[PATCH v3 0/3] Various minor patches
This series contains a number of minor patches collected while completing the ACPI updates for U-Boot.
Changes in v3: - Rebase to master
Changes in v2: - Drop patches already applied - Rebase to master
Simon Glass (3): x86: zimage: Add a little more logging x86: zimage: Sanity-check the kernel version before printing it x86: zimage: Quieten down the zimage boot process
arch/x86/lib/zimage.c | 26 +++++++++++++++++++++----- common/log.c | 1 + include/log.h | 1 + 3 files changed, 23 insertions(+), 5 deletions(-)
Add logging for each part of the boot process, using a new
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
(no changes since v1)
arch/x86/lib/zimage.c | 6 ++++++ common/log.c | 1 + include/log.h | 1 + 3 files changed, 8 insertions(+)
diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index a00964cc8d9..7418c9a5fed 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -12,10 +12,13 @@ * linux/Documentation/i386/boot.txt */
+#define LOG_CATEGORY LOGC_BOOT + #include <common.h> #include <command.h> #include <env.h> #include <irq_func.h> +#include <log.h> #include <malloc.h> #include <acpi/acpi_table.h> #include <asm/io.h> @@ -292,6 +295,7 @@ int setup_zimage(struct boot_params *setup_base, char *cmd_line, int auto_boot, struct setup_header *hdr = &setup_base->hdr; int bootproto = get_boot_protocol(hdr, false);
+ log_debug("Setup E820 entries\n"); setup_base->e820_entries = install_e820_map( ARRAY_SIZE(setup_base->e820_map), setup_base->e820_map);
@@ -317,6 +321,7 @@ int setup_zimage(struct boot_params *setup_base, char *cmd_line, int auto_boot, }
if (cmd_line) { + log_debug("Setup cmdline\n"); if (bootproto >= 0x0202) { hdr->cmd_line_ptr = (uintptr_t)cmd_line; } else if (bootproto >= 0x0200) { @@ -340,6 +345,7 @@ int setup_zimage(struct boot_params *setup_base, char *cmd_line, int auto_boot, if (IS_ENABLED(CONFIG_GENERATE_ACPI_TABLE)) setup_base->acpi_rsdp_addr = acpi_get_rsdp_addr();
+ log_debug("Setup devicetree\n"); setup_device_tree(hdr, (const void *)env_get_hex("fdtaddr", 0)); setup_video(&setup_base->screen_info);
diff --git a/common/log.c b/common/log.c index 4b6f3fcd04a..ce39918e045 100644 --- a/common/log.c +++ b/common/log.c @@ -26,6 +26,7 @@ static const char *const log_cat_name[] = { "bloblist", "devres", "acpi", + "boot", };
_Static_assert(ARRAY_SIZE(log_cat_name) == LOGC_COUNT - LOGC_NONE, diff --git a/include/log.h b/include/log.h index 4d0692f155d..29f18a82dcf 100644 --- a/include/log.h +++ b/include/log.h @@ -96,6 +96,7 @@ enum log_category_t { LOGC_DEVRES, /** @LOGC_ACPI: Advanced Configuration and Power Interface (ACPI) */ LOGC_ACPI, + LOGC_BOOT, /* Related to boot process / boot image processing */
/** @LOGC_COUNT: Number of log categories */ LOGC_COUNT,
- linux/Documentation/i386/boot.txt
if (cmd_line) {
"boot",
LOGC_BOOT, /* Related to boot process / boot image processing */ /** @LOGC_COUNT: Number of log categories */ LOGC_COUNT,
-- 2.29.1.341.ge80a0c044ae-goog
Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
With Chrome OS the kernel setup block is stored in a separate place from the kernel, so it is not possible to access the kernel version string. At present, garbage is printed.
Add a sanity check to avoid this.
arch/x86/lib/zimage.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index 7418c9a5fed..d425ded596d 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -31,6 +31,7 @@ #include <asm/arch/timestamp.h> #endif #include <linux/compiler.h> +#include <linux/ctype.h> #include <linux/libfdt.h>
/* @@ -175,11 +176,19 @@ static const char *get_kernel_version(struct boot_params *params, { struct setup_header *hdr = ¶ms->hdr; int bootproto; + const char *s, *end;
bootproto = get_boot_protocol(hdr, false); if (bootproto < 0x0200 || hdr->setup_sects < 15) return NULL;
+ /* sanity-check the kernel version in case it is missing */ + for (s = kernel_base + hdr->kernel_version + 0x200, end = s + 0x100; *s; + s++) { + if (!isprint(*s)) + return NULL; + } + return kernel_base + hdr->kernel_version + 0x200; }
Much of the output is not very useful. The bootm command is quite a bit quieter. Convert some output to use log_debug().
arch/x86/lib/zimage.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index d425ded596d..50fb16d2dac 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -212,13 +212,13 @@ struct boot_params *load_zimage(char *image, unsigned long kernel_size,
/* determine size of setup */ if (0 == hdr->setup_sects) { - printf("Setup Sectors = 0 (defaulting to 4)\n"); + log_warning("Setup Sectors = 0 (defaulting to 4)\n"); setup_size = 5 * 512; } else { setup_size = (hdr->setup_sects + 1) * 512; }
- printf("Setup Size = 0x%8.8lx\n", (ulong)setup_size); + log_debug("Setup Size = 0x%8.8lx\n", (ulong)setup_size);
if (setup_size > SETUP_MAX_SIZE) printf("Error: Setup is too large (%d bytes)\n", setup_size); @@ -226,8 +226,8 @@ struct boot_params *load_zimage(char *image, unsigned long kernel_size, /* determine boot protocol version */ bootproto = get_boot_protocol(hdr, true);
- printf("Using boot protocol version %x.%02x\n", - (bootproto & 0xff00) >> 8, bootproto & 0xff); + log_debug("Using boot protocol version %x.%02x\n", + (bootproto & 0xff00) >> 8, bootproto & 0xff);
version = get_kernel_version(params, image); if (version) @@ -420,7 +420,8 @@ static int do_zboot_load(struct cmd_tbl *cmdtp, int flag, int argc, struct boot_params *from = (struct boot_params *)state.base_ptr;
base_ptr = (struct boot_params *)DEFAULT_SETUP_BASE; - printf("Building boot_params at 0x%8.8lx\n", (ulong)base_ptr); + log_debug("Building boot_params at 0x%8.8lx\n", + (ulong)base_ptr); memset(base_ptr, '\0', sizeof(*base_ptr)); base_ptr->hdr = from->hdr; } else {
Changes in v3:
- Rebase to master
Changes in v2:
- Rebase to master
log_debug("Setup Size = 0x%8.8lx\n", (ulong)setup_size); if (setup_size > SETUP_MAX_SIZE) printf("Error: Setup is too large (%d bytes)\n", setup_size);
(bootproto & 0xff00) >> 8, bootproto & 0xff); version = get_kernel_version(params, image); if (version)
Changes in v3:
- Rebase to master
Changes in v2:
- Rebase to master
series applied to u-boot-x86, thanks!
Bin Meng
Igor Opaniuk
