[U-Boot] [PATCH 0/5] exynos5: usb: Enable USB 2.0 support
This patchset series adds support to enable USB 2.0 on smdk5250. It includes addition of system and power management registers, functions to enable and disable power to the USB host controller.
This patchset is based on: USB: S5P: Add ehci support.patch
Rajeshwari Shinde (5): exynos5: Add system register structure exynos5: Add structure for PMU register exynos5: Add power Enable/Disable for USB-EHCI exynos5: usb: Fix incorrect USB base addresses exynos5: usb: Enable USB 2.0 on smdk5250
arch/arm/cpu/armv7/exynos/power.c | 59 +++ arch/arm/include/asm/arch-exynos/cpu.h | 5 +- arch/arm/include/asm/arch-exynos/power.h | 627 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/sysreg.h | 44 ++ drivers/usb/host/ehci-s5p.c | 3 + include/configs/smdk5250.h | 6 + 6 files changed, 742 insertions(+), 2 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/sysreg.h
This patch add structure for SYSREG.
Signed-off-by: Che-Liang Chiou clchiou@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Reviewed-by: Vivek Gautam gautam.vivek@samsung.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/include/asm/arch-exynos/sysreg.h | 43 +++++++++++++++++++++++++++++ 1 files changed, 43 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/sysreg.h
diff --git a/arch/arm/include/asm/arch-exynos/sysreg.h b/arch/arm/include/asm/arch-exynos/sysreg.h new file mode 100644 index 0000000..aca4b2b --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/sysreg.h @@ -0,0 +1,43 @@ +/* + * (C) Copyright 2012 Samsung Electronics + * Register map for sysreg + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __EXYNOS5_SYSREG_H__ +#define __EXYNOS5_SYSREG_H__ + +#ifndef __ASSEMBLY__ +/* sysreg map */ +struct exynos5_sysreg { + /* Add registers as and when required */ + unsigned char res1[0x214]; + unsigned int disp1blk_cfg; + unsigned int dispblk_cfg2; + unsigned int hdcp_e_fuse_mem_cfg; + unsigned int gsclblk_cfg0; + unsigned int gsclblk_cfg1; + unsigned int ispblk_cfg; + unsigned int usb20_phy_cfg; + unsigned char res2[0x29c]; + unsigned int mipi_dphy; + unsigned int dptx_phy; + unsigned int phyclk_sel; +}; +#endif + +#endif
Dear Rajeshwari Shinde,
Ccing Minkyu. Can I get your opinion on these patches please?
- (C) Copyright 2012 Samsung Electronics
- Register map for sysreg
- MA 02111-1307 USA
- /* Add registers as and when required */
- unsigned char res1[0x214];
- unsigned int disp1blk_cfg;
- unsigned int dispblk_cfg2;
- unsigned int hdcp_e_fuse_mem_cfg;
- unsigned int gsclblk_cfg0;
- unsigned int gsclblk_cfg1;
- unsigned int ispblk_cfg;
- unsigned int usb20_phy_cfg;
- unsigned char res2[0x29c];
- unsigned int mipi_dphy;
- unsigned int dptx_phy;
- unsigned int phyclk_sel;
+}; +#endif
Best regards, Marek Vasut
+ Minkyu,
- MA 02111-1307 USA
+}; +#endif
Best regards, Marek Vasut _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear Rajeshwari,
- MA 02111-1307 USA
+}; +#endif
Acked-by: Chander kashyap chander.kashyap@linaro.org
Please add your name.
- MA 02111-1307 USA
please modify it to __ASM_ARM_ARCH_SYSREG_H__.
+}; +#endif
Thanks. Minkyu Kang.
Hi Minkyu,
Thank you for the comments.
-- will do so.
- MA 02111-1307 USA
-- Will correct this
+}; +#endif
Thanks. Minkyu Kang. -- from. prom. www.promsoft.net _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Regards, Rajeshwari Shinde.
This patch adds power mananagement register structure for exynos5 SoC.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- arch/arm/include/asm/arch-exynos/power.h | 622 ++++++++++++++++++++++++++++++ 1 files changed, 622 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/power.h b/arch/arm/include/asm/arch-exynos/power.h index 6444fd0..4236beb 100644 --- a/arch/arm/include/asm/arch-exynos/power.h +++ b/arch/arm/include/asm/arch-exynos/power.h @@ -225,6 +225,628 @@ struct exynos4_power { unsigned int gps_alive_status; unsigned int gps_alive_option; }; + +struct exynos5_power { + unsigned int om_stat; + unsigned char res1[0x18]; + unsigned int rtc_clko_sel; + unsigned int gnss_rtc_out_ctrl; + unsigned char res2[0x1dc]; + unsigned int central_seq_configuration; + unsigned int central_seq_status; + unsigned int central_seq_option; + unsigned char res3[0x14]; + unsigned int seq_transition0; + unsigned int seq_transition1; + unsigned int seq_transition2; + unsigned int seq_transition3; + unsigned int seq_transition4; + unsigned int seq_transition5; + unsigned int seq_transition6; + unsigned int seq_transition7; + unsigned int central_seq_dmc_configuration; + unsigned int central_seq_dmc_status; + unsigned int central_seq_dmc_option; + unsigned char res4[0x14]; + unsigned int seq_dmc_transition0; + unsigned int seq_dmc_transition1; + unsigned int seq_dmc_transition2; + unsigned int seq_dmc_transition3; + unsigned int seq_dmc_transition4; + unsigned int seq_dmc_transition5; + unsigned int seq_dmc_transition6; + unsigned int seq_dmc_transition7; + unsigned char res5[0x180]; + unsigned int swreset; + unsigned int rst_stat; + unsigned int automatic_wdt_reset_disable; + unsigned int mask_wdt_reset_request; + unsigned int mask_wreset_request; + unsigned char res6[0xec]; + unsigned int reset_sequencer_configuration; + unsigned int reset_sequencer_status; + unsigned int reset_sequencer_option; + unsigned char res7[0xf4]; + unsigned int wakeup_stat; + unsigned int eint_wakeup_mask; + unsigned int wakeup_mask; + unsigned int wakeup_interrupt; + unsigned char res8[0x10]; + unsigned int wakeup_stat_dmc; + unsigned int eint_wakeup_mask_dmc; + unsigned int wakeup_mask_dmc; + unsigned int wakeup_interrupt_dmc; + unsigned char res9[0xd0]; + unsigned int hdmi_phy_control; + unsigned int usbdrd_phy_control; + unsigned int usbhost_phy_control; + unsigned int efnand_phy_control; + unsigned int mipi_phy0_control; + unsigned int mipi_phy1_control; + unsigned int adc_phy_control; + unsigned int mtcadc_phy_control; + unsigned int dptx_phy_control; + unsigned int sata_phy_control; + unsigned char res10[0xd8]; + unsigned int inform0; + unsigned int inform1; + unsigned int inform2; + unsigned int inform3; + unsigned int sysip_dat0; + unsigned int sysip_dat1; + unsigned int sysip_dat2; + unsigned int sysip_dat3; + unsigned char res11[0xe0]; + unsigned int pmu_spare0; + unsigned int pmu_spare1; + unsigned int pmu_spare2; + unsigned int pmu_spare3; + unsigned char res12[0x70]; + unsigned int irom_data_reg0; + unsigned int irom_data_reg1; + unsigned int irom_data_reg2; + unsigned int irom_data_reg3; + unsigned char res13[0x70]; + unsigned int pmu_debug; + unsigned char res14[0x5fc]; + unsigned int arm_core0_sys_pwr_reg; + unsigned int dis_irq_arm_core0_local_sys_pwr_reg; + unsigned int dis_irq_arm_core0_central_sys_pwr_reg; + unsigned char res15[0x4]; + unsigned int arm_core1_sys_pwr_reg; + unsigned int dis_irq_arm_core1_local_sys_pwr_reg; + unsigned int dis_irq_arm_core1_central_sys_pwr_reg; + unsigned char res16[0x24]; + unsigned int fsys_arm_sys_pwr_reg; + unsigned int dis_irq_fsys_arm_local_sys_pwr_reg; + unsigned int dis_irq_fsys_arm_central_sys_pwr_reg; + unsigned char res17[0x4]; + unsigned int isp_arm_sys_pwr_reg; + unsigned int dis_irq_isp_arm_local_sys_pwr_reg; + unsigned int dis_irq_isp_arm_central_sys_pwr_reg; + unsigned char res18[0x24]; + unsigned int arm_common_sys_pwr_reg; + unsigned char res19[0x3c]; + unsigned int arm_l2_sys_pwr_reg; + unsigned char res20[0x3c]; + unsigned int cmu_aclkstop_sys_pwr_reg; + unsigned int cmu_sclkstop_sys_pwr_reg; + unsigned char res21[0x4]; + unsigned int cmu_reset_sys_pwr_reg; + unsigned char res22[0x10]; + unsigned int cmu_aclkstop_dmc_sys_pwr_reg; + unsigned int cmu_sclkstop_dmc_sys_pwr_reg; + unsigned char res23[0x4]; + unsigned int cmu_reset_dmc_sys_pwr_reg; + unsigned char res24[0x8]; + unsigned int ddrphy_dlllock_sys_pwr_reg; + unsigned char res25[0x4]; + unsigned int apll_sysclk_sys_pwr_reg; + unsigned int mpll_sysclk_sys_pwr_reg; + unsigned int vpll_sysclk_sys_pwr_reg; + unsigned int epll_sysclk_sys_pwr_reg; + unsigned int bpll_sysclk_sys_pwr_reg; + unsigned int cpll_sysclk_sys_pwr_reg; + unsigned int gpll_sysclk_sys_pwr_reg; + unsigned char res26[0x8]; + unsigned int mplluser_sysclk_sys_pwr_reg; + unsigned char res27[0x8]; + unsigned int bplluser_sysclk_sys_pwr_reg; + unsigned char res28[0xc]; + unsigned int top_bus_sys_pwr_reg; + unsigned int top_retention_sys_pwr_reg; + unsigned int top_pwr_sys_pwr_reg; + unsigned char res29[0x4]; + unsigned int top_bus_dmc_sys_pwr_reg; + unsigned int top_retention_dmc_sys_pwr_reg; + unsigned int top_pwr_dmc_sys_pwr_reg; + unsigned char res30[0x4]; + unsigned int logic_reset_sys_pwr_reg; + unsigned int oscclk_gate_sys_pwr_reg; + unsigned char res31[0x8]; + unsigned int logic_reset_dmc_sys_pwr_reg; + unsigned int oscclk_gate_dmc_sys_pwr_reg; + unsigned char res32[0x8]; + unsigned int usbotg_mem_sys_pwr_reg; + unsigned char res33[0x4]; + unsigned int g2d_mem_sys_pwr_reg; + unsigned int usbdrd_mem_sys_pwr_reg; + unsigned int efnand_mem_sys_pwr_reg; + unsigned int cssys_mem_sys_pwr_reg; + unsigned int secss_mem_sys_pwr_reg; + unsigned int rotator_mem_sys_pwr_reg; + unsigned int intram_mem_sys_pwr_reg; + unsigned int introm_mem_sys_pwr_reg; + unsigned int jpeg_mem_sys_pwr_reg; + unsigned int hsi_mem_sys_pwr_reg; + unsigned char res34[0x4]; + unsigned int mcuiop_mem_sys_pwr_reg; + unsigned char res35[0x4]; + unsigned int sata_mem_sys_pwr_reg; + unsigned int pad_retention_dram_sys_pwr_reg; + unsigned int pad_retention_mau_sys_pwr_reg; + unsigned int pad_retention_jtag_sys_pwr_reg; + unsigned char res36[0xc]; + unsigned int pad_retention_mmc2_sys_pwr_reg; + unsigned int pad_retention_mmc3_sys_pwr_reg; + unsigned int pad_retention_gpio_sys_pwr_reg; + unsigned int pad_retention_uart_sys_pwr_reg; + unsigned int pad_retention_mmc0_sys_pwr_reg; + unsigned int pad_retention_mmc1_sys_pwr_reg; + unsigned int pad_retention_ebia_sys_pwr_reg; + unsigned int pad_retention_ebib_sys_pwr_reg; + unsigned int pad_retention_spi_sys_pwr_reg; + unsigned int pad_retention_gpio_dmc_sys_pwr_reg; + unsigned int pad_isolation_sys_pwr_reg; + unsigned char res37[0xc]; + unsigned int pad_isolation_dmc_sys_pwr_reg; + unsigned char res38[0xc]; + unsigned int pad_alv_sel_sys_pwr_reg; + unsigned char res39[0x20]; + unsigned int xxti_sys_pwr_reg; + unsigned char res40[0x38]; + unsigned int ext_regulator_sys_pwr_reg; + unsigned char res41[0x3c]; + unsigned int gpio_mode_sys_pwr_reg; + unsigned char res42[0x1c]; + unsigned int gpio_mode_dmc_sys_pwr_reg; + unsigned char res43[0x1c]; + unsigned int gpio_mode_mau_sys_pwr_reg; + unsigned int top_asb_reset_sys_pwr_reg; + unsigned int top_asb_isolation_sys_pwr_reg; + unsigned char res44[0xb4]; + unsigned int gscl_sys_pwr_reg; + unsigned int isp_sys_pwr_reg; + unsigned int mfc_sys_pwr_reg; + unsigned int g3d_sys_pwr_reg; + unsigned char res45[0x4]; + unsigned int disp1_sys_pwr_reg; + unsigned int mau_sys_pwr_reg; + unsigned char res46[0x64]; + unsigned int cmu_clkstop_gscl_sys_pwr_reg; + unsigned int cmu_clkstop_isp_sys_pwr_reg; + unsigned int cmu_clkstop_mfc_sys_pwr_reg; + unsigned int cmu_clkstop_g3d_sys_pwr_reg; + unsigned char res47[0x4]; + unsigned int cmu_clkstop_disp1_sys_pwr_reg; + unsigned int cmu_clkstop_mau_sys_pwr_reg; + unsigned char res48[0x24]; + unsigned int cmu_sysclk_gscl_sys_pwr_reg; + unsigned int cmu_sysclk_isp_sys_pwr_reg; + unsigned int cmu_sysclk_mfc_sys_pwr_reg; + unsigned int cmu_sysclk_g3d_sys_pwr_reg; + unsigned char res49[0x4]; + unsigned int cmu_sysclk_disp1_sys_pwr_reg; + unsigned int cmu_sysclk_mau_sys_pwr_reg; + unsigned char res50[0xa4]; + unsigned int cmu_reset_gscl_sys_pwr_reg; + unsigned int cmu_reset_isp_sys_pwr_reg; + unsigned int cmu_reset_mfc_sys_pwr_reg; + unsigned int cmu_reset_g3d_sys_pwr_reg; + unsigned char res51[0x4]; + unsigned int cmu_reset_disp1_sys_pwr_reg; + unsigned int cmu_reset_mau_sys_pwr_reg; + unsigned char res52[0xa64]; + unsigned int arm_core0_configuration; + unsigned int arm_core0_status; + unsigned int arm_core0_option; + unsigned char res53[0x14]; + unsigned int dis_irq_arm_core0_local_configuration; + unsigned int dis_irq_arm_core0_local_status; + unsigned int dis_irq_arm_core0_local_option; + unsigned char res54[0x14]; + unsigned int dis_irq_arm_core0_central_configuration; + unsigned int dis_irq_arm_core0_central_status; + unsigned int dis_irq_arm_core0_central_option; + unsigned char res55[0x34]; + unsigned int arm_core1_configuration; + unsigned int arm_core1_status; + unsigned int arm_core1_option; + unsigned char res56[0x14]; + unsigned int dis_irq_arm_core1_local_configuration; + unsigned int dis_irq_arm_core1_local_status; + unsigned int dis_irq_arm_core1_local_option; + unsigned char res57[0x14]; + unsigned int dis_irq_arm_core1_central_configuration; + unsigned int dis_irq_arm_core1_central_status; + unsigned int dis_irq_arm_core1_central_option; + unsigned char res58[0x134]; + unsigned int fsys_arm_configuration; + unsigned int fsys_arm_status; + unsigned int fsys_arm_option; + unsigned char res59[0x14]; + unsigned int dis_irq_fsys_arm_local_configuration; + unsigned int dis_irq_fsys_arm_local_status; + unsigned int dis_irq_fsys_arm_local_option; + unsigned char res60[0x14]; + unsigned int dis_irq_fsys_arm_central_configuration; + unsigned int dis_irq_fsys_arm_central_status; + unsigned int dis_irq_fsys_arm_central_option; + unsigned char res61[0x34]; + unsigned int isp_arm_configuration; + unsigned int isp_arm_status; + unsigned int isp_arm_option; + unsigned char res62[0x14]; + unsigned int dis_irq_isp_arm_local_configuration; + unsigned int dis_irq_isp_arm_local_status; + unsigned int dis_irq_isp_arm_local_option; + unsigned char res63[0x14]; + unsigned int dis_irq_isp_arm_central_configuration; + unsigned int dis_irq_isp_arm_central_status; + unsigned int dis_irq_isp_arm_central_option; + unsigned char res64[0x134]; + unsigned int arm_common_configuration; + unsigned int arm_common_status; + unsigned int arm_common_option; + unsigned char res65[0x1f4]; + unsigned int arm_l2_configuration; + unsigned int arm_l2_status; + unsigned int arm_l2_option; + unsigned char res66[0x1f4]; + unsigned int cmu_aclkstop_configuration; + unsigned int cmu_aclkstop_status; + unsigned int cmu_aclkstop_option; + unsigned char res67[0x14]; + unsigned int cmu_sclkstop_configuration; + unsigned int cmu_sclkstop_status; + unsigned int cmu_sclkstop_option; + unsigned char res68[0x34]; + unsigned int cmu_reset_configuration; + unsigned int cmu_reset_status; + unsigned int cmu_reset_option; + unsigned char res69[0x94]; + unsigned int cmu_aclkstop_dmc_configuration; + unsigned int cmu_aclkstop_dmc_status; + unsigned int cmu_aclkstop_dmc_option; + unsigned char res70[0x14]; + unsigned int cmu_sclkstop_dmc_configuration; + unsigned int cmu_sclkstop_dmc_status; + unsigned int cmu_sclkstop_dmc_option; + unsigned char res71[0x34]; + unsigned int cmu_reset_dmc_configuration; + unsigned int cmu_reset_dmc_status; + unsigned int cmu_reset_dmc_option; + unsigned char res72[0x54]; + unsigned int ddrphy_dlllock_configuration; + unsigned int ddrphy_dlllock_status; + unsigned int ddrphy_dlllock_option; + unsigned char res73[0x34]; + unsigned int apll_sysclk_configuration; + unsigned int apll_sysclk_status; + unsigned int apll_sysclk_option; + unsigned char res74[0x18]; + unsigned int mpll_sysclk_status; + unsigned int mpll_sysclk_option; + unsigned char res75[0x14]; + unsigned int vpll_sysclk_configuration; + unsigned int vpll_sysclk_status; + unsigned int vpll_sysclk_option; + unsigned char res76[0x14]; + unsigned int epll_sysclk_configuration; + unsigned int epll_sysclk_status; + unsigned int epll_sysclk_option; + unsigned char res77[0x14]; + unsigned int bpll_sysclk_configuration; + unsigned int bpll_sysclk_status; + unsigned int bpll_sysclk_option; + unsigned char res78[0x14]; + unsigned int cpll_sysclk_configuration; + unsigned int cpll_sysclk_status; + unsigned int cpll_sysclk_option; + unsigned char res79[0x14]; + unsigned int gpll_sysclk_configuration; + unsigned int gpll_sysclk_status; + unsigned int gpll_sysclk_option; + unsigned char res80[0x54]; + unsigned int mplluser_sysclk_configuration; + unsigned int mplluser_sysclk_status; + unsigned int mplluser_sysclk_option; + unsigned char res81[0x54]; + unsigned int bplluser_sysclk_configuration; + unsigned int bplluser_sysclk_status; + unsigned int bplluser_sysclk_option; + unsigned char res82[0x74]; + unsigned int top_bus_configuration; + unsigned int top_bus_status; + unsigned int top_bus_option; + unsigned char res83[0x14]; + unsigned int top_retention_configuration; + unsigned int top_retention_status; + unsigned int top_retention_option; + unsigned char res84[0x14]; + unsigned int top_pwr_configuration; + unsigned int top_pwr_status; + unsigned int top_pwr_option; + unsigned char res85[0x34]; + unsigned int top_bus_dmc_configuration; + unsigned int top_bus_dmc_status; + unsigned int top_bus_dmc_option; + unsigned char res86[0x14]; + unsigned int top_retention_dmc_configuration; + unsigned int top_retention_dmc_status; + unsigned int top_retention_dmc_option; + unsigned char res87[0x14]; + unsigned int top_pwr_dmc_configuration; + unsigned int top_pwr_dmc_status; + unsigned int top_pwr_dmc_option; + unsigned char res88[0x34]; + unsigned int logic_reset_configuration; + unsigned int logic_reset_status; + unsigned int logic_reset_option; + unsigned char res89[0x14]; + unsigned int oscclk_gate_configuration; + unsigned int oscclk_gate_status; + unsigned int oscclk_gate_option; + unsigned char res90[0x54]; + unsigned int logic_reset_dmc_configuration; + unsigned int logic_reset_dmc_status; + unsigned int logic_reset_dmc_option; + unsigned char res91[0x14]; + unsigned int oscclk_gate_dmc_configuration; + unsigned int oscclk_gate_dmc_status; + unsigned int oscclk_gate_dmc_option; + unsigned char res92[0x54]; + unsigned int usbotg_mem_configuration; + unsigned int usbotg_mem_status; + unsigned int usbotg_mem_option; + unsigned char res93[0x34]; + unsigned int g2d_mem_configuration; + unsigned int g2d_mem_status; + unsigned int g2d_mem_option; + unsigned char res94[0x14]; + unsigned int usbdrd_mem_configuration; + unsigned int usbdrd_mem_status; + unsigned int usbdrd_mem_option; + unsigned char res95[0x14]; + unsigned int efnand_mem_configuration; + unsigned int efnand_mem_status; + unsigned int efnand_mem_option; + unsigned char res96[0x14]; + unsigned int cssys_mem_configuration; + unsigned int cssys_mem_status; + unsigned int cssys_mem_option; + unsigned char res97[0x14]; + unsigned int secss_mem_configuration; + unsigned int secss_mem_status; + unsigned int secss_mem_option; + unsigned char res98[0x14]; + unsigned int rotator_mem_configuration; + unsigned int rotator_mem_status; + unsigned int rotator_mem_option; + unsigned char res99[0x14]; + unsigned int intram_mem_configuration; + unsigned int intram_mem_status; + unsigned int intram_mem_option; + unsigned char res100[0x14]; + unsigned int introm_mem_configuration; + unsigned int introm_mem_status; + unsigned int introm_mem_option; + unsigned char res101[0x14]; + unsigned int jpeg_mem_configuration; + unsigned int jpeg_mem_status; + unsigned int jpeg_mem_option; + unsigned char res102[0x14]; + unsigned int hsi_mem_configuration; + unsigned int hsi_mem_status; + unsigned int hsi_mem_option; + unsigned char res103[0x34]; + unsigned int mcuiop_mem_configuration; + unsigned int mcuiop_mem_status; + unsigned int mcuiop_mem_option; + unsigned char res104[0x14]; + unsigned int sata_mem_configuration; + unsigned int sata_mem_status; + unsigned int sata_mem_option; + unsigned char res105[0x34]; + unsigned int pad_retention_dram_configuration; + unsigned int pad_retention_dram_status; + unsigned int pad_retention_dram_option; + unsigned char res106[0x14]; + unsigned int pad_retention_mau_configuration; + unsigned int pad_retention_mau_status; + unsigned int pad_retention_mau_option; + unsigned char res107[0x14]; + unsigned int pad_retention_jtag_configuration; + unsigned int pad_retention_jtag_status; + unsigned int pad_retention_jtag_option; + unsigned char res108[0x74]; + unsigned int pad_retention_mmc2_configuration; + unsigned int pad_retention_mmc2_status; + unsigned int pad_retention_mmc2_option; + unsigned char res109[0x14]; + unsigned int pad_retention_mmc3_configuration; + unsigned int pad_retention_mmc3_status; + unsigned int pad_retention_mmc3_option; + unsigned char res110[0x14]; + unsigned int pad_retention_gpio_configuration; + unsigned int pad_retention_gpio_status; + unsigned int pad_retention_gpio_option; + unsigned char res111[0x14]; + unsigned int pad_retention_uart_configuration; + unsigned int pad_retention_uart_status; + unsigned int pad_retention_uart_option; + unsigned char res112[0x14]; + unsigned int pad_retention_mmc0_configuration; + unsigned int pad_retention_mmc0_status; + unsigned int pad_retention_mmc0_option; + unsigned char res113[0x14]; + unsigned int pad_retention_mmc1_configuration; + unsigned int pad_retention_mmc1_status; + unsigned int pad_retention_mmc1_option; + unsigned char res114[0x14]; + unsigned int pad_retention_ebia_configuration; + unsigned int pad_retention_ebia_status; + unsigned int pad_retention_ebia_option; + unsigned char res115[0x14]; + unsigned int pad_retention_ebib_configuration; + unsigned int pad_retention_ebib_status; + unsigned int pad_retention_ebib_option; + unsigned char res116[0x14]; + unsigned int pad_retention_spi_configuration; + unsigned int pad_retention_spi_status; + unsigned int pad_retention_spi_option; + unsigned char res117[0x14]; + unsigned int pad_retention_gpio_dmc_configuration; + unsigned int pad_retention_gpio_dmc_status; + unsigned int pad_retention_gpio_dmc_option; + unsigned char res118[0x14]; + unsigned int pad_isolation_configuration; + unsigned int pad_isolation_status; + unsigned int pad_isolation_option; + unsigned char res119[0x74]; + unsigned int pad_isolation_dmc_configuration; + unsigned int pad_isolation_dmc_status; + unsigned int pad_isolation_dmc_option; + unsigned char res120[0x74]; + unsigned int pad_alv_sel_configuration; + unsigned int pad_alv_sel_status; + unsigned int pad_alv_sel_option0; + unsigned int ps_hold_control; + unsigned char res130[0x110]; + unsigned int xxti_configuration; + unsigned int xxti_status; + unsigned int xxti_option; + unsigned char res131[0x10]; + unsigned int xxti_duration3; + unsigned char res132[0x1c0]; + unsigned int ext_regulator_configuration; + unsigned int ext_regulator_status; + unsigned int ext_regulator_option; + unsigned char res133[0x10]; + unsigned int ext_regulator_duration3; + unsigned char res134[0x1e0]; + unsigned int gpio_mode_configuration; + unsigned int gpio_mode_status; + unsigned int gpio_mode_option; + unsigned char res135[0xf4]; + unsigned int gpio_mode_dmc_configuration; + unsigned int gpio_mode_dmc_status; + unsigned int gpio_mode_dmc_option; + unsigned char res136[0xd4]; + unsigned int gpio_mode_mau_configuration; + unsigned int gpio_mode_mau_status; + unsigned int gpio_mode_mau_option; + unsigned char res137[0x14]; + unsigned int top_asb_reset_configuration; + unsigned int top_asb_reset_status; + unsigned int top_asb_reset_option; + unsigned char res138[0x14]; + unsigned int top_asb_isolation_configuration; + unsigned int top_asb_isolation_status; + unsigned int top_asb_isolation_option; + unsigned char res139[0x5d4]; + unsigned int gscl_configuration; + unsigned int gscl_status; + unsigned int gscl_option; + unsigned char res140[0x14]; + unsigned int isp_configuration; + unsigned int isp_status; + unsigned int isp_option; + unsigned char res141[0x14]; + unsigned int mfc_configuration; + unsigned int mfc_status; + unsigned int mfc_option; + unsigned char res142[0x14]; + unsigned int g3d_configuration; + unsigned int g3d_status; + unsigned int g3d_option; + unsigned char res143[0x34]; + unsigned int disp1_configuration; + unsigned int disp1_status; + unsigned int disp1_option; + unsigned char res144[0x14]; + unsigned int mau_configuration; + unsigned int mau_status; + unsigned int mau_option; + unsigned char res145[0x334]; + unsigned int cmu_clkstop_gscl_configuration; + unsigned int cmu_clkstop_gscl_status; + unsigned int cmu_clkstop_gscl_option; + unsigned char res146[0x14]; + unsigned int cmu_clkstop_isp_configuration; + unsigned int cmu_clkstop_isp_status; + unsigned int cmu_clkstop_isp_option; + unsigned char res147[0x14]; + unsigned int cmu_clkstop_mfc_configuration; + unsigned int cmu_clkstop_mfc_status; + unsigned int cmu_clkstop_mfc_option; + unsigned char res148[0x14]; + unsigned int cmu_clkstop_g3d_configuration; + unsigned int cmu_clkstop_g3d_status; + unsigned int cmu_clkstop_g3d_option; + unsigned char res149[0x34]; + unsigned int cmu_clkstop_disp1_configuration; + unsigned int cmu_clkstop_disp1_status; + unsigned int cmu_clkstop_disp1_option; + unsigned char res150[0x14]; + unsigned int cmu_clkstop_mau_configuration; + unsigned int cmu_clkstop_mau_status; + unsigned int cmu_clkstop_mau_option; + unsigned char res151[0x134]; + unsigned int cmu_sysclk_gscl_configuration; + unsigned int cmu_sysclk_gscl_status; + unsigned int cmu_sysclk_gscl_option; + unsigned char res152[0x18]; + unsigned int cmu_sysclk_isp_status; + unsigned int cmu_sysclk_isp_option; + unsigned char res153[0x18]; + unsigned int cmu_sysclk_mfc_status; + unsigned int cmu_sysclk_mfc_option; + unsigned char res154[0x18]; + unsigned int cmu_sysclk_g3d_status; + unsigned int cmu_sysclk_g3d_option; + unsigned char res155[0x38]; + unsigned int cmu_sysclk_disp1_status; + unsigned int cmu_sysclk_disp1_option; + unsigned char res156[0x18]; + unsigned int cmu_sysclk_mau_status; + unsigned int cmu_sysclk_mau_option; + unsigned char res157[0x534]; + unsigned int cmu_reset_gscl_configuration; + unsigned int cmu_reset_gscl_status; + unsigned int cmu_reset_gscl_option; + unsigned char res158[0x14]; + unsigned int cmu_reset_isp_configuration; + unsigned int cmu_reset_isp_status; + unsigned int cmu_reset_isp_option; + unsigned char res159[0x14]; + unsigned int cmu_reset_mfc_configuration; + unsigned int cmu_reset_mfc_status; + unsigned int cmu_reset_mfc_option; + unsigned char res160[0x14]; + unsigned int cmu_reset_g3d_configuration; + unsigned int cmu_reset_g3d_status; + unsigned int cmu_reset_g3d_option; + unsigned char res161[0x34]; + unsigned int cmu_reset_disp1_configuration; + unsigned int cmu_reset_disp1_status; + unsigned int cmu_reset_disp1_option; + unsigned char res162[0x14]; + unsigned int cmu_reset_mau_configuration; + unsigned int cmu_reset_mau_status; + unsigned int cmu_reset_mau_option; + unsigned char res163[0x24]; +}; #endif /* __ASSEMBLY__ */
void set_mipi_phy_ctrl(unsigned int dev_index, unsigned int enable);
Dear Rajeshwari,
s/mananagement/management
-- with warm regards, Chander Kashyap
This patch adds functions to enable/disable the power of USB host controller for exynos5.
This patch depends on the patch: USB: S5P: Add ehci support.patch
Signed-off-by: Vivek Gautam gautam.vivek@samsung.com Signed-off-by: Che-Liang Chiou clchiou@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- arch/arm/cpu/armv7/exynos/power.c | 59 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/power.h | 5 ++ arch/arm/include/asm/arch-exynos/sysreg.h | 1 + drivers/usb/host/ehci-s5p.c | 3 + 4 files changed, 68 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/power.c b/arch/arm/cpu/armv7/exynos/power.c index c765304..a943219 100644 --- a/arch/arm/cpu/armv7/exynos/power.c +++ b/arch/arm/cpu/armv7/exynos/power.c @@ -24,6 +24,8 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/power.h> +#include <asm/arch/cpu.h> +#include <asm/arch/sysreg.h>
static void exynos4_mipi_phy_control(unsigned int dev_index, unsigned int enable) @@ -52,3 +54,60 @@ void set_mipi_phy_ctrl(unsigned int dev_index, unsigned int enable) if (cpu_is_exynos4()) exynos4_mipi_phy_control(dev_index, enable); } + +void exynos5_ps_hold_setup(void) +{ + struct exynos5_power *power = + (struct exynos5_power *)samsung_get_base_power(); + + /* Set PS-Hold high */ + setbits_le32(&power->ps_hold_control, POWER_PS_HOLD_CONTROL_DATA_HIGH); +} + +void exynos5_enable_usb_phy(void) +{ + struct exynos5_sysreg *sysreg = + (struct exynos5_sysreg *)samsung_get_base_sysreg(); + struct exynos5_power *power = + (struct exynos5_power *)samsung_get_base_power(); + unsigned int phy_cfg; + + /* Setting USB20PHY_CONFIG register to USB 2.0 HOST link */ + phy_cfg = readl(&sysreg->usb20_phy_cfg); + if (phy_cfg & USB20_PHY_CFG_EN) { + debug("USB 2.0 HOST link already selected\n"); + } else { + phy_cfg |= USB20_PHY_CFG_EN; + writel(phy_cfg, &sysreg->usb20_phy_cfg); + } + + /* Enabling USBHOST_PHY */ + setbits_le32(&power->usbhost_phy_control, POWER_USB_HOST_PHY_CTRL_EN); +} + +void exynos5_disable_usb_phy(void) +{ + struct exynos5_power *power = + (struct exynos5_power *)samsung_get_base_power(); + + /* Disabling USBHost_PHY */ + clrbits_le32(&power->usbhost_phy_control, POWER_USB_HOST_PHY_CTRL_EN); +} + +void ps_hold_setup(void) +{ + if (cpu_is_exynos5()) + exynos5_ps_hold_setup(); +} + +void power_enable_usb_phy(void) +{ + if (cpu_is_exynos5()) + exynos5_enable_usb_phy(); +} + +void power_disable_usb_phy(void) +{ + if (cpu_is_exynos5()) + exynos5_disable_usb_phy(); +} diff --git a/arch/arm/include/asm/arch-exynos/power.h b/arch/arm/include/asm/arch-exynos/power.h index 4236beb..4e2448b 100644 --- a/arch/arm/include/asm/arch-exynos/power.h +++ b/arch/arm/include/asm/arch-exynos/power.h @@ -855,4 +855,9 @@ void set_mipi_phy_ctrl(unsigned int dev_index, unsigned int enable); #define EXYNOS_MIPI_PHY_SRESETN (1 << 1) #define EXYNOS_MIPI_PHY_MRESETN (1 << 2)
+#define POWER_USB_HOST_PHY_CTRL_EN (1 << 0) +#define POWER_PS_HOLD_CONTROL_DATA_HIGH (1 << 8) +void power_enable_usb_phy(void); +void power_disable_usb_phy(void); + #endif diff --git a/arch/arm/include/asm/arch-exynos/sysreg.h b/arch/arm/include/asm/arch-exynos/sysreg.h index aca4b2b..2d8d35a 100644 --- a/arch/arm/include/asm/arch-exynos/sysreg.h +++ b/arch/arm/include/asm/arch-exynos/sysreg.h @@ -40,4 +40,5 @@ struct exynos5_sysreg { }; #endif
+#define USB20_PHY_CFG_EN (1 << 0) #endif diff --git a/drivers/usb/host/ehci-s5p.c b/drivers/usb/host/ehci-s5p.c index 4dd4ec1..e575c48 100644 --- a/drivers/usb/host/ehci-s5p.c +++ b/drivers/usb/host/ehci-s5p.c @@ -30,6 +30,7 @@ /* Setup the EHCI host controller. */ static void setup_usb_phy(struct s5p_usb_phy *usb) { + power_enable_usb_phy(); clrbits_le32(&usb->usbphyctrl0, HOST_CTRL0_FSEL_MASK | HOST_CTRL0_COMMONON_N | @@ -70,6 +71,8 @@ static void reset_usb_phy(struct s5p_usb_phy *usb) HOST_CTRL0_SIDDQ | HOST_CTRL0_FORCESUSPEND | HOST_CTRL0_FORCESLEEP); + + power_disable_usb_phy(); }
This is not a commit message. Please move it under the "---" line.
cpu.h is already included. please remove it.
also you don't need this header file.. maybe.
- struct exynos5_power *power =
- (struct exynos5_power *)samsung_get_base_power();
- /* Set PS-Hold high */
- setbits_le32(&power->ps_hold_control, POWER_PS_HOLD_CONTROL_DATA_HIGH);
- struct exynos5_sysreg *sysreg =
- (struct exynos5_sysreg *)samsung_get_base_sysreg();
- unsigned int phy_cfg;
- /* Setting USB20PHY_CONFIG register to USB 2.0 HOST link */
- phy_cfg = readl(&sysreg->usb20_phy_cfg);
- if (phy_cfg & USB20_PHY_CFG_EN) {
- debug("USB 2.0 HOST link already selected\n");
Is it useful information for your debugging? just question :)
- } else {
- phy_cfg |= USB20_PHY_CFG_EN;
- writel(phy_cfg, &sysreg->usb20_phy_cfg);
NAK. The codes that are related with sysreg should be moved to system.c.
- /* Enabling USBHOST_PHY */
- setbits_le32(&power->usbhost_phy_control, POWER_USB_HOST_PHY_CTRL_EN);
- /* Disabling USBHost_PHY */
- clrbits_le32(&power->usbhost_phy_control, POWER_USB_HOST_PHY_CTRL_EN);
I think, you can combine enable/disable function to one.
- if (cpu_is_exynos5())
- exynos5_ps_hold_setup();
- exynos5_enable_usb_phy();
- exynos5_disable_usb_phy();
- power_enable_usb_phy();
need space here. and you should separate the function for power and system.
- power_disable_usb_phy();
Hi Minkyu,
--ok
--- will do so
-- will remove this header file.
-- will remove the same :)
- } else {
-- will correct this
-- ok
-- ok
This patch corrects the base addresses for USB_PHY and USB_OTG.
Signed-off-by: Vivek Gautam gautam.vivek@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- arch/arm/include/asm/arch-exynos/cpu.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index ac4ddc7..891970d 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -68,10 +68,10 @@ #define EXYNOS5_DMC_CTRL_BASE 0x10DD0000 #define EXYNOS5_GPIO_PART1_BASE 0x11400000 #define EXYNOS5_MIPI_DSIM_BASE 0x11D00000 +#define EXYNOS5_USBPHY_BASE 0x12130000 +#define EXYNOS5_USBOTG_BASE 0x12140000 #define EXYNOS5_MMC_BASE 0x12200000 #define EXYNOS5_SROMC_BASE 0x12250000 -#define EXYNOS5_USBOTG_BASE 0x12480000 -#define EXYNOS5_USBPHY_BASE 0x12480000 #define EXYNOS5_UART_BASE 0x12C00000 #define EXYNOS5_PWMTIMER_BASE 0x12DD0000 #define EXYNOS5_GPIO_PART2_BASE 0x13400000
Hi Rajeshwari, On 2 May 2012 19:22, Rajeshwari Shinde rajeshwari.s@samsung.com wrote:
Signed-off-by: Vivek Gautam gautam.vivek@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- arch/arm/include/asm/arch-exynos/cpu.h | 1 + include/configs/smdk5250.h | 6 ++++++ 2 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index 891970d..17f8fe3 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -68,6 +68,7 @@ #define EXYNOS5_DMC_CTRL_BASE 0x10DD0000 #define EXYNOS5_GPIO_PART1_BASE 0x11400000 #define EXYNOS5_MIPI_DSIM_BASE 0x11D00000 +#define EXYNOS5_USB_HOST_EHCI_BASE 0x12110000 #define EXYNOS5_USBPHY_BASE 0x12130000 #define EXYNOS5_USBOTG_BASE 0x12140000 #define EXYNOS5_MMC_BASE 0x12200000 diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index 9659f9e..84c7ce8 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -101,6 +101,12 @@ #define CONFIG_BOOTDELAY 3 #define CONFIG_ZERO_BOOTDELAY_CHECK
+/* USB */ +#define CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_S5P +#define CONFIG_USB_STORAGE + /* MMC SPL */ #define CONFIG_SPL #define COPY_BL2_FNPTR_ADDR 0x02020030
Dear Rajeshwari,
Unrelated change. maybe this should be move into "Add ehci support" patch?
Hi Minkyu,
-- will add the same in "Add ehci support" patch.
Can you share the purpose of USB host support at bootloader?
Just curious.
Thank you, Kyungmin Park
-- 1.7.4.4
Dear Kyungmin Park,
You can boot the system completely off a USB stick ...
Just curious.
-- 1.7.4.4
participants (6)
Chander Kashyap
Kyungmin Park
Minkyu Kang
Rajeshwari Birje
Rajeshwari Shinde
