[U-Boot] [PATCH 0/4] Add support for stm32f429-discovery board
The following patches implement basic support for the ARMv7-M microcontroller architecture. Additionally, stm32f429-discovery board support is added with tested ability to boot uClinux from the embedded Flash memory.
Kamil Lulko (4): ARM: Add ARMv7-M support ARMv7M: Add STM32F4 support stm32f4: Add serial driver stm32f4: Add support for stm32f429-discovery board
arch/arm/Kconfig | 9 + arch/arm/cpu/armv7m/Makefile | 11 + arch/arm/cpu/armv7m/config.mk | 8 + arch/arm/cpu/armv7m/cpu.c | 35 +++ arch/arm/cpu/armv7m/start.S | 15 ++ arch/arm/cpu/armv7m/stm32f4/Makefile | 11 + arch/arm/cpu/armv7m/stm32f4/clock.c | 209 +++++++++++++++ arch/arm/cpu/armv7m/stm32f4/flash.c | 143 ++++++++++ arch/arm/cpu/armv7m/stm32f4/soc.c | 37 +++ arch/arm/cpu/armv7m/stm32f4/timer.c | 118 +++++++++ arch/arm/include/asm/arch-stm32f4/fmc.h | 75 ++++++ arch/arm/include/asm/arch-stm32f4/gpio.h | 116 +++++++++ arch/arm/include/asm/arch-stm32f4/stm32.h | 108 ++++++++ arch/arm/include/asm/armv7m.h | 60 +++++ arch/arm/lib/Makefile | 8 +- arch/arm/lib/crt0.S | 30 +++ arch/arm/lib/interrupts_m.c | 95 +++++++ arch/arm/lib/relocate.S | 13 + arch/arm/lib/vectors_m.S | 57 ++++ board/st/stm32f429-discovery/Kconfig | 19 ++ board/st/stm32f429-discovery/MAINTAINERS | 6 + board/st/stm32f429-discovery/Makefile | 12 + board/st/stm32f429-discovery/led.c | 35 +++ board/st/stm32f429-discovery/stm32f429-discovery.c | 288 +++++++++++++++++++++ configs/stm32f429-discovery_defconfig | 2 + drivers/gpio/Makefile | 1 + drivers/gpio/stm32_gpio.c | 199 ++++++++++++++ drivers/serial/Makefile | 1 + drivers/serial/serial.c | 2 + drivers/serial/serial_stm32.c | 117 +++++++++ include/configs/stm32f429-discovery.h | 106 ++++++++ include/flash.h | 2 + 32 files changed, 1946 insertions(+), 2 deletions(-) create mode 100644 arch/arm/cpu/armv7m/Makefile create mode 100644 arch/arm/cpu/armv7m/config.mk create mode 100644 arch/arm/cpu/armv7m/cpu.c create mode 100644 arch/arm/cpu/armv7m/start.S create mode 100644 arch/arm/cpu/armv7m/stm32f4/Makefile create mode 100644 arch/arm/cpu/armv7m/stm32f4/clock.c create mode 100644 arch/arm/cpu/armv7m/stm32f4/flash.c create mode 100644 arch/arm/cpu/armv7m/stm32f4/soc.c create mode 100644 arch/arm/cpu/armv7m/stm32f4/timer.c create mode 100644 arch/arm/include/asm/arch-stm32f4/fmc.h create mode 100644 arch/arm/include/asm/arch-stm32f4/gpio.h create mode 100644 arch/arm/include/asm/arch-stm32f4/stm32.h create mode 100644 arch/arm/include/asm/armv7m.h create mode 100644 arch/arm/lib/interrupts_m.c create mode 100644 arch/arm/lib/vectors_m.S create mode 100644 board/st/stm32f429-discovery/Kconfig create mode 100644 board/st/stm32f429-discovery/MAINTAINERS create mode 100644 board/st/stm32f429-discovery/Makefile create mode 100644 board/st/stm32f429-discovery/led.c create mode 100644 board/st/stm32f429-discovery/stm32f429-discovery.c create mode 100644 configs/stm32f429-discovery_defconfig create mode 100644 drivers/gpio/stm32_gpio.c create mode 100644 drivers/serial/serial_stm32.c create mode 100644 include/configs/stm32f429-discovery.h
Signed-off-by: Kamil Lulko rev13@wp.pl --- arch/arm/Kconfig | 4 ++ arch/arm/cpu/armv7m/Makefile | 10 +++++ arch/arm/cpu/armv7m/config.mk | 8 ++++ arch/arm/cpu/armv7m/cpu.c | 35 ++++++++++++++++ arch/arm/cpu/armv7m/start.S | 15 +++++++ arch/arm/include/asm/armv7m.h | 60 +++++++++++++++++++++++++++ arch/arm/lib/Makefile | 8 +++- arch/arm/lib/crt0.S | 30 ++++++++++++++ arch/arm/lib/interrupts_m.c | 95 +++++++++++++++++++++++++++++++++++++++++++ arch/arm/lib/relocate.S | 13 ++++++ arch/arm/lib/vectors_m.S | 57 ++++++++++++++++++++++++++ 11 files changed, 333 insertions(+), 2 deletions(-) create mode 100644 arch/arm/cpu/armv7m/Makefile create mode 100644 arch/arm/cpu/armv7m/config.mk create mode 100644 arch/arm/cpu/armv7m/cpu.c create mode 100644 arch/arm/cpu/armv7m/start.S create mode 100644 arch/arm/include/asm/armv7m.h create mode 100644 arch/arm/lib/interrupts_m.c create mode 100644 arch/arm/lib/vectors_m.S
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 41f3220..29ea8b4 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -33,6 +33,9 @@ config CPU_V7 bool select HAS_VBAR
+config CPU_V7M + bool + config CPU_PXA bool
@@ -47,6 +50,7 @@ config SYS_CPU default "arm1136" if CPU_ARM1136 default "arm1176" if CPU_ARM1176 default "armv7" if CPU_V7 + default "armv7m" if CPU_V7M default "pxa" if CPU_PXA default "sa1100" if CPU_SA1100 default "armv8" if ARM64 diff --git a/arch/arm/cpu/armv7m/Makefile b/arch/arm/cpu/armv7m/Makefile new file mode 100644 index 0000000..a187f6e --- /dev/null +++ b/arch/arm/cpu/armv7m/Makefile @@ -0,0 +1,10 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +extra-y := start.o +obj-y += cpu.o + diff --git a/arch/arm/cpu/armv7m/config.mk b/arch/arm/cpu/armv7m/config.mk new file mode 100644 index 0000000..0b31e44 --- /dev/null +++ b/arch/arm/cpu/armv7m/config.mk @@ -0,0 +1,8 @@ +# +# (C) Copyright 2015 +# Kamil Lulko, rev13@wp.pl +# +# SPDX-License-Identifier: GPL-2.0+ +# + +PLATFORM_CPPFLAGS += -march=armv7-m -mthumb diff --git a/arch/arm/cpu/armv7m/cpu.c b/arch/arm/cpu/armv7m/cpu.c new file mode 100644 index 0000000..d3ab862 --- /dev/null +++ b/arch/arm/cpu/armv7m/cpu.c @@ -0,0 +1,35 @@ +/* + * (C) Copyright 2010,2011 + * Vladimir Khusainov, Emcraft Systems, vlad@emcraft.com + * + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/armv7m.h> + +/* + * This is called right before passing control to + * the Linux kernel point. + */ +int cleanup_before_linux(void) +{ + return 0; +} + +/* + * Perform the low-level reset. + */ +void reset_cpu(ulong addr) +{ + /* + * Perform reset but keep priority group unchanged. + */ + writel((V7M_AIRCR_VECTKEY << V7M_AIRCR_VECTKEY_SHIFT) + | (V7M_SCB->aircr & V7M_AIRCR_PRIGROUP_MSK) + | V7M_AIRCR_SYSRESET, &V7M_SCB->aircr); +} diff --git a/arch/arm/cpu/armv7m/start.S b/arch/arm/cpu/armv7m/start.S new file mode 100644 index 0000000..e05e984 --- /dev/null +++ b/arch/arm/cpu/armv7m/start.S @@ -0,0 +1,15 @@ +/* + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +.globl reset +.type reset, %function +reset: + b _main + +.globl c_runtime_cpu_setup +c_runtime_cpu_setup: + mov pc, lr diff --git a/arch/arm/include/asm/armv7m.h b/arch/arm/include/asm/armv7m.h new file mode 100644 index 0000000..d2aa1c4 --- /dev/null +++ b/arch/arm/include/asm/armv7m.h @@ -0,0 +1,60 @@ +/* + * (C) Copyright 2010,2011 + * Vladimir Khusainov, Emcraft Systems, vlad@emcraft.com + * + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARMV7M_H +#define ARMV7M_H + +#if defined(__ASSEMBLY__) +.syntax unified +.thumb +#endif + +#define V7M_SCB_BASE 0xE000ED00 +#define V7M_MPU_BASE 0xE000ED90 + +#define V7M_SCB_VTOR 0x08 + +#if !defined(__ASSEMBLY__) +struct v7m_scb { + uint32_t cpuid; /* CPUID Base Register */ + uint32_t icsr; /* Interrupt Control and State Register */ + uint32_t vtor; /* Vector Table Offset Register */ + uint32_t aircr; /* App Interrupt and Reset Control Register */ +}; +#define V7M_SCB ((struct v7m_scb *)V7M_SCB_BASE) + +#define V7M_AIRCR_VECTKEY 0x5fa +#define V7M_AIRCR_VECTKEY_SHIFT 16 +#define V7M_AIRCR_ENDIAN (1 << 15) +#define V7M_AIRCR_PRIGROUP_SHIFT 8 +#define V7M_AIRCR_PRIGROUP_MSK (0x7 << V7M_AIRCR_PRIGROUP_SHIFT) +#define V7M_AIRCR_SYSRESET (1 << 2) + +#define V7M_ICSR_VECTACT_MSK 0xFF + +struct v7m_mpu { + uint32_t type; /* Type Register */ + uint32_t ctrl; /* Control Register */ + uint32_t rnr; /* Region Number Register */ + uint32_t rbar; /* Region Base Address Register */ + uint32_t rasr; /* Region Attribute and Size Register */ +}; +#define V7M_MPU ((struct v7m_mpu *)V7M_MPU_BASE) + +#define V7M_MPU_CTRL_ENABLE (1 << 0) +#define V7M_MPU_CTRL_HFNMIENA (1 << 1) + +#define V7M_MPU_RASR_EN (1 << 0) +#define V7M_MPU_RASR_SIZE_BITS 1 +#define V7M_MPU_RASR_SIZE_4GB (31 << V7M_MPU_RASR_SIZE_BITS) +#define V7M_MPU_RASR_AP_RW_RW (3 << 24) + +#endif /* !defined(__ASSEMBLY__) */ +#endif /* ARMV7M_H */ diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index d74e4b8..3cfeb14 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -8,7 +8,9 @@ lib-$(CONFIG_USE_PRIVATE_LIBGCC) += _ashldi3.o _ashrdi3.o _divsi3.o \ _lshrdi3.o _modsi3.o _udivsi3.o _umodsi3.o div0.o
-ifdef CONFIG_ARM64 +ifdef CONFIG_CPU_V7M +obj-y += vectors_m.o crt0.o +else ifdef CONFIG_ARM64 obj-y += crt0_64.o else obj-y += vectors.o crt0.o @@ -35,7 +37,9 @@ endif obj-$(CONFIG_SEMIHOSTING) += semihosting.o
obj-y += sections.o -ifdef CONFIG_ARM64 +ifdef CONFIG_CPU_V7M +obj-y += interrupts_m.o +else ifdef CONFIG_ARM64 obj-y += gic_64.o obj-y += interrupts_64.o else diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index 22df3e5..51e6bb8 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -9,6 +9,9 @@ #include <config.h> #include <asm-offsets.h> #include <linux/linkage.h> +#ifdef CONFIG_CPU_V7M +#include <asm/armv7m.h> +#endif
/* * This file handles the target-independent stages of the U-Boot @@ -66,15 +69,30 @@ ENTRY(_main) #else ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) #endif +#if defined(CONFIG_CPU_V7M) /* v7M forbids using SP as BIC destination */ + mov r3, sp + bic r3, r3, #7 + mov sp, r3 +#else bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ +#endif mov r2, sp sub sp, sp, #GD_SIZE /* allocate one GD above SP */ +#if defined(CONFIG_CPU_V7M) /* v7M forbids using SP as BIC destination */ + mov r3, sp + bic r3, r3, #7 + mov sp, r3 +#else bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ +#endif mov r9, sp /* GD is above SP */ mov r1, sp mov r0, #0 clr_gd: cmp r1, r2 /* while not at end of GD */ +#if defined(CONFIG_CPU_V7M) + itt lo +#endif strlo r0, [r1] /* clear 32-bit GD word */ addlo r1, r1, #4 /* move to next */ blo clr_gd @@ -94,13 +112,22 @@ clr_gd: */
ldr sp, [r9, #GD_START_ADDR_SP] /* sp = gd->start_addr_sp */ +#if defined(CONFIG_CPU_V7M) /* v7M forbids using SP as BIC destination */ + mov r3, sp + bic r3, r3, #7 + mov sp, r3 +#else bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ +#endif ldr r9, [r9, #GD_BD] /* r9 = gd->bd */ sub r9, r9, #GD_SIZE /* new GD is below bd */
adr lr, here ldr r0, [r9, #GD_RELOC_OFF] /* r0 = gd->reloc_off */ add lr, lr, r0 +#if defined(CONFIG_CPU_V7M) + orr lr, #1 /* As required by Thumb-only */ +#endif ldr r0, [r9, #GD_RELOCADDR] /* r0 = gd->relocaddr */ b relocate_code here: @@ -120,6 +147,9 @@ here: mov r2, #0x00000000 /* prepare zero to clear BSS */
clbss_l:cmp r0, r1 /* while not at end of BSS */ +#if defined(CONFIG_CPU_V7M) + itt lo +#endif strlo r2, [r0] /* clear 32-bit BSS word */ addlo r0, r0, #4 /* move to next */ blo clbss_l diff --git a/arch/arm/lib/interrupts_m.c b/arch/arm/lib/interrupts_m.c new file mode 100644 index 0000000..89ce493 --- /dev/null +++ b/arch/arm/lib/interrupts_m.c @@ -0,0 +1,95 @@ +/* + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +/* + * Upon exception entry ARMv7-M processors automatically save stack + * frames containing some registers. For simplicity initial + * implementation uses only this auto-saved stack frame. + * This does not contain complete register set dump, + * only R0-R3, R12, LR, PC and xPSR are saved. + */ + +struct autosave_regs { + long uregs[8]; +}; + +#define ARM_XPSR uregs[7] +#define ARM_PC uregs[6] +#define ARM_LR uregs[5] +#define ARM_R12 uregs[4] +#define ARM_R3 uregs[3] +#define ARM_R2 uregs[2] +#define ARM_R1 uregs[1] +#define ARM_R0 uregs[0] + +int interrupt_init(void) +{ + return 0; +} + +void enable_interrupts(void) +{ + return; +} + +int disable_interrupts(void) +{ + return 0; +} + +void dump_regs(struct autosave_regs *regs) +{ + printf("pc : %08lx lr : %08lx xPSR : %08lx\n", + regs->ARM_PC, regs->ARM_LR, regs->ARM_XPSR); + printf("r12 : %08lx r3 : %08lx r2 : %08lx\n" + "r1 : %08lx r0 : %08lx\n", + regs->ARM_R12, regs->ARM_R3, regs->ARM_R2, + regs->ARM_R1, regs->ARM_R0); +} + +void bad_mode(void) +{ + panic("Resetting CPU ...\n"); + reset_cpu(0); +} + +void do_hard_fault(struct autosave_regs *autosave_regs) +{ + printf("Hard fault\n"); + dump_regs(autosave_regs); + bad_mode(); +} + +void do_mm_fault(struct autosave_regs *autosave_regs) +{ + printf("Memory management fault\n"); + dump_regs(autosave_regs); + bad_mode(); +} + +void do_bus_fault(struct autosave_regs *autosave_regs) +{ + printf("Bus fault\n"); + dump_regs(autosave_regs); + bad_mode(); +} + +void do_usage_fault(struct autosave_regs *autosave_regs) +{ + printf("Usage fault\n"); + dump_regs(autosave_regs); + bad_mode(); +} + +void do_invalid_entry(struct autosave_regs *autosave_regs) +{ + printf("Exception\n"); + dump_regs(autosave_regs); + bad_mode(); +} diff --git a/arch/arm/lib/relocate.S b/arch/arm/lib/relocate.S index 92f5314..475d503 100644 --- a/arch/arm/lib/relocate.S +++ b/arch/arm/lib/relocate.S @@ -9,6 +9,9 @@ #include <asm-offsets.h> #include <config.h> #include <linux/linkage.h> +#ifdef CONFIG_CPU_V7M +#include <asm/armv7m.h> +#endif
/* * Default/weak exception vectors relocation routine @@ -23,6 +26,15 @@
ENTRY(relocate_vectors)
+#ifdef CONFIG_CPU_V7M + /* + * On ARMv7-M we only have to write the new vector address + * to VTOR register. + */ + ldr r0, [r9, #GD_RELOCADDR] /* r0 = gd->relocaddr */ + ldr r1, =V7M_SCB_BASE + str r0, [r1, V7M_SCB_VTOR] +#else #ifdef CONFIG_HAS_VBAR /* * If the ARM processor has the security extensions, @@ -47,6 +59,7 @@ ENTRY(relocate_vectors) ldmia r0!, {r2-r8,r10} stmia r1!, {r2-r8,r10} #endif +#endif bx lr
ENDPROC(relocate_vectors) diff --git a/arch/arm/lib/vectors_m.S b/arch/arm/lib/vectors_m.S new file mode 100644 index 0000000..abc7f88 --- /dev/null +++ b/arch/arm/lib/vectors_m.S @@ -0,0 +1,57 @@ +/* + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <asm/armv7m.h> +#include <linux/linkage.h> + +.type __hard_fault_entry, %function +__hard_fault_entry: + mov r0, sp @ pass auto-saved registers as argument + b do_hard_fault + +.type __mm_fault_entry, %function +__mm_fault_entry: + mov r0, sp @ pass auto-saved registers as argument + b do_mm_fault + +.type __bus_fault_entry, %function +__bus_fault_entry: + mov r0, sp @ pass auto-saved registers as argument + b do_bus_fault + +.type __usage_fault_entry, %function +__usage_fault_entry: + mov r0, sp @ pass auto-saved registers as argument + b do_usage_fault + +.type __invalid_entry, %function +__invalid_entry: + mov r0, sp @ pass auto-saved registers as argument + b do_invalid_entry + + .section .vectors +ENTRY(_start) + .long CONFIG_SYS_INIT_SP_ADDR @ 0 - Reset stack pointer + .long reset @ 1 - Reset + .long __invalid_entry @ 2 - NMI + .long __hard_fault_entry @ 3 - HardFault + .long __mm_fault_entry @ 4 - MemManage + .long __bus_fault_entry @ 5 - BusFault + .long __usage_fault_entry @ 6 - UsageFault + .long __invalid_entry @ 7 - Reserved + .long __invalid_entry @ 8 - Reserved + .long __invalid_entry @ 9 - Reserved + .long __invalid_entry @ 10 - Reserved + .long __invalid_entry @ 11 - SVCall + .long __invalid_entry @ 12 - Debug Monitor + .long __invalid_entry @ 13 - Reserved + .long __invalid_entry @ 14 - PendSV + .long __invalid_entry @ 15 - SysTick + .rept 255 - 16 + .long __invalid_entry @ 16..255 - External Interrupts + .endr
[snip]
[snip]
- mov r3, sp
- bic r3, r3, #7
- mov sp, r3
There's 4 places where this change comes in. Albert, what do you think about always just doing this in 3 instructions with a comment in the first instance about v7-M support?
Am 05.03.2015 um 16:32 schrieb Tom Rini:
[snip]
[snip]
- mov r3, sp
- bic r3, r3, #7
- mov sp, r3
I remember running into problems like these when working on STM32F429 support late last year and I adopted some helper macros from Linux, I believe. The same problem existed in U-Boot's private libgcc code.
Regards, Andreas
[snip]
[snip]
- mov r3, sp
- bic r3, r3, #7
- mov sp, r3
What macros did you use from the kernel? Thanks!
Signed-off-by: Kamil Lulko rev13@wp.pl --- arch/arm/cpu/armv7m/Makefile | 1 + arch/arm/cpu/armv7m/stm32f4/Makefile | 11 ++ arch/arm/cpu/armv7m/stm32f4/clock.c | 209 ++++++++++++++++++++++++++++++ arch/arm/cpu/armv7m/stm32f4/flash.c | 143 ++++++++++++++++++++ arch/arm/cpu/armv7m/stm32f4/soc.c | 37 ++++++ arch/arm/cpu/armv7m/stm32f4/timer.c | 118 +++++++++++++++++ arch/arm/include/asm/arch-stm32f4/fmc.h | 75 +++++++++++ arch/arm/include/asm/arch-stm32f4/gpio.h | 116 +++++++++++++++++ arch/arm/include/asm/arch-stm32f4/stm32.h | 108 +++++++++++++++ drivers/gpio/Makefile | 1 + drivers/gpio/stm32_gpio.c | 199 ++++++++++++++++++++++++++++ include/flash.h | 2 + 12 files changed, 1020 insertions(+) create mode 100644 arch/arm/cpu/armv7m/stm32f4/Makefile create mode 100644 arch/arm/cpu/armv7m/stm32f4/clock.c create mode 100644 arch/arm/cpu/armv7m/stm32f4/flash.c create mode 100644 arch/arm/cpu/armv7m/stm32f4/soc.c create mode 100644 arch/arm/cpu/armv7m/stm32f4/timer.c create mode 100644 arch/arm/include/asm/arch-stm32f4/fmc.h create mode 100644 arch/arm/include/asm/arch-stm32f4/gpio.h create mode 100644 arch/arm/include/asm/arch-stm32f4/stm32.h create mode 100644 drivers/gpio/stm32_gpio.c
diff --git a/arch/arm/cpu/armv7m/Makefile b/arch/arm/cpu/armv7m/Makefile index a187f6e..b662e03 100644 --- a/arch/arm/cpu/armv7m/Makefile +++ b/arch/arm/cpu/armv7m/Makefile @@ -8,3 +8,4 @@ extra-y := start.o obj-y += cpu.o
+obj-$(CONFIG_STM32F4) += stm32f4/ diff --git a/arch/arm/cpu/armv7m/stm32f4/Makefile b/arch/arm/cpu/armv7m/stm32f4/Makefile new file mode 100644 index 0000000..e982830 --- /dev/null +++ b/arch/arm/cpu/armv7m/stm32f4/Makefile @@ -0,0 +1,11 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2015 +# Kamil Lulko, rev13@wp.pl +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += soc.o clock.o timer.o flash.o diff --git a/arch/arm/cpu/armv7m/stm32f4/clock.c b/arch/arm/cpu/armv7m/stm32f4/clock.c new file mode 100644 index 0000000..2eded1f --- /dev/null +++ b/arch/arm/cpu/armv7m/stm32f4/clock.c @@ -0,0 +1,209 @@ +/* + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * (C) Copyright 2014 + * STMicroelectronics + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/stm32.h> + +#define RCC_CR_HSION (1 << 0) +#define RCC_CR_HSEON (1 << 16) +#define RCC_CR_HSERDY (1 << 17) +#define RCC_CR_HSEBYP (1 << 18) +#define RCC_CR_CSSON (1 << 19) +#define RCC_CR_PLLON (1 << 24) +#define RCC_CR_PLLRDY (1 << 25) + +#define RCC_PLLCFGR_PLLM_MASK 0x3F +#define RCC_PLLCFGR_PLLN_MASK 0x7FC0 +#define RCC_PLLCFGR_PLLP_MASK 0x30000 +#define RCC_PLLCFGR_PLLQ_MASK 0xF000000 +#define RCC_PLLCFGR_PLLSRC (1 << 22) +#define RCC_PLLCFGR_PLLN_SHIFT 6 +#define RCC_PLLCFGR_PLLP_SHIFT 16 +#define RCC_PLLCFGR_PLLQ_SHIFT 24 + +#define RCC_CFGR_AHB_PSC_MASK 0xF0 +#define RCC_CFGR_APB1_PSC_MASK 0x1C00 +#define RCC_CFGR_APB2_PSC_MASK 0xE000 +#define RCC_CFGR_SW0 (1 << 0) +#define RCC_CFGR_SW1 (1 << 1) +#define RCC_CFGR_SW_MASK 0x3 +#define RCC_CFGR_SW_HSI 0 +#define RCC_CFGR_SW_HSE RCC_CFGR_SW0 +#define RCC_CFGR_SW_PLL RCC_CFGR_SW1 +#define RCC_CFGR_SWS0 (1 << 2) +#define RCC_CFGR_SWS1 (1 << 3) +#define RCC_CFGR_SWS_MASK 0xC +#define RCC_CFGR_SWS_HSI 0 +#define RCC_CFGR_SWS_HSE RCC_CFGR_SWS0 +#define RCC_CFGR_SWS_PLL RCC_CFGR_SWS1 +#define RCC_CFGR_HPRE_SHIFT 4 +#define RCC_CFGR_PPRE1_SHIFT 10 +#define RCC_CFGR_PPRE2_SHIFT 13 + +#define RCC_APB1ENR_PWREN (1 << 28) + +#define PWR_CR_VOS0 (1 << 14) +#define PWR_CR_VOS1 (1 << 15) +#define PWR_CR_VOS_MASK 0xC000 +#define PWR_CR_VOS_SCALE_MODE_1 (PWR_CR_VOS0 | PWR_CR_VOS1) +#define PWR_CR_VOS_SCALE_MODE_2 (PWR_CR_VOS1) +#define PWR_CR_VOS_SCALE_MODE_3 (PWR_CR_VOS0) + +#define FLASH_ACR_WS(n) n +#define FLASH_ACR_PRFTEN (1 << 8) +#define FLASH_ACR_ICEN (1 << 9) +#define FLASH_ACR_DCEN (1 << 10) + +struct pll_psc { + u8 pll_m; + u16 pll_n; + u8 pll_p; + u8 pll_q; + u8 ahb_psc; + u8 apb1_psc; + u8 apb2_psc; +}; + +#define AHB_PSC_1 0 +#define AHB_PSC_2 0x8 +#define AHB_PSC_4 0x9 +#define AHB_PSC_8 0xA +#define AHB_PSC_16 0xB +#define AHB_PSC_64 0xC +#define AHB_PSC_128 0xD +#define AHB_PSC_256 0xE +#define AHB_PSC_512 0xF + +#define APB_PSC_1 0 +#define APB_PSC_2 0x4 +#define APB_PSC_4 0x5 +#define APB_PSC_8 0x6 +#define APB_PSC_16 0x7 + +#if !defined(CONFIG_STM32_HSE_HZ) +#error "CONFIG_STM32_HSE_HZ not defined!" +#else +#if (CONFIG_STM32_HSE_HZ == 8000000) +struct pll_psc pll_psc_168 = { + .pll_m = 8, + .pll_n = 336, + .pll_p = 2, + .pll_q = 7, + .ahb_psc = AHB_PSC_1, + .apb1_psc = APB_PSC_4, + .apb2_psc = APB_PSC_2 +}; +#else +#error "No PLL/Prescaler configuration for given CONFIG_STM32_HSE_HZ exists" +#endif +#endif + +int configure_clocks(void) +{ + /* Reset RCC configuration */ + setbits_le32(&STM32_RCC->cr, RCC_CR_HSION); + writel(0, &STM32_RCC->cfgr); /* Reset CFGR */ + clrbits_le32(&STM32_RCC->cr, (RCC_CR_HSEON | RCC_CR_CSSON + | RCC_CR_PLLON)); + writel(0x24003010, &STM32_RCC->pllcfgr); /* Reset value from RM */ + clrbits_le32(&STM32_RCC->cr, RCC_CR_HSEBYP); + writel(0, &STM32_RCC->cir); /* Disable all interrupts */ + + /* Configure for HSE+PLL operation */ + setbits_le32(&STM32_RCC->cr, RCC_CR_HSEON); + while (!(readl(&STM32_RCC->cr) & RCC_CR_HSERDY)) + ; + + /* Enable high performance mode, System frequency up to 168 MHz */ + setbits_le32(&STM32_RCC->apb1enr, RCC_APB1ENR_PWREN); + writel(PWR_CR_VOS_SCALE_MODE_1, &STM32_PWR->cr); + + setbits_le32(&STM32_RCC->cfgr, (( + pll_psc_168.ahb_psc << RCC_CFGR_HPRE_SHIFT) + | (pll_psc_168.apb1_psc << RCC_CFGR_PPRE1_SHIFT) + | (pll_psc_168.apb2_psc << RCC_CFGR_PPRE2_SHIFT))); + + writel(pll_psc_168.pll_m + | (pll_psc_168.pll_n << RCC_PLLCFGR_PLLN_SHIFT) + | (((pll_psc_168.pll_p >> 1) - 1) << RCC_PLLCFGR_PLLP_SHIFT) + | (pll_psc_168.pll_q << RCC_PLLCFGR_PLLQ_SHIFT), + &STM32_RCC->pllcfgr); + setbits_le32(&STM32_RCC->pllcfgr, RCC_PLLCFGR_PLLSRC); + + setbits_le32(&STM32_RCC->cr, RCC_CR_PLLON); + + while (!(readl(&STM32_RCC->cr) & RCC_CR_PLLRDY)) + ; + + /* 5 wait states, Prefetch enabled, D-Cache enabled, I-Cache enabled */ + writel(FLASH_ACR_WS(5) | FLASH_ACR_PRFTEN | FLASH_ACR_ICEN + | FLASH_ACR_DCEN, &STM32_FLASH->acr); + + clrbits_le32(&STM32_RCC->cfgr, (RCC_CFGR_SW0 | RCC_CFGR_SW1)); + setbits_le32(&STM32_RCC->cfgr, RCC_CFGR_SW_PLL); + + while ((readl(&STM32_RCC->cfgr) & RCC_CFGR_SWS_MASK) != + RCC_CFGR_SWS_PLL) + ; + + return 0; +} + +unsigned long clock_get(enum clock clck) +{ + u32 sysclk = 0; + u32 shift = 0; + /* Prescaler table lookups for clock computation */ + u8 ahb_psc_table[16] = { + 0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9 + }; + u8 apb_psc_table[8] = { + 0, 0, 0, 0, 1, 2, 3, 4 + }; + + if ((readl(&STM32_RCC->cfgr) & RCC_CFGR_SWS_MASK) == + RCC_CFGR_SWS_PLL) { + u16 pllm, plln, pllp; + pllm = (readl(&STM32_RCC->pllcfgr) & RCC_PLLCFGR_PLLM_MASK); + plln = ((readl(&STM32_RCC->pllcfgr) & RCC_PLLCFGR_PLLN_MASK) + >> RCC_PLLCFGR_PLLN_SHIFT); + pllp = ((((readl(&STM32_RCC->pllcfgr) & RCC_PLLCFGR_PLLP_MASK) + >> RCC_PLLCFGR_PLLP_SHIFT) + 1) << 1); + sysclk = ((CONFIG_STM32_HSE_HZ / pllm) * plln) / pllp; + } + + switch (clck) { + case CLOCK_CORE: + return sysclk; + break; + case CLOCK_AHB: + shift = ahb_psc_table[( + (readl(&STM32_RCC->cfgr) & RCC_CFGR_AHB_PSC_MASK) + >> RCC_CFGR_HPRE_SHIFT)]; + return sysclk >>= shift; + break; + case CLOCK_APB1: + shift = apb_psc_table[( + (readl(&STM32_RCC->cfgr) & RCC_CFGR_APB1_PSC_MASK) + >> RCC_CFGR_PPRE1_SHIFT)]; + return sysclk >>= shift; + break; + case CLOCK_APB2: + shift = apb_psc_table[( + (readl(&STM32_RCC->cfgr) & RCC_CFGR_APB2_PSC_MASK) + >> RCC_CFGR_PPRE2_SHIFT)]; + return sysclk >>= shift; + break; + default: + return 0; + break; + } +} diff --git a/arch/arm/cpu/armv7m/stm32f4/flash.c b/arch/arm/cpu/armv7m/stm32f4/flash.c new file mode 100644 index 0000000..e5c6111 --- /dev/null +++ b/arch/arm/cpu/armv7m/stm32f4/flash.c @@ -0,0 +1,143 @@ +/* + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/stm32.h> + +#define STM32_FLASH_KEY1 0x45670123 +#define STM32_FLASH_KEY2 0xCDEF89AB + +flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; + +const u32 sect_sz_kb[CONFIG_SYS_MAX_FLASH_SECT] = { + [0 ... 3] = 16 * 1024, + [4] = 64 * 1024, + [5 ... 11] = 128 * 1024 +}; + +static void stm32f4_flash_lock(u8 lock) +{ + if (lock) { + setbits_le32(&STM32_FLASH->cr, STM32_FLASH_CR_LOCK); + } else { + writel(STM32_FLASH_KEY1, &STM32_FLASH->key); + writel(STM32_FLASH_KEY2, &STM32_FLASH->key); + } +} + +unsigned long flash_init(void) +{ + unsigned long total_size = 0; + u8 i, j; + + for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { + flash_info[i].flash_id = FLASH_STM32F4; + flash_info[i].sector_count = CONFIG_SYS_MAX_FLASH_SECT; + flash_info[i].start[0] = CONFIG_SYS_FLASH_BASE + (i << 20); + flash_info[i].size = sect_sz_kb[0]; + for (j = 1; j < CONFIG_SYS_MAX_FLASH_SECT; j++) { + flash_info[i].start[j] = flash_info[i].start[j - 1] + + (sect_sz_kb[j - 1]); + flash_info[i].size += sect_sz_kb[j]; + } + total_size += flash_info[i].size; + } + + return total_size; +} + +void flash_print_info(flash_info_t *info) +{ + int i; + + if (info->flash_id == FLASH_UNKNOWN) { + printf("missing or unknown FLASH type\n"); + return; + } else if (info->flash_id == FLASH_STM32F4) { + printf("STM32F4 Embedded Flash\n"); + } + + printf(" Size: %ld MB in %d Sectors\n", + info->size >> 20, info->sector_count); + + printf(" Sector Start Addresses:"); + for (i = 0; i < info->sector_count; ++i) { + if ((i % 5) == 0) + printf("\n "); + printf(" %08lX%s", + info->start[i], + info->protect[i] ? " (RO)" : " "); + } + printf("\n"); + return; +} + +int flash_erase(flash_info_t *info, int first, int last) +{ + u8 bank = 0xFF; + int i; + + for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { + if (info == &flash_info[i]) { + bank = i; + break; + } + } + if (bank == 0xFF) + return -1; + + stm32f4_flash_lock(0); + + for (i = first; i <= last; i++) { + while (readl(&STM32_FLASH->sr) & STM32_FLASH_SR_BSY) + ; + + if (bank == 0) { + setbits_le32(&STM32_FLASH->cr, + (i << STM32_FLASH_CR_SNB_OFFSET)); + } else if (bank == 1) { + setbits_le32(&STM32_FLASH->cr, + ((0x10 | i) << STM32_FLASH_CR_SNB_OFFSET)); + } else { + stm32f4_flash_lock(1); + return -1; + } + setbits_le32(&STM32_FLASH->cr, STM32_FLASH_CR_SER); + setbits_le32(&STM32_FLASH->cr, STM32_FLASH_CR_STRT); + + while (readl(&STM32_FLASH->sr) & STM32_FLASH_SR_BSY) + ; + + clrbits_le32(&STM32_FLASH->cr, STM32_FLASH_CR_SER); + stm32f4_flash_lock(1); + } + + return 0; +} + +int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) +{ + ulong i; + + while (readl(&STM32_FLASH->sr) & STM32_FLASH_SR_BSY) + ; + + stm32f4_flash_lock(0); + + setbits_le32(&STM32_FLASH->cr, STM32_FLASH_CR_PG); + /* To make things simple use byte writes only */ + for (i = 0; i < cnt; i++) { + *(uchar *)(addr + i) = src[i]; + while (readl(&STM32_FLASH->sr) & STM32_FLASH_SR_BSY) + ; + } + clrbits_le32(&STM32_FLASH->cr, STM32_FLASH_CR_PG); + stm32f4_flash_lock(1); + + return 0; +} diff --git a/arch/arm/cpu/armv7m/stm32f4/soc.c b/arch/arm/cpu/armv7m/stm32f4/soc.c new file mode 100644 index 0000000..202a126 --- /dev/null +++ b/arch/arm/cpu/armv7m/stm32f4/soc.c @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/armv7m.h> +#include <asm/arch/stm32.h> + +u32 get_cpu_rev(void) +{ + return 0; +} + +int arch_cpu_init(void) +{ + configure_clocks(); + + /* + * Configure the memory protection unit (MPU) to allow full access to + * the whole 4GB address space. + */ + writel(0, &V7M_MPU->rnr); + writel(0, &V7M_MPU->rbar); + writel((V7M_MPU_RASR_AP_RW_RW | V7M_MPU_RASR_SIZE_4GB + | V7M_MPU_RASR_EN), &V7M_MPU->rasr); + writel(V7M_MPU_CTRL_ENABLE | V7M_MPU_CTRL_HFNMIENA, &V7M_MPU->ctrl); + + return 0; +} + +void s_init(void) +{ +} diff --git a/arch/arm/cpu/armv7m/stm32f4/timer.c b/arch/arm/cpu/armv7m/stm32f4/timer.c new file mode 100644 index 0000000..102ae6d --- /dev/null +++ b/arch/arm/cpu/armv7m/stm32f4/timer.c @@ -0,0 +1,118 @@ +/* + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/armv7m.h> +#include <asm/arch/stm32.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define STM32_TIM2_BASE (STM32_APB1PERIPH_BASE + 0x0000) + +#define RCC_APB1ENR_TIM2EN (1 << 0) + +struct stm32_tim2_5 { + u32 cr1; + u32 cr2; + u32 smcr; + u32 dier; + u32 sr; + u32 egr; + u32 ccmr1; + u32 ccmr2; + u32 ccer; + u32 cnt; + u32 psc; + u32 arr; + u32 reserved1; + u32 ccr1; + u32 ccr2; + u32 ccr3; + u32 ccr4; + u32 reserved2; + u32 dcr; + u32 dmar; + u32 or; +}; + +#define TIM_CR1_CEN (1 << 0) + +#define TIM_EGR_UG (1 << 0) + +int timer_init(void) +{ + struct stm32_tim2_5 *tim = (struct stm32_tim2_5 *)STM32_TIM2_BASE; + + setbits_le32(&STM32_RCC->apb1enr, RCC_APB1ENR_TIM2EN); + + if (clock_get(CLOCK_AHB) == clock_get(CLOCK_APB1)) + writel((clock_get(CLOCK_APB1) / CONFIG_SYS_HZ_CLOCK) - 1, + &tim->psc); + else + writel(((clock_get(CLOCK_APB1) * 2) / CONFIG_SYS_HZ_CLOCK) - 1, + &tim->psc); + + writel(0xFFFFFFFF, &tim->arr); + writel(TIM_CR1_CEN, &tim->cr1); + setbits_le32(&tim->egr, TIM_EGR_UG); + + gd->arch.tbl = 0; + gd->arch.tbu = 0; + gd->arch.lastinc = 0; + + return 0; +} + +ulong get_timer(ulong base) +{ + return (get_ticks() / (CONFIG_SYS_HZ_CLOCK / CONFIG_SYS_HZ)) - base; +} + +unsigned long long get_ticks(void) +{ + struct stm32_tim2_5 *tim = (struct stm32_tim2_5 *)STM32_TIM2_BASE; + u32 now; + + now = readl(&tim->cnt); + + if (now >= gd->arch.lastinc) + gd->arch.tbl += (now - gd->arch.lastinc); + else + gd->arch.tbl += (0xFFFFFFFF - gd->arch.lastinc) + now; + + gd->arch.lastinc = now; + + return gd->arch.tbl; +} + +void reset_timer(void) +{ + struct stm32_tim2_5 *tim = (struct stm32_tim2_5 *)STM32_TIM2_BASE; + + gd->arch.lastinc = readl(&tim->cnt); + gd->arch.tbl = 0; +} + +/* delay x useconds */ +void __udelay(ulong usec) +{ + unsigned long long start; + + start = get_ticks(); /* get current timestamp */ + while ((get_ticks() - start) < usec) + ; /* loop till time has passed */ +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ_CLOCK; +} diff --git a/arch/arm/include/asm/arch-stm32f4/fmc.h b/arch/arm/include/asm/arch-stm32f4/fmc.h new file mode 100644 index 0000000..4ab3031 --- /dev/null +++ b/arch/arm/include/asm/arch-stm32f4/fmc.h @@ -0,0 +1,75 @@ +/* + * (C) Copyright 2013 + * Pavel Boldin, Emcraft Systems, paboldin@emcraft.com + * + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _MACH_FMC_H_ +#define _MACH_FMC_H_ + +struct stm32_fmc_regs { + u32 sdcr1; /* Control register 1 */ + u32 sdcr2; /* Control register 2 */ + u32 sdtr1; /* Timing register 1 */ + u32 sdtr2; /* Timing register 2 */ + u32 sdcmr; /* Mode register */ + u32 sdrtr; /* Refresh timing register */ + u32 sdsr; /* Status register */ +}; + +/* + * FMC registers base + */ +#define STM32_SDRAM_FMC_BASE 0xA0000140 +#define STM32_SDRAM_FMC ((struct stm32_fmc_regs *)STM32_SDRAM_FMC_BASE) + +/* Control register SDCR */ +#define FMC_SDCR_RPIPE_SHIFT 13 /* RPIPE bit shift */ +#define FMC_SDCR_RBURST_SHIFT 12 /* RBURST bit shift */ +#define FMC_SDCR_SDCLK_SHIFT 10 /* SDRAM clock divisor shift */ +#define FMC_SDCR_WP_SHIFT 9 /* Write protection shift */ +#define FMC_SDCR_CAS_SHIFT 7 /* CAS latency shift */ +#define FMC_SDCR_NB_SHIFT 6 /* Number of banks shift */ +#define FMC_SDCR_MWID_SHIFT 4 /* Memory width shift */ +#define FMC_SDCR_NR_SHIFT 2 /* Number of row address bits shift */ +#define FMC_SDCR_NC_SHIFT 0 /* Number of col address bits shift */ + +/* Timings register SDTR */ +#define FMC_SDTR_TMRD_SHIFT 0 /* Load mode register to active */ +#define FMC_SDTR_TXSR_SHIFT 4 /* Exit self-refresh time */ +#define FMC_SDTR_TRAS_SHIFT 8 /* Self-refresh time */ +#define FMC_SDTR_TRC_SHIFT 12 /* Row cycle delay */ +#define FMC_SDTR_TWR_SHIFT 16 /* Recovery delay */ +#define FMC_SDTR_TRP_SHIFT 20 /* Row precharge delay */ +#define FMC_SDTR_TRCD_SHIFT 24 /* Row-to-column delay */ + + +#define FMC_SDCMR_NRFS_SHIFT 5 + +#define FMC_SDCMR_MODE_NORMAL 0 +#define FMC_SDCMR_MODE_START_CLOCK 1 +#define FMC_SDCMR_MODE_PRECHARGE 2 +#define FMC_SDCMR_MODE_AUTOREFRESH 3 +#define FMC_SDCMR_MODE_WRITE_MODE 4 +#define FMC_SDCMR_MODE_SELFREFRESH 5 +#define FMC_SDCMR_MODE_POWERDOWN 6 + +#define FMC_SDCMR_BANK_1 (1 << 4) +#define FMC_SDCMR_BANK_2 (1 << 3) + +#define FMC_SDCMR_MODE_REGISTER_SHIFT 9 + +#define FMC_SDSR_BUSY (1 << 5) + +#define FMC_BUSY_WAIT() do { \ + __asm__ __volatile__ ("dsb" : : : "memory"); \ + while (STM32_SDRAM_FMC->sdsr & FMC_SDSR_BUSY) \ + ; \ + } while (0) + + +#endif /* _MACH_FMC_H_ */ diff --git a/arch/arm/include/asm/arch-stm32f4/gpio.h b/arch/arm/include/asm/arch-stm32f4/gpio.h new file mode 100644 index 0000000..7cd866e --- /dev/null +++ b/arch/arm/include/asm/arch-stm32f4/gpio.h @@ -0,0 +1,116 @@ +/* + * (C) Copyright 2011 + * Yuri Tikhonov, Emcraft Systems, yur@emcraft.com + * + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _STM32_GPIO_H_ +#define _STM32_GPIO_H_ + +enum stm32_gpio_port { + STM32_GPIO_PORT_A = 0, + STM32_GPIO_PORT_B, + STM32_GPIO_PORT_C, + STM32_GPIO_PORT_D, + STM32_GPIO_PORT_E, + STM32_GPIO_PORT_F, + STM32_GPIO_PORT_G, + STM32_GPIO_PORT_H, + STM32_GPIO_PORT_I +}; + +enum stm32_gpio_pin { + STM32_GPIO_PIN_0 = 0, + STM32_GPIO_PIN_1, + STM32_GPIO_PIN_2, + STM32_GPIO_PIN_3, + STM32_GPIO_PIN_4, + STM32_GPIO_PIN_5, + STM32_GPIO_PIN_6, + STM32_GPIO_PIN_7, + STM32_GPIO_PIN_8, + STM32_GPIO_PIN_9, + STM32_GPIO_PIN_10, + STM32_GPIO_PIN_11, + STM32_GPIO_PIN_12, + STM32_GPIO_PIN_13, + STM32_GPIO_PIN_14, + STM32_GPIO_PIN_15 +}; + +enum stm32_gpio_mode { + STM32_GPIO_MODE_IN = 0, + STM32_GPIO_MODE_OUT, + STM32_GPIO_MODE_AF, + STM32_GPIO_MODE_AN +}; + +enum stm32_gpio_otype { + STM32_GPIO_OTYPE_PP = 0, + STM32_GPIO_OTYPE_OD +}; + +enum stm32_gpio_speed { + STM32_GPIO_SPEED_2M = 0, + STM32_GPIO_SPEED_25M, + STM32_GPIO_SPEED_50M, + STM32_GPIO_SPEED_100M +}; + +enum stm32_gpio_pupd { + STM32_GPIO_PUPD_NO = 0, + STM32_GPIO_PUPD_UP, + STM32_GPIO_PUPD_DOWN +}; + +enum stm32_gpio_af { + STM32_GPIO_AF0 = 0, + STM32_GPIO_AF1, + STM32_GPIO_AF2, + STM32_GPIO_AF3, + STM32_GPIO_AF4, + STM32_GPIO_AF5, + STM32_GPIO_AF6, + STM32_GPIO_AF7, + STM32_GPIO_AF8, + STM32_GPIO_AF9, + STM32_GPIO_AF10, + STM32_GPIO_AF11, + STM32_GPIO_AF12, + STM32_GPIO_AF13, + STM32_GPIO_AF14, + STM32_GPIO_AF15 +}; + +struct stm32_gpio_dsc { + enum stm32_gpio_port port; + enum stm32_gpio_pin pin; +}; + +struct stm32_gpio_ctl { + enum stm32_gpio_mode mode; + enum stm32_gpio_otype otype; + enum stm32_gpio_speed speed; + enum stm32_gpio_pupd pupd; + enum stm32_gpio_af af; +}; + +static inline unsigned stm32_gpio_to_port(unsigned gpio) +{ + return gpio / 16; +} + +static inline unsigned stm32_gpio_to_pin(unsigned gpio) +{ + return gpio % 16; +} + +int stm32_gpio_config(const struct stm32_gpio_dsc *gpio_dsc, + const struct stm32_gpio_ctl *gpio_ctl); +int stm32_gpout_set(const struct stm32_gpio_dsc *gpio_dsc, int state); + +#endif /* _STM32_GPIO_H_ */ diff --git a/arch/arm/include/asm/arch-stm32f4/stm32.h b/arch/arm/include/asm/arch-stm32f4/stm32.h new file mode 100644 index 0000000..a9f88db --- /dev/null +++ b/arch/arm/include/asm/arch-stm32f4/stm32.h @@ -0,0 +1,108 @@ +/* + * (C) Copyright 2011 + * Yuri Tikhonov, Emcraft Systems, yur@emcraft.com + * + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _MACH_STM32_H_ +#define _MACH_STM32_H_ + +/* + * Peripheral memory map + */ +#define STM32_PERIPH_BASE 0x40000000 +#define STM32_APB1PERIPH_BASE (STM32_PERIPH_BASE + 0x00000000) +#define STM32_APB2PERIPH_BASE (STM32_PERIPH_BASE + 0x00010000) +#define STM32_AHB1PERIPH_BASE (STM32_PERIPH_BASE + 0x00020000) +#define STM32_AHB2PERIPH_BASE (STM32_PERIPH_BASE + 0x10000000) + +#define STM32_BUS_MASK 0xFFFF0000 + +/* + * Register maps + */ +struct stm32_rcc_regs { + u32 cr; /* RCC clock control */ + u32 pllcfgr; /* RCC PLL configuration */ + u32 cfgr; /* RCC clock configuration */ + u32 cir; /* RCC clock interrupt */ + u32 ahb1rstr; /* RCC AHB1 peripheral reset */ + u32 ahb2rstr; /* RCC AHB2 peripheral reset */ + u32 ahb3rstr; /* RCC AHB3 peripheral reset */ + u32 rsv0; + u32 apb1rstr; /* RCC APB1 peripheral reset */ + u32 apb2rstr; /* RCC APB2 peripheral reset */ + u32 rsv1[2]; + u32 ahb1enr; /* RCC AHB1 peripheral clock enable */ + u32 ahb2enr; /* RCC AHB2 peripheral clock enable */ + u32 ahb3enr; /* RCC AHB3 peripheral clock enable */ + u32 rsv2; + u32 apb1enr; /* RCC APB1 peripheral clock enable */ + u32 apb2enr; /* RCC APB2 peripheral clock enable */ + u32 rsv3[2]; + u32 ahb1lpenr; /* RCC AHB1 periph clk enable in low pwr mode */ + u32 ahb2lpenr; /* RCC AHB2 periph clk enable in low pwr mode */ + u32 ahb3lpenr; /* RCC AHB3 periph clk enable in low pwr mode */ + u32 rsv4; + u32 apb1lpenr; /* RCC APB1 periph clk enable in low pwr mode */ + u32 apb2lpenr; /* RCC APB2 periph clk enable in low pwr mode */ + u32 rsv5[2]; + u32 bdcr; /* RCC Backup domain control */ + u32 csr; /* RCC clock control & status */ + u32 rsv6[2]; + u32 sscgr; /* RCC spread spectrum clock generation */ + u32 plli2scfgr; /* RCC PLLI2S configuration */ + u32 pllsaicfgr; + u32 dckcfgr; +}; + +struct stm32_pwr_regs { + u32 cr; + u32 csr; +}; + +struct stm32_flash_regs { + u32 acr; + u32 key; + u32 optkeyr; + u32 sr; + u32 cr; + u32 optcr; + u32 optcr1; +}; + +/* + * Registers access macros + */ +#define STM32_RCC_BASE (STM32_AHB1PERIPH_BASE + 0x3800) +#define STM32_RCC ((struct stm32_rcc_regs *)STM32_RCC_BASE) + +#define STM32_PWR_BASE (STM32_APB1PERIPH_BASE + 0x7000) +#define STM32_PWR ((struct stm32_pwr_regs *)STM32_PWR_BASE) + +#define STM32_FLASH_BASE (STM32_AHB1PERIPH_BASE + 0x3C00) +#define STM32_FLASH ((struct stm32_flash_regs *)STM32_FLASH_BASE) + +#define STM32_FLASH_SR_BSY (1 << 16) + +#define STM32_FLASH_CR_PG (1 << 0) +#define STM32_FLASH_CR_SER (1 << 1) +#define STM32_FLASH_CR_STRT (1 << 16) +#define STM32_FLASH_CR_LOCK (1 << 31) +#define STM32_FLASH_CR_SNB_OFFSET 3 + +enum clock { + CLOCK_CORE, + CLOCK_AHB, + CLOCK_APB1, + CLOCK_APB2 +}; + +int configure_clocks(void); +unsigned long clock_get(enum clock clck); + +#endif /* _MACH_STM32_H_ */ diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index aa11f15..93b0ef6 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -37,3 +37,4 @@ obj-$(CONFIG_ADI_GPIO2) += adi_gpio2.o obj-$(CONFIG_TCA642X) += tca642x.o oby-$(CONFIG_SX151X) += sx151x.o obj-$(CONFIG_SUNXI_GPIO) += sunxi_gpio.o +obj-$(CONFIG_STM32_GPIO) += stm32_gpio.o diff --git a/drivers/gpio/stm32_gpio.c b/drivers/gpio/stm32_gpio.c new file mode 100644 index 0000000..d3497e9 --- /dev/null +++ b/drivers/gpio/stm32_gpio.c @@ -0,0 +1,199 @@ +/* + * (C) Copyright 2011 + * Yuri Tikhonov, Emcraft Systems, yur@emcraft.com + * + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/stm32.h> +#include <asm/arch/gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define STM32_GPIOA_BASE (STM32_AHB1PERIPH_BASE + 0x0000) +#define STM32_GPIOB_BASE (STM32_AHB1PERIPH_BASE + 0x0400) +#define STM32_GPIOC_BASE (STM32_AHB1PERIPH_BASE + 0x0800) +#define STM32_GPIOD_BASE (STM32_AHB1PERIPH_BASE + 0x0C00) +#define STM32_GPIOE_BASE (STM32_AHB1PERIPH_BASE + 0x1000) +#define STM32_GPIOF_BASE (STM32_AHB1PERIPH_BASE + 0x1400) +#define STM32_GPIOG_BASE (STM32_AHB1PERIPH_BASE + 0x1800) +#define STM32_GPIOH_BASE (STM32_AHB1PERIPH_BASE + 0x1C00) +#define STM32_GPIOI_BASE (STM32_AHB1PERIPH_BASE + 0x2000) + +static const unsigned long io_base[] = { + STM32_GPIOA_BASE, STM32_GPIOB_BASE, STM32_GPIOC_BASE, + STM32_GPIOD_BASE, STM32_GPIOE_BASE, STM32_GPIOF_BASE, + STM32_GPIOG_BASE, STM32_GPIOH_BASE, STM32_GPIOI_BASE +}; + +struct stm32_gpio_regs { + u32 moder; /* GPIO port mode */ + u32 otyper; /* GPIO port output type */ + u32 ospeedr; /* GPIO port output speed */ + u32 pupdr; /* GPIO port pull-up/pull-down */ + u32 idr; /* GPIO port input data */ + u32 odr; /* GPIO port output data */ + u32 bsrr; /* GPIO port bit set/reset */ + u32 lckr; /* GPIO port configuration lock */ + u32 afr[2]; /* GPIO alternate function */ +}; + +#define CHECK_DSC(x) (!x || x->port > 8 || x->pin > 15) +#define CHECK_CTL(x) (!x || x->af > 15 || x->mode > 3 || x->otype > 1 || \ + x->pupd > 2 || x->speed > 3) + +int stm32_gpio_config(const struct stm32_gpio_dsc *dsc, + const struct stm32_gpio_ctl *ctl) +{ + struct stm32_gpio_regs *gpio_regs; + u32 i; + int rv; + + if (CHECK_DSC(dsc)) { + rv = -EINVAL; + goto out; + } + if (CHECK_CTL(ctl)) { + rv = -EINVAL; + goto out; + } + + gpio_regs = (struct stm32_gpio_regs *)io_base[dsc->port]; + + setbits_le32(&STM32_RCC->ahb1enr, 1 << dsc->port); + + i = (dsc->pin & 0x07) * 4; + clrbits_le32(&gpio_regs->afr[dsc->pin >> 3], (0xF << i)); + setbits_le32(&gpio_regs->afr[dsc->pin >> 3], ctl->af << i); + + i = dsc->pin * 2; + + clrbits_le32(&gpio_regs->moder, (0x3 << i)); + setbits_le32(&gpio_regs->moder, ctl->mode << i); + + clrbits_le32(&gpio_regs->otyper, (0x3 << i)); + setbits_le32(&gpio_regs->otyper, ctl->otype << i); + + clrbits_le32(&gpio_regs->ospeedr, (0x3 << i)); + setbits_le32(&gpio_regs->ospeedr, ctl->speed << i); + + clrbits_le32(&gpio_regs->pupdr, (0x3 << i)); + setbits_le32(&gpio_regs->pupdr, ctl->pupd << i); + + rv = 0; +out: + return rv; +} + +int stm32_gpout_set(const struct stm32_gpio_dsc *dsc, int state) +{ + struct stm32_gpio_regs *gpio_regs; + int rv; + + if (CHECK_DSC(dsc)) { + rv = -EINVAL; + goto out; + } + + gpio_regs = (struct stm32_gpio_regs *)io_base[dsc->port]; + + if (state) + writel(1 << dsc->pin, &gpio_regs->bsrr); + else + writel(1 << (dsc->pin + 16), &gpio_regs->bsrr); + + rv = 0; +out: + return rv; +} + +int stm32_gpin_get(const struct stm32_gpio_dsc *dsc) +{ + struct stm32_gpio_regs *gpio_regs; + int rv; + + if (CHECK_DSC(dsc)) { + rv = -EINVAL; + goto out; + } + + gpio_regs = (struct stm32_gpio_regs *)io_base[dsc->port]; + rv = readl(&gpio_regs->idr) & (1 << dsc->pin); +out: + return rv; +} + +/* Common GPIO API */ + +int gpio_request(unsigned gpio, const char *label) +{ + return 0; +} + +int gpio_free(unsigned gpio) +{ + return 0; +} + +int gpio_direction_input(unsigned gpio) +{ + struct stm32_gpio_dsc dsc; + struct stm32_gpio_ctl ctl; + + dsc.port = stm32_gpio_to_port(gpio); + dsc.pin = stm32_gpio_to_pin(gpio); + ctl.af = STM32_GPIO_AF0; + ctl.mode = STM32_GPIO_MODE_IN; + ctl.pupd = STM32_GPIO_PUPD_NO; + ctl.speed = STM32_GPIO_SPEED_50M; + + return stm32_gpio_config(&dsc, &ctl); +} + +int gpio_direction_output(unsigned gpio, int value) +{ + struct stm32_gpio_dsc dsc; + struct stm32_gpio_ctl ctl; + int res; + + dsc.port = stm32_gpio_to_port(gpio); + dsc.pin = stm32_gpio_to_pin(gpio); + ctl.af = STM32_GPIO_AF0; + ctl.mode = STM32_GPIO_MODE_OUT; + ctl.otype = STM32_GPIO_OTYPE_PP; + ctl.pupd = STM32_GPIO_PUPD_NO; + ctl.speed = STM32_GPIO_SPEED_50M; + + res = stm32_gpio_config(&dsc, &ctl); + if (res < 0) + goto out; + res = stm32_gpout_set(&dsc, value); +out: + return res; +} + +int gpio_get_value(unsigned gpio) +{ + struct stm32_gpio_dsc dsc; + + dsc.port = stm32_gpio_to_port(gpio); + dsc.pin = stm32_gpio_to_pin(gpio); + + return stm32_gpin_get(&dsc); +} + +int gpio_set_value(unsigned gpio, int value) +{ + struct stm32_gpio_dsc dsc; + + dsc.port = stm32_gpio_to_port(gpio); + dsc.pin = stm32_gpio_to_pin(gpio); + + return stm32_gpout_set(&dsc, value); +} diff --git a/include/flash.h b/include/flash.h index 30aa080..48aa3a5 100644 --- a/include/flash.h +++ b/include/flash.h @@ -459,6 +459,8 @@ extern flash_info_t *flash_get_info(ulong base); #define FLASH_S29GL064M 0x00F0 /* Spansion S29GL064M-R6 */ #define FLASH_S29GL128N 0x00F1 /* Spansion S29GL128N */
+#define FLASH_STM32F4 0x00F2 /* STM32F4 Embedded Flash */ + #define FLASH_UNKNOWN 0xFFFF /* unknown flash type */
On Sun, Mar 01, 2015 at 12:44:40PM +0100, rev13@wp.pl wrote:
Signed-off-by: Kamil Lulko rev13@wp.pl Reviewed-by: Tom Rini trini@konsulko.com
Signed-off-by: Kamil Lulko rev13@wp.pl --- drivers/serial/Makefile | 1 + drivers/serial/serial.c | 2 + drivers/serial/serial_stm32.c | 117 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 120 insertions(+) create mode 100644 drivers/serial/serial_stm32.c
diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 63b0cbf..eb935bf 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -45,6 +45,7 @@ obj-$(CONFIG_TEGRA_SERIAL) += serial_tegra.o obj-$(CONFIG_UNIPHIER_SERIAL) += serial_uniphier.o obj-$(CONFIG_OMAP_SERIAL) += serial_omap.o obj-$(CONFIG_X86_SERIAL) += serial_x86.o +obj-$(CONFIG_STM32_SERIAL) += serial_stm32.o
ifndef CONFIG_SPL_BUILD obj-$(CONFIG_USB_TTY) += usbtty.o diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index 95c992a..9249a77 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -155,6 +155,7 @@ serial_initfunc(sa1100_serial_initialize); serial_initfunc(sandbox_serial_initialize); serial_initfunc(sconsole_serial_initialize); serial_initfunc(sh_serial_initialize); +serial_initfunc(stm32_serial_initialize); serial_initfunc(uartlite_serial_initialize); serial_initfunc(zynq_serial_initialize);
@@ -248,6 +249,7 @@ void serial_initialize(void) sandbox_serial_initialize(); sconsole_serial_initialize(); sh_serial_initialize(); + stm32_serial_initialize(); uartlite_serial_initialize(); zynq_serial_initialize();
diff --git a/drivers/serial/serial_stm32.c b/drivers/serial/serial_stm32.c new file mode 100644 index 0000000..3c80096 --- /dev/null +++ b/drivers/serial/serial_stm32.c @@ -0,0 +1,117 @@ +/* + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <serial.h> +#include <asm/arch/stm32.h> + +#define STM32_USART1_BASE (STM32_APB2PERIPH_BASE + 0x1000) +#define RCC_APB2ENR_USART1EN (1 << 4) + +#define USART_BASE STM32_USART1_BASE +#define RCC_USART_ENABLE RCC_APB2ENR_USART1EN + +struct stm32_serial { + u32 sr; + u32 dr; + u32 brr; + u32 cr1; + u32 cr2; + u32 cr3; + u32 gtpr; +}; + +#define USART_CR1_RE (1 << 2) +#define USART_CR1_TE (1 << 3) +#define USART_CR1_UE (1 << 13) + +#define USART_SR_FLAG_RXNE (1 << 5) +#define USART_SR_FLAG_TXE (1 << 7) + +#define USART_BRR_F_MASK 0xF +#define USART_BRR_M_SHIFT 4 +#define USART_BRR_M_MASK 0xFFF0 + +DECLARE_GLOBAL_DATA_PTR; + +static void stm32_serial_setbrg(void) +{ + serial_init(); +} + +static int stm32_serial_init(void) +{ + struct stm32_serial *usart = (struct stm32_serial *)USART_BASE; + u32 clock, int_div, frac_div, tmp; + + if ((USART_BASE & STM32_BUS_MASK) == STM32_APB1PERIPH_BASE) { + setbits_le32(&STM32_RCC->apb1enr, RCC_USART_ENABLE); + clock = clock_get(CLOCK_APB1); + } else if ((USART_BASE & STM32_BUS_MASK) == STM32_APB2PERIPH_BASE) { + setbits_le32(&STM32_RCC->apb2enr, RCC_USART_ENABLE); + clock = clock_get(CLOCK_APB2); + } else { + return -1; + } + + int_div = (25 * clock) / (4 * gd->baudrate); + tmp = ((int_div / 100) << USART_BRR_M_SHIFT) & USART_BRR_M_MASK; + frac_div = int_div - (100 * (tmp >> USART_BRR_M_SHIFT)); + tmp |= (((frac_div * 16) + 50) / 100) & USART_BRR_F_MASK; + + writel(tmp, &usart->brr); + setbits_le32(&usart->cr1, USART_CR1_RE | USART_CR1_TE | USART_CR1_UE); + + return 0; +} + +static int stm32_serial_getc(void) +{ + struct stm32_serial *usart = (struct stm32_serial *)USART_BASE; + while ((readl(&usart->sr) & USART_SR_FLAG_RXNE) == 0) + ; + return readl(&usart->dr); +} + +static void stm32_serial_putc(const char c) +{ + struct stm32_serial *usart = (struct stm32_serial *)USART_BASE; + while ((readl(&usart->sr) & USART_SR_FLAG_TXE) == 0) + ; + writel(c, &usart->dr); +} + +static int stm32_serial_tstc(void) +{ + struct stm32_serial *usart = (struct stm32_serial *)USART_BASE; + u8 ret; + + ret = readl(&usart->sr) & USART_SR_FLAG_RXNE; + return ret; +} + +static struct serial_device stm32_serial_drv = { + .name = "stm32_serial", + .start = stm32_serial_init, + .stop = NULL, + .setbrg = stm32_serial_setbrg, + .putc = stm32_serial_putc, + .puts = default_serial_puts, + .getc = stm32_serial_getc, + .tstc = stm32_serial_tstc, +}; + +void stm32_serial_initialize(void) +{ + serial_register(&stm32_serial_drv); +} + +__weak struct serial_device *default_serial_console(void) +{ + return &stm32_serial_drv; +}
Signed-off-by: Kamil Lulko rev13@wp.pl --- arch/arm/Kconfig | 5 + board/st/stm32f429-discovery/Kconfig | 19 ++ board/st/stm32f429-discovery/MAINTAINERS | 6 + board/st/stm32f429-discovery/Makefile | 12 + board/st/stm32f429-discovery/led.c | 35 +++ board/st/stm32f429-discovery/stm32f429-discovery.c | 288 +++++++++++++++++++++ configs/stm32f429-discovery_defconfig | 2 + include/configs/stm32f429-discovery.h | 106 ++++++++ 8 files changed, 473 insertions(+) create mode 100644 board/st/stm32f429-discovery/Kconfig create mode 100644 board/st/stm32f429-discovery/MAINTAINERS create mode 100644 board/st/stm32f429-discovery/Makefile create mode 100644 board/st/stm32f429-discovery/led.c create mode 100644 board/st/stm32f429-discovery/stm32f429-discovery.c create mode 100644 configs/stm32f429-discovery_defconfig create mode 100644 include/configs/stm32f429-discovery.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 29ea8b4..8835d17 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -839,6 +839,10 @@ config ARCH_UNIPHIER select SPL select OF_CONTROL if !SPL_BUILD
+config TARGET_STM32F429_DISCOVERY + bool "Support STM32F429 Discovery" + select CPU_V7M + endchoice
source "arch/arm/cpu/arm926ejs/davinci/Kconfig" @@ -1000,6 +1004,7 @@ source "board/spear/spear600/Kconfig" source "board/spear/x600/Kconfig" source "board/st-ericsson/snowball/Kconfig" source "board/st-ericsson/u8500/Kconfig" +source "board/st/stm32f429-discovery/Kconfig" source "board/st/stv0991/Kconfig" source "board/sunxi/Kconfig" source "board/syteco/jadecpu/Kconfig" diff --git a/board/st/stm32f429-discovery/Kconfig b/board/st/stm32f429-discovery/Kconfig new file mode 100644 index 0000000..e73d11b --- /dev/null +++ b/board/st/stm32f429-discovery/Kconfig @@ -0,0 +1,19 @@ +if TARGET_STM32F429_DISCOVERY + +config SYS_BOARD + string + default "stm32f429-discovery" + +config SYS_VENDOR + string + default "st" + +config SYS_SOC + string + default "stm32f4" + +config SYS_CONFIG_NAME + string + default "stm32f429-discovery" + +endif diff --git a/board/st/stm32f429-discovery/MAINTAINERS b/board/st/stm32f429-discovery/MAINTAINERS new file mode 100644 index 0000000..27e9545 --- /dev/null +++ b/board/st/stm32f429-discovery/MAINTAINERS @@ -0,0 +1,6 @@ +M: Kamil Lulko rev13@wp.pl +S: Maintained +F: board/st/stm32f429-discovery/ +F: include/configs/stm32f429-discovery.h +F: configs/stm32f429-discovery_defconfig + diff --git a/board/st/stm32f429-discovery/Makefile b/board/st/stm32f429-discovery/Makefile new file mode 100644 index 0000000..7e764e3 --- /dev/null +++ b/board/st/stm32f429-discovery/Makefile @@ -0,0 +1,12 @@ +# +# (C) Copyright 2000-2004 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2015 +# Kamil Lulko, rev13@wp.pl +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := stm32f429-discovery.o +obj-y += led.o diff --git a/board/st/stm32f429-discovery/led.c b/board/st/stm32f429-discovery/led.c new file mode 100644 index 0000000..306e550 --- /dev/null +++ b/board/st/stm32f429-discovery/led.c @@ -0,0 +1,35 @@ +/* + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm-generic/gpio.h> + +void coloured_LED_init(void) +{ + gpio_direction_output(CONFIG_RED_LED, 0); + gpio_direction_output(CONFIG_GREEN_LED, 0); +} + +void red_led_off(void) +{ + gpio_set_value(CONFIG_RED_LED, 0); +} + +void green_led_off(void) +{ + gpio_set_value(CONFIG_GREEN_LED, 0); +} + +void red_led_on(void) +{ + gpio_set_value(CONFIG_RED_LED, 1); +} + +void green_led_on(void) +{ + gpio_set_value(CONFIG_GREEN_LED, 1); +} diff --git a/board/st/stm32f429-discovery/stm32f429-discovery.c b/board/st/stm32f429-discovery/stm32f429-discovery.c new file mode 100644 index 0000000..91b4f2d --- /dev/null +++ b/board/st/stm32f429-discovery/stm32f429-discovery.c @@ -0,0 +1,288 @@ +/* + * (C) Copyright 2011, 2012, 2013 + * Yuri Tikhonov, Emcraft Systems, yur@emcraft.com + * Alexander Potashev, Emcraft Systems, aspotashev@emcraft.com + * Vladimir Khusainov, Emcraft Systems, vlad@emcraft.com + * Pavel Boldin, Emcraft Systems, paboldin@emcraft.com + * + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/armv7m.h> +#include <asm/arch/stm32.h> +#include <asm/arch/gpio.h> +#include <asm/arch/fmc.h> + +DECLARE_GLOBAL_DATA_PTR; + +const struct stm32_gpio_ctl gpio_ctl_gpout = { + .mode = STM32_GPIO_MODE_OUT, + .otype = STM32_GPIO_OTYPE_PP, + .speed = STM32_GPIO_SPEED_50M, + .pupd = STM32_GPIO_PUPD_NO, + .af = STM32_GPIO_AF0 +}; + +const struct stm32_gpio_ctl gpio_ctl_usart = { + .mode = STM32_GPIO_MODE_AF, + .otype = STM32_GPIO_OTYPE_PP, + .speed = STM32_GPIO_SPEED_50M, + .pupd = STM32_GPIO_PUPD_UP, + .af = STM32_GPIO_AF7 +}; + +static const struct stm32_gpio_dsc usart1_gpio[] = { + {STM32_GPIO_PORT_A, STM32_GPIO_PIN_9}, /* TX */ + {STM32_GPIO_PORT_A, STM32_GPIO_PIN_10}, /* RX */ +}; + +int uart1_setup_gpio(void) +{ + int i; + int rv = 0; + + for (i = 0; i < ARRAY_SIZE(usart1_gpio); i++) { + rv = stm32_gpio_config(&usart1_gpio[i], &gpio_ctl_usart); + if (rv) + goto out; + } + +out: + return rv; +} + +const struct stm32_gpio_ctl gpio_ctl_fmc = { + .mode = STM32_GPIO_MODE_AF, + .otype = STM32_GPIO_OTYPE_PP, + .speed = STM32_GPIO_SPEED_100M, + .pupd = STM32_GPIO_PUPD_NO, + .af = STM32_GPIO_AF12 +}; + +static const struct stm32_gpio_dsc ext_ram_fmc_gpio[] = { + /* Chip is LQFP144, see DM00077036.pdf for details */ + {STM32_GPIO_PORT_D, STM32_GPIO_PIN_10}, /* 79, FMC_D15 */ + {STM32_GPIO_PORT_D, STM32_GPIO_PIN_9}, /* 78, FMC_D14 */ + {STM32_GPIO_PORT_D, STM32_GPIO_PIN_8}, /* 77, FMC_D13 */ + {STM32_GPIO_PORT_E, STM32_GPIO_PIN_15}, /* 68, FMC_D12 */ + {STM32_GPIO_PORT_E, STM32_GPIO_PIN_14}, /* 67, FMC_D11 */ + {STM32_GPIO_PORT_E, STM32_GPIO_PIN_13}, /* 66, FMC_D10 */ + {STM32_GPIO_PORT_E, STM32_GPIO_PIN_12}, /* 65, FMC_D9 */ + {STM32_GPIO_PORT_E, STM32_GPIO_PIN_11}, /* 64, FMC_D8 */ + {STM32_GPIO_PORT_E, STM32_GPIO_PIN_10}, /* 63, FMC_D7 */ + {STM32_GPIO_PORT_E, STM32_GPIO_PIN_9}, /* 60, FMC_D6 */ + {STM32_GPIO_PORT_E, STM32_GPIO_PIN_8}, /* 59, FMC_D5 */ + {STM32_GPIO_PORT_E, STM32_GPIO_PIN_7}, /* 58, FMC_D4 */ + {STM32_GPIO_PORT_D, STM32_GPIO_PIN_1}, /* 115, FMC_D3 */ + {STM32_GPIO_PORT_D, STM32_GPIO_PIN_0}, /* 114, FMC_D2 */ + {STM32_GPIO_PORT_D, STM32_GPIO_PIN_15}, /* 86, FMC_D1 */ + {STM32_GPIO_PORT_D, STM32_GPIO_PIN_14}, /* 85, FMC_D0 */ + {STM32_GPIO_PORT_E, STM32_GPIO_PIN_1}, /* 142, FMC_NBL1 */ + {STM32_GPIO_PORT_E, STM32_GPIO_PIN_0}, /* 141, FMC_NBL0 */ + {STM32_GPIO_PORT_G, STM32_GPIO_PIN_5}, /* 90, FMC_A15, BA1 */ + {STM32_GPIO_PORT_G, STM32_GPIO_PIN_4}, /* 89, FMC_A14, BA0 */ + {STM32_GPIO_PORT_G, STM32_GPIO_PIN_1}, /* 57, FMC_A11 */ + {STM32_GPIO_PORT_G, STM32_GPIO_PIN_0}, /* 56, FMC_A10 */ + {STM32_GPIO_PORT_F, STM32_GPIO_PIN_15}, /* 55, FMC_A9 */ + {STM32_GPIO_PORT_F, STM32_GPIO_PIN_14}, /* 54, FMC_A8 */ + {STM32_GPIO_PORT_F, STM32_GPIO_PIN_13}, /* 53, FMC_A7 */ + {STM32_GPIO_PORT_F, STM32_GPIO_PIN_12}, /* 50, FMC_A6 */ + {STM32_GPIO_PORT_F, STM32_GPIO_PIN_5}, /* 15, FMC_A5 */ + {STM32_GPIO_PORT_F, STM32_GPIO_PIN_4}, /* 14, FMC_A4 */ + {STM32_GPIO_PORT_F, STM32_GPIO_PIN_3}, /* 13, FMC_A3 */ + {STM32_GPIO_PORT_F, STM32_GPIO_PIN_2}, /* 12, FMC_A2 */ + {STM32_GPIO_PORT_F, STM32_GPIO_PIN_1}, /* 11, FMC_A1 */ + {STM32_GPIO_PORT_F, STM32_GPIO_PIN_0}, /* 10, FMC_A0 */ + {STM32_GPIO_PORT_B, STM32_GPIO_PIN_6}, /* 136, SDRAM_NE */ + {STM32_GPIO_PORT_F, STM32_GPIO_PIN_11}, /* 49, SDRAM_NRAS */ + {STM32_GPIO_PORT_G, STM32_GPIO_PIN_15}, /* 132, SDRAM_NCAS */ + {STM32_GPIO_PORT_C, STM32_GPIO_PIN_0}, /* 26, SDRAM_NWE */ + {STM32_GPIO_PORT_B, STM32_GPIO_PIN_5}, /* 135, SDRAM_CKE */ + {STM32_GPIO_PORT_G, STM32_GPIO_PIN_8}, /* 93, SDRAM_CLK */ +}; + +static int fmc_setup_gpio(void) +{ + int rv = 0; + int i; + + for (i = 0; i < ARRAY_SIZE(ext_ram_fmc_gpio); i++) { + rv = stm32_gpio_config(&ext_ram_fmc_gpio[i], + &gpio_ctl_fmc); + if (rv) + goto out; + } + +out: + return rv; +} + +/* + * STM32 RCC FMC specific definitions + */ +#define STM32_RCC_ENR_FMC (1 << 0) /* FMC module clock */ + +static inline u32 _ns2clk(u32 ns, u32 freq) +{ + u32 tmp = freq/1000000; + return (tmp * ns) / 1000; +} + +#define NS2CLK(ns) (_ns2clk(ns, freq)) + +/* + * Following are timings for IS42S16400J, from corresponding datasheet + */ +#define SDRAM_CAS 3 /* 3 cycles */ +#define SDRAM_NB 1 /* Number of banks */ +#define SDRAM_MWID 1 /* 16 bit memory */ + +#define SDRAM_NR 0x1 /* 12-bit row */ +#define SDRAM_NC 0x0 /* 8-bit col */ +#define SDRAM_RBURST 0x1 /* Single read requests always as bursts */ +#define SDRAM_RPIPE 0x0 /* No HCLK clock cycle delay */ + +#define SDRAM_TRRD (NS2CLK(14) - 1) +#define SDRAM_TRCD (NS2CLK(15) - 1) +#define SDRAM_TRP (NS2CLK(15) - 1) +#define SDRAM_TRAS (NS2CLK(42) - 1) +#define SDRAM_TRC (NS2CLK(63) - 1) +#define SDRAM_TRFC (NS2CLK(63) - 1) +#define SDRAM_TCDL (1 - 1) +#define SDRAM_TRDL (2 - 1) +#define SDRAM_TBDL (1 - 1) +#define SDRAM_TREF 1386 +#define SDRAM_TCCD (1 - 1) + +#define SDRAM_TXSR (NS2CLK(70) - 1)/* Row cycle time after precharge */ +#define SDRAM_TMRD (3 - 1) /* Page 10, Mode Register Set */ + +/* Last data-in to row precharge, need also comply ineq from RM 37.7.5 */ +#define SDRAM_TWR max(\ + (int)max((int)SDRAM_TRDL, (int)(SDRAM_TRAS - SDRAM_TRCD - 1)), \ + (int)(SDRAM_TRC - SDRAM_TRCD - SDRAM_TRP - 2)\ +) + +#define SDRAM_MODE_BL_SHIFT 0 +#define SDRAM_MODE_CAS_SHIFT 4 +#define SDRAM_MODE_BL 0 +#define SDRAM_MODE_CAS SDRAM_CAS + +int dram_init(void) +{ + u32 freq; + int rv; + + rv = fmc_setup_gpio(); + if (rv) + return rv; + + setbits_le32(&STM32_RCC->ahb3enr, STM32_RCC_ENR_FMC); + + /* + * Get frequency for NS2CLK calculation. + */ + freq = clock_get(CLOCK_AHB) / CONFIG_SYS_RAM_FREQ_DIV; + + writel(CONFIG_SYS_RAM_FREQ_DIV << FMC_SDCR_SDCLK_SHIFT + | SDRAM_RPIPE << FMC_SDCR_RPIPE_SHIFT + | SDRAM_RBURST << FMC_SDCR_RBURST_SHIFT, + &STM32_SDRAM_FMC->sdcr1); + + writel(CONFIG_SYS_RAM_FREQ_DIV << FMC_SDCR_SDCLK_SHIFT + | SDRAM_CAS << FMC_SDCR_CAS_SHIFT + | SDRAM_NB << FMC_SDCR_NB_SHIFT + | SDRAM_MWID << FMC_SDCR_MWID_SHIFT + | SDRAM_NR << FMC_SDCR_NR_SHIFT + | SDRAM_NC << FMC_SDCR_NC_SHIFT + | SDRAM_RPIPE << FMC_SDCR_RPIPE_SHIFT + | SDRAM_RBURST << FMC_SDCR_RBURST_SHIFT, + &STM32_SDRAM_FMC->sdcr2); + + writel(SDRAM_TRP << FMC_SDTR_TRP_SHIFT + | SDRAM_TRC << FMC_SDTR_TRC_SHIFT, + &STM32_SDRAM_FMC->sdtr1); + + writel(SDRAM_TRCD << FMC_SDTR_TRCD_SHIFT + | SDRAM_TRP << FMC_SDTR_TRP_SHIFT + | SDRAM_TWR << FMC_SDTR_TWR_SHIFT + | SDRAM_TRC << FMC_SDTR_TRC_SHIFT + | SDRAM_TRAS << FMC_SDTR_TRAS_SHIFT + | SDRAM_TXSR << FMC_SDTR_TXSR_SHIFT + | SDRAM_TMRD << FMC_SDTR_TMRD_SHIFT, + &STM32_SDRAM_FMC->sdtr2); + + writel(FMC_SDCMR_BANK_2 | FMC_SDCMR_MODE_START_CLOCK, + &STM32_SDRAM_FMC->sdcmr); + + udelay(200); /* 200 us delay, page 10, "Power-Up" */ + FMC_BUSY_WAIT(); + + writel(FMC_SDCMR_BANK_2 | FMC_SDCMR_MODE_PRECHARGE, + &STM32_SDRAM_FMC->sdcmr); + + udelay(100); + FMC_BUSY_WAIT(); + + writel((FMC_SDCMR_BANK_2 | FMC_SDCMR_MODE_AUTOREFRESH + | 7 << FMC_SDCMR_NRFS_SHIFT), &STM32_SDRAM_FMC->sdcmr); + + udelay(100); + FMC_BUSY_WAIT(); + + writel(FMC_SDCMR_BANK_2 | (SDRAM_MODE_BL << SDRAM_MODE_BL_SHIFT + | SDRAM_MODE_CAS << SDRAM_MODE_CAS_SHIFT) + << FMC_SDCMR_MODE_REGISTER_SHIFT | FMC_SDCMR_MODE_WRITE_MODE, + &STM32_SDRAM_FMC->sdcmr); + + udelay(100); + + FMC_BUSY_WAIT(); + + writel(FMC_SDCMR_BANK_2 | FMC_SDCMR_MODE_NORMAL, + &STM32_SDRAM_FMC->sdcmr); + + FMC_BUSY_WAIT(); + + /* Refresh timer */ + writel(SDRAM_TREF, &STM32_SDRAM_FMC->sdrtr); + + /* + * Fill in global info with description of SRAM configuration + */ + gd->bd->bi_dram[0].start = CONFIG_SYS_RAM_BASE; + gd->bd->bi_dram[0].size = CONFIG_SYS_RAM_SIZE; + + gd->ram_size = CONFIG_SYS_RAM_SIZE; + + return rv; +} + +u32 get_board_rev(void) +{ + return 0; +} + +int board_early_init_f(void) +{ + int res; + + res = uart1_setup_gpio(); + if (res) + return res; + + return 0; +} + +int board_init(void) +{ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + return 0; +} + diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig new file mode 100644 index 0000000..6d74d73 --- /dev/null +++ b/configs/stm32f429-discovery_defconfig @@ -0,0 +1,2 @@ +CONFIG_ARM=y +CONFIG_TARGET_STM32F429_DISCOVERY=y diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h new file mode 100644 index 0000000..7f569fd --- /dev/null +++ b/include/configs/stm32f429-discovery.h @@ -0,0 +1,106 @@ +/* + * (C) Copyright 2015 + * Kamil Lulko, rev13@wp.pl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_STM32F4 +#define CONFIG_STM32F4DISCOVERY +#define CONFIG_SYS_GENERIC_BOARD + +#define CONFIG_OF_LIBFDT + +#define CONFIG_BOARD_EARLY_INIT_F + +#define CONFIG_SYS_FLASH_BASE 0x08000000 + +#define CONFIG_SYS_INIT_SP_ADDR 0x10010000 +#define CONFIG_SYS_TEXT_BASE 0x08000000 + +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_DCACHE_OFF + +/* + * Configuration of the external SDRAM memory + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_RAM_SIZE (8 << 20) +#define CONFIG_SYS_RAM_CS 1 +#define CONFIG_SYS_RAM_FREQ_DIV 2 +#define CONFIG_SYS_RAM_BASE 0xD0000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_RAM_BASE +#define CONFIG_SYS_LOAD_ADDR 0xD0400000 +#define CONFIG_LOADADDR 0xD0400000 + +#define CONFIG_SYS_MAX_FLASH_SECT 12 +#define CONFIG_SYS_MAX_FLASH_BANKS 2 + +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_OFFSET (256 << 10) +#define CONFIG_ENV_SECT_SIZE (128 << 10) +#define CONFIG_ENV_SIZE (8 << 10) + +#define CONFIG_BOARD_SPECIFIC_LED +#define CONFIG_RED_LED 110 +#define CONFIG_GREEN_LED 109 + +#define CONFIG_STM32_GPIO +#define CONFIG_STM32_SERIAL + +#define CONFIG_STM32_USART1 + +#define CONFIG_STM32_HSE_HZ 8000000 + +#define CONFIG_SYS_HZ_CLOCK 1000000 /* Timer is clocked at 1MHz */ + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + + sizeof(CONFIG_SYS_PROMPT) + 16) + +#define CONFIG_SYS_MAXARGS 16 + +#define CONFIG_SYS_MALLOC_LEN (2 << 20) + +#define CONFIG_STACKSIZE (64 << 10) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTARGS \ + "console=ttystm0,115200 earlyprintk consoleblank=0 ignore_loglevel" +#define CONFIG_BOOTCOMMAND \ + "run bootcmd_romfs" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootargs_romfs=uclinux.physaddr=0x08180000 root=/dev/mtdblock0\0" \ + "bootcmd_romfs=setenv bootargs ${bootargs} ${bootargs_romfs};" \ + "bootm 0x08044000 - 0x08042000\0" + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_AUTOBOOT + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "U-Boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING + +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_MEM +#define CONFIG_CMD_MISC +#define CONFIG_CMD_TIMER + +#endif /* __CONFIG_H */
Hi Kamil,
I tested this patch-set in STM32 Discovery board. After applied this patch-set on latest u-boot, I could not see the normal u-boot log. I saw broken console log. I used the USART1 port (pa9, pa10 gpio pin).
Could you give me a tip to resolve this issue?
Best Regards, Chanwoo Choi
2015년 3월 1일 일요일, Kamil Lulkorev13@wp.pl님이 작성한 메시지:
The following patches implement basic support for the ARMv7-M microcontroller architecture. Additionally, stm32f429-discovery board support is added with tested ability to boot uClinux from the embedded Flash memory.
Kamil Lulko (4): ARM: Add ARMv7-M support ARMv7M: Add STM32F4 support stm32f4: Add serial driver stm32f4: Add support for stm32f429-discovery board
arch/arm/Kconfig | 9 + arch/arm/cpu/armv7m/Makefile | 11 + arch/arm/cpu/armv7m/config.mk | 8 + arch/arm/cpu/armv7m/cpu.c | 35 +++ arch/arm/cpu/armv7m/start.S | 15 ++ arch/arm/cpu/armv7m/stm32f4/Makefile | 11 + arch/arm/cpu/armv7m/stm32f4/clock.c | 209 +++++++++++++++ arch/arm/cpu/armv7m/stm32f4/flash.c | 143 ++++++++++ arch/arm/cpu/armv7m/stm32f4/soc.c | 37 +++ arch/arm/cpu/armv7m/stm32f4/timer.c | 118 +++++++++ arch/arm/include/asm/arch-stm32f4/fmc.h | 75 ++++++ arch/arm/include/asm/arch-stm32f4/gpio.h | 116 +++++++++ arch/arm/include/asm/arch-stm32f4/stm32.h | 108 ++++++++ arch/arm/include/asm/armv7m.h | 60 +++++ arch/arm/lib/Makefile | 8 +- arch/arm/lib/crt0.S | 30 +++ arch/arm/lib/interrupts_m.c | 95 +++++++ arch/arm/lib/relocate.S | 13 + arch/arm/lib/vectors_m.S | 57 ++++ board/st/stm32f429-discovery/Kconfig | 19 ++ board/st/stm32f429-discovery/MAINTAINERS | 6 + board/st/stm32f429-discovery/Makefile | 12 + board/st/stm32f429-discovery/led.c | 35 +++ board/st/stm32f429-discovery/stm32f429-discovery.c | 288 +++++++++++++++++++++ configs/stm32f429-discovery_defconfig | 2 + drivers/gpio/Makefile | 1 + drivers/gpio/stm32_gpio.c | 199 ++++++++++++++ drivers/serial/Makefile | 1 + drivers/serial/serial.c | 2 + drivers/serial/serial_stm32.c | 117 +++++++++ include/configs/stm32f429-discovery.h | 106 ++++++++ include/flash.h | 2 + 32 files changed, 1946 insertions(+), 2 deletions(-) create mode 100644 arch/arm/cpu/armv7m/Makefile create mode 100644 arch/arm/cpu/armv7m/config.mk create mode 100644 arch/arm/cpu/armv7m/cpu.c create mode 100644 arch/arm/cpu/armv7m/start.S create mode 100644 arch/arm/cpu/armv7m/stm32f4/Makefile create mode 100644 arch/arm/cpu/armv7m/stm32f4/clock.c create mode 100644 arch/arm/cpu/armv7m/stm32f4/flash.c create mode 100644 arch/arm/cpu/armv7m/stm32f4/soc.c create mode 100644 arch/arm/cpu/armv7m/stm32f4/timer.c create mode 100644 arch/arm/include/asm/arch-stm32f4/fmc.h create mode 100644 arch/arm/include/asm/arch-stm32f4/gpio.h create mode 100644 arch/arm/include/asm/arch-stm32f4/stm32.h create mode 100644 arch/arm/include/asm/armv7m.h create mode 100644 arch/arm/lib/interrupts_m.c create mode 100644 arch/arm/lib/vectors_m.S create mode 100644 board/st/stm32f429-discovery/Kconfig create mode 100644 board/st/stm32f429-discovery/MAINTAINERS create mode 100644 board/st/stm32f429-discovery/Makefile create mode 100644 board/st/stm32f429-discovery/led.c create mode 100644 board/st/stm32f429-discovery/stm32f429-discovery.c create mode 100644 configs/stm32f429-discovery_defconfig create mode 100644 drivers/gpio/stm32_gpio.c create mode 100644 drivers/serial/serial_stm32.c create mode 100644 include/configs/stm32f429-discovery.h
-- 1.9.1
U-Boot mailing list U-Boot@lists.denx.de javascript:; http://lists.denx.de/mailman/listinfo/u-boot
On Wed, Mar 25, 2015 at 01:07:47PM +0900, Chanwoo Choi wrote:
Hi Kamil,
I bet this needs changes similar to b81bdf6 as that was a similar problem I believe. In short, DM needs to be enabled now.
-- 1.9.1
Hi Kamil,
I have tested this patch set again with 2015.04-rc4-gf643d92 and serial works without any problems.
Chanwoo, you mention STM32 Discovery board - this patch set supports only STM32F429 Discovery (it should work on SDRAM-less boards but not without modifications). Other than that the only thing I can think of is configuration of the UART<>USB converter.
Tom, does this mean changes are required for this patchset to be accepted? I have more things queued up (like moving some of SDRAM configuration bits out of the board code or LCD display support) but I would prefer to have some kind of assurance that this will not go into /dev/null eventually :)
/Kamil
Hi Kamil,
Right now the patches don't apply cleanly due to 68145d4c but it's an easy enough fixup by hand. I plan to apply the current series after the 2015.04 release. If you want to start posting stuff that depends on the initial series being applied that's fine. Thanks!
Andreas Färber
Chanwoo Choi
Kamil Lulko
