init_crit #endif
@@ -62,8 +62,8 @@ c_runtime_cpu_setup: ************************************************************************* */
-#if !defined(CONFIG_SKIP_LOWLEVEL_INIT) && \ - !defined(CONFIG_SKIP_LOWLEVEL_INIT_ONLY) +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) && \ + !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT_ONLY) cpu_init_crit:
mov ip, lr @@ -76,4 +76,4 @@ cpu_init_crit: mov lr, ip
mov pc, lr -#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ +#endif /* CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */ diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index e2b5f2bff4a9..02cbda9d224f 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -53,7 +53,7 @@ copyex: * we do sys-critical inits only at reboot, * not when booting from ram! */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) bl cpu_init_crit #endif
@@ -78,7 +78,7 @@ c_runtime_cpu_setup: */
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) cpu_init_crit: /* * flush v4 I/D caches @@ -97,7 +97,7 @@ cpu_init_crit: orr r0, r0, #0x00001000 @ set bit 12 (I) I-Cache mcr p15, 0, r0, c1, c0, 0
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT_ONLY +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT_ONLY) /* * before relocating, we have to setup RAM timing * because memory timing is board-dependend, you will @@ -109,4 +109,4 @@ cpu_init_crit: mov lr, ip #endif mov pc, lr -#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ +#endif /* CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */ diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index ff592ba81017..0afcc47aad7d 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -46,7 +46,7 @@ reset: * we do sys-critical inits only at reboot, * not when booting from ram! */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) bl cpu_init_crit #endif
@@ -69,7 +69,7 @@ c_runtime_cpu_setup: * ************************************************************************* */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) cpu_init_crit: /* * flush D cache before disabling it @@ -100,7 +100,7 @@ flush_dcache: #endif mcr p15, 0, r0, c1, c0, 0
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT_ONLY +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT_ONLY) /* * Go setup Memory and board specific bits prior to relocation. */ @@ -109,4 +109,4 @@ flush_dcache: mov lr, r4 /* restore link */ #endif mov pc, lr /* back to my caller */ -#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ +#endif /* CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */ diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 0ec340b1a6e9..2d5186774a76 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -45,7 +45,7 @@ reset: * we do sys-critical inits only at reboot, * not when booting from ram! */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) bl cpu_init_crit #endif
@@ -70,7 +70,7 @@ c_runtime_cpu_setup: */
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) cpu_init_crit: /* * flush v4 I/D caches @@ -89,7 +89,7 @@ cpu_init_crit: orr r0, r0, #0x00001000 /* set bit 12 (I) I-Cache */ mcr p15, 0, r0, c1, c0, 0
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT_ONLY +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT_ONLY) /* * Go setup Memory and board specific bits prior to relocation. */ diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 0e83e394d52b..bfbd85ae64ef 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -17,7 +17,7 @@ obj-$(CONFIG_EFI_LOADER) += sctlr.o obj-$(CONFIG_ARMV7_NONSEC) += exception_level.o endif
-ifneq ($(CONFIG_SKIP_LOWLEVEL_INIT),y) +ifneq ($(CONFIG_$(SPL_)SKIP_LOWLEVEL_INIT),y) obj-y += lowlevel_init.o endif
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index dcb4195d7b48..87329d26e104 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -80,11 +80,11 @@ switch_to_hypervisor_ret: #endif
/* the mask ROM code should have PLL and others stable */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) #ifdef CONFIG_CPU_V7A bl cpu_init_cp15 #endif -#ifndef CONFIG_SKIP_LOWLEVEL_INIT_ONLY +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT_ONLY) bl cpu_init_crit #endif #endif @@ -320,8 +320,8 @@ skip_errata_801819: mov pc, r5 @ back to my caller ENDPROC(cpu_init_cp15)
-#if !defined(CONFIG_SKIP_LOWLEVEL_INIT) && \ - !defined(CONFIG_SKIP_LOWLEVEL_INIT_ONLY) +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) && \ + !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT_ONLY) /************************************************************************* * * CPU_init_critical registers diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 9cef363fbaab..2afeba0304aa 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -4,6 +4,7 @@ config ARCH_LS1012A select ARM_ERRATA_855873 if !TFABOOT select FSL_LAYERSCAPE select FSL_LSCH2 + select SKIP_LOWLEVEL_INIT select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR_BE @@ -59,6 +60,7 @@ config ARCH_LS1043A select FSL_LAYERSCAPE select FSL_LSCH2 select HAS_FSL_XHCI_USB if USB_HOST + select SKIP_LOWLEVEL_INIT select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR @@ -91,6 +93,7 @@ config ARCH_LS1046A select FSL_LAYERSCAPE select FSL_LSCH2 select HAS_FSL_XHCI_USB if USB_HOST + select SKIP_LOWLEVEL_INIT select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR @@ -126,6 +129,7 @@ config ARCH_LS1088A select ARM_ERRATA_855873 if !TFABOOT select FSL_LAYERSCAPE select FSL_LSCH3 + select SKIP_LOWLEVEL_INIT select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR @@ -170,6 +174,7 @@ config ARCH_LS2080A select ARM_ERRATA_833471 select FSL_LAYERSCAPE select FSL_LSCH3 + select SKIP_LOWLEVEL_INIT select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR @@ -278,6 +283,7 @@ config ARCH_LX2160A
config FSL_LSCH2 bool + select SKIP_LOWLEVEL_INIT select SYS_FSL_HAS_CCI400 select SYS_FSL_HAS_SEC select SYS_FSL_SEC_COMPAT_5 diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index 575abac09c27..896e05f1fda4 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -45,7 +45,7 @@ reset: orr r0,r0,#0xd3 msr cpsr,r0
@@ -92,7 +92,7 @@ c_runtime_cpu_setup: * ************************************************************************* */ -#if !defined(CONFIG_SKIP_LOWLEVEL_INIT) || defined(CONFIG_CPU_PXA25X) +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) || defined(CONFIG_CPU_PXA25X) cpu_init_crit: /* * flush v4 I/D caches @@ -111,7 +111,7 @@ cpu_init_crit: mcr p15, 0, r0, c1, c0, 0
mov pc, lr /* back to my caller */ -#endif /* !CONFIG_SKIP_LOWLEVEL_INIT || CONFIG_CPU_PXA25X */ +#endif /* !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) || CONFIG_CPU_PXA25X */
/* * Enable MMU to use DCache as DRAM. diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 8eb005309e0f..2f84f20575c9 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -39,7 +39,7 @@ reset: * we do sys-critical inits only at reboot, * not when booting from ram! */ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) bl cpu_init_crit #endif
@@ -95,7 +95,7 @@ cpu_init_crit: ldr r1, cpuspeed str r1, [r0, #PPCR]
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT_ONLY +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT_ONLY) /* * before relocating, we have to setup RAM timing * because memory timing is board-dependend, you will diff --git a/arch/arm/include/asm/arch-am33xx/chilisom.h b/arch/arm/include/asm/arch-am33xx/chilisom.h index 493be6431167..e423c9d071f9 100644 --- a/arch/arm/include/asm/arch-am33xx/chilisom.h +++ b/arch/arm/include/asm/arch-am33xx/chilisom.h @@ -6,7 +6,7 @@ #ifndef __ARCH_ARM_MACH_CHILISOM_SOM_H__ #define __ARCH_ARM_MACH_CHILISOM_SOM_H__
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) void chilisom_enable_pin_mux(void); void chilisom_spl_board_init(void); #endif diff --git a/arch/arm/mach-at91/arm920t/lowlevel_init.S b/arch/arm/mach-at91/arm920t/lowlevel_init.S index de99c616ac83..5e3cce03b7e7 100644 --- a/arch/arm/mach-at91/arm920t/lowlevel_init.S +++ b/arch/arm/mach-at91/arm920t/lowlevel_init.S @@ -10,7 +10,7 @@
#include <config.h>
#include <asm/arch/hardware.h> #include <asm/arch/at91_mc.h> @@ -148,4 +148,4 @@ SMRDATA1: .word CONFIG_SYS_SDRAM_VAL SMRDATA1E: /* SMRDATA1 is 176 bytes long */ -#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ +#endif /* CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */ diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach-imx/mx7/soc.c index fda25ba66a36..6f9a30bb5f4d 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -224,7 +224,7 @@ const struct rproc_att hostmap[] = { }; #endif
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) /* enable all periherial can be accessed in nosec mode */ static void init_csu(void) { diff --git a/arch/arm/mach-imx/syscounter.c b/arch/arm/mach-imx/syscounter.c index 6dfed365d295..7c02e199a38c 100644 --- a/arch/arm/mach-imx/syscounter.c +++ b/arch/arm/mach-imx/syscounter.c @@ -59,7 +59,7 @@ static inline unsigned long long us_to_tick(unsigned long long usec) return usec; }
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) int timer_init(void) { struct sctr_regs *sctr = (struct sctr_regs *)SCTR_BASE_ADDR; diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index 02a5b880152e..0f32577b9535 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -27,10 +27,6 @@
#define CONFIG_SYS_L2_PL310
-#ifdef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ -#endif - /* * By default the generated mvebu kwbimage.cfg is used * If for some board, different configuration file need to be used, diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 08639653b795..dfb63df9a191 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -120,6 +120,7 @@ config AM33XX select SPECIFY_CONSOLE_INDEX imply NAND_OMAP_ELM imply NAND_OMAP_GPMC + imply SKIP_LOWLEVEL_INIT imply SPL_NAND_AM33XX_BCH imply SPL_NAND_SUPPORT imply SYS_I2C_OMAP24XX diff --git a/arch/arm/mach-omap2/am33xx/Makefile b/arch/arm/mach-omap2/am33xx/Makefile index 61c76d045f3d..4e4f98ea9037 100644 --- a/arch/arm/mach-omap2/am33xx/Makefile +++ b/arch/arm/mach-omap2/am33xx/Makefile @@ -13,7 +13,7 @@ endif obj-$(CONFIG_TI816X) += clock_ti816x.o obj-y += sys_info.o obj-y += ddr.o -ifeq ($(CONFIG_TI816X)$(CONFIG_SKIP_LOWLEVEL_INIT),) +ifeq ($(CONFIG_TI816X)$(CONFIG_$(SPL_)SKIP_LOWLEVEL_INIT),) obj-y += emif4.o endif obj-$(CONFIG_TI816X) += ti816x_emif4.o diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index d390f2e1f3e8..c44667668e9d 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -65,7 +65,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) sdram_init(); #endif
@@ -351,7 +351,7 @@ int arch_misc_init(void)
#endif /* CONFIG_USB_MUSB_* && CONFIG_AM335X_USB* && !CONFIG_DM_USB */
#if defined(CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC) || \ (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT)) @@ -599,7 +599,7 @@ void board_init_f(ulong dummy) int arch_cpu_init_dm(void) { hw_data_init(); -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) early_system_init(); #endif return 0; diff --git a/arch/arm/mach-omap2/am33xx/chilisom.c b/arch/arm/mach-omap2/am33xx/chilisom.c index 15b6b35ae7c1..459bac13e058 100644 --- a/arch/arm/mach-omap2/am33xx/chilisom.c +++ b/arch/arm/mach-omap2/am33xx/chilisom.c @@ -22,7 +22,7 @@ #include <power/tps65217.h> #include <spl.h>
static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE;
@@ -182,4 +182,4 @@ void sdram_init(void) &ddr3_chilisom_emif_reg_data, 0); }
-#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ +#endif /* CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */ diff --git a/arch/arm/mach-omap2/omap3/board.c b/arch/arm/mach-omap2/omap3/board.c index 363af528450b..8b70251457e2 100644 --- a/arch/arm/mach-omap2/omap3/board.c +++ b/arch/arm/mach-omap2/omap3/board.c @@ -76,8 +76,8 @@ void early_system_init(void) hw_data_init(); }
/****************************************************************************** * Routine: secure_unlock diff --git a/arch/arm/mach-omap2/omap3/lowlevel_init.S b/arch/arm/mach-omap2/omap3/lowlevel_init.S index 4fa89418a11f..ab7cdcf3d42e 100644 --- a/arch/arm/mach-omap2/omap3/lowlevel_init.S +++ b/arch/arm/mach-omap2/omap3/lowlevel_init.S @@ -170,8 +170,8 @@ pll_div_val5: go_to_speed_end: #endif
-#if !defined(CONFIG_SKIP_LOWLEVEL_INIT) && \ - !defined(CONFIG_SKIP_LOWLEVEL_INIT_ONLY) +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) && \ + !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT_ONLY) ENTRY(lowlevel_init) ldr sp, SRAM_STACK str ip, [sp] /* stash ip register */ diff --git a/arch/arm/mach-orion5x/Makefile b/arch/arm/mach-orion5x/Makefile index 606153e407c7..a8b87f6d7103 100644 --- a/arch/arm/mach-orion5x/Makefile +++ b/arch/arm/mach-orion5x/Makefile @@ -11,7 +11,7 @@ obj-y = cpu.o obj-y += dram.o obj-y += timer.o
-ifndef CONFIG_SKIP_LOWLEVEL_INIT +ifndef CONFIG_$(SPL_)SKIP_LOWLEVEL_INIT obj-y += lowlevel_init.o endif
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index b164afb52908..d617c4bc89cd 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -100,6 +100,7 @@ config ROCKCHIP_RK3288 bool "Support Rockchip RK3288" select CPU_V7A select OF_BOARD_SETUP + select SKIP_LOWLEVEL_INIT_ONLY select SUPPORT_SPL select SPL select SUPPORT_TPL diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index 478c7a9e388a..8b4b43d965be 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -72,6 +72,7 @@ config TEGRA_ARMV7_COMMON select CPU_V7A select SPL select SPL_BOARD_INIT if SPL + select SPL_SKIP_LOWLEVEL_INIT_ONLY if SPL select SUPPORT_SPL select TEGRA_CLKRST select TEGRA_COMMON diff --git a/arch/mips/cpu/start.S b/arch/mips/cpu/start.S index 335aafa6a8d7..47251a5b92a0 100644 --- a/arch/mips/cpu/start.S +++ b/arch/mips/cpu/start.S @@ -233,7 +233,7 @@ wr_done: # endif #endif
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) # ifdef CONFIG_SYS_MIPS_CACHE_INIT_RAM_LOAD /* Initialize any external memory */ PTR_LA t9, lowlevel_init @@ -254,7 +254,7 @@ wr_done: nop #endif
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) # ifndef CONFIG_SYS_MIPS_CACHE_INIT_RAM_LOAD /* Initialize any external memory */ PTR_LA t9, lowlevel_init diff --git a/arch/mips/mach-mtmips/mt7628/lowlevel_init.S b/arch/mips/mach-mtmips/mt7628/lowlevel_init.S index e4a6c0358082..83cd8fa9b6b5 100644 --- a/arch/mips/mach-mtmips/mt7628/lowlevel_init.S +++ b/arch/mips/mach-mtmips/mt7628/lowlevel_init.S @@ -28,7 +28,7 @@ .set noreorder
LEAF(mips_sram_init) -#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) /* Setup CPU PLL */ li t0, DELAY_USEC(1000000) li t1, KSEG1ADDR(SYSCTL_BASE + SYSCTL_ROM_STATUS_REG) @@ -116,7 +116,7 @@ _cpu_pll_done: sub a1, CONFIG_SYS_DCACHE_LINE_SIZE bnez a1, 3b nop -#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ +#endif /* CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */
jr ra nop diff --git a/arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S b/arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S index 507d79e77b8b..25ec185d69d7 100644 --- a/arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S +++ b/arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S @@ -94,7 +94,7 @@ mem_init: move $lp, $r11 ret
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) .globl lowlevel_init lowlevel_init: move $r10, $lp @@ -144,4 +144,4 @@ enable_fpu: ret #endif
-#endif /* #ifndef CONFIG_SKIP_LOWLEVEL_INIT */ +#endif /* #if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */ diff --git a/arch/nds32/cpu/n1213/ag101/lowlevel_init.S b/arch/nds32/cpu/n1213/ag101/lowlevel_init.S index 73f1f52056a6..ce5fefda7653 100644 --- a/arch/nds32/cpu/n1213/ag101/lowlevel_init.S +++ b/arch/nds32/cpu/n1213/ag101/lowlevel_init.S @@ -164,7 +164,7 @@ sdram_b0_cr: ret
.globl lowlevel_init lowlevel_init: @@ -314,4 +314,4 @@ show_led: li $r8, (CONFIG_DEBUG_LED) swi $r7, [$r8] ret -#endif /* #ifndef CONFIG_SKIP_LOWLEVEL_INIT */ +#endif /* #if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */ diff --git a/arch/nds32/cpu/n1213/start.S b/arch/nds32/cpu/n1213/start.S index 3395721552a3..f02508f04f68 100644 --- a/arch/nds32/cpu/n1213/start.S +++ b/arch/nds32/cpu/n1213/start.S @@ -174,7 +174,7 @@ set_ivb:
jal mem_init
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) jal lowlevel_init /* * gp = ~VMA for burn mode diff --git a/board/bosch/guardian/Makefile b/board/bosch/guardian/Makefile index 11625c9dd672..20cecbfb64e4 100644 --- a/board/bosch/guardian/Makefile +++ b/board/bosch/guardian/Makefile @@ -5,7 +5,7 @@ # Copyright (C) 2018 Robert Bosch Power Tools GmbH #
-ifeq ($(CONFIG_SKIP_LOWLEVEL_INIT),) +ifeq ($(CONFIG_$(SPL_)SKIP_LOWLEVEL_INIT),) obj-y := mux.o endif
diff --git a/board/bosch/guardian/board.c b/board/bosch/guardian/board.c index 179511a67078..b03c68e6608a 100644 --- a/board/bosch/guardian/board.c +++ b/board/bosch/guardian/board.c @@ -40,7 +40,7 @@
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE;
static const struct ddr_data ddr3_data = { diff --git a/board/eets/pdu001/Makefile b/board/eets/pdu001/Makefile index 08c6d536d36d..a5990ce3ad22 100644 --- a/board/eets/pdu001/Makefile +++ b/board/eets/pdu001/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
diff --git a/board/eets/pdu001/board.c b/board/eets/pdu001/board.c index f806d1e7672a..9f3cfd4f842d 100644 --- a/board/eets/pdu001/board.c +++ b/board/eets/pdu001/board.c @@ -162,7 +162,7 @@ static void set_mpu_and_core_voltage(void) } }
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) static const struct ddr_data ddr2_data = { .datardsratio0 = MT47H128M16RT25E_RD_DQS, .datafwsratio0 = MT47H128M16RT25E_PHY_FIFO_WE, @@ -235,7 +235,7 @@ void sdram_init(void) config_ddr(266, &ioregs, &ddr2_data, &ddr2_cmd_ctrl_data, &ddr2_emif_reg_data, 0); } -#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ +#endif /* CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */
#ifdef CONFIG_DEBUG_UART void board_debug_uart_init(void) diff --git a/board/freescale/ls1021aqds/README b/board/freescale/ls1021aqds/README index 6cf7146fb237..e2ce00165bd1 100644 --- a/board/freescale/ls1021aqds/README +++ b/board/freescale/ls1021aqds/README @@ -113,6 +113,5 @@ Start Address End Address Description Size
LS1021a rev1.0 Soc specific Options/Settings -------------------------------------------- -If the LS1021a Soc is rev1.0, you need modify the configure file. -Add the following define in include/configs/ls1021aqds.h: -#define CONFIG_SKIP_LOWLEVEL_INIT +If the LS1021a Soc is rev1.0, you need modify the configuration and enable +CONFIG_SPL_SKIP_LOWLEVEL_INIT in menuconfig or similar. diff --git a/board/freescale/ls1021atwr/README b/board/freescale/ls1021atwr/README index 896a65947682..a4639cd74763 100644 --- a/board/freescale/ls1021atwr/README +++ b/board/freescale/ls1021atwr/README @@ -110,6 +110,5 @@ Start Address End Address Description Size
LS1021a rev1.0 Soc specific Options/Settings -------------------------------------------- -If the LS1021a Soc is rev1.0, you need modify the configure file. -Add the following define in include/configs/ls1021atwr.h: -#define CONFIG_SKIP_LOWLEVEL_INIT +If the LS1021a Soc is rev1.0, you need modify the configuration and enable +CONFIG_SPL_SKIP_LOWLEVEL_INIT in menuconfig or similar. diff --git a/board/grinn/chiliboard/board.c b/board/grinn/chiliboard/board.c index 12480f5729d6..6423c1efb24b 100644 --- a/board/grinn/chiliboard/board.c +++ b/board/grinn/chiliboard/board.c @@ -30,7 +30,7 @@ DECLARE_GLOBAL_DATA_PTR; static __maybe_unused struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE;
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) static struct module_pin_mux uart0_pin_mux[] = { {OFFSET(uart0_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART0_RXD */ {OFFSET(uart0_txd), (MODE(0) | PULLUDEN)}, /* UART0_TXD */ @@ -69,9 +69,7 @@ static void enable_board_pin_mux(void) configure_module_pin_mux(rmii1_pin_mux); configure_module_pin_mux(mmc0_pin_mux); } -#endif /* CONFIG_SKIP_LOWLEVEL_INIT */
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT void set_uart_mux_conf(void) { configure_module_pin_mux(uart0_pin_mux); @@ -86,7 +84,7 @@ void am33xx_spl_board_init(void) { chilisom_spl_board_init(); } -#endif +#endif /* CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */
/* * Basic board specific setup. Pinmux has been handled already. diff --git a/board/qca/ap152/ap152.c b/board/qca/ap152/ap152.c index 1064705d2625..82458c3af421 100644 --- a/board/qca/ap152/ap152.c +++ b/board/qca/ap152/ap152.c @@ -66,7 +66,7 @@ int board_early_init_f(void) void __iomem *rst_regs = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, MAP_NOCACHE);
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) /* CPU:775, DDR:650, AHB:258 */ qca956x_pll_init(); qca956x_ddr_init(); diff --git a/board/tcl/sl50/Makefile b/board/tcl/sl50/Makefile index c2977d777879..0ac0ba36cdb2 100644 --- a/board/tcl/sl50/Makefile +++ b/board/tcl/sl50/Makefile @@ -4,7 +4,7 @@ # # Copyright (C) 2015 Toby Churchill Ltd - http://www.toby-churchill.com/
diff --git a/board/tcl/sl50/board.c b/board/tcl/sl50/board.c index d2136084991d..2420ff7dd4be 100644 --- a/board/tcl/sl50/board.c +++ b/board/tcl/sl50/board.c @@ -40,7 +40,7 @@ DECLARE_GLOBAL_DATA_PTR;
static const struct ddr_data ddr3_sl50_data = { .datardsratio0 = MT41K256M16HA125E_RD_DQS, diff --git a/board/ti/am335x/Makefile b/board/ti/am335x/Makefile index c34b9b1dd8a7..3ccf66be5bb3 100644 --- a/board/ti/am335x/Makefile +++ b/board/ti/am335x/Makefile @@ -4,7 +4,7 @@ # # Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 2e4f3d102b7d..40ce92f8c6b4 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -99,7 +99,7 @@ struct serial_device *default_serial_console(void) } #endif
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) static const struct ddr_data ddr2_data = { .datardsratio0 = MT47H128M16RT25E_RD_DQS, .datafwsratio0 = MT47H128M16RT25E_PHY_FIFO_WE, diff --git a/board/ti/am43xx/Makefile b/board/ti/am43xx/Makefile index 60a11d8c04d2..8dc1d89e3ac8 100644 --- a/board/ti/am43xx/Makefile +++ b/board/ti/am43xx/Makefile @@ -4,7 +4,7 @@ # # Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index a71b588efcb0..5b353aea483c 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -56,7 +56,7 @@ void do_board_detect(void) } #endif
const struct dpll_params dpll_mpu[NUM_CRYSTAL_FREQ][NUM_OPPS] = { { /* 19.2 MHz */ diff --git a/board/tplink/wdr4300/wdr4300.c b/board/tplink/wdr4300/wdr4300.c index f2b92109b6ac..f2de039b6b47 100644 --- a/board/tplink/wdr4300/wdr4300.c +++ b/board/tplink/wdr4300/wdr4300.c @@ -71,7 +71,7 @@ int board_early_init_f(void) wdr4300_pinmux_config(); #endif
-#ifndef CONFIG_SKIP_LOWLEVEL_INIT +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) ar934x_pll_init(560, 480, 240); ar934x_ddr_init(560, 480, 240); #endif diff --git a/board/vscom/baltos/Makefile b/board/vscom/baltos/Makefile index c34b9b1dd8a7..3ccf66be5bb3 100644 --- a/board/vscom/baltos/Makefile +++ b/board/vscom/baltos/Makefile @@ -4,7 +4,7 @@ # # Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/
diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index 238a1c49e1cb..a7f1e7cb2db3 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index 77a8fc6683d4..9b12da30fbd0 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/adp-ae3xx_defconfig b/configs/adp-ae3xx_defconfig index 83faf8098aac..f65420cc574e 100644 --- a/configs/adp-ae3xx_defconfig +++ b/configs/adp-ae3xx_defconfig @@ -1,4 +1,5 @@ CONFIG_NDS32=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x4A000000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index 3e898e5787ba..a520316186b3 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -1,4 +1,5 @@ CONFIG_NDS32=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x11000000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 5d3517689012..854e27d15dae 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 955ea087acb3..ca0fccd91d23 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 98b07b9a1927..85b8ab73103d 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_ISW_ENTRY_ADDR=0x40300350 diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 43f47385ade2..574420f2dff2 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index fa58a3137fb7..0a7a5f901596 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_K3=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 5773d21ff3af..f451557c079d 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_K3=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig index 557517bad684..211db8943f75 100644 --- a/configs/am65x_hs_evm_a53_defconfig +++ b/configs/am65x_hs_evm_a53_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_K3=y CONFIG_TI_SECURE_DEVICE=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index 133c0eb8884e..a6d08d0194f5 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 diff --git a/configs/aspenite_defconfig b/configs/aspenite_defconfig index 37e6871dddfb..91a7c8df5573 100644 --- a/configs/aspenite_defconfig +++ b/configs/aspenite_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_TARGET_ASPENITE=y CONFIG_SYS_TEXT_BASE=0x600000 diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 76ad67bf9ee4..342bc3355604 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 07d3911d900d..221e1aa520a5 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 24a40f2137d3..260c1fd071eb 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 79e3e02e9f86..0ea16fcaea88 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_TARGET_AT91SAM9261EK=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 29e08af51d8c..c892cf87b06a 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_TARGET_AT91SAM9261EK=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index e5d54e463fd7..fc201cf82923 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_TARGET_AT91SAM9261EK=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 64e2ea8eeda0..a7fd5b44012a 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21F00000 diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 64e2ea8eeda0..a7fd5b44012a 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21F00000 diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 73aef06a7cf3..2e6e9e2ed8cf 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21F00000 diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index ee4edec2daad..88c0722f8d5a 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21F00000 diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index a9acd1d46ef2..ca29104eadb3 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_TARGET_AT91SAM9261EK=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index 4c92ee4593cb..12b5cbbd9fad 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_TARGET_AT91SAM9261EK=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 414e41b48fbc..24faef1baa32 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 CONFIG_TARGET_AT91SAM9261EK=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index d3d95c726cba..cf698c246b51 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 4e9f8e2dbc9e..43e8f5853e85 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index e0478ef1a93f..f7cdf0dbf77f 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index 2bc57c8af732..369586e0764c 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 14b32a9e6e86..928bf4a0cd6e 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 07683608d048..e9b45c4e1d2f 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x73f00000 CONFIG_TARGET_AT91SAM9M10G45EK=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 568743d5e2e5..bbfe179bb0a1 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x73f00000 CONFIG_TARGET_AT91SAM9M10G45EK=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 2e0e59696283..d18aedf73b4a 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_TARGET_AT91SAM9N12EK=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 483e5e9618c8..afe509c8415c 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_TARGET_AT91SAM9N12EK=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 0bed29bb431f..d6128182f7fa 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_TARGET_AT91SAM9N12EK=y diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 47eee7d8a0b1..6b55a3e39fb7 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21F00000 diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index 781d91e2ca35..c4843c418128 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21F00000 diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 1fa557ff83fb..fee5c34a40c4 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21F00000 diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index a8e1a36b5072..43bed0e37b24 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_TARGET_AT91SAM9X5EK=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 3bd0897cfed5..c1f39de607d1 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_TARGET_AT91SAM9X5EK=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 90c8f796f9e1..3786ba839eec 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_TARGET_AT91SAM9X5EK=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 71bbd743df65..e5c6f1c94aba 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_TARGET_AT91SAM9X5EK=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index 2573c3c34075..c2c3d1771dfe 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index f2baad78e6c1..4897fea1cc2b 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index a1026a78fd5f..46f90cdeb156 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/axm_defconfig b/configs/axm_defconfig index aa9197f2c0a8..1810a4bc0ea6 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y diff --git a/configs/bcm7260_defconfig b/configs/bcm7260_defconfig index a42a6acb06d5..d63156f6aae7 100644 --- a/configs/bcm7260_defconfig +++ b/configs/bcm7260_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_BCMSTB=y CONFIG_SYS_TEXT_BASE=0x10100000 CONFIG_TARGET_BCM7260=y diff --git a/configs/bcm7445_defconfig b/configs/bcm7445_defconfig index 96e8da0748ae..0d3310144879 100644 --- a/configs/bcm7445_defconfig +++ b/configs/bcm7445_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_BCMSTB=y CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_BCM7445=y diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index f7f1b3538923..0db9715ee9ee 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_ARM64_SUPPORT_AARCH32 is not set CONFIG_ARCH_BCM63158=y CONFIG_SYS_TEXT_BASE=0x10000000 diff --git a/configs/bcm968360bg_ram_defconfig b/configs/bcm968360bg_ram_defconfig index 2d759fa64858..be273275b5c9 100644 --- a/configs/bcm968360bg_ram_defconfig +++ b/configs/bcm968360bg_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_BCM68360=y CONFIG_SYS_TEXT_BASE=0x10000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 diff --git a/configs/bcm968380gerg_ram_defconfig b/configs/bcm968380gerg_ram_defconfig index 4415faa9fe50..b19a102fe7cd 100644 --- a/configs/bcm968380gerg_ram_defconfig +++ b/configs/bcm968380gerg_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 @@ -6,6 +7,8 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="brcm,bcm968380gerg" CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6838=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/bcm968580xref_ram_defconfig b/configs/bcm968580xref_ram_defconfig index 09d09eede6e0..f29a349db602 100644 --- a/configs/bcm968580xref_ram_defconfig +++ b/configs/bcm968580xref_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_BCM6858=y CONFIG_SYS_TEXT_BASE=0x10000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 20262e8be1d5..33a6a02446f7 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index acc3286f09d8..e171923d42bb 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00100000 diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index f3f367a29c13..ba3642f3c866 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index a2901ac08418..a958e3010385 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00100000 diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 30044a802b0f..2c707f9938d0 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00100000 diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index fe6528f190e6..794b4f0cf6f5 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00100000 diff --git a/configs/ci20_mmc_defconfig b/configs/ci20_mmc_defconfig index c2efe3900882..e7203bec6d33 100644 --- a/configs/ci20_mmc_defconfig +++ b/configs/ci20_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBGENERIC_SUPPORT=y @@ -11,6 +12,8 @@ CONFIG_SPL_TEXT_BASE=0xf4000a00 CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL=y CONFIG_ARCH_JZ47XX=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y CONFIG_FIT=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS4,115200 rw rootwait root=/dev/mmcblk0p1" diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index d8edc453fff3..f63ecd2e7072 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_MVEBU=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 289c3fc5b74a..f55e8c90d55d 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index abb811780460..32119c9d39de 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 diff --git a/configs/comtrend_ar5315u_ram_defconfig b/configs/comtrend_ar5315u_ram_defconfig index 0e7d9cd8b152..38ea23789d0d 100644 --- a/configs/comtrend_ar5315u_ram_defconfig +++ b/configs/comtrend_ar5315u_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 @@ -6,6 +7,8 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="comtrend,ar-5315u" CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6318=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/comtrend_ar5387un_ram_defconfig b/configs/comtrend_ar5387un_ram_defconfig index 655db1bba6eb..58ccc528e1de 100644 --- a/configs/comtrend_ar5387un_ram_defconfig +++ b/configs/comtrend_ar5387un_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 @@ -6,6 +7,8 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="comtrend,ar-5387un" CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6328=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/comtrend_ct5361_ram_defconfig b/configs/comtrend_ct5361_ram_defconfig index d051f3db5db8..2bbb8ab386ab 100644 --- a/configs/comtrend_ct5361_ram_defconfig +++ b/configs/comtrend_ct5361_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 @@ -6,6 +7,8 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="comtrend,ct-5361" CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6348=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/comtrend_vr3032u_ram_defconfig b/configs/comtrend_vr3032u_ram_defconfig index ac963efdcc2c..c7614fbb6194 100644 --- a/configs/comtrend_vr3032u_ram_defconfig +++ b/configs/comtrend_vr3032u_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 @@ -6,6 +7,8 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="comtrend,vr-3032u" CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM63268=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/comtrend_wap5813n_ram_defconfig b/configs/comtrend_wap5813n_ram_defconfig index af565c519a0b..9859860adab1 100644 --- a/configs/comtrend_wap5813n_ram_defconfig +++ b/configs/comtrend_wap5813n_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 @@ -6,6 +7,8 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="comtrend,wap-5813n" CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6368=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index bb1e09585c0a..56fb19ef924b 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00800000 diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 42c0a48b23b4..215aa49e4ed9 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SYS_THUMB_BUILD=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 017bb216230e..d7d7304528ab 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index af565f651064..f9a212dd0b31 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_DAVINCI=y CONFIG_SYS_TEXT_BASE=0xc1080000 diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index e69da40a1101..7bd408619e96 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_DAVINCI=y CONFIG_SYS_TEXT_BASE=0x60000000 diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 7803bf5c5060..5234dfb9b48d 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_DAVINCI=y CONFIG_SYS_TEXT_BASE=0xc1080000 diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index 7f9d65f020b1..44f1c3d498be 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00800000 diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 96841d786278..eb399a3e052b 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00800000 diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index 0ab8722c82fc..a503eccfbe18 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00800000 diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index b56408f98afc..5c0dbbb530a3 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_ICACHE_OFF=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index edcdb87d54ff..98d3d1d868e2 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 8d43609cd11a..db77f0deee3b 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index 664391371ad2..db77facd698b 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 9f146ec3d4ac..b21987c9000a 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/ea-lpc3250devkitv2_defconfig b/configs/ea-lpc3250devkitv2_defconfig index e8d60b573eaa..561278862854 100644 --- a/configs/ea-lpc3250devkitv2_defconfig +++ b/configs/ea-lpc3250devkitv2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_ICACHE_OFF=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y diff --git a/configs/elgin-rv1108_defconfig b/configs/elgin-rv1108_defconfig index af4f3f1d231b..a1e0a62d68c1 100644 --- a/configs/elgin-rv1108_defconfig +++ b/configs/elgin-rv1108_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x60000000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 4da3c1d4f4c9..4dc306b06122 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x27000000 diff --git a/configs/evb-px30_defconfig b/configs/evb-px30_defconfig index f4b30ed3bbc7..9cc0872a3752 100644 --- a/configs/evb-px30_defconfig +++ b/configs/evb-px30_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index 50a4bc143656..a63957f21415 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index 324528e29684..e2fd1e0a11dd 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set CONFIG_ARCH_ROCKCHIP=y diff --git a/configs/evb-rk3128_defconfig b/configs/evb-rk3128_defconfig index 10628016423c..1882cecfbaf4 100644 --- a/configs/evb-rk3128_defconfig +++ b/configs/evb-rk3128_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x60000000 CONFIG_NR_DRAM_BANKS=2 diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 02e19fa10cc1..bff5ed80ad1d 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -1,4 +1,7 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y +CONFIG_TPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x61000000 CONFIG_NR_DRAM_BANKS=2 diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 658ddc97504d..313ecb15ab15 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_TPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_NR_DRAM_BANKS=2 diff --git a/configs/evb-rk3308_defconfig b/configs/evb-rk3308_defconfig index bd4a03ae64c6..11d10b2bd936 100644 --- a/configs/evb-rk3308_defconfig +++ b/configs/evb-rk3308_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00600000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 7cc828fb69f5..c8f9ae22e13b 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index d5eba1d903ca..fb71805ce686 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/evb-rk3568_defconfig b/configs/evb-rk3568_defconfig index a102a5a99904..21f25eb6ab65 100644 --- a/configs/evb-rk3568_defconfig +++ b/configs/evb-rk3568_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00a00000 CONFIG_NR_DRAM_BANKS=2 diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig index be7ebd47079c..30343b22f5f6 100644 --- a/configs/evb-rv1108_defconfig +++ b/configs/evb-rv1108_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x60000000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig index a2df9eab3c28..5a4601d28c2e 100644 --- a/configs/ficus-rk3399_defconfig +++ b/configs/ficus-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ENV_OFFSET=0x3F8000 diff --git a/configs/firefly-px30_defconfig b/configs/firefly-px30_defconfig index 64744d534cbe..8ee9c246b732 100644 --- a/configs/firefly-px30_defconfig +++ b/configs/firefly-px30_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 91b7974c408d..922221478d2f 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_TPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 2ca2ac35e431..97dab2370033 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index ae6dbfd6dc81..f3ec2be1307c 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x22900000 diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 46b9849b1c98..80c0f145ff3a 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 @@ -15,6 +16,8 @@ CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_ENV_OFFSET_REDUND=0xB0000 CONFIG_ARCH_MTMIPS=y CONFIG_SOC_MT7628=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/geekbox_defconfig b/configs/geekbox_defconfig index 55892f07f2cc..d6ebd3ea9fb2 100644 --- a/configs/geekbox_defconfig +++ b/configs/geekbox_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SYS_MALLOC_F_LEN=0x1000 diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index d0a9e216a507..acc00c5d9815 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index 896a3b15088d..9ae1681f882b 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x73f00000 CONFIG_TARGET_GURNARD=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 619254c2b551..e359ff139ab1 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index 4e593601efd1..9ba5742404e6 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_MVEBU=y diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index a6aed676d4f6..d3546b852d83 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_HIGHBANK=y diff --git a/configs/huawei_hg556a_ram_defconfig b/configs/huawei_hg556a_ram_defconfig index 987ad3187651..1e05965b65b6 100644 --- a/configs/huawei_hg556a_ram_defconfig +++ b/configs/huawei_hg556a_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 @@ -6,6 +7,8 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="huawei,hg556a" CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6358=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 7f2030439002..3032a469fc22 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index 1e3f85387d52..570eda2e5966 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/imgtec_xilfpga_defconfig b/configs/imgtec_xilfpga_defconfig index c8e09829dff8..ed50882ae4e6 100644 --- a/configs/imgtec_xilfpga_defconfig +++ b/configs/imgtec_xilfpga_defconfig @@ -1,8 +1,11 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_MALLOC_F_LEN=0x600 CONFIG_ENV_SIZE=0x4000 CONFIG_DEFAULT_DEVICE_TREE="nexys4ddr" CONFIG_TARGET_XILFPGA=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_BOOTDELAY=5 diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 6141e15179d6..47dbed063ce6 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 1bd02ce3f277..27657542e416 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KEYSTONE=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index b59cf2bdae2b..216c5ff5eaee 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KEYSTONE=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 000205e0205f..c79ad4bc27b2 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KEYSTONE=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 528b95f680a3..52e235f30520 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KEYSTONE=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 384063fee61f..4289d83be779 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KEYSTONE=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 030dd47c1914..dedf9da6365a 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KEYSTONE=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index f0f2ff1c9c4c..4cc551927feb 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KEYSTONE=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 096d65b302e0..44a4e38bf4c5 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KEYSTONE=y diff --git a/configs/khadas-edge-captain-rk3399_defconfig b/configs/khadas-edge-captain-rk3399_defconfig index c564086704c1..26191dba46e3 100644 --- a/configs/khadas-edge-captain-rk3399_defconfig +++ b/configs/khadas-edge-captain-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/khadas-edge-rk3399_defconfig b/configs/khadas-edge-rk3399_defconfig index 4c63686ef263..2465739e5e47 100644 --- a/configs/khadas-edge-rk3399_defconfig +++ b/configs/khadas-edge-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/khadas-edge-v-rk3399_defconfig b/configs/khadas-edge-v-rk3399_defconfig index 1e44e2b5c173..1a5e53400078 100644 --- a/configs/khadas-edge-v-rk3399_defconfig +++ b/configs/khadas-edge-v-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index e00d14c4933a..ffb3a28b1470 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index 490538d79156..4a9f18ce4049 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index 1f14a9b0fe93..23b871b95258 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index 51f0f87193af..912f5dd7e65f 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index 9b98034e8896..85b01251f0b6 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/kmsuse2_defconfig b/configs/kmsuse2_defconfig index e0b0ad61d12f..069458a53bb0 100644 --- a/configs/kmsuse2_defconfig +++ b/configs/kmsuse2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index c051307939df..f7534a875b56 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set CONFIG_ARCH_ROCKCHIP=y diff --git a/configs/leez-rk3399_defconfig b/configs/leez-rk3399_defconfig index a3afb1d81bdb..50c199d7b240 100644 --- a/configs/leez-rk3399_defconfig +++ b/configs/leez-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 200d9ac2ef1e..aac9b3e1dca2 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_DAVINCI=y CONFIG_SYS_TEXT_BASE=0xc1080000 CONFIG_TARGET_LEGOEV3=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index cf2f204ad461..72d4c897f4b3 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 @@ -12,6 +13,8 @@ CONFIG_SPL=y CONFIG_ARCH_MTMIPS=y CONFIG_SOC_MT7628=y CONFIG_BOARD_LINKIT_SMART_7688=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index 5f7d1018143a..6107493399af 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index cf64f0fc7621..a9de27365e14 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index cb63fb65e82a..f764f33a6d2f 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 072a1e6c7397..9df103320c36 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index e9d29f431449..a82bd5751ef2 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 4c4050a403c2..3c7344afc06a 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 3378fc1e787e..750686f872bb 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 69a02a4af906..126a2d645cf4 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 50ba009d70fd..a8324ba964bc 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 0c74e9b51343..b8d3720940e4 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index d2d2fcc1ba1b..cf6b9910718f 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index fa20ee8c0e96..3268773fa669 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 11d210846c4a..b0435c8f0485 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 50337a874f18..09c13921a60e 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 78196e6485d6..3b52df14ba0d 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 67b83b7739cf..81a06e800a84 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index c82c29781ac6..333ded2b18ee 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig index 5b60c4af8d9b..aa879255053f 100644 --- a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LS1028AQDS=y CONFIG_TFABOOT=y diff --git a/configs/ls1028aqds_tfa_defconfig b/configs/ls1028aqds_tfa_defconfig index 311cfe3c7a2b..e4826f6ed946 100644 --- a/configs/ls1028aqds_tfa_defconfig +++ b/configs/ls1028aqds_tfa_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LS1028AQDS=y CONFIG_TFABOOT=y diff --git a/configs/ls1028aqds_tfa_lpuart_defconfig b/configs/ls1028aqds_tfa_lpuart_defconfig index 6805f5eaaa18..a0f118625b05 100644 --- a/configs/ls1028aqds_tfa_lpuart_defconfig +++ b/configs/ls1028aqds_tfa_lpuart_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_LS1028AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_MALLOC_F_LEN=0x6000 diff --git a/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig index 7eecbae13e75..0a63ee07fbf8 100644 --- a/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LS1028ARDB=y CONFIG_TFABOOT=y diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index 6934a597a52c..54ce71ec91cc 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LS1028ARDB=y CONFIG_TFABOOT=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 79f5960e71d2..e28045ea2cc2 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 08405a1fc761..f318fc13e956 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig index 91fba1961826..e4f1ca7393a8 100644 --- a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LX2160AQDS=y CONFIG_TFABOOT=y diff --git a/configs/lx2160aqds_tfa_defconfig b/configs/lx2160aqds_tfa_defconfig index d52063c7a872..ccd23eb31ce8 100644 --- a/configs/lx2160aqds_tfa_defconfig +++ b/configs/lx2160aqds_tfa_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LX2160AQDS=y CONFIG_TFABOOT=y diff --git a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig index 94e103c5d1dd..a381be35f74e 100644 --- a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LX2160ARDB=y CONFIG_TFABOOT=y diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index d09bcde92e74..723219cf64d6 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LX2160ARDB=y CONFIG_TFABOOT=y diff --git a/configs/lx2160ardb_tfa_stmm_defconfig b/configs/lx2160ardb_tfa_stmm_defconfig index 93b1e49cf2d0..67975463caeb 100644 --- a/configs/lx2160ardb_tfa_stmm_defconfig +++ b/configs/lx2160ardb_tfa_stmm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LX2160ARDB=y CONFIG_TFABOOT=y diff --git a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig index 7ade20205c6d..6028863b891f 100644 --- a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LX2162AQDS=y CONFIG_TFABOOT=y diff --git a/configs/lx2162aqds_tfa_defconfig b/configs/lx2162aqds_tfa_defconfig index 2724f045ed63..23da9bf56c84 100644 --- a/configs/lx2162aqds_tfa_defconfig +++ b/configs/lx2162aqds_tfa_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LX2162AQDS=y CONFIG_TFABOOT=y diff --git a/configs/lx2162aqds_tfa_verified_boot_defconfig b/configs/lx2162aqds_tfa_verified_boot_defconfig index fa2a02753f47..c8e90adfd3f2 100644 --- a/configs/lx2162aqds_tfa_verified_boot_defconfig +++ b/configs/lx2162aqds_tfa_verified_boot_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_GIC_V3_ITS=y CONFIG_TARGET_LX2162AQDS=y CONFIG_TFABOOT=y diff --git a/configs/meesc_dataflash_defconfig b/configs/meesc_dataflash_defconfig index 9d4c9ebff9b7..84b3185944ec 100644 --- a/configs/meesc_dataflash_defconfig +++ b/configs/meesc_dataflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21F00000 diff --git a/configs/meesc_defconfig b/configs/meesc_defconfig index 69d89359bbd5..1ace4d025f39 100644 --- a/configs/meesc_defconfig +++ b/configs/meesc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21F00000 diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index d815fda9a1e5..d3d4ce3a8113 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/mt7620_mt7530_rfb_defconfig b/configs/mt7620_mt7530_rfb_defconfig index 5e9d267f27a3..16cced472640 100644 --- a/configs/mt7620_mt7530_rfb_defconfig +++ b/configs/mt7620_mt7530_rfb_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 @@ -13,6 +14,8 @@ CONFIG_DEBUG_UART_BASE=0xb0000c00 CONFIG_DEBUG_UART_CLOCK=40000000 CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_MT7620_MT7530_RFB=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y CONFIG_MIPS_BOOT_FDT=y CONFIG_DEBUG_UART=y diff --git a/configs/mt7620_rfb_defconfig b/configs/mt7620_rfb_defconfig index cbdd9b67baf5..b53822fffed6 100644 --- a/configs/mt7620_rfb_defconfig +++ b/configs/mt7620_rfb_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 @@ -12,6 +13,8 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xb0000c00 CONFIG_DEBUG_UART_CLOCK=40000000 CONFIG_ARCH_MTMIPS=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y CONFIG_MIPS_BOOT_FDT=y CONFIG_DEBUG_UART=y diff --git a/configs/mt7628_rfb_defconfig b/configs/mt7628_rfb_defconfig index 039686096c6f..e7abd789f492 100644 --- a/configs/mt7628_rfb_defconfig +++ b/configs/mt7628_rfb_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 @@ -12,6 +13,8 @@ CONFIG_SPL=y CONFIG_ARCH_MTMIPS=y CONFIG_SOC_MT7628=y CONFIG_BOARD_MT7628_RFB=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y CONFIG_MIPS_BOOT_FDT=y CONFIG_FIT=y diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig index a94f428deffc..f81da5acd877 100644 --- a/configs/nanopc-t4-rk3399_defconfig +++ b/configs/nanopc-t4-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/nanopi-m4-2gb-rk3399_defconfig b/configs/nanopi-m4-2gb-rk3399_defconfig index c9833fdb8543..eb27163f5af7 100644 --- a/configs/nanopi-m4-2gb-rk3399_defconfig +++ b/configs/nanopi-m4-2gb-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/nanopi-m4-rk3399_defconfig b/configs/nanopi-m4-rk3399_defconfig index 2b2fcac3666d..6c8398956ca1 100644 --- a/configs/nanopi-m4-rk3399_defconfig +++ b/configs/nanopi-m4-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/nanopi-m4b-rk3399_defconfig b/configs/nanopi-m4b-rk3399_defconfig index 6d3afe1b63d6..782a4cbc665c 100644 --- a/configs/nanopi-m4b-rk3399_defconfig +++ b/configs/nanopi-m4b-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/nanopi-neo4-rk3399_defconfig b/configs/nanopi-neo4-rk3399_defconfig index 1bf5d1d0956e..4af3d2deb975 100644 --- a/configs/nanopi-neo4-rk3399_defconfig +++ b/configs/nanopi-neo4-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/nanopi-r2s-rk3328_defconfig b/configs/nanopi-r2s-rk3328_defconfig index 0dfac0a42f71..099fee98c15d 100644 --- a/configs/nanopi-r2s-rk3328_defconfig +++ b/configs/nanopi-r2s-rk3328_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y diff --git a/configs/nanopi-r4s-rk3399_defconfig b/configs/nanopi-r4s-rk3399_defconfig index 351d2eb55361..dd1420dc3408 100644 --- a/configs/nanopi-r4s-rk3399_defconfig +++ b/configs/nanopi-r4s-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 10fcf2144669..3ed254642288 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 841842cefb61..a9fe172f30d1 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/netgear_cg3100d_ram_defconfig b/configs/netgear_cg3100d_ram_defconfig index 94eebdf09991..d4ab9c7b371d 100644 --- a/configs/netgear_cg3100d_ram_defconfig +++ b/configs/netgear_cg3100d_ram_defconfig @@ -1,10 +1,13 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="netgear,cg3100d" CONFIG_ARCH_BMIPS=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/netgear_dgnd3700v2_ram_defconfig b/configs/netgear_dgnd3700v2_ram_defconfig index 1f21f685996e..d435575f8ddc 100644 --- a/configs/netgear_dgnd3700v2_ram_defconfig +++ b/configs/netgear_dgnd3700v2_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 @@ -6,6 +7,8 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="netgear,dgnd3700v2" CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6362=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 1c577faab74c..14d61a4c1c84 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index d5af1150647e..a88c4eaa7139 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 5d9ea06259b2..2de55babf5b2 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index c152a310a273..ae75daecc6aa 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 981e6f95cb1f..b39ad73c5119 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80008000 diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 8765dc3dd187..293b25fdbb0b 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/odroid-go2_defconfig b/configs/odroid-go2_defconfig index aafec84f1091..444acf367918 100644 --- a/configs/odroid-go2_defconfig +++ b/configs/odroid-go2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index f56dfb7d8e2f..a6a2aa75aecb 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index b95cefd54d08..43842d12f60e 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43e00000 diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 0cde86a2f960..fd9a8da601d7 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_DAVINCI=y CONFIG_SYS_TEXT_BASE=0xc1080000 diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 72d6358d4c5a..022333607ef9 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 1b49abb8d788..27a141ca6727 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index fafe53e72ea1..df732bd86a7e 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig index 9f0053914ae1..048d4cc4ef3a 100644 --- a/configs/orangepi-rk3399_defconfig +++ b/configs/orangepi-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 932c107c57c3..ff706701dc30 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index 260d3d459b48..738cf2f1f183 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 92d6be43f817..7b0c01f6bd23 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x23E00000 diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 824a664904e8..809b42b6dab8 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x23E00000 diff --git a/configs/pg_wcom_expu1_defconfig b/configs/pg_wcom_expu1_defconfig index 27e8192ded7c..2c50292fca6f 100644 --- a/configs/pg_wcom_expu1_defconfig +++ b/configs/pg_wcom_expu1_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_PG_WCOM_EXPU1=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/pg_wcom_seli8_defconfig b/configs/pg_wcom_seli8_defconfig index 99389d64059a..be9e83ddc70a 100644 --- a/configs/pg_wcom_seli8_defconfig +++ b/configs/pg_wcom_seli8_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TARGET_PG_WCOM_SELI8=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index 8ee99e54c763..7733eaf6eefa 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/pinebook-pro-rk3399_defconfig b/configs/pinebook-pro-rk3399_defconfig index f97d5e872b06..122bc879da18 100644 --- a/configs/pinebook-pro-rk3399_defconfig +++ b/configs/pinebook-pro-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index 7941ee277240..67018445c785 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x73f00000 CONFIG_TARGET_PM9G45=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index e3d2238794c4..24d62c09095b 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_KIRKWOOD=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 5b6d8cab870a..9cc8911e9430 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index eaa3cddd4e1c..4257065a5649 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y diff --git a/configs/px30-core-ctouch2-px30_defconfig b/configs/px30-core-ctouch2-px30_defconfig index aed790b6a6ff..80c4edb40c11 100644 --- a/configs/px30-core-ctouch2-px30_defconfig +++ b/configs/px30-core-ctouch2-px30_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/px30-core-edimm2.2-px30_defconfig b/configs/px30-core-edimm2.2-px30_defconfig index 0340039ce711..670f2043a175 100644 --- a/configs/px30-core-edimm2.2-px30_defconfig +++ b/configs/px30-core-edimm2.2-px30_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/roc-cc-rk3308_defconfig b/configs/roc-cc-rk3308_defconfig index 257893edcaad..74df0fdc68f6 100644 --- a/configs/roc-cc-rk3308_defconfig +++ b/configs/roc-cc-rk3308_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00600000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/roc-cc-rk3328_defconfig b/configs/roc-cc-rk3328_defconfig index 4351a5f4bc8b..f1da6db4d094 100644 --- a/configs/roc-cc-rk3328_defconfig +++ b/configs/roc-cc-rk3328_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index 8d0f57021b94..bce445eef0a6 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 4e5c90439d39..8410de3aa941 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index f01b6a393541..48b9a753ebb2 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/rock-pi-4c-rk3399_defconfig b/configs/rock-pi-4c-rk3399_defconfig index ae35633292ec..2448f4d9bdce 100644 --- a/configs/rock-pi-4c-rk3399_defconfig +++ b/configs/rock-pi-4c-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/rock-pi-e-rk3328_defconfig b/configs/rock-pi-e-rk3328_defconfig index 4816b1ebbee7..2b8caed87214 100644 --- a/configs/rock-pi-e-rk3328_defconfig +++ b/configs/rock-pi-e-rk3328_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index e5df6779decd..b8465caf10fb 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y diff --git a/configs/rock-pi-n8-rk3288_defconfig b/configs/rock-pi-n8-rk3288_defconfig index 935f569db5cf..1be03f771da5 100644 --- a/configs/rock-pi-n8-rk3288_defconfig +++ b/configs/rock-pi-n8-rk3288_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_TPL_SKIP_LOWLEVEL_INIT_ONLY=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set CONFIG_ARCH_ROCKCHIP=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 2f1743a7065b..2e89528b3c24 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index f0ef1e5c98f4..32b19fd3d03a 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index 0233e0ea5276..f5f9bf094cbc 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ENV_OFFSET=0x3F8000 diff --git a/configs/rock_defconfig b/configs/rock_defconfig index 91221736061e..4a9aceaf3915 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set CONFIG_ARCH_ROCKCHIP=y diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index ae11a8f5eb0f..2806ae5955ae 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index 9001e2b20bc2..326567201361 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_BCM283X=y CONFIG_SYS_TEXT_BASE=0x00008000 diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index a2a44aa63eb1..1aeda84f041e 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_BCM283X=y CONFIG_SYS_TEXT_BASE=0x00008000 diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index f6bb60e9ca8d..b5f9515dccc8 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x44800000 diff --git a/configs/sagem_f@st1704_ram_defconfig b/configs/sagem_f@st1704_ram_defconfig index d29a19e7415e..e8779e8c4e2c 100644 --- a/configs/sagem_f@st1704_ram_defconfig +++ b/configs/sagem_f@st1704_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 @@ -6,6 +7,8 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sagem,f@st1704" CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6338=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/sam9x60ek_mmc_defconfig b/configs/sam9x60ek_mmc_defconfig index e1fceec4bb5b..9a2ea2c1b06d 100644 --- a/configs/sam9x60ek_mmc_defconfig +++ b/configs/sam9x60ek_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x23f00000 CONFIG_TARGET_SAM9X60EK=y diff --git a/configs/sam9x60ek_nandflash_defconfig b/configs/sam9x60ek_nandflash_defconfig index 35368f3139bd..1d714ca2a753 100644 --- a/configs/sam9x60ek_nandflash_defconfig +++ b/configs/sam9x60ek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x23f00000 CONFIG_TARGET_SAM9X60EK=y diff --git a/configs/sam9x60ek_qspiflash_defconfig b/configs/sam9x60ek_qspiflash_defconfig index 1c6abdc476db..922bf63e67a6 100644 --- a/configs/sam9x60ek_qspiflash_defconfig +++ b/configs/sam9x60ek_qspiflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x23f00000 CONFIG_TARGET_SAM9X60EK=y diff --git a/configs/sama5d27_giantboard_defconfig b/configs/sama5d27_giantboard_defconfig index 2d13dc2145ab..960f22283e4e 100644 --- a/configs/sama5d27_giantboard_defconfig +++ b/configs/sama5d27_giantboard_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x23f00000 diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 0326cd3d37a0..a5047ed0e724 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x23f00000 diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index c606c8a12e9c..9c7732e02746 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x23f00000 diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig index 33a0cadb5802..1e53caf22745 100644 --- a/configs/sama5d27_som1_ek_qspiflash_defconfig +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x23f00000 diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index e88b0799d8a0..e7767ba5babc 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_TARGET_SAMA5D27_WLSOM1_EK=y diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index 5902a933c1ad..8384cedf971a 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 CONFIG_TARGET_SAMA5D27_WLSOM1_EK=y diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index 54f5a314be79..2565647f985b 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d2_ptc_ek_mmc_defconfig b/configs/sama5d2_ptc_ek_mmc_defconfig index 8e8d41bb509e..b8d316c7d26b 100644 --- a/configs/sama5d2_ptc_ek_mmc_defconfig +++ b/configs/sama5d2_ptc_ek_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d2_ptc_ek_nandflash_defconfig b/configs/sama5d2_ptc_ek_nandflash_defconfig index cd73859db120..cc2193cf0cf2 100644 --- a/configs/sama5d2_ptc_ek_nandflash_defconfig +++ b/configs/sama5d2_ptc_ek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 9bf34b885ee5..02f12435da8d 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 5871e7bd089c..d094a6a21c22 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index 16534fbc2f4a..323209657826 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 7a8df06249b1..22f8881f03e0 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index 0077217492d9..3dffea70a006 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index ca072f481c1a..b5f6fe765295 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index f4d13a5ac735..0e64eca4cfef 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 1045758824bc..2d809a2ee8fb 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 594424d681c7..c556c9dc59fa 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 106e91db92e9..d5a4f748d9ac 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 2d7d349d6312..e0c6416d3b7a 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 307f1fca9beb..6a96a1a7c242 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 68747d8a79cc..4cbebe937cba 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index c6ff96b1bc0a..75c4b9b04c29 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 42829057b489..19daeabbc8d6 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 098e6ba49bd5..a4a5759623cc 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index fd285a757f7d..a1d2f793211d 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 662568a955de..116f484dec31 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x26f00000 diff --git a/configs/sfr_nb4-ser_ram_defconfig b/configs/sfr_nb4-ser_ram_defconfig index 097d58343024..709fec3283c5 100644 --- a/configs/sfr_nb4-ser_ram_defconfig +++ b/configs/sfr_nb4-ser_ram_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 @@ -7,6 +8,8 @@ CONFIG_DEFAULT_DEVICE_TREE="sfr,nb4-ser" CONFIG_ARCH_BMIPS=y CONFIG_SOC_BMIPS_BCM6358=y CONFIG_BOARD_SFR_NB4_SER=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/sheep-rk3368_defconfig b/configs/sheep-rk3368_defconfig index 60256d19fdab..b8a3799e65be 100644 --- a/configs/sheep-rk3368_defconfig +++ b/configs/sheep-rk3368_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index d09789a96e08..b040cfcab00b 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y CONFIG_SYS_THUMB_BUILD=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index c171ccad2a70..ead13bd86723 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SPL_SYS_ICACHE_OFF=y CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_SPL_SYS_THUMB_BUILD=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index 3ed1947fd682..7b0799b53917 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index 7b739400a5bf..5000917e762e 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x23E00000 diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index ac84fde7d318..2de60eb58a2a 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index f9cc1a6c7e9f..9b6b54502d40 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index e3a325a27100..1daf19742ef2 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x21f00000 diff --git a/configs/snow_defconfig b/configs/snow_defconfig index a5fbd1d346da..d934f70515c4 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 53c375e5b4f2..facfe0214fe7 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set diff --git a/configs/stemmy_defconfig b/configs/stemmy_defconfig index f31960b81473..882bea59afb3 100644 --- a/configs/stemmy_defconfig +++ b/configs/stemmy_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_U8500=y CONFIG_SYS_TEXT_BASE=0x100000 CONFIG_NR_DRAM_BANKS=2 diff --git a/configs/stih410-b2260_defconfig b/configs/stih410-b2260_defconfig index 071dac96aff6..64dda240c6bb 100644 --- a/configs/stih410-b2260_defconfig +++ b/configs/stih410-b2260_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_STI=y CONFIG_SYS_TEXT_BASE=0x7D600000 CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 80f75ce3d2ac..82ad79abb5b3 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SPL_SYS_ICACHE_OFF=y CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 7a93ebb73116..2847e18a8e04 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 3ac314ab891a..824df5c35136 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_TPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_SPL_GPIO=y diff --git a/configs/tinker-s-rk3288_defconfig b/configs/tinker-s-rk3288_defconfig index 35e84b708856..8c66b3341e77 100644 --- a/configs/tinker-s-rk3288_defconfig +++ b/configs/tinker-s-rk3288_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_TPL_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x01000000 CONFIG_SPL_GPIO=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 17c8c7554556..569536ef835b 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43e00000 diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 5709c4fd3c30..e7b2a1bfadbf 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x63300000 diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index cd443ceb300f..d6851ddfa847 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_SPL_SYS_THUMB_BUILD=y CONFIG_ARCH_MVEBU=y diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index 983072dc7fae..9173e307a042 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x23f00000 diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 24a7bdedf0ac..df00784835ce 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index 7cf8ae660420..f958e1d637b2 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 07fb27f68b76..a87b6c0377dd 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_AT91=y CONFIG_SYS_TEXT_BASE=0x20f00000 diff --git a/configs/vocore2_defconfig b/configs/vocore2_defconfig index 9ca285285eca..25d288eb0586 100644 --- a/configs/vocore2_defconfig +++ b/configs/vocore2_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 @@ -13,6 +14,8 @@ CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_ARCH_MTMIPS=y CONFIG_SOC_MT7628=y CONFIG_BOARD_VOCORE2=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y CONFIG_MIPS_BOOT_FDT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index 2faaa801c5aa..043cfef40406 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_TPL_SKIP_LOWLEVEL_INIT_ONLY=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set CONFIG_ARCH_ROCKCHIP=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 507f24fc375a..407b95f02ea7 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_ICACHE_OFF=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_CPU_INIT=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 6df383b81e67..cecf4168cc7f 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00800000 diff --git a/configs/xilinx_zynqmp_r5_defconfig b/configs/xilinx_zynqmp_r5_defconfig index 143c253f0efd..780dfb3e3c5a 100644 --- a/configs/xilinx_zynqmp_r5_defconfig +++ b/configs/xilinx_zynqmp_r5_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_ZYNQMP_R5=y CONFIG_SYS_TEXT_BASE=0x10000000 CONFIG_SYS_MALLOC_F_LEN=0x1000 diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index 2386da77ed66..5600390f1a2f 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="zynq_cse" +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_ICACHE_OFF=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_ZYNQ=y diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index 4ed18451c0d4..1e43f385c4ff 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="zynq_cse" +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_ICACHE_OFF=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_ZYNQ=y diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index b1287c541f05..1cf7d71a28cf 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -1,5 +1,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="zynq_cse" +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_ICACHE_OFF=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARCH_ZYNQ=y diff --git a/doc/board/AndesTech/adp-ag101p.rst b/doc/board/AndesTech/adp-ag101p.rst index 879eba029468..f867eeae3eb2 100644 --- a/doc/board/AndesTech/adp-ag101p.rst +++ b/doc/board/AndesTech/adp-ag101p.rst @@ -23,8 +23,8 @@ CONFIG_MEM_REMAP:
CONFIG_SKIP_LOWLEVEL_INIT: If you want to boot this system from SPI ROM and bypass e-bios (the - other boot loader on ROM). You should undefine CONFIG_SKIP_LOWLEVEL_INIT - in "include/configs/adp-ag101p.h". + other boot loader on ROM). You should enable CONFIG_SKIP_LOWLEVEL_INIT + when running menuconfig or similar.
Build and boot steps -------------------- diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index ded494cfa9b0..49985ba34074 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -11,7 +11,6 @@ */ #define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg
/* additions for new ARM relocation support */ diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index 06bbd8642e3f..eecb34c54163 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -11,7 +11,6 @@ */ #define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg
/* additions for new ARM relocation support */ diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index a7adb599cae4..780ad4d59a1d 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -15,8 +15,6 @@ */ #define CONFIG_USE_INTERRUPT
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_SKIP_TRUNOFF_WATCHDOG
#define CONFIG_ARCH_MAP_SYSMEM diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index afec9ba24253..57522a60c5d5 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -15,8 +15,6 @@ */ #define CONFIG_USE_INTERRUPT
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_ARCH_MAP_SYSMEM
#define CONFIG_BOOTP_SERVERIP diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 31a1c7e392f2..f3d49794d0d4 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -41,14 +41,6 @@ #define CONFIG_SYS_L2_PL310 #define CONFIG_SYS_PL310_BASE 0x48242000
-/* - * Since SPL did pll and ddr initialization for us, - * we don't need to do it twice. - */ -#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_QSPI_BOOT) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* * When building U-Boot such that there is no previous loader * we need to call board_early_init_f. This is taken care of in diff --git a/include/configs/am64x_evm.h b/include/configs/am64x_evm.h index 7c520f4395b5..16d095584e0b 100644 --- a/include/configs/am64x_evm.h +++ b/include/configs/am64x_evm.h @@ -22,10 +22,6 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "tispl.bin" #endif
-#ifndef CONFIG_CPU_V7R -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - #define CONFIG_SPL_MAX_SIZE CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE #if defined(CONFIG_TARGET_AM642_A53_EVM) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE + \ diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h index d4514a0dbada..55fa6419e33d 100644 --- a/include/configs/am65x_evm.h +++ b/include/configs/am65x_evm.h @@ -49,10 +49,6 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "tispl.bin" #endif
#define CONFIG_SYS_BOOTM_LEN SZ_64M diff --git a/include/configs/aspenite.h b/include/configs/aspenite.h index 88e1bf177534..bcb24f773e1f 100644 --- a/include/configs/aspenite.h +++ b/include/configs/aspenite.h @@ -15,7 +15,6 @@ #define CONFIG_SHEEVA_88SV331xV5 1 /* CPU Core subversion */ #define CONFIG_ARMADA100 1 /* SOC Family Name */ #define CONFIG_ARMADA168 1 /* SOC Used on this Board */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * There is no internal RAM in ARMADA100, using DRAM diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index ba21149e43ca..8b8e83f4f422 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -15,10 +15,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */
-#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* * BOOTP options */ diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 780bf0cce7a3..b0a3286ecfac 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -38,7 +38,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index c3fe41636bfc..0c9830444766 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -26,8 +26,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_ATMEL_LEGACY
/* diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 51ecf4173b3c..5356ee3e8c43 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -27,7 +27,6 @@ #define CONFIG_INITRD_TAG 1
#ifndef CONFIG_SYS_USE_BOOT_NORFLASH -#define CONFIG_SKIP_LOWLEVEL_INIT #else #define CONFIG_SYS_USE_NORFLASH #endif diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index b4aaf5995fb5..35beaa7eedd8 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -21,7 +21,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index fe99253e5a1a..b006c8dad8d0 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -17,7 +17,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* LCD */ #define LCD_BPP LCD_COLOR16 diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 92b87a2b492a..394484d05c3b 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -16,8 +16,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* main clock xtal */
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1 diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 6a95b39cdb79..abecaf064f48 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -15,7 +15,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/bcmstb.h b/include/configs/bcmstb.h index 2660d18f35a9..1412484f450c 100644 --- a/include/configs/bcmstb.h +++ b/include/configs/bcmstb.h @@ -36,7 +36,6 @@ extern phys_addr_t prior_stage_fdt_address; /* * CPU configuration. */ -#define CONFIG_SKIP_LOWLEVEL_INIT
/* * Memory configuration. diff --git a/include/configs/bk4r1.h b/include/configs/bk4r1.h index 2abbe7b2ba83..bc21e611cc02 100644 --- a/include/configs/bk4r1.h +++ b/include/configs/bk4r1.h @@ -60,8 +60,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* Enable passing of ATAGs */ #define CONFIG_CMDLINE_TAG
diff --git a/include/configs/bmips_bcm3380.h b/include/configs/bmips_bcm3380.h index 573ff3e40189..3101c890b832 100644 --- a/include/configs/bmips_bcm3380.h +++ b/include/configs/bmips_bcm3380.h @@ -18,7 +18,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + SZ_1M
#if defined(CONFIG_BMIPS_BOOT_RAM) -#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_SYS_INIT_SP_OFFSET SZ_8K #endif
diff --git a/include/configs/bmips_bcm6318.h b/include/configs/bmips_bcm6318.h index 45eb931c257a..649e98b983c0 100644 --- a/include/configs/bmips_bcm6318.h +++ b/include/configs/bmips_bcm6318.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + SZ_1M
diff --git a/include/configs/bmips_bcm63268.h b/include/configs/bmips_bcm63268.h index eed321eb6fc8..90674e818ec9 100644 --- a/include/configs/bmips_bcm63268.h +++ b/include/configs/bmips_bcm63268.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + SZ_1M
diff --git a/include/configs/bmips_bcm6328.h b/include/configs/bmips_bcm6328.h index c78099a49dcd..b2b2e86af6d0 100644 --- a/include/configs/bmips_bcm6328.h +++ b/include/configs/bmips_bcm6328.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + SZ_1M
diff --git a/include/configs/bmips_bcm6338.h b/include/configs/bmips_bcm6338.h index 38dd9e3af3aa..a6c1c528c43a 100644 --- a/include/configs/bmips_bcm6338.h +++ b/include/configs/bmips_bcm6338.h @@ -18,7 +18,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + SZ_1M
diff --git a/include/configs/bmips_bcm6348.h b/include/configs/bmips_bcm6348.h index 547cf857ceb0..a63f253ab422 100644 --- a/include/configs/bmips_bcm6348.h +++ b/include/configs/bmips_bcm6348.h @@ -25,7 +25,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + SZ_1M
diff --git a/include/configs/bmips_bcm6358.h b/include/configs/bmips_bcm6358.h index 116e9705b6be..7b65055bb006 100644 --- a/include/configs/bmips_bcm6358.h +++ b/include/configs/bmips_bcm6358.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + SZ_1M
diff --git a/include/configs/bmips_bcm6362.h b/include/configs/bmips_bcm6362.h index e5e8b15e1872..5f7bb7b47cfe 100644 --- a/include/configs/bmips_bcm6362.h +++ b/include/configs/bmips_bcm6362.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + SZ_1M
diff --git a/include/configs/bmips_bcm6368.h b/include/configs/bmips_bcm6368.h index 4d4403f8d218..9de151ff6c75 100644 --- a/include/configs/bmips_bcm6368.h +++ b/include/configs/bmips_bcm6368.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + SZ_1M
diff --git a/include/configs/bmips_bcm6838.h b/include/configs/bmips_bcm6838.h index f1ff05414d55..71d3d10c26a1 100644 --- a/include/configs/bmips_bcm6838.h +++ b/include/configs/bmips_bcm6838.h @@ -18,7 +18,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + SZ_1M
diff --git a/include/configs/broadcom_bcm963158.h b/include/configs/broadcom_bcm963158.h index 238ae9c010e7..ff16ff779b8f 100644 --- a/include/configs/broadcom_bcm963158.h +++ b/include/configs/broadcom_bcm963158.h @@ -28,8 +28,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_16M) #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE
-#define CONFIG_SKIP_LOWLEVEL_INIT - #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT diff --git a/include/configs/broadcom_bcm968360bg.h b/include/configs/broadcom_bcm968360bg.h index 77690ff40f73..293d68a4053a 100644 --- a/include/configs/broadcom_bcm968360bg.h +++ b/include/configs/broadcom_bcm968360bg.h @@ -27,8 +27,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_16M) #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE
-#define CONFIG_SKIP_LOWLEVEL_INIT - #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT diff --git a/include/configs/broadcom_bcm968580xref.h b/include/configs/broadcom_bcm968580xref.h index febe6c0a04fc..7137a9b6b511 100644 --- a/include/configs/broadcom_bcm968580xref.h +++ b/include/configs/broadcom_bcm968580xref.h @@ -27,8 +27,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_16M) #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE
-#define CONFIG_SKIP_LOWLEVEL_INIT - #ifdef CONFIG_MTD_RAW_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT diff --git a/include/configs/bur_am335x_common.h b/include/configs/bur_am335x_common.h index 51585fcb3713..18f3821b15c7 100644 --- a/include/configs/bur_am335x_common.h +++ b/include/configs/bur_am335x_common.h @@ -47,9 +47,6 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_NOR_BOOT) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif /* !CONFIG_SPL_BUILD, ... */ /* * Our DDR memory always starts at 0x80000000 and U-Boot shall have * relocated itself to higher in memory by the time this value is used. diff --git a/include/configs/ci20.h b/include/configs/ci20.h index 6e46d29c8552..a357bd75ad98 100644 --- a/include/configs/ci20.h +++ b/include/configs/ci20.h @@ -9,8 +9,6 @@ #ifndef __CONFIG_CI20_H__ #define __CONFIG_CI20_H__
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* Ingenic JZ4780 clock configuration. */ #define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MHZ 1200 diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 73205d0de6a5..d870edba1d40 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -62,9 +62,6 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#if !defined(CONFIG_SPL_BUILD) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
#define CONFIG_HSMMC2_8BIT
diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 5bd440f1db33..e77d82edd1b4 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -16,8 +16,6 @@
#define CONFIG_SYS_FSL_CLK
-#define CONFIG_SKIP_LOWLEVEL_INIT - #ifdef CONFIG_VIDEO_FSL_DCU_FB #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index 3b17f75d2093..54ea413c1cef 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -12,8 +12,6 @@ */ #define CONFIG_CUSTOMER_BOARD_SUPPORT
-#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ - /* * TEXT_BASE needs to be below 16MiB, since this area is scrubbed * for DDR ECC byte filling in the SPL before loading the main diff --git a/include/configs/corvus.h b/include/configs/corvus.h index bd4d6e8e39f4..8c498071a195 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -32,7 +32,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 883cbc95d239..dceba9d15c31 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -22,7 +22,6 @@ #define CONFIG_SYS_OSCIN_FREQ 24000000 #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY
#ifdef CONFIG_MTD_NOR_FLASH #define CONFIG_SYS_DV_NOR_BOOT_CFG (0x11) diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 33d71a7042ba..45ad480a12a5 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -14,10 +14,6 @@
#define CONFIG_MACH_TYPE MACH_TYPE_DEVKIT3250
-#if !defined(CONFIG_SPL_BUILD) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* * Memory configurations */ diff --git a/include/configs/dns325.h b/include/configs/dns325.h index 8990efb3f68b..3a943e448bb5 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -22,7 +22,6 @@ */ #define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ #define CONFIG_KW88F6281 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
#include "mv-common.h"
diff --git a/include/configs/dockstar.h b/include/configs/dockstar.h index 04dd0f68c370..75a2476f5ef9 100644 --- a/include/configs/dockstar.h +++ b/include/configs/dockstar.h @@ -16,7 +16,6 @@ */ #define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/ea-lpc3250devkitv2.h b/include/configs/ea-lpc3250devkitv2.h index c1a37c8a790e..506dd32972b8 100644 --- a/include/configs/ea-lpc3250devkitv2.h +++ b/include/configs/ea-lpc3250devkitv2.h @@ -14,7 +14,6 @@ * SoC and board defines */ #define CONFIG_MACH_TYPE MACH_TYPE_LPC3XXX -#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_BOARD_SIZE_LIMIT 0x000fffff /* maximum allowable size for full U-Boot binary */
/* diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index 3f266543b92b..e6de0f1a542c 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -14,7 +14,6 @@ /* The first stage boot loader expects u-boot running at this address. */
/* The first stage boot loader takes care of low level initialization. */ -#define CONFIG_SKIP_LOWLEVEL_INIT
/* Set our official architecture number. */ #define CONFIG_MACH_TYPE MACH_TYPE_ETHERNUT5 diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 8adaf297fe36..5dfa4e622910 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -16,8 +16,6 @@ #include <linux/sizes.h> #include <linux/stringify.h>
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* Keep L2 Cache Disabled */
/* input clock of PLL: 24MHz input clock */ diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index 007cbb043a38..9838f1671351 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -17,11 +17,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */
-#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */
diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index 1b26466eda30..f3d1cf998be5 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -17,9 +17,6 @@ #define CONFIG_SYS_INIT_SP_OFFSET 0x400000
/* SPL */ -#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SPL_BSS_START_ADDR 0x80010000 diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index 2e89d72285d2..43027a506a5f 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -19,7 +19,6 @@ */ #define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * Default GPIO configuration and LED status diff --git a/include/configs/highbank.h b/include/configs/highbank.h index ff92c4f55407..2314f838e50b 100644 --- a/include/configs/highbank.h +++ b/include/configs/highbank.h @@ -46,7 +46,6 @@
#define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_INIT_SP_ADDR 0x01000000 -#define CONFIG_SKIP_LOWLEVEL_INIT
#define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0x20000000\0" \ diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h index ba859a9a2499..4bd3494f1084 100644 --- a/include/configs/ib62x0.h +++ b/include/configs/ib62x0.h @@ -13,7 +13,6 @@ */ #define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ #define CONFIG_KW88F6281 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
diff --git a/include/configs/iconnect.h b/include/configs/iconnect.h index c99490b85dc6..29491327f5c4 100644 --- a/include/configs/iconnect.h +++ b/include/configs/iconnect.h @@ -13,7 +13,6 @@ */ #define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ #define CONFIG_KW88F6281 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * Machine type diff --git a/include/configs/imgtec_xilfpga.h b/include/configs/imgtec_xilfpga.h index fcf1b7f990e1..9435ce36b298 100644 --- a/include/configs/imgtec_xilfpga.h +++ b/include/configs/imgtec_xilfpga.h @@ -11,7 +11,6 @@ #define __XILFPGA_CONFIG_H
/* BootROM + MIG is pretty smart. DDR and Cache initialized */ -#define CONFIG_SKIP_LOWLEVEL_INIT
/*-------------------------------------------- * CPU configuration diff --git a/include/configs/integrator-common.h b/include/configs/integrator-common.h index 89ab0da50cdd..2c893cefe4ef 100644 --- a/include/configs/integrator-common.h +++ b/include/configs/integrator-common.h @@ -48,7 +48,6 @@ * image to run at reset/power up * e.g. whether the ARM Boot Monitor runs before U-Boot */ -/* #define CONFIG_SKIP_LOWLEVEL_INIT */
/* * The ARM boot monitor does not relocate U-Boot. diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 179e145b5ffc..3ae6e9b8bc50 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -59,8 +59,6 @@ "appended one; fi\0" \ ""
-#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ - /* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is diff --git a/include/configs/km/pg-wcom-ls102xa.h b/include/configs/km/pg-wcom-ls102xa.h index a4cc4777290d..0c2cfa2bff97 100644 --- a/include/configs/km/pg-wcom-ls102xa.h +++ b/include/configs/km/pg-wcom-ls102xa.h @@ -8,8 +8,6 @@
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* include common defines/options for all Keymile boards */ #include "keymile-common.h"
diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 88f784f1f0fd..51d044fde721 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -37,7 +37,6 @@ #else #define CONFIG_KW88F6281 #endif -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * SDRAM configuration diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index 8c2c8e110d80..ce96cceccf00 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -22,7 +22,6 @@ #define CONFIG_SYS_OSCIN_FREQ 24000000 #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) -#define CONFIG_SKIP_LOWLEVEL_INIT
/* * Memory Info diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h index e7a7ae319897..df251b84c275 100644 --- a/include/configs/linkit-smart-7688.h +++ b/include/configs/linkit-smart-7688.h @@ -17,9 +17,6 @@ #define CONFIG_SYS_INIT_SP_OFFSET 0x400000
#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SPL_BSS_START_ADDR 0x80010000 diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 670b55de26b1..e186ba44d6ee 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -14,8 +14,6 @@
#define CONFIG_SYS_CLK_FREQ 125000000
-#define CONFIG_SKIP_LOWLEVEL_INIT - #ifdef CONFIG_TFABOOT #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE #else diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 598f6c67a1b2..a752e75e671c 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -11,8 +11,6 @@
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_DEEP_SLEEP
/* diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index ba308c514b9d..48adf958abf4 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -11,7 +11,6 @@
-#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_DEEP_SLEEP
/* diff --git a/include/configs/ls1028a_common.h b/include/configs/ls1028a_common.h index cbcf30e9686f..eb3f576ef168 100644 --- a/include/configs/ls1028a_common.h +++ b/include/configs/ls1028a_common.h @@ -16,8 +16,6 @@ /* Link Definitions */ #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 834c3e6780af..b6bc5c613936 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -39,8 +39,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) #endif
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000 #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 1636f0bb8ff0..4d5345156816 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -16,8 +16,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CLK_FREQ get_board_sys_clk() #define CONFIG_DDR_CLK_FREQ get_board_ddr_clk()
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_LAYERSCAPE_NS_ACCESS
#define CONFIG_DIMM_SLOTS_PER_CTLR 1 diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 289acc02d380..a3bed9b4f166 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -39,8 +39,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) #endif
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000 #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 9102c812b5bc..6e76f1784285 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -16,8 +16,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CLK_FREQ get_board_sys_clk() #define CONFIG_DDR_CLK_FREQ get_board_ddr_clk()
#define CONFIG_DIMM_SLOTS_PER_CTLR 1 diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 3f0679cf05ad..0ebb5f6b3779 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -37,8 +37,6 @@ /* Link Definitions */ #define CONFIG_SYS_FSL_QSPI_BASE 0x20000000
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 45273364cf39..c9b0c46ef76e 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -24,8 +24,6 @@
-#define CONFIG_SKIP_LOWLEVEL_INIT - #ifndef CONFIG_SYS_FSL_DDR4 #define CONFIG_SYS_DDR_RAW_TIMING #endif diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index a4a4739d0dd7..3c9abb3c9366 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -26,8 +26,6 @@ #define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ #define CONFIG_KW88F6281 /* SOC Name */
-#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ - #define CONFIG_KIRKWOOD_GPIO
#include "mv-common.h" diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 1ae7d37dd9f6..0b81bc2ea4f2 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -19,8 +19,6 @@ #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_FLASH_BASE 0x20000000
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* DDR */ #define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ #define CONFIG_SYS_FSL_DDR_INTLV_256B /* force 256 byte interleaving */ diff --git a/include/configs/meesc.h b/include/configs/meesc.h index bd4bac7aab38..c1a3f142a6e6 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -32,7 +32,6 @@ #define CONFIG_SYS_AT91_MAIN_CLOCK 16000000/* 16.0 MHz crystal */
/* Misc CPU related */ -#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SERIAL_TAG diff --git a/include/configs/mt7620.h b/include/configs/mt7620.h index 4d074a368882..7e84e7a80b3b 100644 --- a/include/configs/mt7620.h +++ b/include/configs/mt7620.h @@ -30,9 +30,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SPL_BSS_START_ADDR 0x80010000 diff --git a/include/configs/mt7628.h b/include/configs/mt7628.h index c6752f4acb72..2d6eaf212681 100644 --- a/include/configs/mt7628.h +++ b/include/configs/mt7628.h @@ -39,9 +39,6 @@ 230400, 460800, 921600 }
#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SPL_BSS_START_ADDR 0x80010000 diff --git a/include/configs/mv-plug-common.h b/include/configs/mv-plug-common.h index 486650f183fb..d38d9872c006 100644 --- a/include/configs/mv-plug-common.h +++ b/include/configs/mv-plug-common.h @@ -11,7 +11,6 @@ * High Level Configuration Options (easy to change) */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index 3d8769038276..8aa3a1af18de 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -49,10 +49,5 @@ * launched by OPTEE, because of that we shall skip all the low level * initialization since it was already done by ATF or OPTEE */ -#if (CONFIG_OPTEE_TZDRAM_SIZE != 0) -#ifndef CONFIG_OPTEE -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif -#endif
#endif diff --git a/include/configs/nas220.h b/include/configs/nas220.h index 1fd5471ac5ff..1a43587c40af 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -21,7 +21,6 @@ */ #define CONFIG_FEROCEON_88FR131 /* #define CPU Core subversion */ #define CONFIG_KW88F6192 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* power-on led, regulator, sata0, sata1 */ #define NAS220_GE_OE_VAL_LOW ((1 << 12)|(1 << 14)|(1 << 24)|(1 << 28)) diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 7ef25ea8389c..346fe5792bc2 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -34,8 +34,6 @@ #define V_OSCK 26000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK >> 1)
-#define CONFIG_SKIP_LOWLEVEL_INIT /* X-Loader set everything up */ - #define CONFIG_CMDLINE_TAG /* enable passing kernel command line string */ #define CONFIG_INITRD_TAG /* enable passing initrd */ #define CONFIG_REVISION_TAG /* enable passing revision tag*/ diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index 23cf94ec9920..950549c31ca4 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -13,7 +13,6 @@ #define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ #define CONFIG_KW88F6192 1 /* SOC Name */ #define CONFIG_KW88F6702 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index a37359e6c326..d6a788770b12 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) #define CONFIG_SYS_HZ 1000 -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY
/* * Memory Info diff --git a/include/configs/openrd.h b/include/configs/openrd.h index 03b9393c9b09..56bfe8747ef8 100644 --- a/include/configs/openrd.h +++ b/include/configs/openrd.h @@ -18,7 +18,6 @@ */ #define CONFIG_SHEEVA_88SV131 1 /* CPU Core subversion */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index 960ff982d8b7..123904ecfd0e 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -12,8 +12,6 @@ #include <linux/sizes.h> #include <linux/stringify.h>
diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 382d19a241b1..891fc07e580d 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -132,8 +132,6 @@ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1
-#undef CONFIG_SKIP_LOWLEVEL_INIT - /* * Hardware drivers */ diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index e825270de8a2..a54245e843b7 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -144,7 +144,6 @@ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1
-#undef CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_USER_LOWLEVEL_INIT 1
/* diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 452fbda0668d..364028697aa4 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -22,7 +22,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/pogo_e02.h b/include/configs/pogo_e02.h index cbe5022297e6..ef51da394d15 100644 --- a/include/configs/pogo_e02.h +++ b/include/configs/pogo_e02.h @@ -22,7 +22,6 @@ */ #define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ #define CONFIG_KW88F6281 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
diff --git a/include/configs/px30_common.h b/include/configs/px30_common.h index 76d6ab1c8b4e..9d41e22320c9 100644 --- a/include/configs/px30_common.h +++ b/include/configs/px30_common.h @@ -9,7 +9,6 @@ #include "rockchip-common.h"
#define CONFIG_SYS_CBSIZE 1024 -#define CONFIG_SKIP_LOWLEVEL_INIT
#define CONFIG_SYS_NS16550_MEM32
diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 7f148eff87e5..205fcde4ab57 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -9,7 +9,6 @@ #include "rockchip-common.h"
#define CONFIG_ROCKCHIP_STIMER_BASE 0x200440a0 #define COUNTER_FREQUENCY 24000000 diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index 7c064a0704b7..c58f544ee18e 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -10,7 +10,6 @@
#define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_CBSIZE 1024 -#define CONFIG_SKIP_LOWLEVEL_INIT
#define CONFIG_ROCKCHIP_STIMER_BASE 0x200440a0 #define COUNTER_FREQUENCY 24000000 diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h index 3bcc04808a3c..b208c66dfdc1 100644 --- a/include/configs/rk3188_common.h +++ b/include/configs/rk3188_common.h @@ -11,7 +11,6 @@ #include <asm/arch-rockchip/hardware.h> #include "rockchip-common.h"
-#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY #define CONFIG_SYS_CBSIZE 1024
#ifdef CONFIG_SPL_ROCKCHIP_BACK_TO_BROM diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index 7e0c831174a3..3b53065f1c9c 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -8,7 +8,6 @@ #include <asm/arch-rockchip/hardware.h> #include "rockchip-common.h"
-#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */
diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index addad7a16ddf..5d126b9e8472 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -11,7 +11,6 @@
#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64MB */
#define CONFIG_ROCKCHIP_STIMER_BASE 0xff810020 diff --git a/include/configs/rk3308_common.h b/include/configs/rk3308_common.h index bd9ac826f3df..ef2d0562b3b0 100644 --- a/include/configs/rk3308_common.h +++ b/include/configs/rk3308_common.h @@ -9,7 +9,6 @@ #include "rockchip-common.h"
#define CONFIG_SYS_CBSIZE 1024 -#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_PAGE_SIZE 2048 diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index 0538da751f23..520c5b5a2569 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -14,7 +14,6 @@ #define COUNTER_FREQUENCY 24000000
#define CONFIG_SYS_INIT_SP_ADDR 0x00300000 #define CONFIG_SYS_LOAD_ADDR 0x00800800 diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index fbbb8cf267e6..22cb8af305f4 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -16,7 +16,6 @@ #define CONFIG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xff000000 #define CONFIG_SYS_CBSIZE 1024 -#define CONFIG_SKIP_LOWLEVEL_INIT
#define CONFIG_ROCKCHIP_STIMER_BASE 0xff830020 #define COUNTER_FREQUENCY 24000000 diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index 6d710da901e8..10205a115146 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -9,7 +9,6 @@ #include "rockchip-common.h"
#define COUNTER_FREQUENCY 24000000 #define CONFIG_ROCKCHIP_STIMER_BASE 0xff8680a0 diff --git a/include/configs/rk3568_common.h b/include/configs/rk3568_common.h index b6568917ea8f..6a7ad27e0c2c 100644 --- a/include/configs/rk3568_common.h +++ b/include/configs/rk3568_common.h @@ -9,7 +9,6 @@ #include "rockchip-common.h"
#define COUNTER_FREQUENCY 24000000 #define CONFIG_ROCKCHIP_STIMER_BASE 0xfdd1c020 diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 522b41c02db1..ac86a9ca2dce 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -13,10 +13,6 @@ #include <asm/arch/base.h> #endif
-#if defined(CONFIG_TARGET_RPI_2) || defined(CONFIG_TARGET_RPI_3_32B) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* Architecture, CPU, etc.*/
/* Use SoC timer for AArch32, but architected timer for AArch64 */ diff --git a/include/configs/rv1108_common.h b/include/configs/rv1108_common.h index 758e85e89df7..ca85b81b5a11 100644 --- a/include/configs/rv1108_common.h +++ b/include/configs/rv1108_common.h @@ -11,7 +11,6 @@ #define CONFIG_IRAM_BASE 0x10080000
#define CONFIG_SYS_TIMER_RATE (24 * 1000 * 1000) /* TIMER1,initialized by ddr initialize code */ diff --git a/include/configs/sam9x60ek.h b/include/configs/sam9x60ek.h index 6a6f1de41d1e..4b0d319b949f 100644 --- a/include/configs/sam9x60ek.h +++ b/include/configs/sam9x60ek.h @@ -17,7 +17,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
#define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID 0 /* ignored in arm */ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index a4b4c48d4c4d..0b9ada832418 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -125,9 +125,6 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
#ifndef CONFIG_SPL_BUILD /* diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 5e8637e49484..948ef52c97db 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -43,7 +43,6 @@ #define CONFIG_CMDLINE_TAG /* pass commandline to Kernel */ #define CONFIG_SETUP_MEMORY_TAGS /* pass memory defs to kernel */ #define CONFIG_INITRD_TAG /* pass initrd param to kernel */ -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY /* U-Boot is loaded by a bootloader */
/* We set the max number of command args high to avoid HUSH bugs. */ #define CONFIG_SYS_MAXARGS 32 diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index fc2f6ecf6be3..00af53801b91 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -28,7 +28,6 @@ #define S5P_CHECK_LPA 0xABAD0000
/* MMC SPL */ -#define CONFIG_SKIP_LOWLEVEL_INIT #define COPY_BL2_FNPTR_ADDR 0x00002488
#define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000" diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 529976efee01..963e5b3daa27 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -23,7 +23,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS1 diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index 077e9d667a1e..df6948a51cb5 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -22,7 +22,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS6 diff --git a/include/configs/stemmy.h b/include/configs/stemmy.h index b94ef91c2ba3..3a7a13bd572c 100644 --- a/include/configs/stemmy.h +++ b/include/configs/stemmy.h @@ -13,7 +13,6 @@ * low-level initialization and rely on configuration provided by the Samsung * bootloader. New images are loaded at the same address for compatibility. */ -#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE
diff --git a/include/configs/stih410-b2260.h b/include/configs/stih410-b2260.h index 33b34ee0cd3b..c1ce344e9ba1 100644 --- a/include/configs/stih410-b2260.h +++ b/include/configs/stih410-b2260.h @@ -59,8 +59,6 @@
#define CONFIG_SYS_MAX_FLASH_BANKS 1
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* USB Configs */ #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 6e869462f1e6..ceec56e6a575 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -37,8 +37,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
-#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ #define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */ diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index dd7a75ae4674..e4b64dda7abd 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -110,9 +110,6 @@
/* overrides for SPL build here */ #ifdef CONFIG_SPL_BUILD - -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY - /* remove I2C support */ #ifdef CONFIG_SYS_I2C_TEGRA #undef CONFIG_SYS_I2C_TEGRA diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 67bcc0c21829..9bac3db094fb 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -137,9 +137,6 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
/* Ethernet */ #define CONFIG_NET_RETRY_COUNT 10 diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 44fdc4c30025..c8f5a0763bb7 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -92,9 +92,6 @@ /* Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
/* * Disable MMC DM for SPL build and can be re-enabled after adding diff --git a/include/configs/ti_am335x_common.h b/include/configs/ti_am335x_common.h index c57b20a06a3a..10da12381342 100644 --- a/include/configs/ti_am335x_common.h +++ b/include/configs/ti_am335x_common.h @@ -46,9 +46,6 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_NOR_BOOT) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
/* * When building U-Boot such that there is no previous loader diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index cfc2be7b9f07..cc904c49b9cf 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -12,7 +12,6 @@ #define CONFIG_SOC_KEYSTONE
/* U-Boot Build Configuration */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* U-Boot is a 2nd stage loader */
/* SoC Configuration */ #define CONFIG_SPL_TARGET "u-boot-spi.gph" diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index 73bf2d19da6f..6b3219e2ba7e 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -26,8 +26,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* * Hardware drivers */ diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 4f11018e6d34..140df7a30617 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -15,8 +15,6 @@
#define CONFIG_MACH_TYPE 4146
diff --git a/include/configs/vocore2.h b/include/configs/vocore2.h index dfdb8fcc0469..b867afa2ba99 100644 --- a/include/configs/vocore2.h +++ b/include/configs/vocore2.h @@ -17,9 +17,6 @@ #define CONFIG_SYS_INIT_SP_OFFSET 0x400000
#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SPL_BSS_START_ADDR 0x80010000 diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index f96178bce99b..e3919f5c455d 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -19,10 +19,6 @@ */ #define CONFIG_MACH_TYPE 736
-#if !defined(CONFIG_SPL_BUILD) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* * Memory configurations */ diff --git a/include/configs/xilinx_zynqmp_r5.h b/include/configs/xilinx_zynqmp_r5.h index c0cd72e5642a..09a1742f3389 100644 --- a/include/configs/xilinx_zynqmp_r5.h +++ b/include/configs/xilinx_zynqmp_r5.h @@ -32,6 +32,4 @@ /* Extend size of kernel image for uncompression */ #define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024)
-#define CONFIG_SKIP_LOWLEVEL_INIT - #endif /* __CONFIG_ZYNQ_ZYNQMP_R5_H */ diff --git a/include/configs/zynq_cse.h b/include/configs/zynq_cse.h index 0491cf51361c..7eafdfd9a653 100644 --- a/include/configs/zynq_cse.h +++ b/include/configs/zynq_cse.h @@ -9,8 +9,6 @@ #ifndef __CONFIG_ZYNQ_CSE_H #define __CONFIG_ZYNQ_CSE_H
-#define CONFIG_SKIP_LOWLEVEL_INIT - #include <configs/zynq-common.h>
/* Undef unneeded configs */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d86f35856f78..57753998f191 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1316,8 +1316,6 @@ CONFIG_SH_SDHI_FREQ CONFIG_SH_SDRAM_OFFSET CONFIG_SIEMENS_MACH_TYPE CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION -CONFIG_SKIP_LOWLEVEL_INIT -CONFIG_SKIP_LOWLEVEL_INIT_ONLY CONFIG_SKIP_TRUNOFF_WATCHDOG CONFIG_SLIC CONFIG_SLTTMR
Am Freitag, dem 27.08.2021 um 21:18 -0400 schrieb Tom Rini:
This converts the following to Kconfig: CONFIG_SKIP_LOWLEVEL_INIT CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these options so that we can clearly disable these options only in SPL in some cases, and both instances in other cases.
Signed-off-by: Tom Rini trini@konsulko.com
README | 16 ------ arch/Kconfig | 57 +++++++++++++++++++ arch/arm/cpu/arm1136/start.S | 8 +-- arch/arm/cpu/arm720t/start.S | 10 ++-- arch/arm/cpu/arm920t/start.S | 8 +-- arch/arm/cpu/arm926ejs/start.S | 8 +-- arch/arm/cpu/arm946es/start.S | 6 +- arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/start.S | 8 +-- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 6 ++ arch/arm/cpu/pxa/start.S | 6 +- arch/arm/cpu/sa1100/start.S | 4 +- arch/arm/include/asm/arch-am33xx/chilisom.h | 2 +- arch/arm/mach-at91/arm920t/lowlevel_init.S | 4 +- arch/arm/mach-imx/mx7/soc.c | 2 +- arch/arm/mach-imx/syscounter.c | 2 +- arch/arm/mach-mvebu/include/mach/config.h | 4 -- arch/arm/mach-omap2/Kconfig | 1 + arch/arm/mach-omap2/am33xx/Makefile | 2 +- arch/arm/mach-omap2/am33xx/board.c | 6 +- arch/arm/mach-omap2/am33xx/chilisom.c | 4 +- arch/arm/mach-omap2/omap3/board.c | 4 +- arch/arm/mach-omap2/omap3/lowlevel_init.S | 4 +- arch/arm/mach-orion5x/Makefile | 2 +- arch/arm/mach-rockchip/Kconfig | 1 + arch/arm/mach-tegra/Kconfig | 1 + arch/mips/cpu/start.S | 4 +- arch/mips/mach-mtmips/mt7628/lowlevel_init.S | 4 +- arch/nds32/cpu/n1213/ae3xx/lowlevel_init.S | 4 +- arch/nds32/cpu/n1213/ag101/lowlevel_init.S | 4 +- arch/nds32/cpu/n1213/start.S | 2 +- board/bosch/guardian/Makefile | 2 +- board/bosch/guardian/board.c | 2 +- board/eets/pdu001/Makefile | 2 +- board/eets/pdu001/board.c | 4 +- board/freescale/ls1021aqds/README | 5 +- board/freescale/ls1021atwr/README | 5 +- board/grinn/chiliboard/board.c | 6 +- board/qca/ap152/ap152.c | 2 +- board/tcl/sl50/Makefile | 2 +- board/tcl/sl50/board.c | 2 +- board/ti/am335x/Makefile | 2 +- board/ti/am335x/board.c | 2 +- board/ti/am43xx/Makefile | 2 +- board/ti/am43xx/board.c | 2 +- board/tplink/wdr4300/wdr4300.c | 2 +- board/vscom/baltos/Makefile | 2 +- configs/SBx81LIFKW_defconfig | 1 + configs/SBx81LIFXCAT_defconfig | 1 + configs/adp-ae3xx_defconfig | 1 + configs/adp-ag101p_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/am64x_evm_a53_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/am65x_hs_evm_a53_defconfig | 1 + configs/arndale_defconfig | 2 + configs/aspenite_defconfig | 1 + configs/at91sam9260ek_dataflash_cs0_defconfig | 1 + configs/at91sam9260ek_dataflash_cs1_defconfig | 1 + configs/at91sam9260ek_nandflash_defconfig | 1 + configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9g20ek_2mmc_defconfig | 1 + .../at91sam9g20ek_2mmc_nandflash_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs1_defconfig | 1 + configs/at91sam9g20ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/at91sam9xeek_dataflash_cs0_defconfig | 1 + configs/at91sam9xeek_dataflash_cs1_defconfig | 1 + configs/at91sam9xeek_nandflash_defconfig | 1 + configs/axm_defconfig | 2 + configs/bcm7260_defconfig | 1 + configs/bcm7445_defconfig | 1 + configs/bcm963158_ram_defconfig | 1 + configs/bcm968360bg_ram_defconfig | 1 + configs/bcm968380gerg_ram_defconfig | 3 + configs/bcm968580xref_ram_defconfig | 1 + configs/bk4r1_defconfig | 1 + configs/chromebit_mickey_defconfig | 1 + configs/chromebook_bob_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/chromebook_speedy_defconfig | 1 + configs/ci20_mmc_defconfig | 3 + configs/clearfog_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/colibri_vf_defconfig | 1 + configs/comtrend_ar5315u_ram_defconfig | 3 + configs/comtrend_ar5387un_ram_defconfig | 3 + configs/comtrend_ct5361_ram_defconfig | 3 + configs/comtrend_vr3032u_ram_defconfig | 3 + configs/comtrend_wap5813n_ram_defconfig | 3 + configs/controlcenterdc_defconfig | 2 + configs/corvus_defconfig | 2 + configs/d2net_v2_defconfig | 1 + configs/da850evm_defconfig | 2 + configs/da850evm_direct_nor_defconfig | 1 + configs/da850evm_nand_defconfig | 2 + configs/db-88f6720_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/dns325_defconfig | 1 + configs/dockstar_defconfig | 1 + configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 1 + configs/ea-lpc3250devkitv2_defconfig | 1 + configs/elgin-rv1108_defconfig | 1 + configs/ethernut5_defconfig | 1 + configs/evb-px30_defconfig | 1 + configs/evb-px5_defconfig | 1 + configs/evb-rk3036_defconfig | 2 + configs/evb-rk3128_defconfig | 1 + configs/evb-rk3229_defconfig | 3 + configs/evb-rk3288_defconfig | 2 + configs/evb-rk3308_defconfig | 1 + configs/evb-rk3328_defconfig | 1 + configs/evb-rk3399_defconfig | 1 + configs/evb-rk3568_defconfig | 1 + configs/evb-rv1108_defconfig | 1 + configs/ficus-rk3399_defconfig | 1 + configs/firefly-px30_defconfig | 1 + configs/firefly-rk3288_defconfig | 2 + configs/firefly-rk3399_defconfig | 1 + .../gardena-smart-gateway-at91sam_defconfig | 2 + .../gardena-smart-gateway-mt7688_defconfig | 3 + configs/geekbox_defconfig | 1 + configs/goflexhome_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/helios4_defconfig | 1 + configs/highbank_defconfig | 1 + configs/huawei_hg556a_ram_defconfig | 3 + configs/ib62x0_defconfig | 1 + configs/iconnect_defconfig | 1 + configs/imgtec_xilfpga_defconfig | 3 + configs/inetspace_v2_defconfig | 1 + configs/k2e_evm_defconfig | 2 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 2 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 2 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 2 + configs/k2l_hs_evm_defconfig | 1 + configs/khadas-edge-captain-rk3399_defconfig | 1 + configs/khadas-edge-rk3399_defconfig | 1 + configs/khadas-edge-v-rk3399_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + configs/kmnusa_defconfig | 1 + configs/kmsuse2_defconfig | 1 + configs/kylin-rk3036_defconfig | 2 + configs/leez-rk3399_defconfig | 1 + configs/legoev3_defconfig | 1 + configs/linkit-smart-7688_defconfig | 3 + configs/lion-rk3368_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 2 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 2 + configs/ls1021aqds_sdcard_qspi_defconfig | 2 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 2 + configs/ls1021atwr_sdcard_ifc_defconfig | 2 + configs/ls1021atwr_sdcard_qspi_defconfig | 2 + configs/ls1028aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1028aqds_tfa_defconfig | 1 + configs/ls1028aqds_tfa_lpuart_defconfig | 1 + configs/ls1028ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1028ardb_tfa_defconfig | 1 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/lx2160aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160aqds_tfa_defconfig | 1 + configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160ardb_tfa_defconfig | 1 + configs/lx2160ardb_tfa_stmm_defconfig | 1 + configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2162aqds_tfa_defconfig | 1 + .../lx2162aqds_tfa_verified_boot_defconfig | 1 + configs/meesc_dataflash_defconfig | 1 + configs/meesc_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/mt7620_mt7530_rfb_defconfig | 3 + configs/mt7620_rfb_defconfig | 3 + configs/mt7628_rfb_defconfig | 3 + configs/nanopc-t4-rk3399_defconfig | 1 + configs/nanopi-m4-2gb-rk3399_defconfig | 1 + configs/nanopi-m4-rk3399_defconfig | 1 + configs/nanopi-m4b-rk3399_defconfig | 1 + configs/nanopi-neo4-rk3399_defconfig | 1 + configs/nanopi-r2s-rk3328_defconfig | 1 + configs/nanopi-r4s-rk3399_defconfig | 1 + configs/nas220_defconfig | 1 + configs/net2big_v2_defconfig | 1 + configs/netgear_cg3100d_ram_defconfig | 3 + configs/netgear_dgnd3700v2_ram_defconfig | 3 + configs/netspace_lite_v2_defconfig | 1 + configs/netspace_max_v2_defconfig | 1 + configs/netspace_mini_v2_defconfig | 1 + configs/netspace_v2_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/nsa310s_defconfig | 1 + configs/odroid-go2_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + configs/omapl138_lcdk_defconfig | 2 + configs/openrd_base_defconfig | 1 + configs/openrd_client_defconfig | 1 + configs/openrd_ultimate_defconfig | 1 + configs/orangepi-rk3399_defconfig | 1 + configs/origen_defconfig | 2 + configs/pcm052_defconfig | 1 + configs/peach-pi_defconfig | 2 + configs/peach-pit_defconfig | 2 + configs/pg_wcom_expu1_defconfig | 1 + configs/pg_wcom_seli8_defconfig | 1 + configs/phycore-rk3288_defconfig | 1 + configs/pinebook-pro-rk3399_defconfig | 1 + configs/pm9g45_defconfig | 1 + configs/pogo_e02_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/px30-core-ctouch2-px30_defconfig | 1 + configs/px30-core-edimm2.2-px30_defconfig | 1 + configs/roc-cc-rk3308_defconfig | 1 + configs/roc-cc-rk3328_defconfig | 1 + configs/roc-pc-mezzanine-rk3399_defconfig | 1 + configs/roc-pc-rk3399_defconfig | 1 + configs/rock-pi-4-rk3399_defconfig | 1 + configs/rock-pi-4c-rk3399_defconfig | 1 + configs/rock-pi-e-rk3328_defconfig | 1 + configs/rock-pi-n10-rk3399pro_defconfig | 1 + configs/rock-pi-n8-rk3288_defconfig | 2 + configs/rock2_defconfig | 1 + configs/rock64-rk3328_defconfig | 1 + configs/rock960-rk3399_defconfig | 1 + configs/rock_defconfig | 2 + configs/rockpro64-rk3399_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/sagem_f@st1704_ram_defconfig | 3 + configs/sam9x60ek_mmc_defconfig | 1 + configs/sam9x60ek_nandflash_defconfig | 1 + configs/sam9x60ek_qspiflash_defconfig | 1 + configs/sama5d27_giantboard_defconfig | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 1 + configs/sama5d27_som1_ek_mmc_defconfig | 1 + configs/sama5d27_som1_ek_qspiflash_defconfig | 1 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 1 + .../sama5d27_wlsom1_ek_qspiflash_defconfig | 1 + configs/sama5d2_icp_mmc_defconfig | 1 + configs/sama5d2_ptc_ek_mmc_defconfig | 1 + configs/sama5d2_ptc_ek_nandflash_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_qspiflash_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sfr_nb4-ser_ram_defconfig | 3 + configs/sheep-rk3368_defconfig | 1 + configs/sheevaplug_defconfig | 1 + configs/smartweb_defconfig | 2 + configs/smdk5250_defconfig | 2 + configs/smdk5420_defconfig | 2 + configs/smdkv310_defconfig | 2 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/snow_defconfig | 2 + configs/spring_defconfig | 2 + configs/stemmy_defconfig | 1 + configs/stih410-b2260_defconfig | 1 + configs/taurus_defconfig | 2 + configs/ti816x_evm_defconfig | 1 + configs/tinker-rk3288_defconfig | 2 + configs/tinker-s-rk3288_defconfig | 2 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/usb_a9263_dataflash_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + configs/vinco_defconfig | 1 + configs/vocore2_defconfig | 3 + configs/vyasa-rk3288_defconfig | 2 + configs/work_92105_defconfig | 1 + configs/x530_defconfig | 1 + configs/xilinx_zynqmp_r5_defconfig | 1 + configs/zynq_cse_nand_defconfig | 2 + configs/zynq_cse_nor_defconfig | 2 + configs/zynq_cse_qspi_defconfig | 2 + doc/board/AndesTech/adp-ag101p.rst | 4 +- include/configs/SBx81LIFKW.h | 1 - include/configs/SBx81LIFXCAT.h | 1 - include/configs/adp-ae3xx.h | 2 - include/configs/adp-ag101p.h | 2 - include/configs/am43xx_evm.h | 8 --- include/configs/am64x_evm.h | 4 -- include/configs/am65x_evm.h | 4 -- include/configs/aspenite.h | 1 - include/configs/at91-sama5_common.h | 4 -- include/configs/at91sam9260ek.h | 1 - include/configs/at91sam9261ek.h | 2 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 2 - include/configs/at91sam9x5ek.h | 1 - include/configs/bcmstb.h | 1 - include/configs/bk4r1.h | 2 - include/configs/bmips_bcm3380.h | 1 - include/configs/bmips_bcm6318.h | 1 - include/configs/bmips_bcm63268.h | 1 - include/configs/bmips_bcm6328.h | 1 - include/configs/bmips_bcm6338.h | 1 - include/configs/bmips_bcm6348.h | 1 - include/configs/bmips_bcm6358.h | 1 - include/configs/bmips_bcm6362.h | 1 - include/configs/bmips_bcm6368.h | 1 - include/configs/bmips_bcm6838.h | 1 - include/configs/broadcom_bcm963158.h | 2 - include/configs/broadcom_bcm968360bg.h | 2 - include/configs/broadcom_bcm968580xref.h | 2 - include/configs/bur_am335x_common.h | 3 - include/configs/ci20.h | 2 - include/configs/cm_t43.h | 3 - include/configs/colibri_vf.h | 2 - include/configs/controlcenterdc.h | 2 - include/configs/corvus.h | 1 - include/configs/da850evm.h | 1 - include/configs/devkit3250.h | 4 -- include/configs/dns325.h | 1 - include/configs/dockstar.h | 1 - include/configs/ea-lpc3250devkitv2.h | 1 - include/configs/ethernut5.h | 1 - include/configs/exynos-common.h | 2 - .../configs/gardena-smart-gateway-at91sam.h | 5 -- .../configs/gardena-smart-gateway-mt7688.h | 3 - include/configs/goflexhome.h | 1 - include/configs/highbank.h | 1 - include/configs/ib62x0.h | 1 - include/configs/iconnect.h | 1 - include/configs/imgtec_xilfpga.h | 1 - include/configs/integrator-common.h | 1 - include/configs/km/km_arm.h | 2 - include/configs/km/pg-wcom-ls102xa.h | 2 - include/configs/lacie_kw.h | 1 - include/configs/legoev3.h | 1 - include/configs/linkit-smart-7688.h | 3 - include/configs/ls1012a_common.h | 2 - include/configs/ls1021aqds.h | 2 - include/configs/ls1021atwr.h | 1 - include/configs/ls1028a_common.h | 2 - include/configs/ls1043a_common.h | 2 - include/configs/ls1043aqds.h | 2 - include/configs/ls1046a_common.h | 2 - include/configs/ls1046aqds.h | 2 - include/configs/ls1088a_common.h | 2 - include/configs/ls2080a_common.h | 2 - include/configs/lsxl.h | 2 - include/configs/lx2160a_common.h | 2 - include/configs/meesc.h | 1 - include/configs/mt7620.h | 3 - include/configs/mt7628.h | 3 - include/configs/mv-plug-common.h | 1 - include/configs/mx7_common.h | 5 -- include/configs/nas220.h | 1 - include/configs/nokia_rx51.h | 2 - include/configs/nsa310s.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/openrd.h | 1 - include/configs/pcm052.h | 2 - include/configs/pm9261.h | 2 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/pogo_e02.h | 1 - include/configs/px30_common.h | 1 - include/configs/rk3036_common.h | 1 - include/configs/rk3128_common.h | 1 - include/configs/rk3188_common.h | 1 - include/configs/rk322x_common.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/rk3308_common.h | 1 - include/configs/rk3328_common.h | 1 - include/configs/rk3368_common.h | 1 - include/configs/rk3399_common.h | 1 - include/configs/rk3568_common.h | 1 - include/configs/rpi.h | 4 -- include/configs/rv1108_common.h | 1 - include/configs/sam9x60ek.h | 1 - include/configs/siemens-am33x-common.h | 3 - include/configs/smartweb.h | 1 - include/configs/smdkv310.h | 1 - include/configs/snapper9260.h | 1 - include/configs/snapper9g45.h | 1 - include/configs/stemmy.h | 1 - include/configs/stih410-b2260.h | 2 - include/configs/taurus.h | 2 - include/configs/tegra-common-post.h | 3 - include/configs/ti814x_evm.h | 3 - include/configs/ti816x_evm.h | 3 - include/configs/ti_am335x_common.h | 3 - include/configs/ti_armv7_keystone2.h | 1 - include/configs/usb_a9263.h | 2 - include/configs/vf610twr.h | 2 - include/configs/vocore2.h | 3 - include/configs/work_92105.h | 4 -- include/configs/xilinx_zynqmp_r5.h | 2 - include/configs/zynq_cse.h | 2 - scripts/config_whitelist.txt | 2 - 457 files changed, 514 insertions(+), 311 deletions(-)
+++ b/configs/ci20_mmc_defconfig @@ -1,4 +1,5 @@ CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBGENERIC_SUPPORT=y @@ -11,6 +12,8 @@ CONFIG_SPL_TEXT_BASE=0xf4000a00 CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL=y CONFIG_ARCH_JZ47XX=y +CONFIG_MIPS_CACHE_SETUP=y +CONFIG_MIPS_CACHE_DISABLE=y CONFIG_FIT=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS4,115200 rw rootwait root=/dev/mmcblk0p1"
this doesn't look correct for this SPL enabled MIPS board and some others as well. Problem is the Kconfig dependency to CONFIG_SKIP_LOWLEVEL_INIT:
config MIPS_CACHE_SETUP bool "Allow generic start code to initialize and setup caches" default n if SKIP_LOWLEVEL_INIT default y
config MIPS_CACHE_DISABLE bool "Allow generic start code to initially disable caches" default n if SKIP_LOWLEVEL_INIT default y
Normally both options have to be y in SPL along with SKIP_LOWLEVEL_INIT=n. But in U-Boot proper both options have to be n along with SKIP_LOWLEVEL_INIT=y. I guess we need to introduce SPL_MIPS_CACHE_SETUP and SPL_MIPS_CACHE_DISABLE or is there a better way to deal with dependencies to SKIP_LOWLEVEL_INIT and SPL_SKIP_LOWLEVEL_INIT?
So, size-wise, everything is as it was before this patch is applied. The previous logic wasn't doing anything (you can't do logic with symbols not in Kconfig). Everything should function exactly as well as before. And yes, given how things build today, you will need SPL_xxx symbols to control the SPL build, and for code that's common to both, use CONFIG_IS_ENABLED(xxx) to evaluate the correct setting for the build.
Am Montag, dem 30.08.2021 um 22:48 -0400 schrieb Tom Rini:
hm, then commit 57bfb1aed6a87b19ca7e2a76df83ea387621e2e9 didn't work as intended and both options were incorrectly always y since that. Then your patch is correct. I'll look into fixing those options.
Since this patch series 'make menuconfig' does not look good anymore:
*** Compiler: gcc (Ubuntu 11.2.0-18ubuntu1) 11.2.0 *** Architecture select (ARM architecture) ---> [ ] Skip the calls to certain low level initialization functions [ ] Skip the calls to certain low level initialization functions [ ] Skip the calls to certain low level initialization functions [ ] Skip the call to lowlevel_init during early boot ONLY [ ] Skip the call to lowlevel_init during early boot ONLY ARM architecture ---> General setup --->
Who would be able to understand three entries with the same short text?
Why wouldn't these entries live in "General setup" or some other sub-menu?
(Seen with Bananapro_defconfig)
Best regards
Heinrich
Please send patches to change some of the wording, thanks.
Daniel Schwierzeck
