[PATCH 1/1] test: avoid function name 'setup'
pytest 7.3.2 treats the function name 'setup' as a fixture [1].
This leads to errors like:
TypeError: setup() missing 2 required positional arguments: 'disk_img' and 'osindications'
Rename setup() to capsule_setup().
[1] How to run tests written for nose https://docs.pytest.org/en/7.3.x/how-to/nose.html
Fixes: 482ef90aeb4c ("test: efi_capsule: refactor efi_capsule test") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- test/py/tests/test_efi_capsule/capsule_common.py | 2 +- .../test_efi_capsule/test_capsule_firmware_fit.py | 10 +++++----- .../test_efi_capsule/test_capsule_firmware_raw.py | 12 ++++++------ .../test_capsule_firmware_signed_fit.py | 12 ++++++------ .../test_capsule_firmware_signed_raw.py | 12 ++++++------ 5 files changed, 24 insertions(+), 24 deletions(-)
diff --git a/test/py/tests/test_efi_capsule/capsule_common.py b/test/py/tests/test_efi_capsule/capsule_common.py index 9eef6767a6..fc0d851c61 100644 --- a/test/py/tests/test_efi_capsule/capsule_common.py +++ b/test/py/tests/test_efi_capsule/capsule_common.py @@ -6,7 +6,7 @@
from capsule_defs import CAPSULE_DATA_DIR, CAPSULE_INSTALL_DIR
-def setup(u_boot_console, disk_img, osindications): +def capsule_setup(u_boot_console, disk_img, osindications): """setup the test
Args: diff --git a/test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py b/test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py index a3094c33f4..11bcdc2bb2 100644 --- a/test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py +++ b/test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py @@ -8,7 +8,7 @@ This test verifies capsule-on-disk firmware update for FIT images
import pytest from capsule_common import ( - setup, + capsule_setup, init_content, place_capsule_file, exec_manual_update, @@ -49,7 +49,7 @@ class TestEfiCapsuleFirmwareFit(): disk_img = efi_capsule_data capsule_files = ['Test05'] with u_boot_console.log.section('Test Case 1-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') init_content(u_boot_console, '150000', 'u-boot.env.old', 'Old') place_capsule_file(u_boot_console, capsule_files) @@ -81,7 +81,7 @@ class TestEfiCapsuleFirmwareFit(): disk_img = efi_capsule_data capsule_files = ['Test04'] with u_boot_console.log.section('Test Case 2-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') init_content(u_boot_console, '150000', 'u-boot.env.old', 'Old') place_capsule_file(u_boot_console, capsule_files) @@ -116,7 +116,7 @@ class TestEfiCapsuleFirmwareFit(): disk_img = efi_capsule_data capsule_files = ['Test104'] with u_boot_console.log.section('Test Case 3-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') init_content(u_boot_console, '150000', 'u-boot.env.old', 'Old') place_capsule_file(u_boot_console, capsule_files) @@ -165,7 +165,7 @@ class TestEfiCapsuleFirmwareFit(): disk_img = efi_capsule_data capsule_files = ['Test105'] with u_boot_console.log.section('Test Case 4-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
diff --git a/test/py/tests/test_efi_capsule/test_capsule_firmware_raw.py b/test/py/tests/test_efi_capsule/test_capsule_firmware_raw.py index 80d791e3de..a5b5c8a385 100644 --- a/test/py/tests/test_efi_capsule/test_capsule_firmware_raw.py +++ b/test/py/tests/test_efi_capsule/test_capsule_firmware_raw.py @@ -8,7 +8,7 @@ This test verifies capsule-on-disk firmware update for raw images
import pytest from capsule_common import ( - setup, + capsule_setup, init_content, place_capsule_file, exec_manual_update, @@ -51,7 +51,7 @@ class TestEfiCapsuleFirmwareRaw: disk_img = efi_capsule_data capsule_files = ['Test03'] with u_boot_console.log.section('Test Case 1-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') init_content(u_boot_console, '150000', 'u-boot.env.old', 'Old') place_capsule_file(u_boot_console, capsule_files) @@ -83,7 +83,7 @@ class TestEfiCapsuleFirmwareRaw: disk_img = efi_capsule_data capsule_files = ['Test01', 'Test02'] with u_boot_console.log.section('Test Case 2-a, before reboot'): - setup(u_boot_console, disk_img, None) + capsule_setup(u_boot_console, disk_img, None) init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') init_content(u_boot_console, '150000', 'u-boot.env.old', 'Old') place_capsule_file(u_boot_console, capsule_files) @@ -111,7 +111,7 @@ class TestEfiCapsuleFirmwareRaw: disk_img = efi_capsule_data capsule_files = ['Test01', 'Test02'] with u_boot_console.log.section('Test Case 3-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') init_content(u_boot_console, '150000', 'u-boot.env.old', 'Old') place_capsule_file(u_boot_console, capsule_files) @@ -157,7 +157,7 @@ class TestEfiCapsuleFirmwareRaw: disk_img = efi_capsule_data capsule_files = ['Test101', 'Test102'] with u_boot_console.log.section('Test Case 4-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') init_content(u_boot_console, '150000', 'u-boot.env.old', 'Old') place_capsule_file(u_boot_console, capsule_files) @@ -211,7 +211,7 @@ class TestEfiCapsuleFirmwareRaw: disk_img = efi_capsule_data capsule_files = ['Test103'] with u_boot_console.log.section('Test Case 5-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
diff --git a/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py b/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py index 94d6c3eef0..44a58baa31 100644 --- a/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py +++ b/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py @@ -11,7 +11,7 @@ with signed capsule files containing FIT images
import pytest from capsule_common import ( - setup, + capsule_setup, init_content, place_capsule_file, exec_manual_update, @@ -47,7 +47,7 @@ class TestEfiCapsuleFirmwareSignedFit(): disk_img = efi_capsule_data capsule_files = ['Test13'] with u_boot_console.log.section('Test Case 1-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
@@ -76,7 +76,7 @@ class TestEfiCapsuleFirmwareSignedFit(): disk_img = efi_capsule_data capsule_files = ['Test14'] with u_boot_console.log.section('Test Case 2-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
@@ -107,7 +107,7 @@ class TestEfiCapsuleFirmwareSignedFit(): disk_img = efi_capsule_data capsule_files = ['Test02'] with u_boot_console.log.section('Test Case 3-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
@@ -137,7 +137,7 @@ class TestEfiCapsuleFirmwareSignedFit(): disk_img = efi_capsule_data capsule_files = ['Test114'] with u_boot_console.log.section('Test Case 4-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
@@ -176,7 +176,7 @@ class TestEfiCapsuleFirmwareSignedFit(): disk_img = efi_capsule_data capsule_files = ['Test115'] with u_boot_console.log.section('Test Case 5-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
diff --git a/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_raw.py b/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_raw.py index ad2b1c6324..83a10e160b 100644 --- a/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_raw.py +++ b/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_raw.py @@ -9,7 +9,7 @@ with signed capsule files containing raw images
import pytest from capsule_common import ( - setup, + capsule_setup, init_content, place_capsule_file, exec_manual_update, @@ -44,7 +44,7 @@ class TestEfiCapsuleFirmwareSignedRaw(): disk_img = efi_capsule_data capsule_files = ['Test11'] with u_boot_console.log.section('Test Case 1-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
@@ -72,7 +72,7 @@ class TestEfiCapsuleFirmwareSignedRaw(): disk_img = efi_capsule_data capsule_files = ['Test12'] with u_boot_console.log.section('Test Case 2-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
@@ -101,7 +101,7 @@ class TestEfiCapsuleFirmwareSignedRaw(): disk_img = efi_capsule_data capsule_files = ['Test02'] with u_boot_console.log.section('Test Case 3-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
@@ -131,7 +131,7 @@ class TestEfiCapsuleFirmwareSignedRaw(): disk_img = efi_capsule_data capsule_files = ['Test111', 'Test112'] with u_boot_console.log.section('Test Case 4-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
@@ -175,7 +175,7 @@ class TestEfiCapsuleFirmwareSignedRaw(): disk_img = efi_capsule_data capsule_files = ['Test113'] with u_boot_console.log.section('Test Case 5-a, before reboot'): - setup(u_boot_console, disk_img, '0x0000000000000004') + capsule_setup(u_boot_console, disk_img, '0x0000000000000004') init_content(u_boot_console, '100000', 'u-boot.bin.old', 'Old') place_capsule_file(u_boot_console, capsule_files)
Hi Heinrich,
On Sat, 15 Jul 2023 at 03:05, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Would it make sense to reduce the code duplication a little?
Regards, SImon
On 7/16/23 01:40, Simon Glass wrote:
Hi Heinrich,
Thank you for reviewing.
Fixed 482ef90aeb4c ("test: efi_capsule: refactor efi_capsule test") started the de-duplication effort.
Best regards
Heinrich
On Sun, 16 Jul 2023 at 16:37, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Best regards
Heinrich
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Fixes: 482ef90aeb4c ("test: efi_capsule: refactor efi_capsule test") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
