[U-Boot-Users] [MIPS] Make mips_io_port_base more generic
Although mips_io_port_base is currently a part of IDE command, but it is quite fundamental for MIPS memory mapped I/O port access such as in[bwl] and out[bwl]. So let's move it to MIPS generic part.
This patch adds a helper routine for mips_io_port_base from Linux, and fixes two multiple definition of this variable, tb0229 and gth2.
This change is triggered by gth2 build error: board/gth2/libgth2.a(gth2.o): In function `log_serial_char': /home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base' common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here make: *** [u-boot] Error 1
Signed-off-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp ---
board/gth2/gth2.c | 4 ++-- board/tb0229/tb0229.c | 6 ++---- common/cmd_ide.c | 4 ---- include/asm-mips/io.h | 16 +++++++++++++++- lib_mips/board.c | 5 +++++ 5 files changed, 24 insertions(+), 11 deletions(-)
diff --git a/board/gth2/gth2.c b/board/gth2/gth2.c index ffeaf58..3c5563e 100644 --- a/board/gth2/gth2.c +++ b/board/gth2/gth2.c @@ -26,14 +26,13 @@ #include <asm/au1x00.h> #include <asm/addrspace.h> #include <asm/mipsregs.h> +#include <asm/io.h> #include <watchdog.h>
#include "ee_access.h"
static int wdi_status = 0;
-unsigned long mips_io_port_base = 0; - #define SDRAM_SIZE ((64*1024*1024)-(12*4096))
@@ -90,6 +89,7 @@ long int initdram(int board_type) /* If memory could be changed, we should return the true value here */
WATCHDOG_RESET(); + set_io_port_base(0);
return (SDRAM_SIZE); } diff --git a/board/tb0229/tb0229.c b/board/tb0229/tb0229.c index e7914bd..c80db56 100644 --- a/board/tb0229/tb0229.c +++ b/board/tb0229/tb0229.c @@ -13,10 +13,9 @@ #include <command.h> #include <asm/addrspace.h> #include <asm/inca-ip.h> +#include <asm/io.h> #include <pci.h>
-unsigned long mips_io_port_base = 0; - #if defined(CONFIG_PCI) static struct pci_controller hose;
@@ -26,17 +25,16 @@ void pci_init_board (void) } #endif
- long int initdram(int board_type) { return get_ram_size (CFG_SDRAM_BASE, 0x8000000); }
- int checkboard (void) { printf("Board: TANBAC TB0229 "); printf("(CPU Speed %d MHz)\n", (int)CPU_CLOCK_RATE/1000000);
+ set_io_port_base(0); return 0; } diff --git a/common/cmd_ide.c b/common/cmd_ide.c index bb064ea..feb89d6 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -54,10 +54,6 @@
#ifndef __PPC__ #include <asm/io.h> -#ifdef __MIPS__ -/* Macros depend on this variable */ -unsigned long mips_io_port_base = 0; -#endif #endif
#ifdef CONFIG_IDE_8xx_DIRECT diff --git a/include/asm-mips/io.h b/include/asm-mips/io.h index cd4d5dc..1e060f7 100644 --- a/include/asm-mips/io.h +++ b/include/asm-mips/io.h @@ -71,7 +71,21 @@ * instruction, so the lower 16 bits must be zero. Should be true on * on any sane architecture; generic code does not use this assumption. */ -extern unsigned long mips_io_port_base; +extern const unsigned long mips_io_port_base; + +/* + * Gcc will generate code to load the value of mips_io_port_base after each + * function call which may be fairly wasteful in some cases. So we don't + * play quite by the book. We tell gcc mips_io_port_base is a long variable + * which solves the code generation issue. Now we need to violate the + * aliasing rules a little to make initialization possible and finally we + * will need the barrier() to fight side effects of the aliasing chat. + * This trickery will eventually collapse under gcc's optimizer. Oh well. + */ +static inline void set_io_port_base(unsigned long base) +{ + * (unsigned long *) &mips_io_port_base = base; +}
/* * Thanks to James van Artsdalen for a better timing-fix than diff --git a/lib_mips/board.c b/lib_mips/board.c index 91ccec0..c1a0acf 100644 --- a/lib_mips/board.c +++ b/lib_mips/board.c @@ -62,6 +62,11 @@ static ulong mem_malloc_start; static ulong mem_malloc_end; static ulong mem_malloc_brk;
+/* + * mips_io_port_base is the begin of the address space to which x86 style + * I/O ports are mapped. + */ +unsigned long mips_io_port_base = -1;
/* * The Malloc area is immediately below the monitor copy in DRAM
I should have fixed all MIPS targets not only tb0229 and gth2. They might suppose mips_io_port_base is zero, but I change its initial value to -1 in this patch (since Linux does so).
Please don't apply, I'll re-submit later.
Thanks,
Shinya Kuribayashi
Although mips_io_port_base is currently a part of IDE command, it is quite fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move it to MIPS generic part.
This patch also fixes mips_io_port_base multiple definition bug which gth2 and tb0229 have. board/gth2/libgth2.a(gth2.o): In function `log_serial_char': /home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base' common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here make: *** [u-boot] Error 1
board/dbau1x00/dbau1x00.c | 4 ++++ board/gth2/gth2.c | 6 ++++-- board/incaip/incaip.c | 5 +++-- board/pb1x00/pb1x00.c | 4 ++++ board/purple/purple.c | 3 +++ board/tb0229/tb0229.c | 7 +++---- common/cmd_ide.c | 4 ---- include/asm-mips/io.h | 16 +++++++++++++++- lib_mips/board.c | 5 +++++ 9 files changed, 41 insertions(+), 13 deletions(-)
diff --git a/board/dbau1x00/dbau1x00.c b/board/dbau1x00/dbau1x00.c index d29e8d5..a13eeeb 100644 --- a/board/dbau1x00/dbau1x00.c +++ b/board/dbau1x00/dbau1x00.c @@ -25,6 +25,7 @@ #include <command.h> #include <asm/au1x00.h> #include <asm/mipsregs.h> +#include <asm/io.h>
long int initdram(int board_type) { @@ -77,6 +78,9 @@ int checkboard (void) default: printf ("Unsupported cpu %d, proc_id=0x%x\n", proc_id >> 24, proc_id); } + + set_io_port_base(0); + #ifdef CONFIG_IDE_PCMCIA /* Enable 3.3 V on slot 0 ( VCC ) No 5V */ diff --git a/board/gth2/gth2.c b/board/gth2/gth2.c index ffeaf58..1593f02 100644 --- a/board/gth2/gth2.c +++ b/board/gth2/gth2.c @@ -26,14 +26,13 @@ #include <asm/au1x00.h> #include <asm/addrspace.h> #include <asm/mipsregs.h> +#include <asm/io.h> #include <watchdog.h>
@@ -147,6 +146,9 @@ int checkboard (void) default: printf ("Unsupported cpu %d, proc_id=0x%x\n", proc_id >> 24, proc_id); } + + set_io_port_base(0); + #ifdef CONFIG_IDE_PCMCIA /* PCMCIA is on a 36 bit physical address. We need to map it into a 32 bit addresses */ diff --git a/board/incaip/incaip.c b/board/incaip/incaip.c index b5d9e00..dbf0ecc 100644 --- a/board/incaip/incaip.c +++ b/board/incaip/incaip.c @@ -25,7 +25,7 @@ #include <command.h> #include <asm/addrspace.h> #include <asm/inca-ip.h> - +#include <asm/io.h>
extern uint incaip_get_cpuclk(void);
@@ -85,7 +85,6 @@ long int initdram(int board_type)
int checkboard (void) { - unsigned long chipid = *INCA_IP_WDT_CHIPID; int part_num;
@@ -107,5 +106,7 @@ int checkboard (void)
printf("CPU Speed %d MHz\n", incaip_get_cpuclk()/1000000);
+ set_io_port_base(0); + return 0; } diff --git a/board/pb1x00/pb1x00.c b/board/pb1x00/pb1x00.c index 40ac2a4..95b7d82 100644 --- a/board/pb1x00/pb1x00.c +++ b/board/pb1x00/pb1x00.c @@ -25,6 +25,7 @@ #include <command.h> #include <asm/au1x00.h> #include <asm/mipsregs.h> +#include <asm/io.h>
long int initdram(int board_type) { @@ -69,6 +70,9 @@ int checkboard (void) default: printf ("Unsupported cpu %d, proc_id=0x%x\n", proc_id >> 24, proc_id); } + + set_io_port_base(0); + #if defined(CONFIG_IDE_PCMCIA) && 0 /* Enable 3.3 V on slot 0 ( VCC ) No 5V */ diff --git a/board/purple/purple.c b/board/purple/purple.c index 4c3e5b4..74718af 100644 --- a/board/purple/purple.c +++ b/board/purple/purple.c @@ -26,6 +26,7 @@ #include <asm/inca-ip.h> #include <asm/regdef.h> #include <asm/mipsregs.h> +#include <asm/io.h> #include <asm/addrspace.h> #include <asm/cacheops.h>
@@ -145,6 +146,8 @@ int checkboard (void)
printf("CPU Speed %d MHz\n", CPU_CLOCK_RATE/1000000);
diff --git a/board/tb0229/tb0229.c b/board/tb0229/tb0229.c index e7914bd..61c2e9b 100644 --- a/board/tb0229/tb0229.c +++ b/board/tb0229/tb0229.c @@ -13,10 +13,9 @@ #include <command.h> #include <asm/addrspace.h> #include <asm/inca-ip.h> +#include <asm/io.h> #include <pci.h>
@@ -26,17 +25,17 @@ void pci_init_board (void) } #endif
+ set_io_port_base(0); + return 0; } diff --git a/common/cmd_ide.c b/common/cmd_ide.c index bb064ea..feb89d6 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -54,10 +54,6 @@
Shinya Kuribayashi
Shinya Kuribayashi
