[U-Boot] [PATCH v2] phy: add support for STM32 usb phy controller
This patch adds phy tranceiver driver for STM32 USB PHY Controller (usbphyc) that provides dual port High-Speed phy for OTG (single port) and EHCI/OHCI host controller (two ports). One port of the phy is shared between the two USB controllers through a UTMI+ switch.
Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Amelie Delaunay amelie.delaunay@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
Changes in v2: - Add bindings documentation
.../devicetree/bindings/phy/phy-stm32-usbphyc.txt | 73 ++++ drivers/phy/Kconfig | 13 + drivers/phy/Makefile | 1 + drivers/phy/phy-stm32-usbphyc.c | 403 +++++++++++++++++++++ 4 files changed, 490 insertions(+) create mode 100644 Documentation/devicetree/bindings/phy/phy-stm32-usbphyc.txt create mode 100644 drivers/phy/phy-stm32-usbphyc.c
diff --git a/Documentation/devicetree/bindings/phy/phy-stm32-usbphyc.txt b/Documentation/devicetree/bindings/phy/phy-stm32-usbphyc.txt new file mode 100644 index 000000000000..725ae71ae653 --- /dev/null +++ b/Documentation/devicetree/bindings/phy/phy-stm32-usbphyc.txt @@ -0,0 +1,73 @@ +STMicroelectronics STM32 USB HS PHY controller + +The STM32 USBPHYC block contains a dual port High Speed UTMI+ PHY and a UTMI +switch. It controls PHY configuration and status, and the UTMI+ switch that +selects either OTG or HOST controller for the second PHY port. It also sets +PLL configuration. + +USBPHYC + |_ PLL + | + |_ PHY port#1 _________________ HOST controller + | _ | + | / 1|________________| + |_ PHY port#2 ----| |________________ + | _0| | + |_ UTMI switch_______| OTG controller + + +Phy provider node +================= + +Required properties: +- compatible: must be "st,stm32mp1-usbphyc" +- reg: address and length of the usb phy control register set +- clocks: phandle + clock specifier for the PLL phy clock +- #address-cells: number of address cells for phys sub-nodes, must be <1> +- #size-cells: number of size cells for phys sub-nodes, must be <0> + +Optional properties: +- assigned-clocks: phandle + clock specifier for the PLL phy clock +- assigned-clock-parents: the PLL phy clock parent +- resets: phandle + reset specifier + +Required nodes: one sub-node per port the controller provides. + +Phy sub-nodes +============== + +Required properties: +- reg: phy port index +- phy-supply: phandle to the regulator providing 3V3 power to the PHY, + see phy-bindings.txt in the same directory. +- vdda1v1-supply: phandle to the regulator providing 1V1 power to the PHY +- vdda1v8-supply: phandle to the regulator providing 1V8 power to the PHY +- #phy-cells: see phy-bindings.txt in the same directory, must be <0> for PHY + port#1 and must be <1> for PHY port#2, to select USB controller + + +Example: + usbphyc: usb-phy@5a006000 { + compatible = "st,stm32mp1-usbphyc"; + reg = <0x5a006000 0x1000>; + clocks = <&rcc_clk USBPHY_K>; + resets = <&rcc_rst USBPHY_R>; + #address-cells = <1>; + #size-cells = <0>; + + usbphyc_port0: usb-phy@0 { + reg = <0>; + phy-supply = <&vdd_usb>; + vdda1v1-supply = <®11>; + vdda1v8-supply = <®18> + #phy-cells = <0>; + }; + + usbphyc_port1: usb-phy@1 { + reg = <1>; + phy-supply = <&vdd_usb>; + vdda1v1-supply = <®11>; + vdda1v8-supply = <®18> + #phy-cells = <1>; + }; + }; diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index 4e9d09910c32..1de3f31bcdd1 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -110,4 +110,17 @@ config STI_USB_PHY used by USB2 and USB3 Host controllers available on STiH407 SoC families.
+config PHY_STM32_USBPHYC + tristate "STMicroelectronics STM32 SoC USB HS PHY driver" + depends on PHY && ARCH_STM32MP + help + Enable this to support the High-Speed USB transceiver that is part of + STMicroelectronics STM32 SoCs. + + This driver controls the entire USB PHY block: the USB PHY controller + (USBPHYC) and the two 8-bit wide UTMI+ interface. First interface is + used by an HS USB Host controller, and the second one is shared + between an HS USB OTG controller and an HS USB Host controller, + selected by an USB switch. + endmenu diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile index 68087ae3b134..e93c3257230d 100644 --- a/drivers/phy/Makefile +++ b/drivers/phy/Makefile @@ -14,3 +14,4 @@ obj-$(CONFIG_BCM6368_USBH_PHY) += bcm6368-usbh-phy.o obj-$(CONFIG_PHY_SANDBOX) += sandbox-phy.o obj-$(CONFIG_$(SPL_)PIPE3_PHY) += ti-pipe3-phy.o obj-$(CONFIG_STI_USB_PHY) += sti_usb_phy.o +obj-$(CONFIG_PHY_STM32_USBPHYC) += phy-stm32-usbphyc.o diff --git a/drivers/phy/phy-stm32-usbphyc.c b/drivers/phy/phy-stm32-usbphyc.c new file mode 100644 index 000000000000..744a26c4cd3d --- /dev/null +++ b/drivers/phy/phy-stm32-usbphyc.c @@ -0,0 +1,403 @@ +/* + * Copyright (C) 2018, STMicroelectronics - All Rights Reserved + * + * SPDX-License-Identifier: GPL-2.0+ BSD-3-Clause + */ + +#include <common.h> +#include <clk.h> +#include <div64.h> +#include <dm.h> +#include <fdtdec.h> +#include <generic-phy.h> +#include <reset.h> +#include <syscon.h> +#include <usb.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include <power/regulator.h> + +/* USBPHYC registers */ +#define STM32_USBPHYC_PLL 0x0 +#define STM32_USBPHYC_MISC 0x8 + +/* STM32_USBPHYC_PLL bit fields */ +#define PLLNDIV GENMASK(6, 0) +#define PLLNDIV_SHIFT 0 +#define PLLFRACIN GENMASK(25, 10) +#define PLLFRACIN_SHIFT 10 +#define PLLEN BIT(26) +#define PLLSTRB BIT(27) +#define PLLSTRBYP BIT(28) +#define PLLFRACCTL BIT(29) +#define PLLDITHEN0 BIT(30) +#define PLLDITHEN1 BIT(31) + +/* STM32_USBPHYC_MISC bit fields */ +#define SWITHOST BIT(0) + +#define MAX_PHYS 2 + +#define PLL_LOCK_TIME_US 100 +#define PLL_PWR_DOWN_TIME_US 5 +#define PLL_FVCO 2880 /* in MHz */ +#define PLL_INFF_MIN_RATE 19200000 /* in Hz */ +#define PLL_INFF_MAX_RATE 38400000 /* in Hz */ + +struct pll_params { + u8 ndiv; + u16 frac; +}; + +struct stm32_usbphyc { + fdt_addr_t base; + struct clk clk; + struct stm32_usbphyc_phy { + struct udevice *vdd; + struct udevice *vdda1v1; + struct udevice *vdda1v8; + int index; + bool init; + bool powered; + } phys[MAX_PHYS]; +}; + +void stm32_usbphyc_get_pll_params(u32 clk_rate, struct pll_params *pll_params) +{ + unsigned long long fvco, ndiv, frac; + + /* + * | FVCO = INFF*2*(NDIV + FRACT/2^16 ) when DITHER_DISABLE[1] = 1 + * | FVCO = 2880MHz + * | NDIV = integer part of input bits to set the LDF + * | FRACT = fractional part of input bits to set the LDF + * => PLLNDIV = integer part of (FVCO / (INFF*2)) + * => PLLFRACIN = fractional part of(FVCO / INFF*2) * 2^16 + * <=> PLLFRACIN = ((FVCO / (INFF*2)) - PLLNDIV) * 2^16 + */ + fvco = (unsigned long long)PLL_FVCO * 1000000; /* In Hz */ + + ndiv = fvco; + do_div(ndiv, (clk_rate * 2)); + pll_params->ndiv = (u8)ndiv; + + frac = fvco * (1 << 16); + do_div(frac, (clk_rate * 2)); + frac = frac - (ndiv * (1 << 16)); + pll_params->frac = (u16)frac; +} + +static int stm32_usbphyc_pll_init(struct stm32_usbphyc *usbphyc) +{ + struct pll_params pll_params; + u32 clk_rate = clk_get_rate(&usbphyc->clk); + u32 usbphyc_pll; + + if ((clk_rate < PLL_INFF_MIN_RATE) || (clk_rate > PLL_INFF_MAX_RATE)) { + pr_debug("%s: input clk freq (%dHz) out of range\n", + __func__, clk_rate); + return -EINVAL; + } + + stm32_usbphyc_get_pll_params(clk_rate, &pll_params); + + usbphyc_pll = PLLDITHEN1 | PLLDITHEN0 | PLLSTRBYP; + usbphyc_pll |= ((pll_params.ndiv << PLLNDIV_SHIFT) & PLLNDIV); + + if (pll_params.frac) { + usbphyc_pll |= PLLFRACCTL; + usbphyc_pll |= ((pll_params.frac << PLLFRACIN_SHIFT) + & PLLFRACIN); + } + + writel(usbphyc_pll, usbphyc->base + STM32_USBPHYC_PLL); + + pr_debug("%s: input clk freq=%dHz, ndiv=%d, frac=%d\n", __func__, + clk_rate, pll_params.ndiv, pll_params.frac); + + return 0; +} + +static bool stm32_usbphyc_is_init(struct stm32_usbphyc *usbphyc) +{ + int i; + + for (i = 0; i < MAX_PHYS; i++) { + if (usbphyc->phys[i].init) + return true; + } + + return false; +} + +static bool stm32_usbphyc_is_powered(struct stm32_usbphyc *usbphyc) +{ + int i; + + for (i = 0; i < MAX_PHYS; i++) { + if (usbphyc->phys[i].powered) + return true; + } + + return false; +} + +static int stm32_usbphyc_phy_init(struct phy *phy) +{ + struct stm32_usbphyc *usbphyc = dev_get_priv(phy->dev); + struct stm32_usbphyc_phy *usbphyc_phy = usbphyc->phys + phy->id; + bool pllen = readl(usbphyc->base + STM32_USBPHYC_PLL) & PLLEN ? + true : false; + int ret; + + pr_debug("%s phy ID = %lu\n", __func__, phy->id); + /* Check if one phy port has already configured the pll */ + if (pllen && stm32_usbphyc_is_init(usbphyc)) + goto initialized; + + if (pllen) { + clrbits_le32(usbphyc->base + STM32_USBPHYC_PLL, PLLEN); + udelay(PLL_PWR_DOWN_TIME_US); + } + + ret = stm32_usbphyc_pll_init(usbphyc); + if (ret) + return ret; + + setbits_le32(usbphyc->base + STM32_USBPHYC_PLL, PLLEN); + + /* + * We must wait PLL_LOCK_TIME_US before checking that PLLEN + * bit is still set + */ + udelay(PLL_LOCK_TIME_US); + + if (!(readl(usbphyc->base + STM32_USBPHYC_PLL) & PLLEN)) + return -EIO; + +initialized: + usbphyc_phy->init = true; + + return 0; +} + +static int stm32_usbphyc_phy_exit(struct phy *phy) +{ + struct stm32_usbphyc *usbphyc = dev_get_priv(phy->dev); + struct stm32_usbphyc_phy *usbphyc_phy = usbphyc->phys + phy->id; + + pr_debug("%s phy ID = %lu\n", __func__, phy->id); + usbphyc_phy->init = false; + + /* Check if other phy port requires pllen */ + if (stm32_usbphyc_is_init(usbphyc)) + return 0; + + clrbits_le32(usbphyc->base + STM32_USBPHYC_PLL, PLLEN); + + /* + * We must wait PLL_PWR_DOWN_TIME_US before checking that PLLEN + * bit is still clear + */ + udelay(PLL_PWR_DOWN_TIME_US); + + if (readl(usbphyc->base + STM32_USBPHYC_PLL) & PLLEN) + return -EIO; + + return 0; +} + +static int stm32_usbphyc_phy_power_on(struct phy *phy) +{ + struct stm32_usbphyc *usbphyc = dev_get_priv(phy->dev); + struct stm32_usbphyc_phy *usbphyc_phy = usbphyc->phys + phy->id; + int ret; + + pr_debug("%s phy ID = %lu\n", __func__, phy->id); + if (usbphyc_phy->vdda1v1) { + ret = regulator_set_enable(usbphyc_phy->vdda1v1, true); + if (ret) + return ret; + } + + if (usbphyc_phy->vdda1v8) { + ret = regulator_set_enable(usbphyc_phy->vdda1v8, true); + if (ret) + return ret; + } + if (usbphyc_phy->vdd) { + ret = regulator_set_enable(usbphyc_phy->vdd, true); + if (ret) + return ret; + } + + usbphyc_phy->powered = true; + + return 0; +} + +static int stm32_usbphyc_phy_power_off(struct phy *phy) +{ + struct stm32_usbphyc *usbphyc = dev_get_priv(phy->dev); + struct stm32_usbphyc_phy *usbphyc_phy = usbphyc->phys + phy->id; + int ret; + + pr_debug("%s phy ID = %lu\n", __func__, phy->id); + usbphyc_phy->powered = false; + + if (stm32_usbphyc_is_powered(usbphyc)) + return 0; + + if (usbphyc_phy->vdda1v1) { + ret = regulator_set_enable(usbphyc_phy->vdda1v1, false); + if (ret) + return ret; + } + + if (usbphyc_phy->vdda1v8) { + ret = regulator_set_enable(usbphyc_phy->vdda1v8, false); + if (ret) + return ret; + } + + if (usbphyc_phy->vdd) { + ret = regulator_set_enable(usbphyc_phy->vdd, false); + if (ret) + return ret; + } + + return 0; +} + +static int stm32_usbphyc_get_regulator(struct udevice *dev, ofnode node, + char *supply_name, + struct udevice **regulator) +{ + struct ofnode_phandle_args regulator_phandle; + int ret; + + ret = ofnode_parse_phandle_with_args(node, supply_name, + NULL, 0, 0, + ®ulator_phandle); + if (ret) { + dev_err(dev, "Can't find %s property (%d)\n", supply_name, ret); + return ret; + } + + ret = uclass_get_device_by_ofnode(UCLASS_REGULATOR, + regulator_phandle.node, + regulator); + + if (ret) { + dev_err(dev, "Can't get %s regulator (%d)\n", supply_name, ret); + return ret; + } + + return 0; +} + +static int stm32_usbphyc_of_xlate(struct phy *phy, + struct ofnode_phandle_args *args) +{ + if (args->args_count > 1) { + pr_debug("%s: invalid args_count: %d\n", __func__, + args->args_count); + return -EINVAL; + } + + if (args->args[0] >= MAX_PHYS) + return -ENODEV; + + if (args->args_count) + phy->id = args->args[0]; + else + phy->id = 0; + + return 0; +} + +static const struct phy_ops stm32_usbphyc_phy_ops = { + .init = stm32_usbphyc_phy_init, + .exit = stm32_usbphyc_phy_exit, + .power_on = stm32_usbphyc_phy_power_on, + .power_off = stm32_usbphyc_phy_power_off, + .of_xlate = stm32_usbphyc_of_xlate, +}; + +static int stm32_usbphyc_probe(struct udevice *dev) +{ + struct stm32_usbphyc *usbphyc = dev_get_priv(dev); + struct reset_ctl reset; + ofnode node; + int i, ret; + + usbphyc->base = dev_read_addr(dev); + if (usbphyc->base == FDT_ADDR_T_NONE) + return -EINVAL; + + /* Enable clock */ + ret = clk_get_by_index(dev, 0, &usbphyc->clk); + if (ret) + return ret; + + ret = clk_enable(&usbphyc->clk); + if (ret) + return ret; + + /* Reset */ + ret = reset_get_by_index(dev, 0, &reset); + if (!ret) { + reset_assert(&reset); + udelay(2); + reset_deassert(&reset); + } + + /* + * parse all PHY subnodes in order to populate regulator associated + * to each PHY port + */ + node = dev_read_first_subnode(dev); + for (i = 0; i < MAX_PHYS; i++) { + struct stm32_usbphyc_phy *usbphyc_phy = usbphyc->phys + i; + + usbphyc_phy->index = i; + usbphyc_phy->init = false; + usbphyc_phy->powered = false; + ret = stm32_usbphyc_get_regulator(dev, node, "phy-supply", + &usbphyc_phy->vdd); + if (ret) + return ret; + + ret = stm32_usbphyc_get_regulator(dev, node, "vdda1v1-supply", + &usbphyc_phy->vdda1v1); + if (ret) + return ret; + + ret = stm32_usbphyc_get_regulator(dev, node, "vdda1v8-supply", + &usbphyc_phy->vdda1v8); + if (ret) + return ret; + + node = dev_read_next_subnode(node); + } + + /* Check if second port has to be used for host controller */ + if (dev_read_bool(dev, "st,port2-switch-to-host")) + setbits_le32(usbphyc->base + STM32_USBPHYC_MISC, SWITHOST); + + return 0; +} + +static const struct udevice_id stm32_usbphyc_of_match[] = { + { .compatible = "st,stm32mp1-usbphyc", }, + { }, +}; + +U_BOOT_DRIVER(stm32_usb_phyc) = { + .name = "stm32-usbphyc", + .id = UCLASS_PHY, + .of_match = stm32_usbphyc_of_match, + .ops = &stm32_usbphyc_phy_ops, + .probe = stm32_usbphyc_probe, + .priv_auto_alloc_size = sizeof(struct stm32_usbphyc), +};
Oh, I see.
- struct stm32_usbphyc *usbphyc = dev_get_priv(dev);
- struct reset_ctl reset;
- ofnode node;
- int i, ret;
- usbphyc->base = dev_read_addr(dev);
- if (usbphyc->base == FDT_ADDR_T_NONE)
return -EINVAL;
- /* Enable clock */
- ret = clk_get_by_index(dev, 0, &usbphyc->clk);
- if (ret)
return ret;
- ret = clk_enable(&usbphyc->clk);
- if (ret)
return ret;
- /* Reset */
- ret = reset_get_by_index(dev, 0, &reset);
- if (!ret) {
udelay(2);
Shouldn't the reset delay be a reset controller property ?
Looks good, Reviewed-by: Marek Vasut marex@denx.de
Remind me to pick it after the release please.
Hi Marek
Oh, I see.
- ofnode node;
- int i, ret;
return -EINVAL;
- if (ret)
return ret;
- if (ret)
return ret;
- /* Reset */
- if (!ret) {
udelay(2);
There is no delay property in reset framework. The delay is more dependent of the reseted IP than the reset controller.
Ok
Thanks
Patrice
On 04/27/2018 04:28 PM, Patrice CHOTARD wrote:
Hi Marek
Oh, I see.
- ofnode node;
- int i, ret;
return -EINVAL;
- if (ret)
return ret;
- if (ret)
return ret;
- /* Reset */
- if (!ret) {
udelay(2);
OK, so be it.
Hi Marek
Oh, I see.
- ofnode node;
- int i, ret;
return -EINVAL;
- if (ret)
return ret;
- if (ret)
return ret;
- /* Reset */
- if (!ret) {
udelay(2);
As you requested to me, can you pick the patch ?
Thanks
Patrice
On 05/15/2018 03:27 PM, Patrice CHOTARD wrote:
Hi Marek
Oh, I see.
- ofnode node;
- int i, ret;
return -EINVAL;
- if (ret)
return ret;
- if (ret)
return ret;
- /* Reset */
- if (!ret) {
udelay(2);
I had to tweak the patch a bit, since it didnt apply anymore. Please check if it's correct, it should be OK though.
Hi Marek
Hi Marek
Oh, I see.
- ofnode node;
- int i, ret;
return -EINVAL;
- if (ret)
return ret;
- if (ret)
return ret;
- /* Reset */
- if (!ret) {
udelay(2);
Perfect !
Thanks
Patrice
Patrice CHOTARD
Patrice Chotard
