[U-Boot] [PULL] u-boot-atmel/master -> u-boot/master
The following changes since commit 6b3943f1b04be60f147ee540fbd72c4c7ea89f80:
siemens,am33x: add draco etamin board (2016-06-09 13:53:13 -0400)
git://git.denx.de/u-boot-atmel.git master
for you to fetch changes up to c1631c8a04f53e694dd73bbb987b97eed5188517:
serial: atmel_usart: Add device tree support (2016-06-12 23:49:38 +0200)
---------------------------------------------------------------- Andre Renaud (6): at91: Add support for the AT91 slow clock controller net: Handle an empty bootp extension section arm: at91: Add a header file for the real-time clock at91: Correct NAND ECC register access at91: nand: Set up the ECC strength correctly arm: at91: Add support for gurnard
Andreas Bießmann (1): linux/compat.h: add dev_warn()
Marek Vasut (3): gpio: at91: Fix pullup/pulldown configuration on PIO3 ARM: at91: sama5: Extend boot device autodetection ARM: at91: Fix PMC bit definitions
Simon Glass (10): arm: Allow skipping of low-level init with I-cache on bootm: Align cache flush end address correctly net: macb: Prepare for driver-model conversion net: macb: Flush correct cache portion when sending net: macb: Convert to driver model arm: at91: dts: Bring in device tree file for AT91SAM9G45 at91: Add driver-model GPIO devices for AT91SAM9G45 at91: video: Prepare for driver-model conversion at91: video: Support driver-model for the LCD driver fdt: Correct return value in fdtdec_decode_display_timing()
Wenyou Yang (1): serial: atmel_usart: Add device tree support
README | 5 + arch/arm/cpu/arm1136/start.S | 2 + arch/arm/cpu/arm920t/start.S | 3 +- arch/arm/cpu/arm926ejs/start.S | 2 + arch/arm/cpu/arm946es/start.S | 2 + arch/arm/cpu/armv7/start.S | 5 +- arch/arm/cpu/sa1100/start.S | 2 + arch/arm/dts/Makefile | 1 + arch/arm/dts/at91sam9g45-gurnard.dts | 157 ++ arch/arm/dts/at91sam9g45.dtsi | 1335 ++++++++++ arch/arm/mach-at91/Kconfig | 9 + arch/arm/mach-at91/Makefile | 4 +- .../mach-at91/arm926ejs/at91sam9m10g45_devices.c | 18 + arch/arm/mach-at91/include/mach/at91_pmc.h | 16 +- arch/arm/mach-at91/include/mach/at91_rtc.h | 71 + arch/arm/mach-at91/include/mach/at91_sck.h | 21 + arch/arm/mach-at91/include/mach/at91sam9g45.h | 1 + arch/arm/mach-at91/include/mach/sama5_boot.h | 25 + arch/arm/mach-at91/include/mach/sama5d2.h | 12 - arch/arm/mach-at91/spl.c | 19 +- board/bluewater/gurnard/Kconfig | 12 + board/bluewater/gurnard/MAINTAINERS | 6 + board/bluewater/gurnard/Makefile | 11 + board/bluewater/gurnard/gurnard.c | 449 ++++ board/bluewater/gurnard/splash_logo.h | 2619 ++++++++++++++++++++ common/bootm.c | 2 +- configs/gurnard_defconfig | 20 + drivers/gpio/at91_gpio.c | 11 +- drivers/mtd/nand/atmel_nand.c | 5 +- drivers/net/macb.c | 320 ++- drivers/serial/atmel_usart.c | 19 + drivers/video/atmel_lcdfb.c | 197 +- include/atmel_lcd.h | 9 + include/configs/snapper9g45.h | 155 ++ include/dt-bindings/clock/at91.h | 23 + include/dt-bindings/dma/at91.h | 52 + include/dt-bindings/pinctrl/at91.h | 40 + include/linux/compat.h | 2 + lib/fdtdec.c | 2 +- net/bootp.c | 9 + 40 files changed, 5523 insertions(+), 150 deletions(-) create mode 100644 arch/arm/dts/at91sam9g45-gurnard.dts create mode 100644 arch/arm/dts/at91sam9g45.dtsi create mode 100644 arch/arm/mach-at91/include/mach/at91_rtc.h create mode 100644 arch/arm/mach-at91/include/mach/at91_sck.h create mode 100644 arch/arm/mach-at91/include/mach/sama5_boot.h create mode 100644 board/bluewater/gurnard/Kconfig create mode 100644 board/bluewater/gurnard/MAINTAINERS create mode 100644 board/bluewater/gurnard/Makefile create mode 100644 board/bluewater/gurnard/gurnard.c create mode 100644 board/bluewater/gurnard/splash_logo.h create mode 100644 configs/gurnard_defconfig create mode 100644 include/configs/snapper9g45.h create mode 100644 include/dt-bindings/clock/at91.h create mode 100644 include/dt-bindings/dma/at91.h create mode 100644 include/dt-bindings/pinctrl/at91.h
Andreas Bießmann
