[PATCH 00/14] arm: dts: k3-j7200: Sync with kernel.org
Nishanth Menon posted a series to sync between uboot and kernel dt for AM64 SOC. https://lore.kernel.org/u-boot/20230414075726.387461-1-nm@ti.com/
This patch series extend that work to J7200 SOC.
Linux device tree changes for J7200 are posted to Linux list
https://lore.kernel.org/all/20230426103219.1565266-1-u-kumar1@ti.com/
Keerthy (1): arch: arm: dts: k3-j7200: Fix physical address of pin
Nishanth Menon (1): arm: dts: k3-j7200: Update devicetree to sync with v6.3-rc6
Udit Kumar (11): arch: arm: dts: k3-j7200-som: Enable I2C arch: arm: dts: k3-j7200: Add general purpose timers arch: arm: dts: k3-j7200: Configure pinctrl for timer IO pad arch: arm: dts: k3-j7200 move main_pmx to common file arch: arm: dts: k3-j7200 move wkup_pmx to common file arch: arm: dts: k3-j7200 cleanup r5 and uboot dts arch: arm: dts: k3-j7200: remove duplicate usb nodes arch: arm: dts: k3-7200: cleanup r5 i2c node arch: arm: dts: k3-j7200: removed unused clock node arch: arm: dts: k3-j7200: cleanup hmbc node arch: arm: dts: k3-j7200 rearrange bootph property in various node
Vaishnav Achath (1): arch: arm: dts: k3-j7200: Add MCSPI nodes
.../k3-j7200-common-proc-board-u-boot.dtsi | 98 +--- arch/arm/dts/k3-j7200-common-proc-board.dts | 133 +++--- arch/arm/dts/k3-j7200-main.dtsi | 421 +++++++++++++++++- arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 242 +++++++++- .../arm/dts/k3-j7200-r5-common-proc-board.dts | 165 +------ arch/arm/dts/k3-j7200-som-p0.dtsi | 74 ++- arch/arm/dts/k3-j7200.dtsi | 10 +- 7 files changed, 778 insertions(+), 365 deletions(-)
Sync with Kernel.org v6.3-rc6 tag.
Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/dts/k3-j7200-common-proc-board.dts | 63 +++++++----------- arch/arm/dts/k3-j7200-main.dtsi | 72 +++++++++++++++++++-- arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 59 +++++++++++++++-- arch/arm/dts/k3-j7200-som-p0.dtsi | 46 +------------ arch/arm/dts/k3-j7200.dtsi | 10 ++- 5 files changed, 154 insertions(+), 96 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index d14f3c18b6..0d39d6b8cc 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -12,6 +12,9 @@ #include <dt-bindings/phy/phy.h>
/ { + compatible = "ti,j7200-evm", "ti,j7200"; + model = "Texas Instruments J7200 EVM"; + chosen { stdout-path = "serial2:115200n8"; bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000"; @@ -77,7 +80,7 @@ }; };
-&wkup_pmx0 { +&wkup_pmx2 { mcu_cpsw_pins_default: mcu-cpsw-pins-default { pinctrl-single,pins = < J721E_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */ @@ -131,15 +134,17 @@ >; };
- main_usbss0_pins_default: main-usbss0-pins-default { + vdd_sd_dv_pins_default: vdd-sd-dv-pins-default { pinctrl-single,pins = < - J721E_IOPAD(0x120, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */ + J721E_IOPAD(0xd0, PIN_OUTPUT, 7) /* (T5) SPI0_D1.GPIO0_55 */ >; }; +};
- vdd_sd_dv_pins_default: vdd-sd-dv-pins-default { +&main_pmx1 { + main_usbss0_pins_default: main-usbss0-pins-default { pinctrl-single,pins = < - J721E_IOPAD(0xd0, PIN_OUTPUT, 7) /* (T5) SPI0_D1.GPIO0_55 */ + J721E_IOPAD(0x04, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */ >; }; }; @@ -149,51 +154,27 @@ status = "reserved"; };
+&mcu_uart0 { + status = "okay"; + /* Default pinmux */ +}; + &main_uart0 { + status = "okay"; /* Shared with ATF on this platform */ power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; };
+&main_uart1 { + status = "okay"; + /* Default pinmux */ +}; + &main_uart2 { /* MAIN UART 2 is used by R5F firmware */ status = "reserved"; };
-&main_uart3 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart4 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart5 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart6 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart7 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart8 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart9 { - /* UART not brought out */ - status = "disabled"; -}; - &main_gpio2 { status = "disabled"; }; @@ -229,6 +210,7 @@ };
&main_i2c0 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; clock-frequency = <400000>; @@ -256,6 +238,7 @@ * The i2c1 of the CPB (as it is labeled) is not connected to j7200. */ &main_i2c1 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c1_pins_default>; clock-frequency = <400000>; diff --git a/arch/arm/dts/k3-j7200-main.dtsi b/arch/arm/dts/k3-j7200-main.dtsi index e8a41d09b4..138381f43c 100644 --- a/arch/arm/dts/k3-j7200-main.dtsi +++ b/arch/arm/dts/k3-j7200-main.dtsi @@ -32,7 +32,7 @@ #size-cells = <1>; ranges = <0x00 0x00 0x00100000 0x1c000>;
- serdes_ln_ctrl: serdes-ln-ctrl@4080 { + serdes_ln_ctrl: mux-controller@4080 { compatible = "mmio-mux"; #mux-control-cells = <1>; mux-reg-masks = <0x4080 0x3>, <0x4084 0x3>, /* SERDES0 lane0/1 select */ @@ -54,7 +54,10 @@ #interrupt-cells = <3>; interrupt-controller; reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */ - <0x00 0x01900000 0x00 0x100000>; /* GICR */ + <0x00 0x01900000 0x00 0x100000>, /* GICR */ + <0x00 0x6f000000 0x00 0x2000>, /* GICC */ + <0x00 0x6f010000 0x00 0x1000>, /* GICH */ + <0x00 0x6f020000 0x00 0x2000>; /* GICV */
/* vcpumntirq: virtual CPU interface maintenance interrupt */ interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; @@ -139,6 +142,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster1: mailbox@31f81000 { @@ -148,6 +152,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster2: mailbox@31f82000 { @@ -157,6 +162,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster3: mailbox@31f83000 { @@ -166,6 +172,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster4: mailbox@31f84000 { @@ -175,6 +182,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster5: mailbox@31f85000 { @@ -184,6 +192,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster6: mailbox@31f86000 { @@ -193,6 +202,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster7: mailbox@31f87000 { @@ -202,6 +212,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster8: mailbox@31f88000 { @@ -211,6 +222,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster9: mailbox@31f89000 { @@ -220,6 +232,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster10: mailbox@31f8a000 { @@ -229,6 +242,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster11: mailbox@31f8b000 { @@ -238,6 +252,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
main_ringacc: ringacc@3c000000 { @@ -292,7 +307,16 @@ main_pmx0: pinctrl@11c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */ - reg = <0x00 0x11c000 0x00 0x2b4>; + reg = <0x00 0x11c000 0x00 0x10c>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + main_pmx1: pinctrl@11c11c { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x11c11c 0x00 0xc>; #pinctrl-cells = <1>; pinctrl-single,register-width = <32>; pinctrl-single,function-mask = <0xffffffff>; @@ -307,6 +331,7 @@ power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 146 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart1: serial@2810000 { @@ -318,6 +343,7 @@ power-domains = <&k3_pds 278 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 278 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart2: serial@2820000 { @@ -329,6 +355,7 @@ power-domains = <&k3_pds 279 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 279 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart3: serial@2830000 { @@ -340,6 +367,7 @@ power-domains = <&k3_pds 280 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 280 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart4: serial@2840000 { @@ -351,6 +379,7 @@ power-domains = <&k3_pds 281 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 281 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart5: serial@2850000 { @@ -362,6 +391,7 @@ power-domains = <&k3_pds 282 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 282 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart6: serial@2860000 { @@ -373,6 +403,7 @@ power-domains = <&k3_pds 283 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 283 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart7: serial@2870000 { @@ -384,6 +415,7 @@ power-domains = <&k3_pds 284 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 284 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart8: serial@2880000 { @@ -395,6 +427,7 @@ power-domains = <&k3_pds 285 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 285 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart9: serial@2890000 { @@ -406,6 +439,7 @@ power-domains = <&k3_pds 286 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 286 2>; clock-names = "fclk"; + status = "disabled"; };
main_i2c0: i2c@2000000 { @@ -417,6 +451,7 @@ clock-names = "fck"; clocks = <&k3_clks 187 1>; power-domains = <&k3_pds 187 TI_SCI_PD_SHARED>; + status = "disabled"; };
main_i2c1: i2c@2010000 { @@ -428,6 +463,7 @@ clock-names = "fck"; clocks = <&k3_clks 188 1>; power-domains = <&k3_pds 188 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c2: i2c@2020000 { @@ -439,6 +475,7 @@ clock-names = "fck"; clocks = <&k3_clks 189 1>; power-domains = <&k3_pds 189 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c3: i2c@2030000 { @@ -450,6 +487,7 @@ clock-names = "fck"; clocks = <&k3_clks 190 1>; power-domains = <&k3_pds 190 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c4: i2c@2040000 { @@ -461,6 +499,7 @@ clock-names = "fck"; clocks = <&k3_clks 191 1>; power-domains = <&k3_pds 191 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c5: i2c@2050000 { @@ -472,6 +511,7 @@ clock-names = "fck"; clocks = <&k3_clks 192 1>; power-domains = <&k3_pds 192 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c6: i2c@2060000 { @@ -483,6 +523,7 @@ clock-names = "fck"; clocks = <&k3_clks 193 1>; power-domains = <&k3_pds 193 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_sdhci0: mmc@4f80000 { @@ -606,10 +647,10 @@ clock-names = "fck"; #address-cells = <3>; #size-cells = <2>; - bus-range = <0x0 0xf>; + bus-range = <0x0 0xff>; cdns,no-bar-match-nbits = <64>; - vendor-id = /bits/ 16 <0x104c>; - device-id = /bits/ 16 <0xb00f>; + vendor-id = <0x104c>; + device-id = <0xb00f>; msi-map = <0x0 &gic_its 0x0 0x10000>; dma-coherent; ranges = <0x01000000 0x0 0x18001000 0x00 0x18001000 0x0 0x0010000>, @@ -633,6 +674,7 @@ clocks = <&k3_clks 240 6>; clock-names = "fck"; max-functions = /bits/ 8 <6>; + max-virtual-functions = /bits/ 8 <4 4 4 4 0 0>; dma-coherent; };
@@ -735,6 +777,24 @@ clock-names = "gpio"; };
+ watchdog0: watchdog@2200000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x0 0x2200000 0x0 0x100>; + clocks = <&k3_clks 252 1>; + power-domains = <&k3_pds 252 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 252 1>; + assigned-clock-parents = <&k3_clks 252 5>; + }; + + watchdog1: watchdog@2210000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x0 0x2210000 0x0 0x100>; + clocks = <&k3_clks 253 1>; + power-domains = <&k3_pds 253 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 253 1>; + assigned-clock-parents = <&k3_clks 253 5>; + }; + main_r5fss0: r5fss@5c00000 { compatible = "ti,j7200-r5fss"; ti,cluster-mode = <1>; diff --git a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi index 1044ec6c4b..de56a0165b 100644 --- a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi @@ -12,8 +12,8 @@
mbox-names = "rx", "tx";
- mboxes= <&secure_proxy_main 11>, - <&secure_proxy_main 13>; + mboxes = <&secure_proxy_main 11>, + <&secure_proxy_main 13>;
reg-names = "debug_messages"; reg = <0x00 0x44083000 0x00 0x1000>; @@ -56,7 +56,34 @@ wkup_pmx0: pinctrl@4301c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */ - reg = <0x00 0x4301c000 0x00 0x178>; + reg = <0x00 0x4301c000 0x00 0x34>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_pmx1: pinctrl@0x4301c038 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c038 0x00 0x8>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_pmx2: pinctrl@0x4301c068 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c068 0x00 0xec>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_pmx3: pinctrl@0x4301c174 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c174 0x00 0x20>; #pinctrl-cells = <1>; pinctrl-single,register-width = <32>; pinctrl-single,function-mask = <0xffffffff>; @@ -79,6 +106,7 @@ power-domains = <&k3_pds 287 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 287 2>; clock-names = "fclk"; + status = "disabled"; };
mcu_uart0: serial@40a00000 { @@ -90,6 +118,7 @@ power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 149 2>; clock-names = "fclk"; + status = "disabled"; };
wkup_gpio_intr: interrupt-controller@42200000 { @@ -249,6 +278,7 @@ clock-names = "fck"; clocks = <&k3_clks 194 1>; power-domains = <&k3_pds 194 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
mcu_i2c1: i2c@40b10000 { @@ -260,6 +290,7 @@ clock-names = "fck"; clocks = <&k3_clks 195 1>; power-domains = <&k3_pds 195 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
wkup_i2c0: i2c@42120000 { @@ -271,6 +302,7 @@ clock-names = "fck"; clocks = <&k3_clks 197 1>; power-domains = <&k3_pds 197 TI_SCI_PD_SHARED>; + status = "disabled"; };
fss: syscon@47000000 { @@ -325,7 +357,7 @@ clocks = <&k3_clks 0 1>; assigned-clocks = <&k3_clks 0 3>; assigned-clock-rates = <60000000>; - clock-names = "adc_tsc_fck"; + clock-names = "fck"; dmas = <&main_udmap 0x7400>, <&main_udmap 0x7401>; dma-names = "fifo0", "fifo1"; @@ -375,4 +407,23 @@ ti,loczrama = <1>; }; }; + + mcu_crypto: crypto@40900000 { + compatible = "ti,j721e-sa2ul"; + reg = <0x00 0x40900000 0x00 0x1200>; + power-domains = <&k3_pds 265 TI_SCI_PD_SHARED>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x00 0x40900000 0x00 0x40900000 0x00 0x30000>; + dmas = <&mcu_udmap 0xf501>, <&mcu_udmap 0x7502>, + <&mcu_udmap 0x7503>; + dma-names = "tx", "rx1", "rx2"; + + rng: rng@40910000 { + compatible = "inside-secure,safexcel-eip76"; + reg = <0x00 0x40910000 0x00 0x7d>; + interrupts = <GIC_SPI 945 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; /* Used by OP-TEE */ + }; + }; }; diff --git a/arch/arm/dts/k3-j7200-som-p0.dtsi b/arch/arm/dts/k3-j7200-som-p0.dtsi index 3472444017..fa44ed4c17 100644 --- a/arch/arm/dts/k3-j7200-som-p0.dtsi +++ b/arch/arm/dts/k3-j7200-som-p0.dtsi @@ -144,6 +144,7 @@ };
&mailbox0_cluster0 { + status = "okay"; interrupts = <436>;
mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 { @@ -158,6 +159,7 @@ };
&mailbox0_cluster1 { + status = "okay"; interrupts = <432>;
mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 { @@ -171,46 +173,6 @@ }; };
-&mailbox0_cluster2 { - status = "disabled"; -}; - -&mailbox0_cluster3 { - status = "disabled"; -}; - -&mailbox0_cluster4 { - status = "disabled"; -}; - -&mailbox0_cluster5 { - status = "disabled"; -}; - -&mailbox0_cluster6 { - status = "disabled"; -}; - -&mailbox0_cluster7 { - status = "disabled"; -}; - -&mailbox0_cluster8 { - status = "disabled"; -}; - -&mailbox0_cluster9 { - status = "disabled"; -}; - -&mailbox0_cluster10 { - status = "disabled"; -}; - -&mailbox0_cluster11 { - status = "disabled"; -}; - &mcu_r5fss0_core0 { mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core0>; memory-region = <&mcu_r5fss0_core0_dma_memory_region>, @@ -256,7 +218,7 @@ pinctrl-names = "default"; pinctrl-0 = <&mcu_fss0_ospi0_pins_default>;
- flash@0{ + flash@0 { compatible = "jedec,spi-nor"; reg = <0x0>; spi-tx-bus-width = <8>; @@ -267,7 +229,5 @@ cdns,tchsh-ns = <60>; cdns,tslch-ns = <60>; cdns,read-delay = <4>; - #address-cells = <1>; - #size-cells = <1>; }; }; diff --git a/arch/arm/dts/k3-j7200.dtsi b/arch/arm/dts/k3-j7200.dtsi index b7005b8031..d74f86b0f6 100644 --- a/arch/arm/dts/k3-j7200.dtsi +++ b/arch/arm/dts/k3-j7200.dtsi @@ -30,6 +30,8 @@ serial9 = &main_uart7; serial10 = &main_uart8; serial11 = &main_uart9; + mmc0 = &main_sdhci0; + mmc1 = &main_sdhci1; };
chosen { }; @@ -60,7 +62,7 @@ i-cache-sets = <256>; d-cache-size = <0x8000>; d-cache-line-size = <64>; - d-cache-sets = <128>; + d-cache-sets = <256>; next-level-cache = <&L2_0>; };
@@ -74,7 +76,7 @@ i-cache-sets = <256>; d-cache-size = <0x8000>; d-cache-line-size = <64>; - d-cache-sets = <128>; + d-cache-sets = <256>; next-level-cache = <&L2_0>; }; }; @@ -82,9 +84,10 @@ L2_0: l2-cache0 { compatible = "cache"; cache-level = <2>; + cache-unified; cache-size = <0x100000>; cache-line-size = <64>; - cache-sets = <2048>; + cache-sets = <1024>; next-level-cache = <&msmc_l3>; };
@@ -127,6 +130,7 @@ <0x00 0x00a40000 0x00 0x00a40000 0x00 0x00000800>, /* timesync router */ <0x00 0x01000000 0x00 0x01000000 0x00 0x0d000000>, /* Most peripherals */ <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>, /* MAIN NAVSS */ + <0x00 0x6f000000 0x00 0x6f000000 0x00 0x00310000>, /* A72 PERIPHBASE */ <0x00 0x70000000 0x00 0x70000000 0x00 0x00800000>, /* MSMC RAM */ <0x00 0x18000000 0x00 0x18000000 0x00 0x08000000>, /* PCIe1 DAT0 */ <0x41 0x00000000 0x41 0x00000000 0x01 0x00000000>, /* PCIe1 DAT1 */
we are few days away from rc1 tag. I'd rather we refresh.
- compatible = "ti,j7200-evm", "ti,j7200";
- model = "Texas Instruments J7200 EVM";
- chosen { stdout-path = "serial2:115200n8"; bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
- vdd_sd_dv_pins_default: vdd-sd-dv-pins-default { pinctrl-single,pins = <
+&main_pmx1 {
- main_usbss0_pins_default: main-usbss0-pins-default { pinctrl-single,pins = <
;};}; @@ -149,51 +154,27 @@ status = "reserved"; };
+&mcu_uart0 {
- status = "okay";
- /* Default pinmux */
&main_uart0 {
- status = "okay"; /* Shared with ATF on this platform */ power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>;
+&main_uart1 {
- status = "okay";
-&main_uart3 {
-&main_uart4 {
-&main_uart5 {
-&main_uart6 {
-&main_uart7 {
-&main_uart8 {
-&main_uart9 {
&main_i2c0 {
- status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; clock-frequency = <400000>;
@@ -256,6 +238,7 @@
- The i2c1 of the CPB (as it is labeled) is not connected to j7200.
*/ &main_i2c1 {
- status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c1_pins_default>; clock-frequency = <400000>;
- main_pmx1: pinctrl@11c11c {
#pinctrl-cells = <1>; pinctrl-single,register-width = <32>; pinctrl-single,function-mask = <0xffffffff>;reg = <0x00 0x11c11c 0x00 0xc>;
cdns,no-bar-match-nbits = <64>;bus-range = <0x0 0xff>;
msi-map = <0x0 &gic_its 0x0 0x10000>; dma-coherent; ranges = <0x01000000 0x0 0x18001000 0x00 0x18001000 0x0 0x0010000>,device-id = <0xb00f>;
dma-coherent; };max-virtual-functions = /bits/ 8 <4 4 4 4 0 0>;
- watchdog0: watchdog@2200000 {
- watchdog1: watchdog@2210000 {
- main_r5fss0: r5fss@5c00000 { compatible = "ti,j7200-r5fss"; ti,cluster-mode = <1>;
- wkup_pmx1: pinctrl@0x4301c038 {
- wkup_pmx2: pinctrl@0x4301c068 {
- wkup_pmx3: pinctrl@0x4301c174 {
#pinctrl-cells = <1>; pinctrl-single,register-width = <32>; pinctrl-single,function-mask = <0xffffffff>;reg = <0x00 0x4301c174 0x00 0x20>;
dmas = <&main_udmap 0x7400>, <&main_udmap 0x7401>; dma-names = "fifo0", "fifo1";clock-names = "fck";
- mcu_crypto: crypto@40900000 {
#size-cells = <2>;
rng: rng@40910000 {
- flash@0{
- flash@0 { compatible = "jedec,spi-nor"; reg = <0x0>; spi-tx-bus-width = <8>;
};#size-cells = <1>;
chosen { };
};d-cache-sets = <256>; next-level-cache = <&L2_0>;
}; };d-cache-sets = <256>; next-level-cache = <&L2_0>;
cache-size = <0x100000>; cache-line-size = <64>;cache-unified;
next-level-cache = <&msmc_l3>; };cache-sets = <1024>;
-- 2.34.1
Thanks
wkup_pmx splits into multiple regions. Like
wkup_pmx0 -> 13 pins (WKUP_PADCONFIG 0 - 12) wkup_pmx1 -> 2 pins (WKUP_PADCONFIG 14 - 15) wkup_pmx2 -> 59 pins (WKUP_PADCONFIG 26 - 84) wkup_pmx3 -> 8 pins (WKUP_PADCONFIG 93 - 100)
With this split, pin offset needs to be adjusted to match with new pmx for all pins above wkup_pmx0.
Example a pin under wkup_pmx1 should start from 0 instead of old offset(0x38 WKUP_PADCONFIG 14 offset)
J7200 Datasheet (Table 6-106, Section 6.4 Pin Multiplexing) : https://www.ti.com/lit/ds/symlink/dra821u.pdf
Signed-off-by: Keerthy j-keerthy@ti.com Signed-off-by: Udit Kumar u-kumar1@ti.com --- arch/arm/dts/k3-j7200-common-proc-board.dts | 28 ++++++++++----------- 1 file changed, 14 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index 0d39d6b8cc..63633e4f6c 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -83,25 +83,25 @@ &wkup_pmx2 { mcu_cpsw_pins_default: mcu-cpsw-pins-default { pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */ - J721E_WKUP_IOPAD(0x006c, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */ - J721E_WKUP_IOPAD(0x0070, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */ - J721E_WKUP_IOPAD(0x0074, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */ - J721E_WKUP_IOPAD(0x0078, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */ - J721E_WKUP_IOPAD(0x007c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */ - J721E_WKUP_IOPAD(0x0088, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */ - J721E_WKUP_IOPAD(0x008c, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */ - J721E_WKUP_IOPAD(0x0090, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */ - J721E_WKUP_IOPAD(0x0094, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */ - J721E_WKUP_IOPAD(0x0080, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */ - J721E_WKUP_IOPAD(0x0084, PIN_INPUT, 0) /* MCU_RGMII1_RXC */ + J721E_WKUP_IOPAD(0x0000, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */ + J721E_WKUP_IOPAD(0x0004, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */ + J721E_WKUP_IOPAD(0x0008, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */ + J721E_WKUP_IOPAD(0x000c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */ + J721E_WKUP_IOPAD(0x0010, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */ + J721E_WKUP_IOPAD(0x0014, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */ + J721E_WKUP_IOPAD(0x0020, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */ + J721E_WKUP_IOPAD(0x0024, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */ + J721E_WKUP_IOPAD(0x0028, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */ + J721E_WKUP_IOPAD(0x002c, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */ + J721E_WKUP_IOPAD(0x0018, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */ + J721E_WKUP_IOPAD(0x001c, PIN_INPUT, 0) /* MCU_RGMII1_RXC */ >; };
mcu_mdio_pins_default: mcu-mdio1-pins-default { pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x009c, PIN_OUTPUT, 0) /* (L1) MCU_MDIO0_MDC */ - J721E_WKUP_IOPAD(0x0098, PIN_INPUT, 0) /* (L4) MCU_MDIO0_MDIO */ + J721E_WKUP_IOPAD(0x0034, PIN_OUTPUT, 0) /* (L1) MCU_MDIO0_MDC */ + J721E_WKUP_IOPAD(0x0030, PIN_INPUT, 0) /* (L4) MCU_MDIO0_MDIO */ >; }; };
2.34.1
Not in upstream k.org. NAK.
Upstream linux patch posted at https://lore.kernel.org/all/20230419040007.3022780-3-u-kumar1@ti.com/
This patch enables wkup_i2c0 node in board dts file along with pin mux and speed. Also enables underneath eeprom CAV24C256WE.
J7200 User Guide (Section 4.3, Table 4-2) : https://www.ti.com/lit/ug/spruiw7a/spruiw7a.pdf
Signed-off-by: Udit Kumar u-kumar1@ti.com --- .../arm/dts/k3-j7200-r5-common-proc-board.dts | 7 ------- arch/arm/dts/k3-j7200-som-p0.dtsi | 21 +++++++++++++++++++ 2 files changed, 21 insertions(+), 7 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index e62f9218e8..9d9ffcbb89 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -126,13 +126,6 @@ >; };
- wkup_i2c0_pins_default: wkup-i2c0-pins-default { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x100, PIN_INPUT_PULLUP, 0) /* (F20) WKUP_I2C0_SCL */ - J721E_WKUP_IOPAD(0x104, PIN_INPUT_PULLUP, 0) /* (H21) WKUP_I2C0_SDA */ - >; - }; - mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-pins-default { pinctrl-single,pins = < J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 1) /* (E20) MCU_OSPI0_CLK.MCU_HYPERBUS0_CK */ diff --git a/arch/arm/dts/k3-j7200-som-p0.dtsi b/arch/arm/dts/k3-j7200-som-p0.dtsi index fa44ed4c17..2694241547 100644 --- a/arch/arm/dts/k3-j7200-som-p0.dtsi +++ b/arch/arm/dts/k3-j7200-som-p0.dtsi @@ -118,6 +118,15 @@ }; };
+&wkup_pmx2 { + wkup_i2c0_pins_default: wkup-i2c0-pins-default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x98, PIN_INPUT_PULLUP, 0) /* (F20) WKUP_I2C0_SCL */ + J721E_WKUP_IOPAD(0x9c, PIN_INPUT_PULLUP, 0) /* (H21) WKUP_I2C0_SDA */ + >; + }; +}; + &main_pmx0 { main_i2c0_pins_default: main-i2c0-pins-default { pinctrl-single,pins = < @@ -214,6 +223,18 @@ }; };
+&wkup_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_i2c0_pins_default>; + clock-frequency = <400000>; + + eeprom@50 { + compatible = "atmel,24c256"; + reg = <0x50>; + }; +}; + &ospi0 { pinctrl-names = "default"; pinctrl-0 = <&mcu_fss0_ospi0_pins_default>;
a) link here does'nt belong to commit message. b) Let this be accepted into k.org master prior to u-boot sync.
+&wkup_pmx2 {
+&wkup_i2c0 {
- status = "okay";
- pinctrl-names = "default";
- pinctrl-0 = <&wkup_i2c0_pins_default>;
- clock-frequency = <400000>;
- eeprom@50 {
reg = <0x50>;
&ospi0 { pinctrl-names = "default"; pinctrl-0 = <&mcu_fss0_ospi0_pins_default>; -- 2.34.1
There are 20 general purpose timers on j7200 that can be used for things like PWM using pwm-omap-dmtimer driver. There are also additional ten timers in the MCU domain.
MCU timer 0 is used by R5 uboot as always on. So change properties in u-boot specific files
Signed-off-by: Udit Kumar u-kumar1@ti.com --- .../k3-j7200-common-proc-board-u-boot.dtsi | 7 + arch/arm/dts/k3-j7200-main.dtsi | 240 ++++++++++++++++++ arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 130 ++++++++++ 3 files changed, 377 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index f57c2306ba..789dc54617 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -30,7 +30,14 @@ bootph-pre-ram;
timer1: timer@40400000 { + /delete-property/ clocks; + /delete-property/ clock-name; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + /delete-property/ power-domains; + /delete-property/ ti,timer-pwm; compatible = "ti,omap5430-timer"; + status = "okay"; reg = <0x0 0x40400000 0x0 0x80>; ti,timer-alwon; clock-frequency = <250000000>; diff --git a/arch/arm/dts/k3-j7200-main.dtsi b/arch/arm/dts/k3-j7200-main.dtsi index 138381f43c..54795db9c3 100644 --- a/arch/arm/dts/k3-j7200-main.dtsi +++ b/arch/arm/dts/k3-j7200-main.dtsi @@ -795,6 +795,246 @@ assigned-clock-parents = <&k3_clks 253 5>; };
+ main_timer0: timer@2400000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2400000 0x00 0x400>; + interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 49 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 49 1>; + assigned-clock-parents = <&k3_clks 49 2>; + power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer1: timer@2410000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2410000 0x00 0x400>; + interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 50 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 50 1>; + assigned-clock-parents = <&k3_clks 50 2>; + power-domains = <&k3_pds 50 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer2: timer@2420000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2420000 0x00 0x400>; + interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 51 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 51 1>; + assigned-clock-parents = <&k3_clks 51 2>; + power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer3: timer@2430000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2430000 0x00 0x400>; + interrupts = <GIC_SPI 227 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 52 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 52 1>; + assigned-clock-parents = <&k3_clks 52 2>; + power-domains = <&k3_pds 52 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer4: timer@2440000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2440000 0x00 0x400>; + interrupts = <GIC_SPI 228 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 53 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 53 1>; + assigned-clock-parents = <&k3_clks 53 2>; + power-domains = <&k3_pds 53 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer5: timer@2450000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2450000 0x00 0x400>; + interrupts = <GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 54 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 54 1>; + assigned-clock-parents = <&k3_clks 54 2>; + power-domains = <&k3_pds 54 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer6: timer@2460000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2460000 0x00 0x400>; + interrupts = <GIC_SPI 230 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 55 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 55 1>; + assigned-clock-parents = <&k3_clks 55 2>; + power-domains = <&k3_pds 55 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer7: timer@2470000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2470000 0x00 0x400>; + interrupts = <GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 57 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 57 1>; + assigned-clock-parents = <&k3_clks 57 2>; + power-domains = <&k3_pds 57 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer8: timer@2480000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2480000 0x00 0x400>; + interrupts = <GIC_SPI 232 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 58 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 58 1>; + assigned-clock-parents = <&k3_clks 58 2>; + power-domains = <&k3_pds 58 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer9: timer@2490000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2490000 0x00 0x400>; + interrupts = <GIC_SPI 233 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 59 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 59 1>; + assigned-clock-parents = <&k3_clks 59 2>; + power-domains = <&k3_pds 59 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer10: timer@24a0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24a0000 0x00 0x400>; + interrupts = <GIC_SPI 234 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 60 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 60 1>; + assigned-clock-parents = <&k3_clks 60 2>; + power-domains = <&k3_pds 60 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer11: timer@24b0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24b0000 0x00 0x400>; + interrupts = <GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 62 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 62 1>; + assigned-clock-parents = <&k3_clks 62 2>; + power-domains = <&k3_pds 62 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer12: timer@24c0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24c0000 0x00 0x400>; + interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 63 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 63 1>; + assigned-clock-parents = <&k3_clks 63 2>; + power-domains = <&k3_pds 63 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer13: timer@24d0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24d0000 0x00 0x400>; + interrupts = <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 63 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 63 1>; + assigned-clock-parents = <&k3_clks 63 2>; + power-domains = <&k3_pds 63 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer14: timer@24e0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24e0000 0x00 0x400>; + interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 65 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 65 1>; + assigned-clock-parents = <&k3_clks 65 2>; + power-domains = <&k3_pds 65 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer15: timer@24f0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24f0000 0x00 0x400>; + interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 66 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 66 1>; + assigned-clock-parents = <&k3_clks 66 2>; + power-domains = <&k3_pds 66 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer16: timer@2500000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2500000 0x00 0x400>; + interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 67 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 67 1>; + assigned-clock-parents = <&k3_clks 67 2>; + power-domains = <&k3_pds 67 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer17: timer@2510000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2510000 0x00 0x400>; + interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 68 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 68 1>; + assigned-clock-parents = <&k3_clks 68 2>; + power-domains = <&k3_pds 68 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer18: timer@2520000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2520000 0x00 0x400>; + interrupts = <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 69 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 69 1>; + assigned-clock-parents = <&k3_clks 69 2>; + power-domains = <&k3_pds 69 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer19: timer@2530000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2530000 0x00 0x400>; + interrupts = <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 70 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 70 1>; + assigned-clock-parents = <&k3_clks 70 2>; + power-domains = <&k3_pds 70 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + main_r5fss0: r5fss@5c00000 { compatible = "ti,j7200-r5fss"; ti,cluster-mode = <1>; diff --git a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi index de56a0165b..02c2493064 100644 --- a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi @@ -34,6 +34,136 @@ }; };
+ mcu_timer0: timer@40400000 { + compatible = "ti,am654-timer"; + status = "reserved"; + reg = <0x00 0x40400000 0x00 0x400>; + interrupts = <GIC_SPI 816 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 35 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 35 1>; + assigned-clock-parents = <&k3_clks 35 2>; + power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer1: timer@40410000 { + compatible = "ti,am654-timer"; + status = "reserved"; + reg = <0x00 0x40410000 0x00 0x400>; + interrupts = <GIC_SPI 817 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 71 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 71 1>; + assigned-clock-parents = <&k3_clks 71 2>; + power-domains = <&k3_pds 71 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer2: timer@40420000 { + compatible = "ti,am654-timer"; + status = "reserved"; + reg = <0x00 0x40420000 0x00 0x400>; + interrupts = <GIC_SPI 818 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 72 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 72 1>; + assigned-clock-parents = <&k3_clks 72 2>; + power-domains = <&k3_pds 72 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer3: timer@40430000 { + compatible = "ti,am654-timer"; + status = "reserved"; + reg = <0x00 0x40430000 0x00 0x400>; + interrupts = <GIC_SPI 819 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 73 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 73 1>; + assigned-clock-parents = <&k3_clks 73 2>; + power-domains = <&k3_pds 73 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer4: timer@40440000 { + compatible = "ti,am654-timer"; + status = "reserved"; + reg = <0x00 0x40440000 0x00 0x400>; + interrupts = <GIC_SPI 820 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 74 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 74 1>; + assigned-clock-parents = <&k3_clks 74 2>; + power-domains = <&k3_pds 74 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer5: timer@40450000 { + compatible = "ti,am654-timer"; + status = "reserved"; + reg = <0x00 0x40450000 0x00 0x400>; + interrupts = <GIC_SPI 821 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 75 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 75 1>; + assigned-clock-parents = <&k3_clks 75 2>; + power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer6: timer@40460000 { + compatible = "ti,am654-timer"; + status = "reserved"; + reg = <0x00 0x40460000 0x00 0x400>; + interrupts = <GIC_SPI 822 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 76 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 76 1>; + assigned-clock-parents = <&k3_clks 76 2>; + power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer7: timer@40470000 { + compatible = "ti,am654-timer"; + status = "reserved"; + reg = <0x00 0x40470000 0x00 0x400>; + interrupts = <GIC_SPI 823 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 77 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 77 1>; + assigned-clock-parents = <&k3_clks 77 2>; + power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer8: timer@40480000 { + compatible = "ti,am654-timer"; + status = "reserved"; + reg = <0x00 0x40480000 0x00 0x400>; + interrupts = <GIC_SPI 824 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 78 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 78 1>; + assigned-clock-parents = <&k3_clks 78 2>; + power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer9: timer@40490000 { + compatible = "ti,am654-timer"; + status = "reserved"; + reg = <0x00 0x40490000 0x00 0x400>; + interrupts = <GIC_SPI 825 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 79 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 79 1>; + assigned-clock-parents = <&k3_clks 79 2>; + power-domains = <&k3_pds 79 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + mcu_conf: syscon@40f00000 { compatible = "syscon", "simple-mfd"; reg = <0x00 0x40f00000 0x00 0x20000>;
NAK. upstream k.org first.
compatible = "ti,omap5430-timer";/delete-property/ ti,timer-pwm;
status = "okay";
Curious: Do we need to delete all these properties, cant we get the R5 SPL to work with these?
- main_timer0: timer@2400000 {
ti,timer-pwm;
- main_timer1: timer@2410000 {
ti,timer-pwm;
- main_timer2: timer@2420000 {
ti,timer-pwm;
- main_timer3: timer@2430000 {
ti,timer-pwm;
- main_timer4: timer@2440000 {
ti,timer-pwm;
- main_timer5: timer@2450000 {
ti,timer-pwm;
- main_timer6: timer@2460000 {
ti,timer-pwm;
- main_timer7: timer@2470000 {
ti,timer-pwm;
- main_timer8: timer@2480000 {
ti,timer-pwm;
- main_timer9: timer@2490000 {
ti,timer-pwm;
- main_timer10: timer@24a0000 {
ti,timer-pwm;
- main_timer11: timer@24b0000 {
ti,timer-pwm;
- main_timer12: timer@24c0000 {
ti,timer-pwm;
- main_timer13: timer@24d0000 {
ti,timer-pwm;
- main_timer14: timer@24e0000 {
ti,timer-pwm;
- main_timer15: timer@24f0000 {
ti,timer-pwm;
- main_timer16: timer@2500000 {
ti,timer-pwm;
- main_timer17: timer@2510000 {
ti,timer-pwm;
- main_timer18: timer@2520000 {
ti,timer-pwm;
- main_timer19: timer@2530000 {
ti,timer-pwm;
- mcu_timer0: timer@40400000 {
ti,timer-pwm;
- mcu_timer1: timer@40410000 {
ti,timer-pwm;
- mcu_timer2: timer@40420000 {
ti,timer-pwm;
- mcu_timer3: timer@40430000 {
ti,timer-pwm;
- mcu_timer4: timer@40440000 {
ti,timer-pwm;
- mcu_timer5: timer@40450000 {
ti,timer-pwm;
- mcu_timer6: timer@40460000 {
ti,timer-pwm;
- mcu_timer7: timer@40470000 {
ti,timer-pwm;
- mcu_timer8: timer@40480000 {
ti,timer-pwm;
- mcu_timer9: timer@40490000 {
ti,timer-pwm;
- mcu_conf: syscon@40f00000 { compatible = "syscon", "simple-mfd"; reg = <0x00 0x40f00000 0x00 0x20000>;
-- 2.34.1
There are timer IO pads in the MCU domain, and in the MAIN domain. These pads can be muxed for the related timers.
There are timer IO control registers for input and output. The registers for CTRLMMR_TIMER*_CTRL and CTRLMMR_MCU_TIMER*_CTRL are used to control the input. The registers for CTCTRLMMR_TIMERIO*_CTRL and CTRLMMR_MCU_TIMERIO*_CTRL the output.
The multiplexing is documented in TRM "5.1.2.3.1.4 Timer IO Muxing Control Registers" and "5.1.3.3.1.5 Timer IO Muxing Control Registers", and the CASCADE_EN bit is documented in TRM "12.6.3.1 Timers Overview".
For chaining timers, the timer IO control registers also have a CASCADE_EN input bit in the CTRLMMR_TIMER*_CTRL in the registers. The CASCADE_EN bit muxes the previous timer output, or possibly and external TIMER_IO pad source, to the input clock of the selected timer instance for odd numered timers. For the even numbered timers, the CASCADE_EN bit does not do anything. The timer cascade input routing options are shown in TRM "Figure 12-3224. Timers Overview". For handling beyond multiplexing, the driver support for timer cascading should be likely be handled via the clock framework.
Cc: Nishanth Menon nm@ti.com Cc: Vignesh Raghavendra vigneshr@ti.com Cc: Tony Lindgren tony@atomide.com Signed-off-by: Udit Kumar u-kumar1@ti.com --- arch/arm/dts/k3-j7200-main.dtsi | 18 ++++++++++++++++++ arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 18 ++++++++++++++++++ 2 files changed, 36 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-main.dtsi b/arch/arm/dts/k3-j7200-main.dtsi index 54795db9c3..fb9e4842c1 100644 --- a/arch/arm/dts/k3-j7200-main.dtsi +++ b/arch/arm/dts/k3-j7200-main.dtsi @@ -304,6 +304,24 @@ }; };
+ /* TIMERIO pad input CTRLMMR_TIMER*_CTRL registers */ + main_timerio_input: pinctrl@104200 { + compatible = "pinctrl-single"; + reg = <0x0 0x104200 0x0 0x50>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x000001ff>; + }; + + /* TIMERIO pad output CTCTRLMMR_TIMERIO*_CTRL registers */ + main_timerio_output: pinctrl@104280 { + compatible = "pinctrl-single"; + reg = <0x0 0x104280 0x0 0x20>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000001f>; + }; + main_pmx0: pinctrl@11c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */ diff --git a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi index 02c2493064..7ed6c31c7c 100644 --- a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi @@ -183,6 +183,24 @@ reg = <0x00 0x43000014 0x00 0x4>; };
+ /* MCU_TIMERIO pad input CTRLMMR_MCU_TIMER*_CTRL registers */ + mcu_timerio_input: pinctrl@40f04200 { + compatible = "pinctrl-single"; + reg = <0x0 0x40f04200 0x0 0x28>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000F>; + }; + + /* MCU_TIMERIO pad output CTRLMMR_MCU_TIMERIO*_CTRL registers */ + mcu_timerio_output: pinctrl@40f04280 { + compatible = "pinctrl-single"; + reg = <0x0 0x40f04280 0x0 0x28>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000F>; + }; + wkup_pmx0: pinctrl@4301c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */
- /* TIMERIO pad input CTRLMMR_TIMER*_CTRL registers */
- main_timerio_input: pinctrl@104200 {
- /* TIMERIO pad output CTCTRLMMR_TIMERIO*_CTRL registers */
- main_timerio_output: pinctrl@104280 {
- main_pmx0: pinctrl@11c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */
- /* MCU_TIMERIO pad input CTRLMMR_MCU_TIMER*_CTRL registers */
- mcu_timerio_input: pinctrl@40f04200 {
- /* MCU_TIMERIO pad output CTRLMMR_MCU_TIMERIO*_CTRL registers */
- mcu_timerio_output: pinctrl@40f04280 {
- wkup_pmx0: pinctrl@4301c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */
-- 2.34.1
Needs to get to k.org master.
This patch moves pin mux from r5 dts to common dts file. Along with removing duplicated defines.
Signed-off-by: Udit Kumar u-kumar1@ti.com --- arch/arm/dts/k3-j7200-common-proc-board.dts | 16 ++++-- .../arm/dts/k3-j7200-r5-common-proc-board.dts | 51 +------------------ arch/arm/dts/k3-j7200-som-p0.dtsi | 3 ++ 3 files changed, 17 insertions(+), 53 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index 63633e4f6c..98d1fde4db 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -107,10 +107,15 @@ };
&main_pmx0 { - main_i2c0_pins_default: main-i2c0-pins-default { + bootph-pre-ram; + + main_uart0_pins_default: main_uart0_pins_default { + bootph-pre-ram; pinctrl-single,pins = < - J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */ - J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */ + J721E_IOPAD(0xb0, PIN_INPUT, 0) /* (T16) UART0_RXD */ + J721E_IOPAD(0xb4, PIN_OUTPUT, 0) /* (T17) UART0_TXD */ + J721E_IOPAD(0xc0, PIN_INPUT, 2) /* (W3) SPI0_CS0.UART0_CTSn */ + J721E_IOPAD(0xc4, PIN_OUTPUT, 2) /* (U5) SPI0_CS1.UART0_RTSn */ >; };
@@ -122,6 +127,7 @@ };
main_mmc1_pins_default: main-mmc1-pins-default { + bootph-pre-ram; pinctrl-single,pins = < J721E_IOPAD(0x104, PIN_INPUT, 0) /* (M20) MMC1_CMD */ J721E_IOPAD(0x100, PIN_INPUT, 0) /* (P21) MMC1_CLK */ @@ -142,7 +148,9 @@ };
&main_pmx1 { + bootph-pre-ram; main_usbss0_pins_default: main-usbss0-pins-default { + bootph-pre-ram; pinctrl-single,pins = < J721E_IOPAD(0x04, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */ >; @@ -163,6 +171,8 @@ status = "okay"; /* Shared with ATF on this platform */ power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; + pinctrl-names = "default"; + pinctrl-0 = <&main_uart0_pins_default>; };
&main_uart1 { diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index 9d9ffcbb89..9b42e4d2ca 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -5,7 +5,7 @@
/dts-v1/;
-#include "k3-j7200-som-p0.dtsi" +#include "k3-j7200-common-proc-board.dts" #include "k3-j7200-ddr-evm-lp4-2666.dtsi" #include "k3-j721e-ddr.dtsi"
@@ -152,47 +152,6 @@ }; };
-&main_pmx0 { - bootph-pre-ram; - - main_uart0_pins_default: main_uart0_pins_default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_IOPAD(0xb0, PIN_INPUT, 0) /* (T16) UART0_RXD */ - J721E_IOPAD(0xb4, PIN_OUTPUT, 0) /* (T17) UART0_TXD */ - J721E_IOPAD(0xc0, PIN_INPUT, 2) /* (W3) SPI0_CS0.UART0_CTSn */ - J721E_IOPAD(0xc4, PIN_OUTPUT, 2) /* (U5) SPI0_CS1.UART0_RTSn */ - >; - }; - - main_i2c0_pins_default: main-i2c0-pins-default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */ - J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */ - >; - }; - - main_mmc1_pins_default: main_mmc1_pins_default { - pinctrl-single,pins = < - J721E_IOPAD(0x104, PIN_INPUT, 0) /* (M20) MMC1_CMD */ - J721E_IOPAD(0x100, PIN_INPUT, 0) /* (P21) MMC1_CLK */ - J721E_IOPAD(0xfc, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */ - J721E_IOPAD(0xf8, PIN_INPUT, 0) /* (M19) MMC1_DAT0 */ - J721E_IOPAD(0xf4, PIN_INPUT, 0) /* (N21) MMC1_DAT1 */ - J721E_IOPAD(0xf0, PIN_INPUT, 0) /* (N20) MMC1_DAT2 */ - J721E_IOPAD(0xec, PIN_INPUT, 0) /* (N19) MMC1_DAT3 */ - J721E_IOPAD(0xe4, PIN_INPUT, 8) /* (V1) TIMER_IO0.MMC1_SDCD */ - >; - }; - - main_usbss0_pins_default: main_usbss0_pins_default { - pinctrl-single,pins = < - J721E_IOPAD(0x120, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */ - >; - }; -}; - &wkup_uart0 { bootph-pre-ram; pinctrl-names = "default"; @@ -210,14 +169,6 @@ clock-frequency = <96000000>; };
-&main_uart0 { - status = "okay"; - power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; - pinctrl-names = "default"; - pinctrl-0 = <&main_uart0_pins_default>; - status = "okay"; -}; - &main_sdhci0 { /delete-property/ power-domains; /delete-property/ assigned-clocks; diff --git a/arch/arm/dts/k3-j7200-som-p0.dtsi b/arch/arm/dts/k3-j7200-som-p0.dtsi index 2694241547..7eaa2411a5 100644 --- a/arch/arm/dts/k3-j7200-som-p0.dtsi +++ b/arch/arm/dts/k3-j7200-som-p0.dtsi @@ -128,12 +128,15 @@ };
&main_pmx0 { + main_i2c0_pins_default: main-i2c0-pins-default { + bootph-pre-ram; pinctrl-single,pins = < J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */ J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */ >; }; + };
&hbmc {
&main_pmx0 {
- bootph-pre-ram;
pinctrl-single,pins = <bootph-pre-ram;
;};@@ -122,6 +127,7 @@ };
pinctrl-single,pins = < J721E_IOPAD(0x104, PIN_INPUT, 0) /* (M20) MMC1_CMD */ J721E_IOPAD(0x100, PIN_INPUT, 0) /* (P21) MMC1_CLK */bootph-pre-ram;
&main_pmx1 {
- bootph-pre-ram; main_usbss0_pins_default: main-usbss0-pins-default {
pinctrl-single,pins = < J721E_IOPAD(0x04, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */bootph-pre-ram;
;@@ -163,6 +171,8 @@ status = "okay"; /* Shared with ATF on this platform */ power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>;
/dts-v1/;
-&main_pmx0 {
- bootph-pre-ram;
bootph-pre-ram;
bootph-pre-ram;
-&main_uart0 {
- status = "okay";
- status = "okay";
&main_pmx0 {
pinctrl-single,pins = < J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */ J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */bootph-pre-ram;
&hbmc {
2.34.1
a) Once we have the core dts changes in k.org.... b) sync u-boot back in. the bootph-pre-ram etc changes can come in via u-boot.dtsi at this point c) then get the ph-pre-ram etc changes into k.org d) drop them from u-boot.dtsi etc.
But, NOT yet.
This patch move wkup_pmx into common file, along with cleanup of duplicated pin mux under wkup_pmx.
Also remove double define for mcu_uart.
Signed-off-by: Udit Kumar u-kumar1@ti.com --- arch/arm/dts/k3-j7200-common-proc-board.dts | 24 +++++++- .../arm/dts/k3-j7200-r5-common-proc-board.dts | 55 ------------------- arch/arm/dts/k3-j7200-som-p0.dtsi | 3 + 3 files changed, 26 insertions(+), 56 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index 98d1fde4db..8cdc17dd01 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -80,6 +80,26 @@ }; };
+&wkup_pmx0 { + bootph-pre-ram; + mcu_uart0_pins_default: mcu_uart0_pins_default { + bootph-pre-ram; + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xf4, PIN_INPUT, 0) /* (D20) MCU_UART0_RXD */ + J721E_WKUP_IOPAD(0xf0, PIN_OUTPUT, 0) /* (D19) MCU_UART0_TXD */ + J721E_WKUP_IOPAD(0xf8, PIN_INPUT, 0) /* (E20) MCU_UART0_CTSn */ + J721E_WKUP_IOPAD(0xfc, PIN_OUTPUT, 0) /* (E21) MCU_UART0_RTSn */ + >; + }; + wkup_uart0_pins_default: wkup_uart0_pins_default { + bootph-pre-ram; + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 0) /* (B14) WKUP_UART0_RXD */ + J721E_WKUP_IOPAD(0xb4, PIN_OUTPUT, 0) /* (A14) WKUP_UART0_TXD */ + >; + }; +}; + &wkup_pmx2 { mcu_cpsw_pins_default: mcu-cpsw-pins-default { pinctrl-single,pins = < @@ -164,7 +184,9 @@
&mcu_uart0 { status = "okay"; - /* Default pinmux */ + pinctrl-names = "default"; + pinctrl-0 = <&mcu_uart0_pins_default>; + clock-frequency = <96000000>; };
&main_uart0 { diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index 9b42e4d2ca..f8750229ad 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -106,52 +106,6 @@ ti,secure-host; };
-&wkup_pmx0 { - bootph-pre-ram; - wkup_uart0_pins_default: wkup_uart0_pins_default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 0) /* (B14) WKUP_UART0_RXD */ - J721E_WKUP_IOPAD(0xb4, PIN_OUTPUT, 0) /* (A14) WKUP_UART0_TXD */ - >; - }; - - mcu_uart0_pins_default: mcu_uart0_pins_default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0xf4, PIN_INPUT, 0) /* (D20) WKUP_GPIO0_13.MCU_UART0_RXD */ - J721E_WKUP_IOPAD(0xf0, PIN_OUTPUT, 0) /* (D19) WKUP_GPIO0_12.MCU_UART0_TXD */ - J721E_WKUP_IOPAD(0xf8, PIN_INPUT, 0) /* (E20) WKUP_GPIO0_14.MCU_UART0_CTSn */ - J721E_WKUP_IOPAD(0xfc, PIN_OUTPUT, 0) /* (E21) WKUP_GPIO0_15.MCU_UART0_RTSn */ - >; - }; - - mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-pins-default { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 1) /* (E20) MCU_OSPI0_CLK.MCU_HYPERBUS0_CK */ - J721E_WKUP_IOPAD(0x4, PIN_OUTPUT, 1) /* (C21) MCU_OSPI0_LBCLKO.MCU_HYPERBUS0_CKn */ - J721E_WKUP_IOPAD(0x2c, PIN_OUTPUT, 1) /* (F19) MCU_OSPI0_CSn0.MCU_HYPERBUS0_CSn0 */ - J721E_WKUP_IOPAD(0x54, PIN_OUTPUT, 3) /* (E22) MCU_OSPI1_CSn1.MCU_HYPERBUS0_CSn1 */ - J721E_WKUP_IOPAD(0x30, PIN_OUTPUT, 1) /* (E19) MCU_OSPI0_CSn1.MCU_HYPERBUS0_RESETn */ - J721E_WKUP_IOPAD(0x8, PIN_INPUT, 1) /* (D21) MCU_OSPI0_DQS.MCU_HYPERBUS0_RWDS */ - J721E_WKUP_IOPAD(0xc, PIN_INPUT, 1) /* (D20) MCU_OSPI0_D0.MCU_HYPERBUS0_DQ0 */ - J721E_WKUP_IOPAD(0x10, PIN_INPUT, 1) /* (G19) MCU_OSPI0_D1.MCU_HYPERBUS0_DQ1 */ - J721E_WKUP_IOPAD(0x14, PIN_INPUT, 1) /* (G20) MCU_OSPI0_D2.MCU_HYPERBUS0_DQ2 */ - J721E_WKUP_IOPAD(0x18, PIN_INPUT, 1) /* (F20) MCU_OSPI0_D3.MCU_HYPERBUS0_DQ3 */ - J721E_WKUP_IOPAD(0x1c, PIN_INPUT, 1) /* (F21) MCU_OSPI0_D4.MCU_HYPERBUS0_DQ4 */ - J721E_WKUP_IOPAD(0x20, PIN_INPUT, 1) /* (E21) MCU_OSPI0_D5.MCU_HYPERBUS0_DQ5 */ - J721E_WKUP_IOPAD(0x24, PIN_INPUT, 1) /* (B22) MCU_OSPI0_D6.MCU_HYPERBUS0_DQ6 */ - J721E_WKUP_IOPAD(0x28, PIN_INPUT, 1) /* (G21) MCU_OSPI0_D7.MCU_HYPERBUS0_DQ7 */ - >; - }; - - wkup_gpio_pins_default: wkup-gpio-pins-default { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0xd8, PIN_INPUT, 7) /* (C14) WKUP_GPIO0_6 */ - >; - }; -}; - &wkup_uart0 { bootph-pre-ram; pinctrl-names = "default"; @@ -159,15 +113,6 @@ status = "okay"; };
-&mcu_uart0 { - /delete-property/ power-domains; - /delete-property/ clocks; - /delete-property/ clock-names; - pinctrl-names = "default"; - pinctrl-0 = <&mcu_uart0_pins_default>; - status = "okay"; - clock-frequency = <96000000>; -};
&main_sdhci0 { /delete-property/ power-domains; diff --git a/arch/arm/dts/k3-j7200-som-p0.dtsi b/arch/arm/dts/k3-j7200-som-p0.dtsi index 7eaa2411a5..7776f2d0ba 100644 --- a/arch/arm/dts/k3-j7200-som-p0.dtsi +++ b/arch/arm/dts/k3-j7200-som-p0.dtsi @@ -116,10 +116,13 @@ J721E_WKUP_IOPAD(0x0008, PIN_INPUT, 0) /* MCU_OSPI0_DQS */ >; }; + };
&wkup_pmx2 { + bootph-pre-ram; wkup_i2c0_pins_default: wkup-i2c0-pins-default { + bootph-pre-ram; pinctrl-single,pins = < J721E_WKUP_IOPAD(0x98, PIN_INPUT_PULLUP, 0) /* (F20) WKUP_I2C0_SCL */ J721E_WKUP_IOPAD(0x9c, PIN_INPUT_PULLUP, 0) /* (H21) WKUP_I2C0_SDA */
remove Alias and chosen properties
Signed-off-by: Udit Kumar u-kumar1@ti.com --- .../dts/k3-j7200-common-proc-board-u-boot.dtsi | 15 --------------- arch/arm/dts/k3-j7200-r5-common-proc-board.dts | 6 ------ 2 files changed, 21 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index 789dc54617..9b89813743 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -3,21 +3,6 @@ * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ */
-/ { - chosen { - stdout-path = "serial2:115200n8"; - tick-timer = &timer1; - }; - - aliases { - ethernet0 = &cpsw_port1; - i2c0 = &wkup_i2c0; - i2c1 = &mcu_i2c0; - i2c2 = &mcu_i2c1; - i2c3 = &main_i2c0; - }; -}; - &cbass_main { bootph-pre-ram; }; diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index f8750229ad..8fbbf59cf2 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -10,13 +10,7 @@ #include "k3-j721e-ddr.dtsi"
/ { - aliases { - remoteproc0 = &sysctrler; - remoteproc1 = &a72_0; - }; - chosen { - stdout-path = &main_uart0; tick-timer = &timer1; firmware-loader = &fs_loader0; };
This patch remove duplicated USB node from r5 board dts
Signed-off-by: Udit Kumar u-kumar1@ti.com --- arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi | 8 -------- arch/arm/dts/k3-j7200-common-proc-board.dts | 1 + arch/arm/dts/k3-j7200-r5-common-proc-board.dts | 12 ------------ 3 files changed, 1 insertion(+), 20 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index 9b89813743..4c92223d2c 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -139,14 +139,6 @@ }; };
-&main_usbss0_pins_default { - bootph-pre-ram; -}; - -&usbss0 { - bootph-pre-ram; - ti,usb2-only; -};
&usb0 { dr_mode = "peripheral"; diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index 8cdc17dd01..4fd2bb5bd6 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -313,6 +313,7 @@ };
&usbss0 { + bootph-pre-ram; pinctrl-names = "default"; pinctrl-0 = <&main_usbss0_pins_default>; ti,vbus-divider; diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index 8fbbf59cf2..144c00efbe 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -181,18 +181,6 @@ }; };
-&usbss0 { - pinctrl-names = "default"; - pinctrl-0 = <&main_usbss0_pins_default>; - ti,vbus-divider; - ti,usb2-only; -}; - -&usb0 { - dr_mode = "otg"; - maximum-speed = "high-speed"; -}; - &hbmc { status = "okay"; pinctrl-names = "default";
This patch cleans up duplicated main_i2c node from r5 file. Since this node needs bootph property, So add in common file.
Signed-off-by: Udit Kumar u-kumar1@ti.com --- .../k3-j7200-common-proc-board-u-boot.dtsi | 16 --------------- arch/arm/dts/k3-j7200-common-proc-board.dts | 2 ++ .../arm/dts/k3-j7200-r5-common-proc-board.dts | 20 ------------------- 3 files changed, 2 insertions(+), 36 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index 4c92223d2c..6ac68720ed 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -110,22 +110,6 @@ bootph-pre-ram; };
-&wkup_i2c0 { - bootph-pre-ram; -}; - -&main_i2c0 { - bootph-pre-ram; -}; - -&main_i2c0_pins_default { - bootph-pre-ram; -}; - -&exp2 { - bootph-pre-ram; -}; - &mcu_cpsw { reg = <0x0 0x46000000 0x0 0x200000>, <0x0 0x40f00200 0x0 0x8>; diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index 4fd2bb5bd6..77f9922260 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -243,6 +243,7 @@
&main_i2c0 { status = "okay"; + bootph-pre-ram; pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; clock-frequency = <400000>; @@ -255,6 +256,7 @@ };
exp2: gpio@22 { + bootph-pre-ram; compatible = "ti,tca6424"; reg = <0x22>; gpio-controller; diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index 144c00efbe..c247ad1b2e 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -161,26 +161,6 @@ bootph-pre-ram; };
-&main_i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c0_pins_default>; - clock-frequency = <400000>; - - exp1: gpio@20 { - compatible = "ti,tca6416"; - reg = <0x20>; - gpio-controller; - #gpio-cells = <2>; - }; - - exp2: gpio@22 { - compatible = "ti,tca6424"; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - &hbmc { status = "okay"; pinctrl-names = "default";
remove non used 19Mhz clock node
Signed-off-by: Udit Kumar u-kumar1@ti.com --- arch/arm/dts/k3-j7200-r5-common-proc-board.dts | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index c247ad1b2e..30fb359489 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -43,12 +43,6 @@ bootph-pre-ram; };
- clk_19_2mhz: dummy_clock_19_2mhz { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <19200000>; - bootph-pre-ram; - }; };
&memorycontroller {
move bootph to common file and remove duplicated properties of node.
Signed-off-by: Udit Kumar u-kumar1@ti.com --- arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi | 7 ------- arch/arm/dts/k3-j7200-r5-common-proc-board.dts | 8 ++------ 2 files changed, 2 insertions(+), 13 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index 6ac68720ed..e5ae8f44ed 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -137,13 +137,6 @@ bootph-pre-ram; };
-&hbmc { - bootph-pre-ram; - - flash@0,0 { - bootph-pre-ram; - }; -};
&hbmc_mux { bootph-pre-ram; diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index 30fb359489..f852df00e9 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -157,16 +157,12 @@
&hbmc { status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mcu_fss0_hpb0_pins_default>; - reg = <0x0 0x47040000 0x0 0x100>, - <0x0 0x50000000 0x0 0x8000000>; + bootph-pre-ram; ranges = <0x0 0x0 0x0 0x50000000 0x4000000>, /* 64MB Flash on CS0 */ <0x1 0x0 0x0 0x54000000 0x800000>; /* 8MB flash on CS1 */
flash@0,0 { - compatible = "cypress,hyperflash", "cfi-flash"; - reg = <0x0 0x0 0x4000000>; + bootph-pre-ram; }; };
To align with kernel and remove duplication rearrange boothm node.
Signed-off-by: Udit Kumar u-kumar1@ti.com --- .../k3-j7200-common-proc-board-u-boot.dtsi | 45 ------------------- arch/arm/dts/k3-j7200-common-proc-board.dts | 3 ++ arch/arm/dts/k3-j7200-main.dtsi | 3 ++ arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 2 + arch/arm/dts/k3-j7200-som-p0.dtsi | 1 + 5 files changed, 9 insertions(+), 45 deletions(-)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index e5ae8f44ed..fa3baf242b 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -3,14 +3,6 @@ * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ */
-&cbass_main { - bootph-pre-ram; -}; - -&main_navss { - bootph-pre-ram; -}; - &cbass_mcu_wakeup { bootph-pre-ram;
@@ -62,10 +54,6 @@ }; };
-&secure_proxy_main { - bootph-pre-ram; -}; - &dmsc { bootph-pre-ram; k3_sysreset: sysreset-controller { @@ -86,22 +74,6 @@ bootph-pre-ram; };
-&wkup_pmx0 { - bootph-pre-ram; -}; - -&main_pmx0 { - bootph-pre-ram; -}; - -&main_uart0 { - bootph-pre-ram; -}; - -&mcu_uart0 { - bootph-pre-ram; -}; - &main_sdhci0 { bootph-pre-ram; }; @@ -129,19 +101,6 @@ bootph-pre-ram; };
-&mcu_fss0_hpb0_pins_default { - bootph-pre-ram; -}; - -&fss { - bootph-pre-ram; -}; - - -&hbmc_mux { - bootph-pre-ram; -}; - &serdes_ln_ctrl { u-boot,mux-autoprobe; }; @@ -150,10 +109,6 @@ u-boot,mux-autoprobe; };
-&serdes0 { - bootph-pre-ram; -}; - &main_r5fss0 { ti,cluster-mode = <0>; }; diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index 77f9922260..9e6edecbde 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -183,6 +183,7 @@ };
&mcu_uart0 { + bootph-pre-ram; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&mcu_uart0_pins_default>; @@ -190,6 +191,7 @@ };
&main_uart0 { + bootph-pre-ram; status = "okay"; /* Shared with ATF on this platform */ power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; @@ -338,6 +340,7 @@ };
&serdes0 { + bootph-pre-ram; serdes0_pcie_link: phy@0 { reg = <0>; cdns,num-lanes = <2>; diff --git a/arch/arm/dts/k3-j7200-main.dtsi b/arch/arm/dts/k3-j7200-main.dtsi index fb9e4842c1..3dfbeca4ef 100644 --- a/arch/arm/dts/k3-j7200-main.dtsi +++ b/arch/arm/dts/k3-j7200-main.dtsi @@ -13,6 +13,7 @@ };
&cbass_main { + bootph-pre-ram; msmc_ram: sram@70000000 { compatible = "mmio-sram"; reg = <0x00 0x70000000 0x00 0x100000>; @@ -84,6 +85,7 @@ };
main_navss: bus@30000000 { + bootph-pre-ram; compatible = "simple-mfd"; #address-cells = <2>; #size-cells = <2>; @@ -119,6 +121,7 @@ };
secure_proxy_main: mailbox@32c00000 { + bootph-pre-ram; compatible = "ti,am654-secure-proxy"; #mbox-cells = <1>; reg-names = "target_data", "rt", "scfg"; diff --git a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi index 7ed6c31c7c..e302c3d6ac 100644 --- a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi @@ -454,6 +454,7 @@ };
fss: syscon@47000000 { + bootph-pre-ram; compatible = "syscon", "simple-mfd"; reg = <0x00 0x47000000 0x00 0x100>; #address-cells = <2>; @@ -461,6 +462,7 @@ ranges;
hbmc_mux: hbmc-mux { + bootph-pre-ram; compatible = "mmio-mux"; #mux-control-cells = <1>; mux-reg-masks = <0x4 0x2>; /* HBMC select */ diff --git a/arch/arm/dts/k3-j7200-som-p0.dtsi b/arch/arm/dts/k3-j7200-som-p0.dtsi index 7776f2d0ba..db1d749b52 100644 --- a/arch/arm/dts/k3-j7200-som-p0.dtsi +++ b/arch/arm/dts/k3-j7200-som-p0.dtsi @@ -84,6 +84,7 @@
&wkup_pmx0 { mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-pins-default { + bootph-pre-ram; pinctrl-single,pins = < J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 1) /* (B6) MCU_OSPI0_CLK.MCU_HYPERBUS0_CK */ J721E_WKUP_IOPAD(0x4, PIN_OUTPUT, 1) /* (C8) MCU_OSPI0_LBCLKO.MCU_HYPERBUS0_CKn */
Upstream Linux commit id 8f6c475f4ca7a
J7200 has 8 MCSPI instances in the main domain and 3 instances in the MCU domain. Add the DT nodes for all the 11 instances and keep them disabled. MAIN_MCSPI4 is connected as a slave to MCU_MCSPI2 by default at power-up, MAIN_MCSPI4 and MCU_MCSPI2 are not pinned out externally.
Signed-off-by: Vaishnav Achath vaishnav.a@ti.com Reviewed-by: Keerthy j-keerthy@ti.com Link: https://lore.kernel.org/r/20230321082827.14274-3-vaishnav.a@ti.com Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/dts/k3-j7200-main.dtsi | 88 +++++++++++++++++++++++++++ arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 33 ++++++++++ 2 files changed, 121 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-main.dtsi b/arch/arm/dts/k3-j7200-main.dtsi index 3dfbeca4ef..be8034bf5b 100644 --- a/arch/arm/dts/k3-j7200-main.dtsi +++ b/arch/arm/dts/k3-j7200-main.dtsi @@ -798,6 +798,94 @@ clock-names = "gpio"; };
+ main_spi0: spi@2100000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02100000 0x00 0x400>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 266 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 266 1>; + status = "disabled"; + }; + + main_spi1: spi@2110000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02110000 0x00 0x400>; + interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 267 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 267 1>; + status = "disabled"; + }; + + main_spi2: spi@2120000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02120000 0x00 0x400>; + interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 268 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 268 1>; + status = "disabled"; + }; + + main_spi3: spi@2130000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02130000 0x00 0x400>; + interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 269 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 269 1>; + status = "disabled"; + }; + + main_spi4: spi@2140000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02140000 0x00 0x400>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 270 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 270 1>; + status = "disabled"; + }; + + main_spi5: spi@2150000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02150000 0x00 0x400>; + interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 271 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 271 1>; + status = "disabled"; + }; + + main_spi6: spi@2160000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02160000 0x00 0x400>; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 272 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 272 1>; + status = "disabled"; + }; + + main_spi7: spi@2170000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02170000 0x00 0x400>; + interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 273 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 273 1>; + status = "disabled"; + }; + watchdog0: watchdog@2200000 { compatible = "ti,j7-rti-wdt"; reg = <0x0 0x2200000 0x0 0x100>; diff --git a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi index e302c3d6ac..3328f4bc6f 100644 --- a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi @@ -453,6 +453,39 @@ status = "disabled"; };
+ mcu_spi0: spi@40300000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040300000 0x00 0x400>; + interrupts = <GIC_SPI 848 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 274 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 274 0>; + status = "disabled"; + }; + + mcu_spi1: spi@40310000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040310000 0x00 0x400>; + interrupts = <GIC_SPI 849 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 275 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 275 0>; + status = "disabled"; + }; + + mcu_spi2: spi@40320000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040320000 0x00 0x400>; + interrupts = <GIC_SPI 850 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 276 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 276 0>; + status = "disabled"; + }; + fss: syscon@47000000 { bootph-pre-ram; compatible = "syscon", "simple-mfd";
NAK. I have'nt signed-off on u-boot patches. As my first message went - you will get this for free and save a bunch of the patch repeat by waiting a few days.. (we are 3-4 days away from 6.4-rc1)..
- main_spi0: spi@2100000 {
#size-cells = <0>;
- main_spi1: spi@2110000 {
#size-cells = <0>;
- main_spi2: spi@2120000 {
#size-cells = <0>;
- main_spi3: spi@2130000 {
#size-cells = <0>;
- main_spi4: spi@2140000 {
#size-cells = <0>;
- main_spi5: spi@2150000 {
#size-cells = <0>;
- main_spi6: spi@2160000 {
#size-cells = <0>;
- main_spi7: spi@2170000 {
#size-cells = <0>;
- watchdog0: watchdog@2200000 { compatible = "ti,j7-rti-wdt"; reg = <0x0 0x2200000 0x0 0x100>;
- mcu_spi0: spi@40300000 {
#size-cells = <0>;
- mcu_spi1: spi@40310000 {
#size-cells = <0>;
- mcu_spi2: spi@40320000 {
#size-cells = <0>;
- fss: syscon@47000000 { bootph-pre-ram; compatible = "syscon", "simple-mfd";
-- 2.34.1
Kumar, Udit
Nishanth Menon
Udit Kumar
