[U-Boot] [PATCH 1/2] arm: imx6: Add DDR3 calibration code for MX6 Q/D/DL
Add DDR3 calibration code for i.MX6Q, i.MX6D and i.MX6DL. This code fine-tunes the behavior of the MMDC controller in order to improve the signal integrity and memory stability.
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/armv7/mx6/ddr.c | 559 ++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx6/mx6-ddr.h | 5 + 2 files changed, 564 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/ddr.c b/arch/arm/cpu/armv7/mx6/ddr.c index 6b039e4..194411f 100644 --- a/arch/arm/cpu/armv7/mx6/ddr.c +++ b/arch/arm/cpu/armv7/mx6/ddr.c @@ -13,6 +13,565 @@ #include <asm/io.h> #include <asm/types.h>
+#if defined(CONFIG_MX6QDL) || defined(CONFIG_MX6Q) || defined(CONFIG_MX6D) + +static int wait_for_bit(void *reg, const uint32_t mask, bool set) +{ + unsigned int timeout = 1000; + u32 val; + + while (--timeout) { + val = readl(reg); + if (!set) + val = ~val; + + if ((val & mask) == mask) + return 0; + + udelay(1); + } + + printf("%s: Timeout (reg=%p mask=%08x wait_set=%i)\n", + __func__, reg, mask, set); + hang(); /* DRAM couldn't be calibrated, game over :-( */ +} + +static void reset_read_data_fifos(void) +{ + struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; + + /* Reset data FIFOs twice. */ + setbits_le32(&mmdc0->mpdgctrl0, 1 << 31); + wait_for_bit(&mmdc0->mpdgctrl0, 1 << 31, 0); + + setbits_le32(&mmdc0->mpdgctrl0, 1 << 31); + wait_for_bit(&mmdc0->mpdgctrl0, 1 << 31, 0); +} + +static void precharge_all(const bool cs0_enable, const bool cs1_enable) +{ + struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; + + /* + * Issue the Precharge-All command to the DDR device for both + * chip selects. Note, CON_REQ bit should also remain set. If + * only using one chip select, then precharge only the desired + * chip select. + */ + if (cs0_enable) { /* CS0 */ + writel(0x04008050, &mmdc0->mdscr); + wait_for_bit(&mmdc0->mdscr, 1 << 14, 1); + } + + if (cs1_enable) { /* CS1 */ + writel(0x04008058, &mmdc0->mdscr); + wait_for_bit(&mmdc0->mdscr, 1 << 14, 1); + } +} + +static void force_delay_measurement(int bus_size) +{ + struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; + struct mmdc_p_regs *mmdc1 = (struct mmdc_p_regs *)MMDC_P1_BASE_ADDR; + + writel(0x800, &mmdc0->mpmur0); + if (bus_size == 0x2) + writel(0x800, &mmdc1->mpmur0); +} + +static void modify_dg_result(u32 *reg_st0, u32 *reg_st1, u32 *reg_ctrl) +{ + u32 dg_tmp_val, dg_dl_abs_offset, dg_hc_del, val_ctrl; + + /* + * DQS gating absolute offset should be modified from reflecting + * (HW_DG_LOWx + HW_DG_UPx)/2 to reflecting (HW_DG_UPx - 0x80) + */ + + val_ctrl = readl(reg_ctrl); + val_ctrl &= 0xf0000000; + + dg_tmp_val = ((readl(reg_st0) & 0x07ff0000) >> 16) - 0xc0; + dg_dl_abs_offset = dg_tmp_val & 0x7f; + dg_hc_del = (dg_tmp_val & 0x780) << 1; + + val_ctrl |= dg_dl_abs_offset + dg_hc_del; + + dg_tmp_val = ((readl(reg_st1) & 0x07ff0000) >> 16) - 0xc0; + dg_dl_abs_offset = dg_tmp_val & 0x7f; + dg_hc_del = (dg_tmp_val & 0x780) << 1; + + val_ctrl |= (dg_dl_abs_offset + dg_hc_del) << 16; + + writel(val_ctrl, reg_ctrl); +} + +int mmdc_do_write_level_calibration(void) +{ + struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; + struct mmdc_p_regs *mmdc1 = (struct mmdc_p_regs *)MMDC_P1_BASE_ADDR; + u32 esdmisc_val, zq_val; + u32 errors = 0; + u32 ldectrl[4]; + u32 ddr_mr1 = 0x4; + + /* + * Stash old values in case calibration fails, + * we need to restore them + */ + ldectrl[0] = readl(&mmdc0->mpwldectrl0); + ldectrl[1] = readl(&mmdc0->mpwldectrl1); + ldectrl[2] = readl(&mmdc1->mpwldectrl0); + ldectrl[3] = readl(&mmdc1->mpwldectrl1); + + /* disable DDR logic power down timer */ + clrbits_le32(&mmdc0->mdpdc, 0xff00); + + /* disable Adopt power down timer */ + setbits_le32(&mmdc0->mapsr, 0x1); + + debug("Starting write leveling calibration.\n"); + + /* + * 2. disable auto refresh and ZQ calibration + * before proceeding with Write Leveling calibration + */ + esdmisc_val = readl(&mmdc0->mdref); + writel(0x0000C000, &mmdc0->mdref); + zq_val = readl(&mmdc0->mpzqhwctrl); + writel(zq_val & ~0x3, &mmdc0->mpzqhwctrl); + + /* 3. increase walat and ralat to maximum */ + setbits_le32(&mmdc0->mdmisc, + (1 << 6) | (1 << 7) | (1 << 8) | (1 << 16) | (1 << 17)); + setbits_le32(&mmdc1->mdmisc, + (1 << 6) | (1 << 7) | (1 << 8) | (1 << 16) | (1 << 17)); + /* + * 4 & 5. Configure the external DDR device to enter write-leveling + * mode through Load Mode Register command. + * Register setting: + * Bits[31:16] MR1 value (0x0080 write leveling enable) + * Bit[9] set WL_EN to enable MMDC DQS output + * Bits[6:4] set CMD bits for Load Mode Register programming + * Bits[2:0] set CMD_BA to 0x1 for DDR MR1 programming + */ + writel(0x00808231, &mmdc0->mdscr); + + /* 6. Activate automatic calibration by setting MPWLGCR[HW_WL_EN] */ + writel(0x00000001, &mmdc0->mpwlgcr); + + /* + * 7. Upon completion of this process the MMDC de-asserts + * the MPWLGCR[HW_WL_EN] + */ + wait_for_bit(&mmdc0->mpwlgcr, 1 << 0, 0); + + /* + * 8. check for any errors: check both PHYs for x64 configuration, + * if x32, check only PHY0 + */ + if (readl(&mmdc0->mpwlgcr) & 0x00000F00) + errors |= 1; + if (readl(&mmdc1->mpwlgcr) & 0x00000F00) + errors |= 2; + + debug("Ending write leveling calibration. Error mask: 0x%x\n", errors); + + /* check to see if cal failed */ + if ((readl(&mmdc0->mpwldectrl0) == 0x001F001F) && + (readl(&mmdc0->mpwldectrl1) == 0x001F001F) && + (readl(&mmdc1->mpwldectrl0) == 0x001F001F) && + (readl(&mmdc1->mpwldectrl1) == 0x001F001F)) { + debug("Cal seems to have soft-failed due to memory not supporting write leveling on all channels. Restoring original write leveling values.\n"); + writel(ldectrl[0], &mmdc0->mpwldectrl0); + writel(ldectrl[1], &mmdc0->mpwldectrl1); + writel(ldectrl[2], &mmdc1->mpwldectrl0); + writel(ldectrl[3], &mmdc1->mpwldectrl1); + errors |= 4; + } + + /* + * User should issue MRS command to exit write leveling mode + * through Load Mode Register command + * Register setting: + * Bits[31:16] MR1 value "ddr_mr1" value from initialization + * Bit[9] clear WL_EN to disable MMDC DQS output + * Bits[6:4] set CMD bits for Load Mode Register programming + * Bits[2:0] set CMD_BA to 0x1 for DDR MR1 programming + */ + writel((ddr_mr1 << 16) + 0x8031, &mmdc0->mdscr); + + /* re-enable auto refresh and zq cal */ + writel(esdmisc_val, &mmdc0->mdref); + writel(zq_val, &mmdc0->mpzqhwctrl); + + debug("\tMMDC_MPWLDECTRL0 after write level cal: 0x%08X\n", + readl(&mmdc0->mpwldectrl0)); + debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08X\n", + readl(&mmdc0->mpwldectrl1)); + debug("\tMMDC_MPWLDECTRL0 after write level cal: 0x%08X\n", + readl(&mmdc1->mpwldectrl0)); + debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08X\n", + readl(&mmdc1->mpwldectrl1)); + + /* We must force a readback of these values, to get them to stick */ + readl(&mmdc0->mpwldectrl0); + readl(&mmdc0->mpwldectrl1); + readl(&mmdc1->mpwldectrl0); + readl(&mmdc1->mpwldectrl1); + + /* enable DDR logic power down timer: */ + setbits_le32(&mmdc0->mdpdc, 0x00005500); + + /* Enable Adopt power down timer: */ + clrbits_le32(&mmdc0->mapsr, 0x1); + + /* Clear CON_REQ */ + writel(0, &mmdc0->mdscr); + + return errors; +} + +int mmdc_do_dqs_calibration(void) +{ + struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; + struct mmdc_p_regs *mmdc1 = (struct mmdc_p_regs *)MMDC_P1_BASE_ADDR; + struct mx6dq_iomux_ddr_regs *mx6_ddr_iomux = + (struct mx6dq_iomux_ddr_regs *)MX6DQ_IOM_DDR_BASE; + bool cs0_enable; + bool cs1_enable; + bool cs0_enable_initial; + bool cs1_enable_initial; + u32 esdmisc_val; + u32 bus_size; + u32 temp_ref; + u32 pddword = 0x00ffff00; /* best so far, place into MPPDCMPR1 */ + u32 errors = 0; + u32 initdelay = 0x40404040; + + /* check to see which chip selects are enabled */ + cs0_enable_initial = readl(&mmdc0->mdctl) & 0x80000000; + cs1_enable_initial = readl(&mmdc0->mdctl) & 0x40000000; + + /* disable DDR logic power down timer: */ + clrbits_le32(&mmdc0->mdpdc, 0xff00); + + /* disable Adopt power down timer: */ + setbits_le32(&mmdc0->mapsr, 0x1); + + /* set DQS pull ups */ + setbits_le32(&mx6_ddr_iomux->dram_sdqs0, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs1, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs2, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs3, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs4, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs5, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs6, 0x7000); + setbits_le32(&mx6_ddr_iomux->dram_sdqs7, 0x7000); + + /* Save old RALAT and WALAT values */ + esdmisc_val = readl(&mmdc0->mdmisc); + + setbits_le32(&mmdc0->mdmisc, + (1 << 6) | (1 << 7) | (1 << 8) | (1 << 16) | (1 << 17)); + + /* Disable auto refresh before proceeding with calibration */ + temp_ref = readl(&mmdc0->mdref); + writel(0x0000c000, &mmdc0->mdref); + + /* + * Per the ref manual, issue one refresh cycle MDSCR[CMD]= 0x2, + * this also sets the CON_REQ bit. + */ + if (cs0_enable_initial) + writel(0x00008020, &mmdc0->mdscr); + if (cs1_enable_initial) + writel(0x00008028, &mmdc0->mdscr); + + /* poll to make sure the con_ack bit was asserted */ + wait_for_bit(&mmdc0->mdscr, 1 << 14, 1); + + /* + * Check MDMISC register CALIB_PER_CS to see which CS calibration + * is targeted to (under normal cases, it should be cleared + * as this is the default value, indicating calibration is directed + * to CS0). + * Disable the other chip select not being target for calibration + * to avoid any potential issues. This will get re-enabled at end + * of calibration. + */ + if ((readl(&mmdc0->mdmisc) & 0x00100000) == 0) + clrbits_le32(&mmdc0->mdctl, 1 << 30); /* clear SDE_1 */ + else + clrbits_le32(&mmdc0->mdctl, 1 << 31); /* clear SDE_0 */ + + /* + * Check to see which chip selects are now enabled for + * the remainder of the calibration. + */ + cs0_enable = readl(&mmdc0->mdctl) & 0x80000000; + cs1_enable = readl(&mmdc0->mdctl) & 0x40000000; + + /* Check to see what the data bus size is */ + bus_size = (readl(&mmdc0->mdctl) & 0x30000) >> 16; + debug("Data bus size: %d (%d bits)\n", bus_size, 1 << (bus_size + 4)); + + precharge_all(cs0_enable, cs1_enable); + + /* Write the pre-defined value into MPPDCMPR1 */ + writel(pddword, &mmdc0->mppdcmpr1); + + /* + * Issue a write access to the external DDR device by setting + * the bit SW_DUMMY_WR (bit 0) in the MPSWDAR0 and then poll + * this bit until it clears to indicate completion of the write access. + */ + setbits_le32(&mmdc0->mpswdar0, 1); + wait_for_bit(&mmdc0->mpswdar0, 1 << 0, 0); + + /* Set the RD_DL_ABS# bits to their default values + * (will be calibrated later in the read delay-line calibration). + * Both PHYs for x64 configuration, if x32, do only PHY0. + */ + writel(initdelay, &mmdc0->mprddlctl); + if (bus_size == 0x2) + writel(initdelay, &mmdc1->mprddlctl); + + /* Force a measurment, for previous delay setup to take effect. */ + force_delay_measurement(bus_size); + + /* + * *************************** + * Read DQS Gating calibration + * *************************** + */ + debug("Starting Read DQS Gating calibration.\n"); + + /* + * Reset the read data FIFOs (two resets); only need to issue reset + * to PHY0 since in x64 mode, the reset will also go to PHY1. + */ + reset_read_data_fifos(); + + /* + * Start the automatic read DQS gating calibration process by + * asserting MPDGCTRL0[HW_DG_EN] and MPDGCTRL0[DG_CMP_CYC] + * and then poll MPDGCTRL0[HW_DG_EN]] until this bit clears + * to indicate completion. + * Also, ensure that MPDGCTRL0[HW_DG_ERR] is clear to indicate + * no errors were seen during calibration. + */ + + /* + * Set bit 30: chooses option to wait 32 cycles instead of + * 16 before comparing read data. + */ + setbits_le32(&mmdc0->mpdgctrl0, 1 << 30); + + /* Set bit 28 to start automatic read DQS gating calibration */ + setbits_le32(&mmdc0->mpdgctrl0, 5 << 28); + + /* Poll for completion. MPDGCTRL0[HW_DG_EN] should be 0 */ + wait_for_bit(&mmdc0->mpdgctrl0, 1 << 28, 0); + + /* + * Check to see if any errors were encountered during calibration + * (check MPDGCTRL0[HW_DG_ERR]). + * Check both PHYs for x64 configuration, if x32, check only PHY0. + */ + if (readl(&mmdc0->mpdgctrl0) & 0x00001000) + errors |= 1; + + if ((bus_size == 0x2) && (readl(&mmdc1->mpdgctrl0) & 0x00001000)) + errors |= 2; + + /* + * DQS gating absolute offset should be modified from + * reflecting (HW_DG_LOWx + HW_DG_UPx)/2 to + * reflecting (HW_DG_UPx - 0x80) + */ + modify_dg_result(&mmdc0->mpdghwst0, &mmdc0->mpdghwst1, + &mmdc0->mpdgctrl0); + modify_dg_result(&mmdc0->mpdghwst2, &mmdc0->mpdghwst3, + &mmdc0->mpdgctrl1); + if (bus_size == 0x2) { + modify_dg_result(&mmdc1->mpdghwst0, &mmdc1->mpdghwst1, + &mmdc1->mpdgctrl0); + modify_dg_result(&mmdc1->mpdghwst2, &mmdc1->mpdghwst3, + &mmdc1->mpdgctrl1); + } + debug("Ending Read DQS Gating calibration. Error mask: 0x%x\n", errors); + + /* + * ********************** + * Read Delay calibration + * ********************** + */ + debug("Starting Read Delay calibration.\n"); + + reset_read_data_fifos(); + + /* + * 4. Issue the Precharge-All command to the DDR device for both + * chip selects. If only using one chip select, then precharge + * only the desired chip select. + */ + precharge_all(cs0_enable, cs1_enable); + + /* + * 9. Read delay-line calibration + * Start the automatic read calibration process by asserting + * MPRDDLHWCTL[HW_RD_DL_EN]. + */ + writel(0x00000030, &mmdc0->mprddlhwctl); + + /* + * 10. poll for completion + * MMDC indicates that the write data calibration had finished by + * setting MPRDDLHWCTL[HW_RD_DL_EN] = 0. Also, ensure that + * no error bits were set. + */ + wait_for_bit(&mmdc0->mprddlhwctl, 1 << 4, 0); + + /* check both PHYs for x64 configuration, if x32, check only PHY0 */ + if (readl(&mmdc0->mprddlhwctl) & 0x0000000f) + errors |= 4; + + if ((bus_size == 0x2) && (readl(&mmdc1->mprddlhwctl) & 0x0000000f)) + errors |= 8; + + debug("Ending Read Delay calibration. Error mask: 0x%x\n", errors); + + /* + * *********************** + * Write Delay Calibration + * *********************** + */ + debug("Starting Write Delay calibration.\n"); + + reset_read_data_fifos(); + + /* + * 4. Issue the Precharge-All command to the DDR device for both + * chip selects. If only using one chip select, then precharge + * only the desired chip select. + */ + precharge_all(cs0_enable, cs1_enable); + + /* + * 8. Set the WR_DL_ABS# bits to their default values. + * Both PHYs for x64 configuration, if x32, do only PHY0. + */ + writel(initdelay, &mmdc0->mpwrdlctl); + if (bus_size == 0x2) + writel(initdelay, &mmdc1->mpwrdlctl); + + /* + * XXX This isn't in the manual. Force a measurement, + * for previous delay setup to effect. + */ + force_delay_measurement(bus_size); + + /* + * 9. 10. Start the automatic write calibration process + * by asserting MPWRDLHWCTL0[HW_WR_DL_EN]. + */ + writel(0x00000030, &mmdc0->mpwrdlhwctl); + + /* + * Poll for completion. + * MMDC indicates that the write data calibration had finished + * by setting MPWRDLHWCTL[HW_WR_DL_EN] = 0. + * Also, ensure that no error bits were set. + */ + wait_for_bit(&mmdc0->mpwrdlhwctl, 1 << 4, 0); + + /* Check both PHYs for x64 configuration, if x32, check only PHY0 */ + if (readl(&mmdc0->mpwrdlhwctl) & 0x0000000f) + errors |= 16; + + if ((bus_size == 0x2) && (readl(&mmdc1->mpwrdlhwctl) & 0x0000000f)) + errors |= 32; + + debug("Ending Write Delay calibration. Error mask: 0x%x\n", errors); + + reset_read_data_fifos(); + + /* Enable DDR logic power down timer */ + setbits_le32(&mmdc0->mdpdc, 0x00005500); + + /* Enable Adopt power down timer */ + clrbits_le32(&mmdc0->mapsr, 0x1); + + /* Restore MDMISC value (RALAT, WALAT) to MMDCP1 */ + writel(esdmisc_val, &mmdc0->mdmisc); + + /* Clear DQS pull ups */ + clrbits_le32(&mx6_ddr_iomux->dram_sdqs0, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs1, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs2, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs3, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs4, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs5, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs6, 0x7000); + clrbits_le32(&mx6_ddr_iomux->dram_sdqs7, 0x7000); + + /* Re-enable SDE (chip selects) if they were set initially */ + if (cs1_enable_initial) + /* Set SDE_1 */ + setbits_le32(&mmdc0->mdctl, 1 << 30); + + if (cs0_enable_initial) + /* Set SDE_0 */ + setbits_le32(&mmdc0->mdctl, 1 << 31); + + /* Re-enable to auto refresh */ + writel(temp_ref, &mmdc0->mdref); + + /* Clear the MDSCR (including the con_req bit) */ + writel(0x0, &mmdc0->mdscr); /* CS0 */ + + /* Poll to make sure the con_ack bit is clear */ + wait_for_bit(&mmdc0->mdscr, 1 << 14, 0); + + /* + * Print out the registers that were updated as a result + * of the calibration process. + */ + debug("MMDC registers updated from calibration\n"); + debug("Read DQS gating calibration:\n"); + debug("\tMPDGCTRL0 PHY0 = 0x%08X\n", readl(&mmdc0->mpdgctrl0)); + debug("\tMPDGCTRL1 PHY0 = 0x%08X\n", readl(&mmdc0->mpdgctrl1)); + debug("\tMPDGCTRL0 PHY1 = 0x%08X\n", readl(&mmdc1->mpdgctrl0)); + debug("\tMPDGCTRL1 PHY1 = 0x%08X\n", readl(&mmdc1->mpdgctrl1)); + debug("Read calibration:\n"); + debug("\tMPRDDLCTL PHY0 = 0x%08X\n", readl(&mmdc0->mprddlctl)); + debug("\tMPRDDLCTL PHY1 = 0x%08X\n", readl(&mmdc1->mprddlctl)); + debug("Write calibration:\n"); + debug("\tMPWRDLCTL PHY0 = 0x%08X\n", readl(&mmdc0->mpwrdlctl)); + debug("\tMPWRDLCTL PHY1 = 0x%08X\n", readl(&mmdc1->mpwrdlctl)); + + /* + * Registers below are for debugging purposes. These print out + * the upper and lower boundaries captured during + * read DQS gating calibration. + */ + debug("Status registers bounds for read DQS gating:\n"); + debug("\tMPDGHWST0 PHY0 = 0x%08x\n", readl(&mmdc0->mpdghwst0)); + debug("\tMPDGHWST1 PHY0 = 0x%08x\n", readl(&mmdc0->mpdghwst1)); + debug("\tMPDGHWST2 PHY0 = 0x%08x\n", readl(&mmdc0->mpdghwst2)); + debug("\tMPDGHWST3 PHY0 = 0x%08x\n", readl(&mmdc0->mpdghwst3)); + debug("\tMPDGHWST0 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst0)); + debug("\tMPDGHWST1 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst1)); + debug("\tMPDGHWST2 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst2)); + debug("\tMPDGHWST3 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst3)); + + debug("Final do_dqs_calibration error mask: 0x%x\n", errors); + + return errors; +} +#endif + #if defined(CONFIG_MX6SX) /* Configure MX6SX mmdc iomux */ void mx6sx_dram_iocfg(unsigned width, diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h index 68d9bda..12c30d2 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-ddr.h +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -456,6 +456,11 @@ void mx6sl_dram_iocfg(unsigned width, const struct mx6sl_iomux_ddr_regs *, const struct mx6sl_iomux_grp_regs *);
+#if defined(CONFIG_MX6QDL) || defined(CONFIG_MX6Q) || defined(CONFIG_MX6D) +int mmdc_do_write_level_calibration(void); +int mmdc_do_dqs_calibration(void); +#endif + /* configure mx6 mmdc registers */ void mx6_dram_cfg(const struct mx6_ddr_sysinfo *, const struct mx6_mmdc_calibration *,
Enable the DDR calibration functionality on Novena to deal with the memory SoDIMM on this board. Moreover, tweak the initial DDR DRAM parameters so the calibration works properly.
Signed-off-by: Marek Vasut marex@denx.de --- board/kosagi/novena/novena_spl.c | 23 ++++++++++++++--------- 1 file changed, 14 insertions(+), 9 deletions(-)
diff --git a/board/kosagi/novena/novena_spl.c b/board/kosagi/novena/novena_spl.c index eb46265..f779bb4 100644 --- a/board/kosagi/novena/novena_spl.c +++ b/board/kosagi/novena/novena_spl.c @@ -434,8 +434,8 @@ static struct mx6dq_iomux_ddr_regs novena_ddr_ioregs = { .dram_ras = 0x00000038, .dram_reset = 0x00000038, /* SDCKE[0:1]: 100k pull-up */ - .dram_sdcke0 = 0x00003000, - .dram_sdcke1 = 0x00003000, + .dram_sdcke0 = 0x00000038, + .dram_sdcke1 = 0x00000038, /* SDBA2: pull-up disabled */ .dram_sdba2 = 0x00000000, /* SDODT[0:1]: 100k pull-up, 40 ohm */ @@ -512,10 +512,10 @@ static struct mx6_ddr_sysinfo novena_ddr_info = { /* Single chip select */ .ncs = 1, .cs1_mirror = 0, - .rtt_wr = 1, /* RTT_Wr = RZQ/4 */ - .rtt_nom = 2, /* RTT_Nom = RZQ/2 */ - .walat = 3, /* Write additional latency */ - .ralat = 7, /* Read additional latency */ + .rtt_wr = 0, /* RTT_Wr = RZQ/4 */ + .rtt_nom = 1, /* RTT_Nom = RZQ/2 */ + .walat = 0, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ .mif3_mode = 3, /* Command prediction working mode */ .bi_on = 1, /* Bank interleaving enabled */ .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ @@ -530,9 +530,9 @@ static struct mx6_ddr3_cfg elpida_4gib_1600 = { .rowaddr = 16, .coladdr = 10, .pagesz = 2, - .trcd = 1300, - .trcmin = 4900, - .trasmin = 3590, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, };
static void ccgr_init(void) @@ -601,6 +601,11 @@ void board_init_f(ulong dummy) mx6dq_dram_iocfg(64, &novena_ddr_ioregs, &novena_grp_ioregs); mx6_dram_cfg(&novena_ddr_info, &novena_mmdc_calib, &elpida_4gib_1600);
+ /* Perform DDR DRAM calibration */ + udelay(100); + mmdc_do_write_level_calibration(); + mmdc_do_dqs_calibration(); + /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
Hi Marek,
Shouldn't this be in two patches?
- .dram_sdcke0 = 0x00000038,
- .dram_sdcke1 = 0x00000038, /* SDBA2: pull-up disabled */ .dram_sdba2 = 0x00000000, /* SDODT[0:1]: 100k pull-up, 40 ohm */
- .rtt_wr = 0, /* RTT_Wr = RZQ/4 */
- .rtt_nom = 1, /* RTT_Nom = RZQ/2 */
- .walat = 0, /* Write additional latency */
- .ralat = 5, /* Read additional latency */ .mif3_mode = 3, /* Command prediction working mode */ .bi_on = 1, /* Bank interleaving enabled */ .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */
- .trcd = 1300,
- .trcmin = 4900,
- .trasmin = 3590,
- .trcd = 1375,
- .trcmin = 4875,
- .trasmin = 3500,
- /* Perform DDR DRAM calibration */
- udelay(100);
Shouldn't the return values be tested?
- mmdc_do_write_level_calibration();
- mmdc_do_dqs_calibration();
- /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
Hi Marek,
I'm glad to see that others are interested in this.
I've been working on something similar, but struggling to have time to finish and clean it up: https://github.com/ericnelsonaz/u-boot/tree/memcal-pass1
My aim is/was a bit different though, and aims to be a replacement for the DDR stress tool, which is cumbersome to use.
To do that, I put together a pseudo-board with Kconfig options for the serial console, memory bus width, and such.
I'll review this in detail later, but off-hand, I think this could use a new CONFIG_ variable to exclude it from boards that don't use it.
It also shouldn't be difficult to support i.MX6SL and LPDDR here.
- unsigned int timeout = 1000;
- u32 val;
Regards,
Eric
On Wednesday, December 16, 2015 at 04:00:38 PM, Eric Nelson wrote:
Hi Marek,
Excellent, we can add this as an optional feature or something which can be triggered by command, since the "full" calibration takes some time.
Or maybe this can be built as a mutated SPL ?
This is OK, the code will be compiled for these MX6 variants, but it will be dropped from the final binary if you don't call it explicitly (see patch 2/2).
I don't have SX/SL, so I couldn't test it there.
Thanks!
- u32 val;
Regards,
Eric
Best regards, Marek Vasut
Hi Marek,
Hi Marek,
That's how I have things hacked together. The board "mx6memcal" essentially **only** produces SPL.
It runs calibration, then spits out the results in a form usable by either a .cfg file or SPL data structure.
I'd like to add a trailing memory test with frequency walking as done with the DDR stress tool before submitting it though.
Gotcha.
I have a couple of SL boards, so I can do that (mx6slevk and a custom board using DDR3). Both of them support SPL, so it shouldn't take long to validate.
Regards,
Eric
On Wednesday, December 16, 2015 at 05:28:48 PM, Eric Nelson wrote:
Hi Marek,
Hi!
Hi Marek,
Gotcha! That'd be great thing to have %^)
Gotcha.
Excellent! Let's do this as a subsequent patch though, since this code is actually tested extensively and I'd like to keep it as a reference for possible bisecting ;-)
Hi Marek,
Will do.
I'll review and test your patch first, then follow up with SoloLite and LPDDR2 support.
Regards,
Eric
On Wednesday, December 16, 2015 at 06:07:02 PM, Eric Nelson wrote:
Hi Marek,
Hi!
Will do.
Excellent, thanks!
On Wed, Dec 16, 2015 at 7:00 AM, Eric Nelson eric@nelint.com wrote:
Hi Marek,
Eric,
I would love to see a series posted that adds IMX6 MMDC calibration and stress test to U-Boot. I agree the Freescale code is very difficult to use and I don't trust what its doing. I'm currently seeing the Freescale DDR3 stress test fail on 8Gb density memory and I am not convinced its not a problem with their code (yet I haven't had time to pick through it with a fine toothed comb and compare with how I setup the MMDC in U-Boot).
Regards,
Tim
Hi Tim,
Hi Marek,
Eric,
Will do. Some other demands on my time will push this into next week (and Christmas) though.
I'll try to get an RFC version out before the holiday though, (after reviewing Marek's patch).
It's always tough to trust code that you can't see and discuss.
Because it's a pain to run, I also suspect that many (most) boards are running with calibration gathered from a small set of boards, and I've seen lots of board->board variation.
Something that can be run using imx_usb can make the process of gathering data much easier.
The board->board variations hint that Marek's on the right track and that calibration really should be done at run-time.
I haven't seen any issues with 8GiB densities, but have only tested on a small set of board designs (primarily Nitrogen6_max).
Regards,
Eric
Marek,
This is great - this would be a great addition to U-Boot IMX6 SPL.
You must have forgotten to post a dependent patch that adds some of the registers to mmdc_p_regs. If you can post that I can run this through some testing. Also, in a follow-on post we should add some more verbiage about how long this takes to perform (I believe you told me ~10ms) and where to refer in the IMX6 RM's for the steps followed.
Regards,
Tim
Marek,
What exactly is missing please ? I am using this on Novena for a while without issues.
Freescale AN4467 is the right thing ... I mean NXP AN4467 of course.
Marek,
sorry my bad... forgot I was on an old branch. All is good.
I will run some boards with this through some stress testing and review.
Tim
Marek,
Whew! OKi, thanks!
Hi Marek,
Great work!
Regards, Nikolay
On Thursday, December 17, 2015 at 10:32:03 PM, Nikolay Dimitrov wrote:
Hi Marek,
Great work!
Thanks, I am flattered :)
Hi Marek,
It would be good to have a reference to AN4467 in the commit message, since that document is the best reference to understanding this code:
http://cache.freescale.com/files/32bit/doc/app_note/AN4467.pdf
Note that there's another implementation of this in the barebox project:
http://git.pengutronix.de/?p=barebox.git;a=blob;f=arch/arm/mach-imx/imx6-mmd...
Should this use the common wait_for_bit? http://lists.denx.de/pipermail/u-boot/2015-December/thread.html#237952
I'm not certain that the <ctrl-c> handling is appropriate when used here.
- u32 val;
- while (--timeout) {
val = readl(reg);
if (!set)
val = ~val;
udelay(1);
- printf("%s: Timeout (reg=%p mask=%08x wait_set=%i)\n",
- hang(); /* DRAM couldn't be calibrated, game over :-( */
- struct mmdc_p_regs *mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR;
- /* Reset data FIFOs twice. */
- setbits_le32(&mmdc0->mpdgctrl0, 1 << 31);
- wait_for_bit(&mmdc0->mpdgctrl0, 1 << 31, 0);
See comments below about chip-selects during calibration.
* chip select.
AN4467 says that a wait for tRP is needed here, though none of the other implementations explicitly do that.
The wait for CON_ACK seems like a good idea, though I wonder if the waits shouldn't be performed **before** the commands are issued.
I'd also like to see a named constant for MDSCR_CON_ACK, and since waiting for it is done in multiple places, perhaps wait_for_con_ack().
- if (cs0_enable) { /* CS0 */
- if (cs1_enable) { /* CS1 */
- struct mmdc_p_regs *mmdc1 = (struct mmdc_p_regs *)MMDC_P1_BASE_ADDR;
- writel(0x800, &mmdc0->mpmur0);
- if (bus_size == 0x2)
- u32 dg_tmp_val, dg_dl_abs_offset, dg_hc_del, val_ctrl;
- val_ctrl = readl(reg_ctrl);
- val_ctrl &= 0xf0000000;
Though this matches the app note and other implementations, I think this would be easier to understand by shifting first and anding with 0x7ff.
- dg_tmp_val = ((readl(reg_st0) & 0x07ff0000) >> 16) - 0xc0;
Especially since these calculations operate on the shifted values:
- dg_dl_abs_offset = dg_tmp_val & 0x7f;
- dg_hc_del = (dg_tmp_val & 0x780) << 1;
- val_ctrl |= dg_dl_abs_offset + dg_hc_del;
- dg_tmp_val = ((readl(reg_st1) & 0x07ff0000) >> 16) - 0xc0;
- val_ctrl |= (dg_dl_abs_offset + dg_hc_del) << 16;
- writel(val_ctrl, reg_ctrl);
I'd recommend passing parameters of mx6_ddr_sysinfo (input) and mx6_mmdc_calibration (output) to this routine.
- u32 esdmisc_val, zq_val;
- u32 errors = 0;
- u32 ldectrl[4];
I believe the 4 here comes from this calculation:
ddr_mr1 = ((sysinfo->rtt_nom & 1) ? 1 : 0) << 2 | ((sysinfo->rtt_nom & 2) ? 1 : 0) << 6;
- u32 ddr_mr1 = 0x4;
I'm not sure how this is useful (trying to proceed if things fail).
Have you seen this triggered?
- ldectrl[0] = readl(&mmdc0->mpwldectrl0);
- ldectrl[1] = readl(&mmdc0->mpwldectrl1);
- ldectrl[2] = readl(&mmdc1->mpwldectrl0);
- ldectrl[3] = readl(&mmdc1->mpwldectrl1);
- /* disable DDR logic power down timer */
- clrbits_le32(&mmdc0->mdpdc, 0xff00);
Either s/Adopt/Automatic/ or just get rid of Adopt...
This is a typo in the app note.
- /* disable Adopt power down timer */
- setbits_le32(&mmdc0->mapsr, 0x1);
- debug("Starting write leveling calibration.\n");
Trusting the esdmisc value read from here seems like a bad idea. It would be clearer if the code below that restores things just (re)configures mdref directly.
- esdmisc_val = readl(&mmdc0->mdref);
- writel(0x0000C000, &mmdc0->mdref);
- zq_val = readl(&mmdc0->mpzqhwctrl);
clrbits_le32?
- writel(zq_val & ~0x3, &mmdc0->mpzqhwctrl);
- /* 3. increase walat and ralat to maximum */
(3 << 16) | (7 << 6) would be clearer, since these are numeric values in tbe bitfields.
- setbits_le32(&mmdc0->mdmisc,
- setbits_le32(&mmdc1->mdmisc,
I had a concern about this bit of code (setting RALAT and WALAT to maximum values). It seems odd that we calibrate with one set of delays and then choose a different set later.
Experimentally, I've found using min or max values seems to have no effect on the result.
* Register setting:
wait_for_con_ack() seems like a good idea here:
- writel(0x00808231, &mmdc0->mdscr);
- /* 6. Activate automatic calibration by setting MPWLGCR[HW_WL_EN] */
- writel(0x00000001, &mmdc0->mpwlgcr);
Why 1 << 0?
- wait_for_bit(&mmdc0->mpwlgcr, 1 << 0, 0);
- if (readl(&mmdc0->mpwlgcr) & 0x00000F00)
errors |= 1;
This should be conditional on (sysinfo->dsize == 2) to allow use with a 32-bit bus:
- if (readl(&mmdc1->mpwlgcr) & 0x00000F00)
errors |= 2;
- debug("Ending write leveling calibration. Error mask: 0x%x\n", errors);
Where are you getting this test from?
I have code that tests each byte individually against a max value of 0x2f, but I'm having trouble finding the source of the test at the moment.
- /* check to see if cal failed */
- if ((readl(&mmdc0->mpwldectrl0) == 0x001F001F) &&
Ditto (sysinfo->dsize == 2):
errors |= 4;
* Register setting:
- writel((ddr_mr1 << 16) + 0x8031, &mmdc0->mdscr);
As mentioned earlier, you can just set mdref here, instead of using a saved value. The only assignment is currently this:
mmdc0->mdref = (0 << 14) | (3 << 11);
- /* re-enable auto refresh and zq cal */
- writel(esdmisc_val, &mmdc0->mdref);
I think you can just use clrbits32_le here and get rid of zq_val.
- writel(zq_val, &mmdc0->mpzqhwctrl);
- debug("\tMMDC_MPWLDECTRL0 after write level cal: 0x%08X\n",
- debug("\tMMDC_MPWLDECTRL1 after write level cal: 0x%08X\n",
Why the dummy reads below?
I'd like to see the values fed back in an output parameter: calib->p0_mpwldectrl0 = readl(&mmdc0->mpwldectrl0); calib->p0_mpwldectrl1 = readl(&mmdc0->mpwldectrl1);
Absent that, I don't think a dummy read is needed.
- /* We must force a readback of these values, to get them to stick */
- readl(&mmdc0->mpwldectrl0);
- readl(&mmdc0->mpwldectrl1);
- readl(&mmdc1->mpwldectrl0);
- readl(&mmdc1->mpwldectrl1);
- /* enable DDR logic power down timer: */
- setbits_le32(&mmdc0->mdpdc, 0x00005500);
Again, s/Adopt/Automatic/
- /* Enable Adopt power down timer: */
- clrbits_le32(&mmdc0->mapsr, 0x1);
- /* Clear CON_REQ */
- writel(0, &mmdc0->mdscr);
- return errors;
This should also have parameters of mx6_ddr_sysinfo (input) and mx6_mmdc_calibration (output), at least for sysinfo->dsize
Note that this is specific to MX6DQ:
- struct mx6dq_iomux_ddr_regs *mx6_ddr_iomux =
- bool cs0_enable;
- bool cs1_enable;
- bool cs0_enable_initial;
- bool cs1_enable_initial;
- u32 esdmisc_val;
- u32 bus_size;
- u32 temp_ref;
- u32 pddword = 0x00ffff00; /* best so far, place into MPPDCMPR1 */
- u32 errors = 0;
- u32 initdelay = 0x40404040;
sysinfo can be used here instead of reading mdctl, and I think cs0_enable_initial has to be true because of the way we're using sysinfo->ncs.
i.e. cs1_enable_initial = (sysinfo->ncs == 2);
- /* check to see which chip selects are enabled */
- cs0_enable_initial = readl(&mmdc0->mdctl) & 0x80000000;
- cs1_enable_initial = readl(&mmdc0->mdctl) & 0x40000000;
- /* disable DDR logic power down timer: */
- /* disable Adopt power down timer: */
- /* set DQS pull ups */
These should use clrsetbits_le32 to clear bit 15:
- setbits_le32(&mx6_ddr_iomux->dram_sdqs0, 0x7000);
- setbits_le32(&mx6_ddr_iomux->dram_sdqs1, 0x7000);
- setbits_le32(&mx6_ddr_iomux->dram_sdqs2, 0x7000);
- setbits_le32(&mx6_ddr_iomux->dram_sdqs3, 0x7000);
- setbits_le32(&mx6_ddr_iomux->dram_sdqs4, 0x7000);
- setbits_le32(&mx6_ddr_iomux->dram_sdqs5, 0x7000);
- setbits_le32(&mx6_ddr_iomux->dram_sdqs6, 0x7000);
- setbits_le32(&mx6_ddr_iomux->dram_sdqs7, 0x7000);
- /* Save old RALAT and WALAT values */
RALAT and WALAT are in sysinfo, and esdmisc_val isn't needed.
- esdmisc_val = readl(&mmdc0->mdmisc);
See previous notes about mdref.
It also seems that we'll always call both of the calibration routines in this order: mmdc_do_write_level_calibration() mmdc_do_dqs_calibration()
So restoring refresh values in mmdc_do_write_level_calibration() only to disable them again seems pointless and perhaps the two routines should be combined.
- /* Disable auto refresh before proceeding with calibration */
- temp_ref = readl(&mmdc0->mdref);
- writel(0x0000c000, &mmdc0->mdref);
wait_for_con_ack() before the command?
Also, the cs0_enable_initial is superfluous (we have to have one chip select and don't support only CS1):
- if (cs0_enable_initial)
- if (cs1_enable_initial)
- /* poll to make sure the con_ack bit was asserted */
- wait_for_bit(&mmdc0->mdscr, 1 << 14, 1);
* to CS0).
* of calibration.
As far as I can tell, we have no way of setting bit 20 (CALIB_PER_CS), and if we did, I think we'd need additional logic, at least to clear the other bit in mdctl.
Tim, handling of these bits may be the source of the issue you're having with multiple chip selects.
- if ((readl(&mmdc0->mdmisc) & 0x00100000) == 0)
- else
Here's what Section 5 of the app note says:
The user has the option of populating DDR memory devices on chip select 0 (CSD0), chip select 1 (CSD1), or both chip selects. The control mechanism to decide which chip select the associated calibration is targeted to is found in MDMISC[CALIB_PER_CS] bit. If the DDR memory devices are populated on CSD0, then this bit would be cleared. If these devices are populated only on CSD1, then this bit would be set. Should both chip selects be populated, it is an absolute must that the memories populated on CSD1 are “mirrored” with the memories populated on CSD0, as both CSD share the same delay line register set during normal DDR operation. Given the similarities in memory device layout, either setting can be used for MDMISC[CALIB_PER_CS] bit. However, the examples in this document clear this bit, hence targeting calibration toward CSD0.
Given this, it seems as if the test above is useless and we should always target CS0.
And this should go away:
- cs0_enable = readl(&mmdc0->mdctl) & 0x80000000;
- cs1_enable = readl(&mmdc0->mdctl) & 0x40000000;
bus_size is in sysinfo.
- /* Check to see what the data bus size is */
- bus_size = (readl(&mmdc0->mdctl) & 0x30000) >> 16;
- debug("Data bus size: %d (%d bits)\n", bus_size, 1 << (bus_size + 4));
And the parameters here can go away:
- precharge_all(cs0_enable, cs1_enable);
- /* Write the pre-defined value into MPPDCMPR1 */
- writel(pddword, &mmdc0->mppdcmpr1);
- setbits_le32(&mmdc0->mpswdar0, 1);
- wait_for_bit(&mmdc0->mpswdar0, 1 << 0, 0);
- /* Set the RD_DL_ABS# bits to their default values
- writel(initdelay, &mmdc0->mprddlctl);
if (sysinfo->dsize == 0x2)
- /* Force a measurment, for previous delay setup to take effect. */
- force_delay_measurement(bus_size);
- debug("Starting Read DQS Gating calibration.\n");
- reset_read_data_fifos();
- setbits_le32(&mmdc0->mpdgctrl0, 1 << 30);
I think you need to poll for bit 30 clear here.
- /* Set bit 28 to start automatic read DQS gating calibration */
1 << 28 ?
- setbits_le32(&mmdc0->mpdgctrl0, 5 << 28);
- /* Poll for completion. MPDGCTRL0[HW_DG_EN] should be 0 */
- wait_for_bit(&mmdc0->mpdgctrl0, 1 << 28, 0);
- if (readl(&mmdc0->mpdgctrl0) & 0x00001000)
errors |= 1;
sysinfo->dsize
- if ((bus_size == 0x2) && (readl(&mmdc1->mpdgctrl0) & 0x00001000))
errors |= 2;
- modify_dg_result(&mmdc0->mpdghwst0, &mmdc0->mpdghwst1,
&mmdc0->mpdgctrl0);
- modify_dg_result(&mmdc0->mpdghwst2, &mmdc0->mpdghwst3,
&mmdc0->mpdgctrl1);
- if (bus_size == 0x2) {
&mmdc1->mpdgctrl0);
&mmdc1->mpdgctrl1);
- debug("Ending Read DQS Gating calibration. Error mask: 0x%x\n", errors);
- debug("Starting Read Delay calibration.\n");
- writel(0x00000030, &mmdc0->mprddlhwctl);
- wait_for_bit(&mmdc0->mprddlhwctl, 1 << 4, 0);
- /* check both PHYs for x64 configuration, if x32, check only PHY0 */
- if (readl(&mmdc0->mprddlhwctl) & 0x0000000f)
errors |= 4;
- if ((bus_size == 0x2) && (readl(&mmdc1->mprddlhwctl) & 0x0000000f))
errors |= 8;
- debug("Ending Read Delay calibration. Error mask: 0x%x\n", errors);
- debug("Starting Write Delay calibration.\n");
- writel(initdelay, &mmdc0->mpwrdlctl);
- writel(0x00000030, &mmdc0->mpwrdlhwctl);
- wait_for_bit(&mmdc0->mpwrdlhwctl, 1 << 4, 0);
- /* Check both PHYs for x64 configuration, if x32, check only PHY0 */
- if (readl(&mmdc0->mpwrdlhwctl) & 0x0000000f)
errors |= 16;
- if ((bus_size == 0x2) && (readl(&mmdc1->mpwrdlhwctl) & 0x0000000f))
errors |= 32;
- debug("Ending Write Delay calibration. Error mask: 0x%x\n", errors);
- /* Enable DDR logic power down timer */
s/Adopt/Automatic/
- /* Enable Adopt power down timer */
sysinfo->ralat, sysinfo->walat
- /* Restore MDMISC value (RALAT, WALAT) to MMDCP1 */
- writel(esdmisc_val, &mmdc0->mdmisc);
i.e. clrsetbits_le32(&mmdc0->mdmisc, (3 << 16) | (7 << 6), (sysinfo->walat << 16) | (sysinfo->ralat << 6));
- /* Clear DQS pull ups */
- clrbits_le32(&mx6_ddr_iomux->dram_sdqs0, 0x7000);
- clrbits_le32(&mx6_ddr_iomux->dram_sdqs1, 0x7000);
- clrbits_le32(&mx6_ddr_iomux->dram_sdqs2, 0x7000);
- clrbits_le32(&mx6_ddr_iomux->dram_sdqs3, 0x7000);
- clrbits_le32(&mx6_ddr_iomux->dram_sdqs4, 0x7000);
- clrbits_le32(&mx6_ddr_iomux->dram_sdqs5, 0x7000);
- clrbits_le32(&mx6_ddr_iomux->dram_sdqs6, 0x7000);
- clrbits_le32(&mx6_ddr_iomux->dram_sdqs7, 0x7000);
- /* Re-enable SDE (chip selects) if they were set initially */
/* Set SDE_1 */
Again, I think this test is superfluous since we don't support a routing of CS1 by itself.
/* Set SDE_0 */
writel((0 << 14) | /* REF_SEL: Periodic refresh cycle: 64kHz */ (3 << 11) /* REFR: Refresh Rate - 4 refreshes */, &mmdc0->mdref);
- /* Re-enable to auto refresh */
- writel(temp_ref, &mmdc0->mdref);
- /* Clear the MDSCR (including the con_req bit) */
- writel(0x0, &mmdc0->mdscr); /* CS0 */
- /* Poll to make sure the con_ack bit is clear */
- wait_for_bit(&mmdc0->mdscr, 1 << 14, 0);
- debug("MMDC registers updated from calibration\n");
- debug("Read DQS gating calibration:\n");
- debug("\tMPDGCTRL0 PHY0 = 0x%08X\n", readl(&mmdc0->mpdgctrl0));
- debug("\tMPDGCTRL1 PHY0 = 0x%08X\n", readl(&mmdc0->mpdgctrl1));
- debug("\tMPDGCTRL0 PHY1 = 0x%08X\n", readl(&mmdc1->mpdgctrl0));
- debug("\tMPDGCTRL1 PHY1 = 0x%08X\n", readl(&mmdc1->mpdgctrl1));
- debug("Read calibration:\n");
- debug("\tMPRDDLCTL PHY0 = 0x%08X\n", readl(&mmdc0->mprddlctl));
- debug("\tMPRDDLCTL PHY1 = 0x%08X\n", readl(&mmdc1->mprddlctl));
- debug("Write calibration:\n");
- debug("\tMPWRDLCTL PHY0 = 0x%08X\n", readl(&mmdc0->mpwrdlctl));
- debug("\tMPWRDLCTL PHY1 = 0x%08X\n", readl(&mmdc1->mpwrdlctl));
Here's where it would be useful to update a calibration output parameter:
calib->p0_mpdgctrl0 = readl(&mmdc0->mpdgctrl0); calib->p0_mpdgctrl1 = readl(&mmdc0->mpdgctrl1); calib->p0_mprddlctl = readl(&mmdc0->mprddlctl); calib->p0_mpwrdlctl = readl(&mmdc0->mpwrdlctl); if (sysinfo->dsize == 2) { calib->p1_mpwldectrl0 = readl(&mmdc1->mpwldectrl0); calib->p1_mpwldectrl1 = readl(&mmdc1->mpwldectrl1); calib->p1_mpdgctrl0 = readl(&mmdc1->mpdgctrl0); calib->p1_mpdgctrl1 = readl(&mmdc1->mpdgctrl1); calib->p1_mprddlctl = readl(&mmdc1->mprddlctl); calib->p1_mpwrdlctl = readl(&mmdc1->mpwrdlctl); }
- debug("Status registers bounds for read DQS gating:\n");
- debug("\tMPDGHWST0 PHY0 = 0x%08x\n", readl(&mmdc0->mpdghwst0));
- debug("\tMPDGHWST1 PHY0 = 0x%08x\n", readl(&mmdc0->mpdghwst1));
- debug("\tMPDGHWST2 PHY0 = 0x%08x\n", readl(&mmdc0->mpdghwst2));
- debug("\tMPDGHWST3 PHY0 = 0x%08x\n", readl(&mmdc0->mpdghwst3));
- debug("\tMPDGHWST0 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst0));
- debug("\tMPDGHWST1 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst1));
- debug("\tMPDGHWST2 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst2));
- debug("\tMPDGHWST3 PHY1 = 0x%08x\n", readl(&mmdc1->mpdghwst3));
- debug("Final do_dqs_calibration error mask: 0x%x\n", errors);
Finally, I'm not sure what the current caller(s) will do if errors are returned from either of these two routines...
- return errors;
+} +#endif
On Sunday, December 20, 2015 at 08:31:46 PM, Eric Nelson wrote:
Hi Marek,
OK
http://git.pengutronix.de/?p=barebox.git;a=blob;f=arch/arm/mach-imx/imx6-mm dc.c;h=146df573e4eeed7132e93899b4b539e842bb6ba2;hb=HEAD
Yeah, I sent them a patch for it too ;-)
Yes, that's why I called it exactly the same, so once the patches above hit mainline, I could just nuke this function and replace it with the common one.
- u32 val;
val = readl(reg);
if (!set)
val = ~val;
udelay(1);
* chip select.
That'd be great. Do you know of some header where the MMDC register bits are defined ? I am definitelly not gonna rewrite the the i.MX6 MMDC bits from the datasheet by hand.
Implementing a function for the sake of just wrapping another function seems wasteful to me.
I think it is better to stick with the appnote, so it's easy to map the code and the appnote between one another.
Why exactly ?
- u32 errors = 0;
- u32 ldectrl[4];
What ? I see an assignment , what would trigger here ?
OK
Can you elaborate some more on why is it a bad idea?
clrbits_le32?
The zq_val is used further in the code, so no.
OK
* Register setting:
Why ?
Why 1 << 0?
It waits for the autocalibration to finish, see 6. above.
errors |= 1;
I believe mmdc1 will contain 0x0 << 8 if you use 32bit bus, right ?
errors |= 2;
This one came I think from the freescale code from novena repo.
supporting
errors |= 4;
* Register setting:
You do not need those values anymore, since they are already loaded into the hardware ... or why would you want them to be adjusted ?
- return errors;
Would it be possible for you to send a subsequent patch(set)? I would like to have this code as a working base , since I tested this thoroughly. If I apply all of your changes, it would basically mean almost complete rewrite of the code and that would disallow me bisect possible bugs introduced by these changes.
Hi Marek,
Sounds good.
* chip select.
I don't.
I think this is stuff that's supposed to be done by the boot loader ;).
How about just one constant?
I was thinking macro, but okay.
Okay. My hope is that a future app note will refer to the new code...
Why exactly ?
I sent a note about this in response to Tim's comment.
- u32 errors = 0;
- u32 ldectrl[4];
This code appears to be saving calibration data so that it can be restored later in the case of failure.
I don't understand why.
This is another case where you're assuming prior configuration of registers, when the value written should be based on the board's configuration.
Using an input sysinfo structure makes that clearer.
clrbits_le32?
zq_val can go away.
Just clrbits_le32 here and set the bits later.
ZQ_MODE should always be 3 on exit from the routine.
* Register setting:
Why ?
The RM says that the CON_ACK bit should be polled after issuing commands with the CON_REQ bit set.
This isn't always done in the code from the app note, but it's not clear that this is by design.
Why 1 << 0?
This was a nit-pick: why not simply 1?
errors |= 1;
This will become important when we support devices that only have one MMDC. (See MMDC1 macro)
errors |= 2;
I think this test is wrong, and we should really find the proper test for failure.
errors |= 4;
* Register setting:
Sorry: I mean setbits_le32:
setbits_le32(&mmdc0->mpzqhwctrl, 3);
Not adjusted, just returned so they can be printf'd by a caller.
Still, why the dummy reads?
- return errors;
I think that's a bit of overstatement, but I'm okay sending patches in principle.
I do think that at least the test for calibration failure should be fixed before your patch is applied.
This also has the benefit of allowing discussion about each of my points individually instead of in one e-mail thread.
Regards,
Eric
On Tuesday, December 22, 2015 at 04:37:12 PM, Eric Nelson wrote:
Hi Marek,
Hi Eric,
I have to admit I'm a bit lost in this. What do you say we ask Stefano to apply this so people can start fiddling with it. I'd also like to see the patches for MX6SX and your fixes (if you feel like it).
Hi Marek,
Hi Marek,
Hi Eric,
I'm okay with that.
I was hoping to check out the error handling code but unfortunately, the boards I have that are supporting SPL are all either i.MX6DL, i.MX6S, or i.MX6SL.
You should be able to force a failure by setting WALAT and/or RALAT to extreme values and see how the DDR controller responds.
Regards,
Eric
On Thursday, January 14, 2016 at 03:37:09 AM, Eric Nelson wrote:
Hi Marek,
Hi!
Hi Marek,
Hi Eric,
I'm okay with that.
I only have Q ;-) The DDR calibration code _should_ work on DL though.
Hi Marek,
Hi!
Hi Marek,
Hi Eric,
I'm okay with that.
It at least needs a change to some #ifdefs:
Regards,
Eric
Hi Marek,
Hi!
Hi Marek,
Hi Eric,
> This should also have parameters of mx6_ddr_sysinfo (input) and > mx6_mmdc_calibration (output), at least for sysinfo->dsize
I'm okay with that.
And then you can test it ;-) Have fun, I'm looking forward to improvements :)
Hi Marek,
Hi!
Hi Marek,
Hi Eric,
>> This should also have parameters of mx6_ddr_sysinfo (input) and >> mx6_mmdc_calibration (output), at least for sysinfo->dsize > > Would it be possible for you to send a subsequent patch(set)? I would > like to have this code as a working base , since I tested this > thoroughly. If I apply all of your changes, it would basically mean > almost complete rewrite of the code and that would disallow me bisect > possible bugs introduced by these changes.
I'm okay with that.
I was able to test the auto calibration a couple of weeks ago on a set of boards. I have a mix of boards with IMX6Q/IMX6DL 16/32/64bit 2/4/8Gb density - a pretty broad range. I did find the that a couple of my boards hung during mx6_dram_cfg if I skip writing anything to the calib registers (I made mx6_dram_cfg able to take a null struct mx6_mmc_calibration and call mmdc_do_write_level_calibration() and mmdc_do_dqs_calibration() automatically if null after config). I haven't had time to troubleshoot yet. Its possible I need some initial value for the calib registers or its possible there is a step in the init that should differ if we have not yet calibrated.
I am all for committing what we have (as its opt-in) and we can continue to improve/test/troubleshoot.
Tim
Hi Tim, Marek, Fabio,
I was thinking about it and I agree that it is better to get it in and goes on with tests, as we can achieve much more testers.
However, I have seen that there is a general attempt for a wait_for_bit() function, posted here:
http://patchwork.ozlabs.org/patch/572085/
This can help to drop the i.MX6 implementation and reuse a general utility.
Best regards, Stefano Babic
This patch was not applied yet, but the conversion will be straightforward once it is applied.
So, please apply these patches.
Hi Marek,
Yes, it is - then it is better to this before applying.
We are not hurry for the release, and I think we have time to make things right at once.
On Sunday, January 24, 2016 at 06:03:52 PM, Stefano Babic wrote:
Hi Marek,
wait_for_bit() function, posted here: http://patchwork.ozlabs.org/patch/572085/
It is not clear when the wait_for_bit() will be applied, I am certain there will be another round for so. I do not want to wait for it and I don't see a reason why those patches should block this if the conversion can be done afterward.
The shorter they will be in the tree, the less testing they will have.
Just wait for a while - if it takes too much, I reconsider to apply this first and factorize wait_for_bit() in a follow-up patch.
I have waited for over a month and I fail to see a reason why patches which will be applied at uncertain point in the future shall block this patchset. The wait_for_bit() can be removed by a subsequent patch, it is already pulled out explicitly in the code, so I don't see a problem with applying this.
Did I miss something or isn't v4 of wait_for_bit good to go?
I don't really know if it's good to go, but this patch does not depend on it in any way. A subsequent patch can drop the wait_for_bit() from here, it's the same as the wait_for_bit() in dwc2 and other wait_for_bit() anywhere else, but I don't see a reason why this patch should not be applied now.
If I follow the logic in this thread, it would also be possible to say that this patch should wait until Eric submits the MX6S DDR support for example. We could indefinitelly wait for new and new stuff which might possibly block this.
Why don't you ack/test/review the wait_for_bit series and post a follow-up to this one that uses the common function, which can be squashed into the original and then this gets picked up?
Why ? I can send subsequent patch which removes the duplicate wait_for_bit() from this code once the wait_for_bit series is applied. I don't see a problem with that and the wait_for_bit() being so explicitly pulled out from the code is done with that in mind. But that does not block this patch from being applied now. Does it?
On 24/01/2016 18:11, Marek Vasut wrote: > It is not clear when the wait_for_bit() will be applied, I am > certain there will be another round for so. I do not want to > wait for it and I don't see a reason why those patches should > block this if the conversion can be done afterward.
If I tell you I'm probably going to have the wait_for_bit stuff applied before the next imx PR is ready... ?
On Sunday, January 24, 2016 at 06:18:23 PM, Stefano Babic wrote: > On 24/01/2016 18:11, Marek Vasut wrote: > > It is not clear when the wait_for_bit() will be applied, I am > > certain there will be another round for so. I do not want to > > wait for it and I don't see a reason why those patches should > > block this if the conversion can be done afterward. > > Just wait for a while - if it takes too much, I reconsider to > apply this first and factorize wait_for_bit() in a follow-up > patch.
Well so what ? I still do not see why these patches should be blocked by the wait_for_bit() stuff. The conversion to wait_for_bit() can well be done after that, so what is the problem ?
So, why is this patchset not applied yet ... ?
On Sun, Jan 24, 2016 at 06:22:10PM +0100, Marek Vasut wrote: > On Sunday, January 24, 2016 at 06:18:23 PM, Stefano Babic wrote: > > On 24/01/2016 18:11, Marek Vasut wrote: > > > It is not clear when the wait_for_bit() will be applied, I am > > > certain there will be another round for so. I do not want to > > > wait for it and I don't see a reason why those patches should > > > block this if the conversion can be done afterward. > > > > Just wait for a while - if it takes too much, I reconsider to > > apply this first and factorize wait_for_bit() in a follow-up > > patch. > > I have waited for over a month and I fail to see a reason why > patches which will be applied at uncertain point in the future > shall block this patchset. The wait_for_bit() can be removed by > a subsequent patch, it is already pulled out explicitly in the > code, so I don't see a problem with applying this.
Stefano,
I would also like to see this applied. I have some time in the coming weeks to do some extensive testing of it over a variety of memory chips and configurations.
Regards,
Tim
Hi Tim,
Stefano,
Did I not ? Sorry if it is not, but I was convinced I applied Marek's.
In log I see:
commit d339f16911c790196f5aaea3682819b9c03633bb Author: Marek Vasut marex@denx.de Date: Wed Dec 16 15:40:06 2015 +0100
What have I missed ?
Nice - let us know your progress.
On Thu, Jun 2, 2016 at 7:23 AM, Stefano Babic sbabic@denx.de wrote:
Hi Tim,
Stefano,
In log I see:
Stefano,
Sorry - my mistake. Yes it's in there.
Thanks!
Tim
On Sun, Dec 20, 2015 at 11:31 AM, Eric Nelson eric@nelint.com wrote:
Hi Marek,
<snip>
I don't know that this would make sense. The mx6_ddr_sysinfo shouldn't be affected by calibration and the mx6_mmdc_calibration structure would not be used if you are using auto-calibration.
In fact, I recommend an additional patch that will call the auto-calibration functions in mx6_ddr3_cfg if it is passed a NULL for mx6_ddr_calibration.
Tim
Hi Tim,
Hi Marek,
<snip> > I'd recommend passing parameters of mx6_ddr_sysinfo (input) and > mx6_mmdc_calibration (output) to this routine. >
Using sysinfo allows simpler determination of things like bus size and rtt_nom.
This should be based on a board's configuration instead of inferring the parameters by reading and interpreting registers that must have been set before the calls to do_write_level_calibration().
The DDR stress tool does this (read from registers) because it's distributed as a binary and JTAG is used to configure things before running.
The calibration parameter would be used in a subsequent patch to add a "calibration" pseudo-board.
Regards,
Eric
participants (6)
Eric Nelson
Nikolay Dimitrov
Stefano Babic
Tim Harvey
