[PATCH v2 00/13] rockchip: rk35xx: Update defconfigs and enable boot from SPI NOR flash
This series sync some defconfig options across the different rk35xx boards and enables boot from SPI NOR flash on rk3568-rock-3a and rk3588-rock-5b.
Patch 1 fixes use of sfc-no-dma prop in rockchip sfc driver. Patch 2-7 updates defconfig for rk356x boards. Patch 8 enables boot from SPI NOR flash on rk3568-rock-3a. Patch 9-12 updates defconfig for rk3588 boards. Patch 13 enables boot from SPI NOR flash on rk3588-rock-5b.
Changes in v2: - Use IS_ENABLED(CONFIG_SPL_BUILD) instead of ifdef - Use bootph-all in pinctrl nodes - Reorder nodes alphabetically - Rsync rock5b-rk3588_defconfig using moveconfig.py - Drop change to disable CONFIG_SPL_MMC_SDHCI_SDMA, fixed in "rockchip: Fix eMMC performance regression" series - Add and use BROM_BOOTSOURCE_SPINOR_RK3588 enum value - Rebased on custodians/u-boot-rockchip master branch, excluding patches picked from this series - Drop patch that reverts addition of regulator-boot-on props - Collect r-b tags
This series can also be found at [1].
[1] https://github.com/Kwiboo/u-boot-rockchip/commits/rk35xx-defconfig-spi-v2
Jonas Karlman (13): spi: rockchip_sfc: Use linux rockchip,sfc-no-dma prop rockchip: rk356x-u-boot: Add xin24m clock node to SPL rockchip: rk3566-radxa-cm3-io: Update defconfig rockchip: rk3566-radxa-cm3-io: Use pinctrl for sdmmc and sdhci in SPL rockchip: rk3568-evb: Update defconfig rockchip: rk3568-rock-3a: Update defconfig rockchip: rk3568-rock-3a: Use pinctrl for sdmmc and sdhci in SPL rockchip: rk3568-rock-3a: Enable boot from SPI NOR flash rockchip: rk3588: Select DM_RESET and DM_REGULATOR_FIXED in arch Kconfig rockchip: rk3588-evb: Update defconfig rockchip: rk3588-rock-5b: Update defconfig rockchip: rk3588-rock-5b: Add bootph prop to pinctrl for uart2 and sdhci rockchip: rk3588-rock-5b: Enable boot from SPI NOR flash
arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi | 61 ++++++++++++++++ arch/arm/dts/rk3568-rock-3a-u-boot.dtsi | 77 ++++++++++++++++++++ arch/arm/dts/rk356x-u-boot.dtsi | 16 ++++ arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 52 +++++++++++++ arch/arm/dts/rk3588s-u-boot.dtsi | 20 +++++ arch/arm/mach-rockchip/Kconfig | 2 + arch/arm/mach-rockchip/rk3588/rk3588.c | 1 + configs/evb-rk3568_defconfig | 15 ++-- configs/evb-rk3588_defconfig | 9 ++- configs/neu6a-io-rk3588_defconfig | 1 - configs/radxa-cm3-io-rk3566_defconfig | 10 ++- configs/rock-3a-rk3568_defconfig | 20 +++-- configs/rock5b-rk3588_defconfig | 19 +++-- drivers/spi/rockchip_sfc.c | 10 ++- 14 files changed, 284 insertions(+), 29 deletions(-)
Use the same prop as linux to control the use of fifo or dma mode. Also add a u-boot,spl-sfc-no-dma prop to control the same in SPL.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Use IS_ENABLED(CONFIG_SPL_BUILD) instead of ifdef - Collect r-b tag
drivers/spi/rockchip_sfc.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/spi/rockchip_sfc.c b/drivers/spi/rockchip_sfc.c index 851a6482985b..596c22aa0108 100644 --- a/drivers/spi/rockchip_sfc.c +++ b/drivers/spi/rockchip_sfc.c @@ -227,10 +227,10 @@ static int rockchip_sfc_ofdata_to_platdata(struct udevice *bus) struct rockchip_sfc *sfc = dev_get_plat(bus);
sfc->regbase = dev_read_addr_ptr(bus); - if (ofnode_read_bool(dev_ofnode(bus), "sfc-no-dma")) - sfc->use_dma = false; - else - sfc->use_dma = true; + sfc->use_dma = !dev_read_bool(bus, "rockchip,sfc-no-dma"); + + if (IS_ENABLED(CONFIG_SPL_BUILD) && sfc->use_dma) + sfc->use_dma = !dev_read_bool(bus, "u-boot,spl-sfc-no-dma");
#if CONFIG_IS_ENABLED(CLK) int ret;
Add bootph-all prop to xin24m clock node, it is referenced by cru node.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Collect r-b tag
arch/arm/dts/rk356x-u-boot.dtsi | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/rk356x-u-boot.dtsi b/arch/arm/dts/rk356x-u-boot.dtsi index 0a764ce5119c..a1c2d03c52f0 100644 --- a/arch/arm/dts/rk356x-u-boot.dtsi +++ b/arch/arm/dts/rk356x-u-boot.dtsi @@ -34,6 +34,11 @@ }; };
+&xin24m { + bootph-all; + status = "okay"; +}; + &cru { bootph-all; status = "okay";
Update defconfig for rk3566-radxa-cm3-io with new defaults. Also add missing supported mmc modes to sdhci node.
Remove the SPL_ROCKCHIP_BACK_TO_BROM=y option, SPL is expected to load next stage from a FIT image and then jump to next stage not back to BootRom.
Add CONFIG_SPL_FIT_SIGNATURE=y to let SPL verify an auto generated hash of FIT images. This help indicate if there is an issue loading any of the images to DRAM or SRAM.
Extend SPL_MAX_SIZE to 0x40000, SPL is loaded to 0x0 and TF-A is loaded to 0x40000, use the space in between as SPL_MAX_SIZE.
Add config option to include useful gpio cmd.
Remove the CONFIG_NET_RANDOM_ETHADDR=y option, ethaddr and eth1addr is set based on cpuid read from OTP.
Filter out assigned-clock props with CONFIG_OF_SPL_REMOVE_PROPS, U-Boot proper will read and configure assigned-clock props.
Add CONFIG_SYS_NS16550_MEM32=y to use 32bit access of serial register.
arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi | 5 +++++ configs/radxa-cm3-io-rk3566_defconfig | 9 +++++---- 2 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi b/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi index d183e935754d..a8c31fecafd8 100644 --- a/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi +++ b/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi @@ -11,6 +11,11 @@ }; };
+&sdhci { + cap-mmc-highspeed; + mmc-ddr-1_8v; +}; + &uart2 { clock-frequency = <24000000>; bootph-all; diff --git a/configs/radxa-cm3-io-rk3566_defconfig b/configs/radxa-cm3-io-rk3566_defconfig index 1df9cab79d51..dfaacbc8839e 100644 --- a/configs/radxa-cm3-io-rk3566_defconfig +++ b/configs/radxa-cm3-io-rk3566_defconfig @@ -10,9 +10,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 CONFIG_DEFAULT_DEVICE_TREE="rk3566-radxa-cm3-io" CONFIG_ROCKCHIP_RK3568=y -CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y -CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_TARGET_EVB_RK3568=y @@ -23,11 +21,12 @@ CONFIG_SYS_LOAD_ADDR=0xc00800 CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-radxa-cm3-io.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x4000000 @@ -36,6 +35,7 @@ CONFIG_SPL_BSS_MAX_SIZE=0x4000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y @@ -46,7 +46,7 @@ CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y -CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -70,6 +70,7 @@ CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y
Enable pinctrl for sdmmc and sdhci in SPL to support loading of FIT image from SD and eMMC storage when booting from SPI NOR flash.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Use bootph-all in pinctrl nodes - Reorder nodes alphabetically - Collect r-b tag
arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi | 56 ++++++++++++++++++++ configs/radxa-cm3-io-rk3566_defconfig | 3 +- 2 files changed, 58 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi b/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi index a8c31fecafd8..f91740c1c0c8 100644 --- a/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi +++ b/arch/arm/dts/rk3566-radxa-cm3-io-u-boot.dtsi @@ -11,11 +11,67 @@ }; };
+&emmc_bus8 { + bootph-all; +}; + +&emmc_clk { + bootph-all; +}; + +&emmc_cmd { + bootph-all; +}; + +&emmc_datastrobe { + bootph-all; +}; + +&pinctrl { + bootph-all; +}; + +&pcfg_pull_none { + bootph-all; +}; + +&pcfg_pull_up_drv_level_2 { + bootph-all; +}; + +&pcfg_pull_up { + bootph-all; +}; + +&sdmmc0_bus4 { + bootph-all; +}; + +&sdmmc0_clk { + bootph-all; +}; + +&sdmmc0_cmd { + bootph-all; +}; + +&sdmmc0_det { + bootph-all; +}; + +&sdmmc0_pwren { + bootph-all; +}; + &sdhci { cap-mmc-highspeed; mmc-ddr-1_8v; };
+&uart2m0_xfer { + bootph-all; +}; + &uart2 { clock-frequency = <24000000>; bootph-all; diff --git a/configs/radxa-cm3-io-rk3566_defconfig b/configs/radxa-cm3-io-rk3566_defconfig index dfaacbc8839e..dd1dd36a59b7 100644 --- a/configs/radxa-cm3-io-rk3566_defconfig +++ b/configs/radxa-cm3-io-rk3566_defconfig @@ -46,7 +46,7 @@ CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y -CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -63,6 +63,7 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_RK8XX=y
Update defconfig for rk3568-evb with new defaults.
Add config options to include useful gpio, i2c, pmic and regulator cmd.
Add config options to enable support for the RK809 PMIC.
configs/evb-rk3568_defconfig | 15 ++++++++++----- 1 file changed, 10 insertions(+), 5 deletions(-)
diff --git a/configs/evb-rk3568_defconfig b/configs/evb-rk3568_defconfig index c929bac509c0..0b4fc52e263d 100644 --- a/configs/evb-rk3568_defconfig +++ b/configs/evb-rk3568_defconfig @@ -10,9 +10,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 CONFIG_DEFAULT_DEVICE_TREE="rk3568-evb" CONFIG_ROCKCHIP_RK3568=y -CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y -CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_TARGET_EVB_RK3568=y @@ -23,11 +21,12 @@ CONFIG_SYS_LOAD_ADDR=0xc00800 CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x4000000 @@ -36,13 +35,17 @@ CONFIG_SPL_BSS_MAX_SIZE=0x4000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y -CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -57,7 +60,9 @@ CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y -CONFIG_REGULATOR_PWM=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000
Update defconfig for rk3568-rock-3a with new defaults.
Remove the CONFIG_SPL_PMIC_RK8XX=y option, the pmic is not used in SPL.
configs/rock-3a-rk3568_defconfig | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig index f0db15baa30e..5126feb6b11d 100644 --- a/configs/rock-3a-rk3568_defconfig +++ b/configs/rock-3a-rk3568_defconfig @@ -10,9 +10,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 CONFIG_DEFAULT_DEVICE_TREE="rk3568-rock-3a" CONFIG_ROCKCHIP_RK3568=y -CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y -CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_TARGET_EVB_RK3568=y @@ -23,11 +21,12 @@ CONFIG_SYS_LOAD_ADDR=0xc00800 CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-rock-3a.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x4000000 @@ -36,6 +35,7 @@ CONFIG_SPL_BSS_MAX_SIZE=0x4000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y @@ -46,7 +46,7 @@ CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y -CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -65,7 +65,6 @@ CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y -CONFIG_SPL_PMIC_RK8XX=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y
arch/arm/dts/rk3568-rock-3a-u-boot.dtsi | 52 +++++++++++++++++++++++++ configs/rock-3a-rk3568_defconfig | 3 +- 2 files changed, 54 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi b/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi index c7855135906f..8cccd7e22659 100644 --- a/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi +++ b/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi @@ -12,6 +12,54 @@ }; };
+&emmc_bus8 { + bootph-all; +}; + +&emmc_clk { + bootph-all; +}; + +&emmc_cmd { + bootph-all; +}; + +&emmc_datastrobe { + bootph-all; +}; + +&pinctrl { + bootph-all; +}; + +&pcfg_pull_none { + bootph-all; +}; + +&pcfg_pull_up_drv_level_2 { + bootph-all; +}; + +&pcfg_pull_up { + bootph-all; +}; + +&sdmmc0_bus4 { + bootph-all; +}; + +&sdmmc0_clk { + bootph-all; +}; + +&sdmmc0_cmd { + bootph-all; +}; + +&sdmmc0_det { + bootph-all; +}; + &sdhci { cap-mmc-highspeed; mmc-ddr-1_8v; @@ -28,6 +76,10 @@ status = "disabled"; };
+&uart2m0_xfer { + bootph-all; +}; + &uart2 { clock-frequency = <24000000>; bootph-all; diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig index 5126feb6b11d..2e556dc2c1a2 100644 --- a/configs/rock-3a-rk3568_defconfig +++ b/configs/rock-3a-rk3568_defconfig @@ -46,7 +46,7 @@ CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y -CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -63,6 +63,7 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_RK8XX=y
Add sfc and flash node to device tree and config options to enable support for booting from SPI NOR flash on Radxa ROCK 3 Model A.
Unlike prior generation SoCs the BootRom in RK3568 can read all data and look for idbloader at 0x8000, same as on SD and eMMC.
Use the rksd format and modify the mkimage offset to generate a bootable u-boot-rockchip-spi.bin that can be written to 0x0 of SPI NOR flash. The FIT image is loaded from 0x60000.
=> sf probe SF: Detected mx25u12835f with page size 256 Bytes, erase size 4 KiB, total 16 MiB
=> load mmc 1:1 10000000 u-boot-rockchip-spi.bin 1384448 bytes read in 119 ms (11.1 MiB/s)
=> sf update $fileaddr 0 $filesize device 0 offset 0x0, size 0x152000 1179648 bytes written, 204800 bytes skipped in 9.901s, speed 143185 B/s
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Reorder nodes alphabetically - Collect r-b tag
arch/arm/dts/rk3568-rock-3a-u-boot.dtsi | 25 +++++++++++++++++++++++++ arch/arm/dts/rk356x-u-boot.dtsi | 11 +++++++++++ configs/rock-3a-rk3568_defconfig | 10 ++++++++++ 3 files changed, 46 insertions(+)
diff --git a/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi b/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi index 8cccd7e22659..bbf54f888fa0 100644 --- a/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi +++ b/arch/arm/dts/rk3568-rock-3a-u-boot.dtsi @@ -7,6 +7,10 @@ #include "rk356x-u-boot.dtsi"
/ { + aliases { + spi0 = &sfc; + }; + chosen { stdout-path = &uart2; }; @@ -28,6 +32,10 @@ bootph-all; };
+&fspi_pins { + bootph-all; +}; + &pinctrl { bootph-all; }; @@ -68,6 +76,23 @@ mmc-hs400-enhanced-strobe; };
+&sfc { + bootph-pre-ram; + u-boot,spl-sfc-no-dma; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + flash@0 { + bootph-pre-ram; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <24000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; + &sdmmc2 { status = "disabled"; }; diff --git a/arch/arm/dts/rk356x-u-boot.dtsi b/arch/arm/dts/rk356x-u-boot.dtsi index a1c2d03c52f0..c340c2bba6ff 100644 --- a/arch/arm/dts/rk356x-u-boot.dtsi +++ b/arch/arm/dts/rk356x-u-boot.dtsi @@ -68,3 +68,14 @@ bootph-pre-ram; status = "okay"; }; + +#ifdef CONFIG_ROCKCHIP_SPI_IMAGE +&binman { + simple-bin-spi { + mkimage { + args = "-n", CONFIG_SYS_SOC, "-T", "rksd"; + offset = <0x8000>; + }; + }; +}; +#endif diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig index 2e556dc2c1a2..64864a300153 100644 --- a/configs/rock-3a-rk3568_defconfig +++ b/configs/rock-3a-rk3568_defconfig @@ -8,15 +8,20 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="rk3568-rock-3a" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_ROCKCHIP_SPI_IMAGE=y CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_TARGET_EVB_RK3568=y CONFIG_SPL_STACK=0x400000 CONFIG_DEBUG_UART_BASE=0xFE660000 CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0xc00800 CONFIG_DEBUG_UART=y CONFIG_FIT=y @@ -34,6 +39,8 @@ CONFIG_SPL_BSS_MAX_SIZE=0x4000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x60000 CONFIG_SPL_ATF=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y @@ -59,6 +66,8 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_XTX=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y @@ -72,6 +81,7 @@ CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SFC=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y
Like other Rockchip SoCs, DM_RESET and DM_REGULATOR_FIXED is useful across RK3588 platform. Select them from arch Kconfig.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Rsync using moveconfig.py - Rebased to resolve conflicts - Collect r-b tag
arch/arm/mach-rockchip/Kconfig | 2 ++ configs/evb-rk3588_defconfig | 1 - configs/neu6a-io-rk3588_defconfig | 1 - configs/rock5b-rk3588_defconfig | 4 +--- 4 files changed, 3 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 327779a79818..9d6d20bf8ed6 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -311,6 +311,8 @@ config ROCKCHIP_RK3588 select REGMAP select SYSCON select BOARD_LATE_INIT + select DM_REGULATOR_FIXED + select DM_RESET imply SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF imply ROCKCHIP_COMMON_BOARD imply OF_LIBFDT_OVERLAY diff --git a/configs/evb-rk3588_defconfig b/configs/evb-rk3588_defconfig index 7911cc7c0b77..8760671a1772 100644 --- a/configs/evb-rk3588_defconfig +++ b/configs/evb-rk3588_defconfig @@ -9,7 +9,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 CONFIG_DEFAULT_DEVICE_TREE="rk3588-evb1-v10" -CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3588=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y CONFIG_SPL_SERIAL=y diff --git a/configs/neu6a-io-rk3588_defconfig b/configs/neu6a-io-rk3588_defconfig index fb1ce4c1746f..09729a0ea429 100644 --- a/configs/neu6a-io-rk3588_defconfig +++ b/configs/neu6a-io-rk3588_defconfig @@ -9,7 +9,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 CONFIG_DEFAULT_DEVICE_TREE="rk3588-edgeble-neu6a-io" -CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3588=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y CONFIG_SPL_SERIAL=y diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index c35dd451032e..6cfd161b64f4 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -9,7 +9,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 CONFIG_DEFAULT_DEVICE_TREE="rk3588-rock-5b" -CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3588=y CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y @@ -21,6 +20,7 @@ CONFIG_SPL_STACK=0x400000 CONFIG_DEBUG_UART_BASE=0xFEB50000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -65,13 +65,11 @@ CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y -CONFIG_PCI=y CONFIG_PCIE_DW_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y CONFIG_SPL_PINCTRL=y CONFIG_REGULATOR_PWM=y -CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000
Update defconfig for rk3588-evb with new defaults.
Add config options to include useful gpio and regulator cmd.
Remove CONFIG_DEBUG_UART_ANNOUNCE=y to remove debug messages.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Drop change to disable CONFIG_SPL_MMC_SDHCI_SDMA, fixed in "rockchip: Fix eMMC performance regression" series - Collect r-b tag
configs/evb-rk3588_defconfig | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/configs/evb-rk3588_defconfig b/configs/evb-rk3588_defconfig index 8760671a1772..d5f1c4b9ebc7 100644 --- a/configs/evb-rk3588_defconfig +++ b/configs/evb-rk3588_defconfig @@ -21,12 +21,13 @@ CONFIG_SYS_LOAD_ADDR=0xc00800 CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-evb1-v10.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x4000000 @@ -35,14 +36,15 @@ CONFIG_SPL_BSS_MAX_SIZE=0x4000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" -CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -62,6 +64,6 @@ CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 -CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_ERRNO_STR=y
Update defconfig for rk3588-rock-5b with new defaults.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Rebased to resolve conflicts - Collect r-b tag
configs/rock5b-rk3588_defconfig | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index 6cfd161b64f4..5fe3a3542e11 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -10,9 +10,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 CONFIG_DEFAULT_DEVICE_TREE="rk3588-rock-5b" CONFIG_ROCKCHIP_RK3588=y -CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y -CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_TARGET_ROCK5B_RK3588=y @@ -30,7 +28,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-rock-5b.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x4000000 @@ -39,6 +37,7 @@ CONFIG_SPL_BSS_MAX_SIZE=0x4000 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y @@ -49,7 +48,6 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" -CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -74,6 +72,7 @@ CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y
Enable pinctrl for sdhci in SPL to support loading of FIT image from SD and eMMC storage when booting from SPI NOR flash.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Reorder nodes alphabetically - Rebased to resolve conflicts - Collect r-b tag
arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 28 +++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index 406303920d95..db342e6a9391 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -34,6 +34,26 @@ status = "okay"; };
+&emmc_bus8 { + bootph-all; +}; + +&emmc_clk { + bootph-all; +}; + +&emmc_cmd { + bootph-all; +}; + +&emmc_data_strobe { + bootph-all; +}; + +&emmc_rstnout { + bootph-all; +}; + &pcie2x1l2 { pinctrl-names = "default"; pinctrl-0 = <&pcie2x1l2_pins &pcie_reset_h>; @@ -62,6 +82,10 @@ }; };
+&pcfg_pull_none { + bootph-all; +}; + &pcfg_pull_up_drv_level_2 { bootph-all; }; @@ -99,6 +123,10 @@ pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_data_strobe &emmc_rstnout>; };
+&uart2m0_xfer { + bootph-all; +}; + &usb_host0_ehci { companion = <&usb_host0_ohci>; phys = <&u2phy2_host>;
Add sfc and flash node to device tree and config options to enable support for booting from SPI NOR flash on Radxa ROCK 5 Model B.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Add and use BROM_BOOTSOURCE_SPINOR_RK3588 enum value - Rebased to resolve conflicts - Collect r-b tag
arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 24 ++++++++++++++++++++ arch/arm/dts/rk3588s-u-boot.dtsi | 20 ++++++++++++++++ arch/arm/include/asm/arch-rockchip/bootrom.h | 1 + arch/arm/mach-rockchip/rk3588/rk3588.c | 1 + configs/rock5b-rk3588_defconfig | 10 ++++++++ 5 files changed, 56 insertions(+)
diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index db342e6a9391..1cd8a57a6fa6 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -11,6 +11,7 @@ / { aliases { mmc1 = &sdmmc; + spi0 = &sfc; };
chosen { @@ -54,6 +55,10 @@ bootph-all; };
+&fspim2_pins { + bootph-all; +}; + &pcie2x1l2 { pinctrl-names = "default"; pinctrl-0 = <&pcie2x1l2_pins &pcie_reset_h>; @@ -123,6 +128,25 @@ pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_data_strobe &emmc_rstnout>; };
+&sfc { + bootph-pre-ram; + u-boot,spl-sfc-no-dma; + pinctrl-names = "default"; + pinctrl-0 = <&fspim2_pins>; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + flash@0 { + bootph-pre-ram; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <24000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; + &uart2m0_xfer { bootph-all; }; diff --git a/arch/arm/dts/rk3588s-u-boot.dtsi b/arch/arm/dts/rk3588s-u-boot.dtsi index 2c4cad82b38f..64c309046587 100644 --- a/arch/arm/dts/rk3588s-u-boot.dtsi +++ b/arch/arm/dts/rk3588s-u-boot.dtsi @@ -165,6 +165,15 @@ }; };
+ sfc: spi@fe2b0000 { + compatible = "rockchip,sfc"; + reg = <0x0 0xfe2b0000 0x0 0x4000>; + interrupts = <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru SCLK_SFC>, <&cru HCLK_SFC>; + clock-names = "clk_sfc", "hclk_sfc"; + status = "disabled"; + }; + otp: nvmem@fecc0000 { compatible = "rockchip,rk3588-otp"; reg = <0x0 0xfecc0000 0x0 0x400>; @@ -241,3 +250,14 @@ &ioc { bootph-pre-ram; }; + +#ifdef CONFIG_ROCKCHIP_SPI_IMAGE +&binman { + simple-bin-spi { + mkimage { + args = "-n", CONFIG_SYS_SOC, "-T", "rksd"; + offset = <0x8000>; + }; + }; +}; +#endif diff --git a/arch/arm/include/asm/arch-rockchip/bootrom.h b/arch/arm/include/asm/arch-rockchip/bootrom.h index 4276a0f6811a..7dab18fbc3fb 100644 --- a/arch/arm/include/asm/arch-rockchip/bootrom.h +++ b/arch/arm/include/asm/arch-rockchip/bootrom.h @@ -48,6 +48,7 @@ enum { BROM_BOOTSOURCE_SPINOR = 3, BROM_BOOTSOURCE_SPINAND = 4, BROM_BOOTSOURCE_SD = 5, + BROM_BOOTSOURCE_SPINOR_RK3588 = 6, BROM_BOOTSOURCE_USB = 10, BROM_LAST_BOOTSOURCE = BROM_BOOTSOURCE_USB }; diff --git a/arch/arm/mach-rockchip/rk3588/rk3588.c b/arch/arm/mach-rockchip/rk3588/rk3588.c index 18e67b5ca9b2..b1f535fad505 100644 --- a/arch/arm/mach-rockchip/rk3588/rk3588.c +++ b/arch/arm/mach-rockchip/rk3588/rk3588.c @@ -41,6 +41,7 @@ const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { [BROM_BOOTSOURCE_EMMC] = "/mmc@fe2e0000", [BROM_BOOTSOURCE_SPINOR] = "/spi@fe2b0000/flash@0", [BROM_BOOTSOURCE_SD] = "/mmc@fe2c0000", + [BROM_BOOTSOURCE_SPINOR_RK3588] = "/spi@fe2b0000/flash@0", };
static struct mm_region rk3588_mem_map[] = { diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index 5fe3a3542e11..9d0b55c01ac9 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -8,15 +8,20 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="rk3588-rock-5b" CONFIG_ROCKCHIP_RK3588=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_ROCKCHIP_SPI_IMAGE=y CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_TARGET_ROCK5B_RK3588=y CONFIG_SPL_STACK=0x400000 CONFIG_DEBUG_UART_BASE=0xFEB50000 CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0xc00800 CONFIG_PCI=y CONFIG_DEBUG_UART=y @@ -36,6 +41,8 @@ CONFIG_SPL_BSS_MAX_SIZE=0x4000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x60000 CONFIG_SPL_ATF=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y @@ -61,6 +68,8 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y # CONFIG_SPL_MMC_SDHCI_SDMA is not set CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_XTX=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y CONFIG_PCIE_DW_ROCKCHIP=y @@ -73,6 +82,7 @@ CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SFC=y CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y
Hi Jonas,
v2:
Collect r-b tag
spi0 = &sfc;
chosen {
+&fspim2_pins {
- bootph-all;
- &pcie2x1l2 { pinctrl-names = "default"; pinctrl-0 = <&pcie2x1l2_pins &pcie_reset_h>;
+&sfc {
- bootph-pre-ram;
- u-boot,spl-sfc-no-dma;
- pinctrl-names = "default";
- pinctrl-0 = <&fspim2_pins>;
- #address-cells = <1>;
- #size-cells = <0>;
- status = "okay";
- flash@0 {
bootph-pre-ram;
reg = <0>;
- &uart2m0_xfer { bootph-all; };
- sfc: spi@fe2b0000 {
- otp: nvmem@fecc0000 { compatible = "rockchip,rk3588-otp"; reg = <0x0 0xfecc0000 0x0 0x400>;
- simple-bin-spi {
mkimage {
offset = <0x8000>;
- BROM_BOOTSOURCE_SPINOR_RK3588 = 6,
Why we need a new type of SPINOR_RK3588?
And this patch not able to apply due to conflict at rk3588s-u-boot.dtsi.
- [BROM_BOOTSOURCE_SPINOR_RK3588] = "/spi@fe2b0000/flash@0",
BROM_BOOTSOURCE_SPINOR is already there, why add BROM_BOOTSOURCE_SPINOR_RK3588 ?
Thanks,
- Kever
Hi Kever,
On 2023-05-18 02:41, Kever Yang wrote:
Hi Jonas,
v2:
Collect r-b tag
spi0 = &sfc;
chosen {
+&fspim2_pins {
- bootph-all;
+&sfc {
- bootph-pre-ram;
- status = "okay";
- flash@0 {
bootph-pre-ram;
reg = <0>;
- simple-bin-spi {
mkimage {
offset = <0x8000>;
Based on my testing I got an unexpected brom_bootdevice_id value when booting from SPI Flash on my RK3588 ROCK 5B board.
On my RK3568 ROCK 3A board (and other RK3399 boards) brom_bootdevice_id = 3 (SPINOR) Yet on my RK3588 ROCK 5B board I get brom_bootdevice_id = 6 instead.
RK3568: board_spl_was_booted_from: brom_bootdevice_id 3 maps to '/spi@fe300000/flash@0' RK3588: board_spl_was_booted_from: brom_bootdevice_id 6 maps to '/spi@fe2b0000/flash@0'
I did not find any new define in vendor u-boot for bootdevice_id 6 so do not really know what we should call this new value, maybe SPINOR2 or SPINOR_ALT?
Will resend a rebased version of this patch, I was expecting this to be applied in a different order :-)
I think I added BROM_BOOTSOURCE_SPINOR in a prior patch before I tested booting from spi nor flash with the expectation that bootdevice_id would match other socs.
After runtime testing and seeing the bootdevice_id being 6 instead of 3 it still felt best to keep the other one in case different soc revision would use 3 instead of the new value 6.
Please share any insights into why bootrom use value 6 instead of 3 compared to other socs, and if we can expect to see value 3 when booting from spi nor flash on any other rk3588 soc revision.
Regards, Jonas
Thanks,
- Kever
Jonas Karlman
Kever Yang
