[U-Boot] Please pull u-boot-mpc85xx.git
The following changes since commit 53237afe5b64abe7b17fbfed958f3dc83f503ffa:
cmd_mem: fix cp command (2013-05-24 10:38:08 -0400)
git://www.denx.de/git/u-boot-mpc85xx.git master
for you to fetch changes up to a71d45d706a5b51c348160163b6c159632273fed:
powerpc/mpc85xx: Clear L1 D-cache lock (2013-05-24 16:54:14 -0500)
---------------------------------------------------------------- Ed Swarthout (2): powerpc/qixis: add clock measurement registers powerpc/t4qds: use clock measurement for sysclk and ddr clock
James Yang (2): Enable L2 cache parity/ECC error checking Add e6500 L2 replacement policy selection
Poonam Aggrwal (1): powerpc/B4: Merge B4420 and B4860 in config_mpc85xx.h
Ruchika Gupta (1): SECURE BOOT - Removed deletion of TLB entries code
Shaohui Xie (6): net/phy: fix select line for TN80xx T4240/ramboot: enable PBL tool for T4240 powerpc/p5040: enable NAND, SD, SPI boot support powerpc/p5040: enable PBL tool support powerpc/p2041: fix serdes reference clock frequency display for PC board powerpc/p5040: fix mdio mux for 10G port
Shaveta Leekha (2): powerpc/b4860: fix for Serdes connectivity to SFP's powerpc/b4860qds: Add LAW Target ID and Create LAW entry for Maple
Shengzhou Liu (1): powerpc/t4240qds: fix PHY reset timeout issue
Stephen George (1): board/t4240qds, b4860qds: LAW/TLB for DCSR set to size 32M
Suresh Gupta (1): Enable XAUI interface for B4860QDS
Xie Xiaobo (1): sf: spansion: Add support for S25FL128S
York Sun (10): common: Update cmd_bdinfo for PPC powerpc/t4240qds: Add board detail for bdinfo command powerpc/mpc85xx: check if core is disabled for showing status powerpc/t4240qds: Add VDD override powerpc/T4160: Merge T4160 and T4240 in config_mpc85xx.h powerpc/mpc8xxx: Add T1040 and variant SoCs powerpc/chassis2: Change core numbering scheme powerpc/mpc8xxx: Allow DDR overclock powerpc/t4qds: Add SW7[4] in the DIP switch display powerpc/mpc85xx: Clear L1 D-cache lock
arch/powerpc/cpu/mpc85xx/Makefile | 3 + arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 +- arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 7 - arch/powerpc/cpu/mpc85xx/mp.c | 2 + arch/powerpc/cpu/mpc85xx/release.S | 41 +++-- arch/powerpc/cpu/mpc85xx/speed.c | 20 +-- arch/powerpc/cpu/mpc85xx/start.S | 4 +- arch/powerpc/cpu/mpc85xx/t1040_ids.c | 135 +++++++++++++++ arch/powerpc/cpu/mpc85xx/t1040_serdes.c | 93 +++++++++++ arch/powerpc/cpu/mpc8xxx/cpu.c | 59 ++++++- .../cpu/mpc8xxx/ddr/lc_common_dimm_params.c | 2 - arch/powerpc/include/asm/config_mpc85xx.h | 98 +++++------ arch/powerpc/include/asm/fsl_law.h | 2 + arch/powerpc/include/asm/fsl_secure_boot.h | 10 -- arch/powerpc/include/asm/fsl_serdes.h | 8 + arch/powerpc/include/asm/immap_85xx.h | 29 ++-- arch/powerpc/include/asm/processor.h | 17 ++ board/freescale/b4860qds/b4860qds.c | 6 +- board/freescale/b4860qds/b4860qds_crossbar_con.h | 31 ++-- board/freescale/b4860qds/eth_b4860qds.c | 35 ++++ board/freescale/b4860qds/law.c | 6 +- board/freescale/b4860qds/tlb.c | 2 +- board/freescale/common/qixis.h | 6 +- board/freescale/corenet_ds/eth_superhydra.c | 8 +- board/freescale/corenet_ds/rcw_p5040ds.cfg | 11 ++ board/freescale/p2041rdb/p2041rdb.c | 11 ++ board/freescale/t4qds/eth.c | 19 ++- board/freescale/t4qds/law.c | 3 +- board/freescale/t4qds/t4_pbi.cfg | 36 ++++ board/freescale/t4qds/t4_rcw.cfg | 7 + board/freescale/t4qds/t4qds.c | 172 +++++++++++++++++++- board/freescale/t4qds/tlb.c | 2 +- boards.cfg | 3 + common/cmd_bdinfo.c | 5 + doc/README.b4860qds | 4 +- doc/README.t4240qds | 26 ++- drivers/mtd/spi/spansion.c | 2 +- drivers/net/fm/b4860.c | 6 +- drivers/net/phy/teranetics.c | 16 +- include/configs/B4860QDS.h | 16 +- include/configs/corenet_ds.h | 2 + include/configs/t4qds.h | 3 +- 42 files changed, 805 insertions(+), 165 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/t1040_ids.c create mode 100644 arch/powerpc/cpu/mpc85xx/t1040_serdes.c create mode 100644 board/freescale/corenet_ds/rcw_p5040ds.cfg create mode 100644 board/freescale/t4qds/t4_pbi.cfg create mode 100644 board/freescale/t4qds/t4_rcw.cfg
Andy Fleming
