[PATCH v2 1/1] cmd: eficonfig: create shortened boot options
The boot options created by eficonfig should use shortened device-paths to avoid problems if drives are enumerated in a different sequence.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: Correctly handle the case that dp_volume does not refer to a block device. --- cmd/eficonfig.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index e6e8a0a488..34a59cb15d 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -528,7 +528,10 @@ struct efi_device_path *eficonfig_create_device_path(struct efi_device_path *dp_ p += fp_size; *((struct efi_device_path *)p) = END;
- dp = efi_dp_append(dp_volume, (struct efi_device_path *)buf); + dp = efi_dp_shorten(dp_volume); + if (!dp) + dp = dp_volume; + dp = efi_dp_append(dp, &fp->dp); free(buf);
return dp;
On Sat, 18 Nov 2023 at 13:40, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
if (!dp)
dp = dp_volume;
dp = efi_dp_append(dp, &fp->dp); free(buf); return dp;
-- 2.40.1
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
