[U-Boot] [PATCH 1/4] net/fman: Add support for 10GEC3 and 10GEC4
There are more than two 10GEC in single FMAN in some SoCs(e.g. T2080). This patch adds support for 10GEC3 and 10GEC4.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- Against master branch of upstream.
arch/powerpc/include/asm/fsl_serdes.h | 2 ++ arch/powerpc/include/asm/immap_85xx.h | 2 ++ drivers/net/fm/eth.c | 8 ++++++-- drivers/net/fm/fm.h | 2 ++ drivers/net/fm/init.c | 18 ++++++++++++++---- include/fm_eth.h | 18 ++++++++++++++++++ 6 files changed, 44 insertions(+), 6 deletions(-)
diff --git a/arch/powerpc/include/asm/fsl_serdes.h b/arch/powerpc/include/asm/fsl_serdes.h index cce892c..404ded4 100644 --- a/arch/powerpc/include/asm/fsl_serdes.h +++ b/arch/powerpc/include/asm/fsl_serdes.h @@ -62,6 +62,8 @@ enum srds_prtcl { QSGMII_FM1_B, /* B indicates MACs 5,6,9,10 */ QSGMII_FM2_A, QSGMII_FM2_B, + XFI_FM1_MAC1, + XFI_FM1_MAC2, XFI_FM1_MAC9, XFI_FM1_MAC10, XFI_FM2_MAC9, diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 060e0d7..e47da1d 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1717,6 +1717,8 @@ typedef struct ccsr_gur { #define FSL_CORENET_DEVDISR2_DTSEC1_10 0x00400000 #define FSL_CORENET_DEVDISR2_10GEC1_1 0x00800000 #define FSL_CORENET_DEVDISR2_10GEC1_2 0x00400000 +#define FSL_CORENET_DEVDISR2_10GEC1_3 0x80000000 +#define FSL_CORENET_DEVDISR2_10GEC1_4 0x40000000 #define FSL_CORENET_DEVDISR2_DTSEC2_1 0x00080000 #define FSL_CORENET_DEVDISR2_DTSEC2_2 0x00040000 #define FSL_CORENET_DEVDISR2_DTSEC2_3 0x00020000 diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index cb099cd..e346cd2 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -557,8 +557,12 @@ static int fm_eth_init_mac(struct fm_eth *fm_eth, struct ccsr_fman *reg) num = fm_eth->num;
#ifdef CONFIG_SYS_FMAN_V3 - if (fm_eth->type == FM_ETH_10G_E) - num += 8; + if (fm_eth->type == FM_ETH_10G_E) { + if (fm_eth->num >= 2) + num -= 2; + else + num += 8; + } base = ®->memac[num].fm_memac; phyregs = ®->memac[num].fm_memac_mdio; #else diff --git a/drivers/net/fm/fm.h b/drivers/net/fm/fm.h index 3ec49a4..43de114 100644 --- a/drivers/net/fm/fm.h +++ b/drivers/net/fm/fm.h @@ -18,9 +18,11 @@ #define RX_PORT_1G_BASE 0x08 #define MAX_NUM_RX_PORT_1G CONFIG_SYS_NUM_FM1_DTSEC #define RX_PORT_10G_BASE 0x10 +#define RX_PORT_10G_BASE2 0x08 #define TX_PORT_1G_BASE 0x28 #define MAX_NUM_TX_PORT_1G CONFIG_SYS_NUM_FM1_DTSEC #define TX_PORT_10G_BASE 0x30 +#define TX_PORT_10G_BASE2 0x28 #define MIIM_TIMEOUT 0xFFFF
struct fm_muram { diff --git a/drivers/net/fm/init.c b/drivers/net/fm/init.c index 35edd7a..cd787f4 100644 --- a/drivers/net/fm/init.c +++ b/drivers/net/fm/init.c @@ -64,6 +64,12 @@ struct fm_eth_info fm_info[] = { #if (CONFIG_SYS_NUM_FM1_10GEC >= 2) FM_TGEC_INFO_INITIALIZER(1, 2), #endif +#if (CONFIG_SYS_NUM_FM1_10GEC >= 3) + FM_TGEC_INFO_INITIALIZER2(1, 3), +#endif +#if (CONFIG_SYS_NUM_FM1_10GEC >= 4) + FM_TGEC_INFO_INITIALIZER2(1, 4), +#endif #if (CONFIG_SYS_NUM_FM2_10GEC >= 1) FM_TGEC_INFO_INITIALIZER(2, 1), #endif @@ -239,10 +245,14 @@ static void ft_fixup_port(void *blob, struct fm_eth_info *info, char *prop) * FM1_10GEC1 is enabled and FM1_DTSEC9 is disabled, ensure that the * dual-role MAC is not disabled, ditto for other dual-role MACs. */ - if (((info->port == FM1_DTSEC9) && (PORT_IS_ENABLED(FM1_10GEC1))) || - ((info->port == FM1_DTSEC10) && (PORT_IS_ENABLED(FM1_10GEC2))) || - ((info->port == FM1_10GEC1) && (PORT_IS_ENABLED(FM1_DTSEC9))) || - ((info->port == FM1_10GEC2) && (PORT_IS_ENABLED(FM1_DTSEC10))) + if (((info->port == FM1_DTSEC9) && (PORT_IS_ENABLED(FM1_10GEC1))) || + ((info->port == FM1_DTSEC10) && (PORT_IS_ENABLED(FM1_10GEC2))) || + ((info->port == FM1_DTSEC1) && (PORT_IS_ENABLED(FM1_10GEC3))) || + ((info->port == FM1_DTSEC2) && (PORT_IS_ENABLED(FM1_10GEC4))) || + ((info->port == FM1_10GEC1) && (PORT_IS_ENABLED(FM1_DTSEC9))) || + ((info->port == FM1_10GEC2) && (PORT_IS_ENABLED(FM1_DTSEC10))) || + ((info->port == FM1_10GEC3) && (PORT_IS_ENABLED(FM1_DTSEC1))) || + ((info->port == FM1_10GEC4) && (PORT_IS_ENABLED(FM1_DTSEC2))) #if (CONFIG_SYS_NUM_FMAN == 2) || ((info->port == FM2_DTSEC9) && (PORT_IS_ENABLED(FM2_10GEC1))) || diff --git a/include/fm_eth.h b/include/fm_eth.h index 5a4fb70..98edfcf 100644 --- a/include/fm_eth.h +++ b/include/fm_eth.h @@ -22,6 +22,8 @@ enum fm_port { FM1_DTSEC10, FM1_10GEC1, FM1_10GEC2, + FM1_10GEC3, + FM1_10GEC4, FM2_DTSEC1, FM2_DTSEC2, FM2_DTSEC3, @@ -85,6 +87,22 @@ enum fm_eth_type { .compat_offset = CONFIG_SYS_FSL_FM##idx##_OFFSET + \ offsetof(struct ccsr_fman, memac[n-1+8]),\ } + +#if (CONFIG_SYS_NUM_FM1_10GEC >= 3) +#define FM_TGEC_INFO_INITIALIZER2(idx, n) \ +{ \ + FM_ETH_INFO_INITIALIZER(idx, CONFIG_SYS_FM1_TGEC_MDIO_ADDR) \ + .index = idx, \ + .num = n - 1, \ + .type = FM_ETH_10G_E, \ + .port = FM##idx##_10GEC##n, \ + .rx_port_id = RX_PORT_10G_BASE2 + n - 3, \ + .tx_port_id = TX_PORT_10G_BASE2 + n - 3, \ + .compat_offset = CONFIG_SYS_FSL_FM##idx##_OFFSET + \ + offsetof(struct ccsr_fman, memac[n-1-2]),\ +} +#endif + #else #define FM_DTSEC_INFO_INITIALIZER(idx, n) \ { \
- XFI_FM1_MAC1,
- XFI_FM1_MAC2, XFI_FM1_MAC9, XFI_FM1_MAC10, XFI_FM2_MAC9,
num += 8;
- if (fm_eth->type == FM_ETH_10G_E) {
num -= 2;
else
num += 8;
It would be nice if you can add some comments here.
- FM_TGEC_INFO_INITIALIZER2(1, 3),
- FM_TGEC_INFO_INITIALIZER2(1, 4),
Revise this comment to match your change.
York
-----Original Message----- From: York Sun [mailto:yorksun@freescale.com] Sent: Friday, November 22, 2013 1:51 AM To: Liu Shengzhou-B36685; u-boot@lists.denx.de Subject: Re: [PATCH 1/4] net/fman: Add support for 10GEC3 and 10GEC4
num += 8;
num -= 2;
else
num += 8;
[Shengzhou] ok, will do.
*info, char *prop)
[Shengzhou] This comment doesn't need to revise, the comment takes FM1_10GEC1 an example, then "ditto for other dual-role MACs", it still matches the change of this patch. Thanks.
Shengzhou Liu
York Sun
