[U-Boot] [PATCH] UBIFS: Improve error message when reading superblock failed
In addition to the error message also display the error code. I had the problem that my malloc memory was not enough (ENOMEM), and if u-boot had displayed the error code immediately that would have saved me some debugging.
Signed-off-by: Bernhard Walle walle@corscience.de --- fs/ubifs/super.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/fs/ubifs/super.c b/fs/ubifs/super.c index 26b48f0..0b1440b 100644 --- a/fs/ubifs/super.c +++ b/fs/ubifs/super.c @@ -1191,7 +1191,7 @@ int ubifs_mount(char *vol_name) mnt = NULL; ret = ubifs_get_sb(&ubifs_fs_type, flags, name, data, mnt); if (ret) { - printf("Error reading superblock on volume '%s'!\n", name); + printf("Error reading superblock on volume '%s': %d!\n", name, -ret); return -1; }
Hi Bernhard,
return -1; }printf("Error reading superblock on volume '%s': %d!\n", name, -ret);
I think this makes sense, but I think it would be more natural to print the real error code, not the negative value. I don't know how to search for all such occurrences, but I cannot find any but a lot of sites printing the error code as is.
Cheers Detlev
Hi Detlev,
* Detlev Zundel dzu@denx.de [2012-02-17 15:15]:
well, the return value is negative, so my intention was to print the error code as positive number. So you think we should display it as negative number (-12 instead of 12 for ENOMEM)?
Regards, Bernhard
Hi Bernhard,
Hi Detlev,
- Detlev Zundel dzu@denx.de [2012-02-17 15:15]:
Personally I believe that any transformation in the printing can mislead people in the search for the cause or the responsible code.
So if the error value is -12, then we should print it. After all, the assignment to generate that value will very likely be "return -ENOMEM" and people will thus know what to look for.
On the other hand I am open to the consistency argument, so if every error printing would do such a transformation then it would be better to also do it. But as I said, I don't know an easy grep pattern to search for such locations and quick searches showed that I all places I found print the error codes unmangeld.
Cheers Detlev
Signed-off-by: Bernhard Walle walle@corscience.de --- v2: Print the non-negated error value.
diff --git a/fs/ubifs/super.c b/fs/ubifs/super.c index 26b48f0..e6c02f5 100644 --- a/fs/ubifs/super.c +++ b/fs/ubifs/super.c @@ -1191,7 +1191,7 @@ int ubifs_mount(char *vol_name) mnt = NULL; ret = ubifs_get_sb(&ubifs_fs_type, flags, name, data, mnt); if (ret) { - printf("Error reading superblock on volume '%s'!\n", name); + printf("Error reading superblock on volume '%s': %d!\n", name, ret); return -1; }
Hi Bernard,
Signed-off-by: Bernhard Wallewalle@corscience.de
return -1; }printf("Error reading superblock on volume '%s': %d!\n", name, ret);
Dry numbers as error messages are better than no error messages but only marginally IMO. Isn't there a way to emit a readable message re malloc instead of emitting an int value?
Amicalement,
Am 20.02.2012 09:59, schrieb Albert ARIBAUD:
Well, I'm not familiar with the u-boot codebase. Does u-boot have a strerror table? How is it handled on other places? Should an error message printed directly before returning -ENOMEM?
Regards, Bernhard
Hi Bernhard,
I don't think there is an strerror() API. But at least, if the newly printed int uses errno values, then instead of '... %d!", you could print "... errno=%d", which would give some hint to the reader.
Regards, Bernhard
Amicalement,
Use ubifs_err instead of printf. Add "errno=%d" in output as suggested by Albert Aribaud. Signed-off-by: Thomas Weber weber@corscience.de --- fs/ubifs/super.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/fs/ubifs/super.c b/fs/ubifs/super.c index 26b48f0..30ccd98 100644 --- a/fs/ubifs/super.c +++ b/fs/ubifs/super.c @@ -1191,7 +1191,7 @@ int ubifs_mount(char *vol_name) mnt = NULL; ret = ubifs_get_sb(&ubifs_fs_type, flags, name, data, mnt); if (ret) { - printf("Error reading superblock on volume '%s'!\n", name); + ubifs_err("Error reading superblock on volume '%s' errno=%d!\n", name, ret); return -1; }
Ccing Albert
Thomas
return -1; }ubifs_err("Error reading superblock on volume '%s' errno=%d!\n", name, ret);
Dear Thomas Weber,
Applied, thanks.
Stefan, I hope this is OK with you.
participants (6)
Albert ARIBAUD
Bernhard Walle
Detlev Zundel
Thomas Weber
Thomas Weber
