[PATCH] armv8: lx2160a: fix reset sequence
From: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com
Make sure that SW_RST_REQ and RST_REQ_MSK are cleared before triggering hardware reset request.
Signed-off-by: Thirupathaiah Annapureddy thiruan@linux.microsoft.com Signed-off-by: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 8a2f404..e610528 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017-2019 NXP + * Copyright 2017-2020 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. */
@@ -1229,13 +1229,15 @@ __efi_runtime_data u32 __iomem *rstcr = (u32 *)CONFIG_SYS_FSL_RST_ADDR;
void __efi_runtime reset_cpu(ulong addr) { - u32 val; - #ifdef CONFIG_ARCH_LX2160A - val = in_le32(rstcr); - val |= 0x01; - out_le32(rstcr, val); + /* clear the RST_REQ_MSK and SW_RST_REQ */ + out_le32(rstcr, 0x0); + + /* initiate the sw reset request */ + out_le32(rstcr, 0x1); #else + u32 val; + /* Raise RESET_REQ_B */ val = scfg_in32(rstcr); val |= 0x02;
-----Original Message----- From: Meenakshi Aggarwal meenakshi.aggarwal@nxp.com Sent: Wednesday, September 9, 2020 2:06 PM To: u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com Cc: Varun Sethi V.Sethi@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; Thirupathaiah Annapureddy thiruan@linux.microsoft.com Subject: [PATCH] armv8: lx2160a: fix reset sequence
- Copyright 2017-2019 NXP
- Copyright 2017-2020 NXP
- Copyright 2014-2015 Freescale Semiconductor, Inc.
- u32 val;
- val |= 0x01;
- /* clear the RST_REQ_MSK and SW_RST_REQ */
- out_le32(rstcr, 0x0);
- /* initiate the sw reset request */
- out_le32(rstcr, 0x1);
#else
- u32 val;
- /* Raise RESET_REQ_B */ val = scfg_in32(rstcr); val |= 0x02;
-- 2.7.4
Reviewed-by: Priyanka Jain priyanka.jain@nxp.com
Priyanka Jain
