[U-Boot] [GIT PULL] integratorap patches
With the risk of the board being removed I have no choice but to request that these patches be pulled in, do I... they are all reviewed on the list, patch entitled "integratorap: fixup SDRAM memory size detection" had a comment about TAB intentation and this is fixed in this set, the only other change is that they are have consistently Subject: "integratorap: foo" except the MAINTAINERS patch.
The two patches NACK:ed by Wolfgang are not part of this pull request, the first one was misguided and is dropped and the second regarding cache is being worked out.
So the following makes the integratorap compile and run, there is still a cache problem when issuing "bootm" but I'm working on it, by simply configuring off the D-Cache the resulting U-boot will work fine for booting a recent kernel.
So please pull this.
The following changes since commit 68d4230c3ccce96a72c5b99e48399bf1796fe3c6:
powerpc/85xx: Add default usb mode and phy type to hwconfig (2011-07-11 13:24:21 -0500)
are available in the git repository at: git://git.linaro.org/people/triad/u-boot for-albert
Linus Walleij (7): MAINTAINERS: integrator+versatile boards integratorap: make the compile work again integratorap: support relocation integratorap: support the hush shell integratorap: support some rudimentary commands integratorap: fixup SDRAM memory size detection integratorap: remove hardcoded 32MB memory cmdline
MAINTAINERS | 11 ++++++----- board/armltd/integrator/integrator.c | 15 +++++++-------- board/armltd/integrator/lowlevel_init.S | 2 +- include/configs/integratorap.h | 18 ++++++++++++++++-- 4 files changed, 30 insertions(+), 16 deletions(-)
Thanks, Linus Walleij
Hi Albert,
since I think we have now resolved the remaining issue with the build system I'm reiterating this pull request.
Changes from last time: - MAINTAINERS change also covers me taking over the integratorcp board - Build the integratorap/cp variants using boards.cfg configuration
The latest version of all patches are used, i.e those that have yielded no further comments.
The following changes since commit 74fac70084bb040342fafc3b0d2ef50fbe35646f: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-mmc
Linus Walleij (9): MAINTAINERS: integrator+versatile boards integratorap: make the compile work again integratorap: support relocation integratorap: support the hush shell integratorap: support some rudimentary commands integratorap: fixup SDRAM memory size detection integratorap: remove hardcoded 32MB memory cmdline integratorcp: make the board compile integrator: convert to new build system
MAINTAINERS | 11 +- MAKEALL | 22 --- Makefile | 27 ---- arch/arm/cpu/arm720t/cpu.c | 5 - board/armltd/integrator/integrator.c | 15 +- board/armltd/integrator/lowlevel_init.S | 2 +- board/armltd/integrator/split_by_variant.sh | 220 --------------------------- boards.cfg | 8 + include/configs/integratorap.h | 21 +++- include/configs/integratorcp.h | 8 + 10 files changed, 49 insertions(+), 290 deletions(-) delete mode 100755 board/armltd/integrator/split_by_variant.sh
Le 22/07/2011 15:46, Linus Walleij a écrit :
Hi Albert,
From a process standpoint, I'd rather apply the last version of each patch present on the list / on patchwork and apply it, rather than pulling in a repo other than the U-boot official repos.
If any of the patches in your repo are not yet posted on the list, please do so; if they all are, then can you provide the list of the patchwork URLs? Thanks a lot in advance.
Amicalement,
On Sat, Jul 23, 2011 at 3:20 PM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
OK no problem!
Well, one of them is missing because I corrected one TAB character in it, as stated in the pull request :-P
These are the patches with one missing: http://patchwork.ozlabs.org/patch/105595/ http://patchwork.ozlabs.org/patch/104349/ http://patchwork.ozlabs.org/patch/104346/ http://patchwork.ozlabs.org/patch/104347/ http://patchwork.ozlabs.org/patch/104348/ http://patchwork.ozlabs.org/patch/104661/ http://patchwork.ozlabs.org/patch/105593/ http://patchwork.ozlabs.org/patch/106013/
I'll provide new links to the patchwork repost soon.
Thanks! Linus Walleij
Here are the patchwork links to the latest versions (v3): http://patchwork.ozlabs.org/patch/106463/ http://patchwork.ozlabs.org/patch/106462/ http://patchwork.ozlabs.org/patch/106464/ http://patchwork.ozlabs.org/patch/106465/ http://patchwork.ozlabs.org/patch/106466/ http://patchwork.ozlabs.org/patch/106467/ http://patchwork.ozlabs.org/patch/106468/ http://patchwork.ozlabs.org/patch/106469/ http://patchwork.ozlabs.org/patch/106470/
Albert ARIBAUD
Linus Walleij
