[U-Boot] [PATCH] config.mk: avoid -traditional-cpp on OS X 10.5
Simply trying to include a basic header file like stdlib.h on OS X 10.5 and then building with -traditional-cpp fails with lots of errors like: In file included from /usr/include/stdlib.h:63, from test.c:3: /usr/include/available.h:85: error: stray '#' in program /usr/include/available.h:85: error: syntax error before numeric constant /usr/include/available.h:86: error: stray '#' in program
In the past, I hadn't noticed because the old logic for these flags were restricted to Darwin running on PowerPC systems while I'm running on an Intel system. But after some recent clean ups and changes, the flag was being applied to all Darwin systems and my host tools broke.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- Note: i've only tested Darwin/x86 as my Darwin/ppc is having hardware trouble atm ... not sure when/if i'll get it fixed
config.mk | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/config.mk b/config.mk index bcda776..eb95093 100644 --- a/config.mk +++ b/config.mk @@ -68,13 +68,13 @@ ifeq ($(HOSTOS),darwin) DARWIN_MAJOR_VERSION = $(shell sw_vers -productVersion | cut -f 1 -d '.') DARWIN_MINOR_VERSION = $(shell sw_vers -productVersion | cut -f 2 -d '.')
-before-snow-leopard = $(shell if [ $(DARWIN_MAJOR_VERSION) -le 10 -a \ - $(DARWIN_MINOR_VERSION) -le 5 ] ; then echo "$(1)"; else echo "$(2)"; fi ;) +os_x_before = $(shell if [ $(DARWIN_MAJOR_VERSION) -le $(1) -a \ + $(DARWIN_MINOR_VERSION) -le $(2) ] ; then echo "$(3)"; else echo "$(4)"; fi ;)
# Snow Leopards build environment has no longer restrictions as described above -HOSTCC = $(call before-snow-leopard, "cc", "gcc") -HOSTCFLAGS += $(call before-snow-leopard, "-traditional-cpp") -HOSTLDFLAGS += $(call before-snow-leopard, "-multiply_defined suppress") +HOSTCC = $(call os_x_before, 10, 5, "cc", "gcc") +HOSTCFLAGS += $(call os_x_before, 10, 4, "-traditional-cpp") +HOSTLDFLAGS += $(call os_x_before, 10, 5, "-multiply_defined suppress") else HOSTCC = gcc endif
Dear Mike Frysinger,
i have tested your patch on my old mini running 10.5.8 and it works.
Am 04.08.2010 um 01:17 schrieb Mike Frysinger:
- $(DARWIN_MINOR_VERSION) -le $(2) ] ; then echo "$(3)"; else echo "$(4)"; fi ;)
I figured out that I can even switch to gcc on that box:
---8<--- $ gcc --version powerpc-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5490) Copyright (C) 2005 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. --->8---
Therefore your patch could be simplified by switching from 'before-snow-leopard' to 'before-leopard' logic. Nevertheless i like the os_x_before macro more than the first solution.
regards
Andreas Bießmann
Applied, thanks.
Andreas Bießmann
Mike Frysinger
