[U-Boot] [PATCH] drivers/mmc/fsl_esdhc: Set the eSHDC DMACTL[SNOOP] bit after the completion of Host Controller reset.
eSDHC host controller reset results in clearing of snoop bit also. This patch sets the SNOOP bit after the completion of host controller reset. Without this patch mmc reads are not consistent.
Signed-off-by: P.V.Suresh pala@freescale.com ---
This patch applies to master branch of git://git.denx.de/u-boot.git
drivers/mmc/fsl_esdhc.c | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index a368fe6..57cd4ee 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -384,10 +384,6 @@ static int esdhc_init(struct mmc *mmc) int ret = 0; u8 card_absent;
- /* Enable cache snooping */ - if (cfg && !cfg->no_snoop) - esdhc_write32(®s->scr, 0x00000040); - /* Reset the entire host controller */ esdhc_write32(®s->sysctl, SYSCTL_RSTA);
@@ -395,6 +391,10 @@ static int esdhc_init(struct mmc *mmc) while ((esdhc_read32(®s->sysctl) & SYSCTL_RSTA) && --timeout) udelay(1000);
+ /* Enable cache snooping */ + if (cfg && !cfg->no_snoop) + esdhc_write32(®s->scr, 0x00000040); + esdhc_write32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN);
/* Set the initial clock speed */
applied to 85xx
[shortened the commit one liner]
- k
Kumar Gala
P.V.Suresh
