[U-Boot] [PATCH] board: evb64260: delete an unused source file
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de Cc: Nye Liu nyet@zumanetworks.com --- board/evb64260/ecctest.c | 111 ----------------------------------------------- 1 file changed, 111 deletions(-) delete mode 100644 board/evb64260/ecctest.c
diff --git a/board/evb64260/ecctest.c b/board/evb64260/ecctest.c deleted file mode 100644 index 5d3679a..0000000 --- a/board/evb64260/ecctest.c +++ /dev/null @@ -1,111 +0,0 @@ -indent: Standard input:27: Warning:old style assignment ambiguity in "=*". Assuming "= *" - -#ifdef ECC_TEST -static inline void ecc_off (void) -{ - *(volatile int *) (INTERNAL_REG_BASE_ADDR + 0x4b4) &= ~0x00200000; -} - -static inline void ecc_on (void) -{ - *(volatile int *) (INTERNAL_REG_BASE_ADDR + 0x4b4) |= 0x00200000; -} - -static int putshex (const char *buf, int len) -{ - int i; - - for (i = 0; i < len; i++) { - printf ("%02x", buf[i]); - } - return 0; -} - -static int char_memcpy (void *d, const void *s, int len) -{ - int i; - char *cd = d; - const char *cs = s; - - for (i = 0; i < len; i++) { - *(cd++) = *(cs++); - } - return 0; -} - -static int memory_test (char *buf) -{ - const char src[][16] = { - {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}, - {0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, - 0x01, 0x01, 0x01, 0x01, 0x01, 0x01}, - {0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, - 0x02, 0x02, 0x02, 0x02, 0x02, 0x02}, - {0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, - 0x04, 0x04, 0x04, 0x04, 0x04, 0x04}, - {0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, - 0x08, 0x08, 0x08, 0x08, 0x08, 0x08}, - {0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, - 0x10, 0x10, 0x10, 0x10, 0x10, 0x10}, - {0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, - 0x20, 0x20, 0x20, 0x20, 0x20, 0x20}, - {0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, - 0x40, 0x40, 0x40, 0x40, 0x40, 0x40}, - {0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, - 0x80, 0x80, 0x80, 0x80, 0x80, 0x80}, - {0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, - 0x55, 0x55, 0x55, 0x55, 0x55, 0x55}, - {0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, - 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa}, - {0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, - 0xff, 0xff, 0xff, 0xff, 0xff, 0xff} - }; - const int foo[] = { 0 }; - int i, j, a; - - printf ("\ntest @ %d %p\n", foo[0], buf); - for (i = 0; i < 12; i++) { - for (a = 0; a < 8; a++) { - const char *s = src[i] + a; - int align = (unsigned) (s) & 0x7; - - /* ecc_off(); */ - memcpy (buf, s, 8); - /* ecc_on(); */ - putshex (s, 8); - if (memcmp (buf, s, 8)) { - putc ('\n'); - putshex (buf, 8); - printf (" [FAIL] (%p) align=%d\n", s, align); - for (j = 0; j < 8; j++) { - s[j] == buf[j] ? puts (" ") : - printf ("%02x", - (s[j]) ^ (buf[j])); - } - putc ('\n'); - } else { - printf (" [PASS] (%p) align=%d\n", s, align); - } - /* ecc_off(); */ - char_memcpy (buf, s, 8); - /* ecc_on(); */ - putshex (s, 8); - if (memcmp (buf, s, 8)) { - putc ('\n'); - putshex (buf, 8); - printf (" [FAIL] (%p) align=%d\n", s, align); - for (j = 0; j < 8; j++) { - s[j] == buf[j] ? puts (" ") : - printf ("%02x", - (s[j]) ^ (buf[j])); - } - putc ('\n'); - } else { - printf (" [PASS] (%p) align=%d\n", s, align); - } - } - } - - return 0; -} -#endif
Masahiro Yamada
