Re: [PATCH] riscv: Try to get cpu frequency from device tree
Hi Sean
From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Lukas Auer Sent: Monday, January 27, 2020 6:26 AM To: u-boot@lists.denx.de; seanga2@gmail.com Subject: Re: [PATCH] riscv: Try to get cpu frequency from device tree
On Sun, 2020-01-26 at 13:20 -0500, Sean Anderson wrote:
On 1/26/20 11:34 AM, Lukas Auer wrote:
Hi Sean, Usually, ret is used as a variable name here. I think it would actually make the code a bit nicer to read here, because the clock rate is not read from variable err.
Hm, I chose err instead of ret since that variable is never the return value of the function. I can change that for v2 if you'd like.
Makes sense. I think it's fine to keep it as is.
But this patch seem depend on [PATCH v2 06/11] riscv: Fix incorrect cpu frequency on RV64. Can you combine those two patches as one patch-set and also modify err as ret BTW.
Thanks Rick
But that's just nit-picking. The patch looks good otherwise!
Reviewed-by: Lukas Auer lukas@auer.io
On 2/4/20 5:36 AM, Bin Meng wrote:
On Mon, Feb 3, 2020 at 1:40 AM Sean Anderson seanga2@gmail.com wrote: I believe both 2 patches in this series are needed by "riscv: Add Sipeed Maix support" series? If yes, I think you can just put 2 patches into the same series, to give people a good context next time.
Hm, I had split them off due to the following comment
I guess the intention was to combine them *in* the patch series.
--Sean
Hi Sean,
I meant you can include these 2 patches in the "riscv: Add Sipeed Maix support" series.
Regards, Bin
On 2/4/20 9:27 AM, Bin Meng wrote:
Hi Sean,
Yes, I can do that in the next revision, sorry for the confusion.
Bin Meng
Rick Chen
Sean Anderson
