[U-Boot] [PATCH 1/3] MX31: add support for setting pin pads
The patch adds a utility function and defines to set the pad as it is done in linux.
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/cpu/arm1136/mx31/generic.c | 17 ++ arch/arm/include/asm/arch-mx31/mx31-regs.h | 404 ++++++++++++++++++++++++++++ drivers/video/mx3fb.c | 31 --- 3 files changed, 421 insertions(+), 31 deletions(-)
diff --git a/arch/arm/cpu/arm1136/mx31/generic.c b/arch/arm/cpu/arm1136/mx31/generic.c index 1415d6c..cbe8243 100644 --- a/arch/arm/cpu/arm1136/mx31/generic.c +++ b/arch/arm/cpu/arm1136/mx31/generic.c @@ -23,6 +23,7 @@
#include <common.h> #include <asm/arch/mx31-regs.h> +#include <asm/io.h>
static u32 mx31_decode_pll(u32 reg, u32 infreq) { @@ -90,6 +91,22 @@ void mx31_gpio_mux(unsigned long mode) __REG(reg) = tmp; }
+void mx31_set_pad(enum iomux_pins pin, u32 config) +{ + u32 field, l; + void *reg; + + pin &= IOMUX_PADNUM_MASK; + reg = (IOMUXC_BASE + 0x154) + (pin + 2) / 3 * 4; + field = (pin + 2) % 3; + + l = __raw_readl(reg); + l &= ~(0x1ff << (field * 10)); + l |= config << (field * 10); + __raw_writel(l, reg); + +} + #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo (void) { diff --git a/arch/arm/include/asm/arch-mx31/mx31-regs.h b/arch/arm/include/asm/arch-mx31/mx31-regs.h index 7a98d1c..46ed47c 100644 --- a/arch/arm/include/asm/arch-mx31/mx31-regs.h +++ b/arch/arm/include/asm/arch-mx31/mx31-regs.h @@ -64,6 +64,370 @@ struct gpio_regs { u32 gpio_psr; };
+#define IOMUX_PADNUM_MASK 0x1ff +#define IOMUX_PIN(gpionum, padnum) ((padnum) & IOMUX_PADNUM_MASK) + +/* + * various IOMUX pad functions + */ +enum iomux_pad_config { + PAD_CTL_NOLOOPBACK = 0x0 << 9, + PAD_CTL_LOOPBACK = 0x1 << 9, + PAD_CTL_PKE_NONE = 0x0 << 8, + PAD_CTL_PKE_ENABLE = 0x1 << 8, + PAD_CTL_PUE_KEEPER = 0x0 << 7, + PAD_CTL_PUE_PUD = 0x1 << 7, + PAD_CTL_100K_PD = 0x0 << 5, + PAD_CTL_100K_PU = 0x1 << 5, + PAD_CTL_47K_PU = 0x2 << 5, + PAD_CTL_22K_PU = 0x3 << 5, + PAD_CTL_HYS_CMOS = 0x0 << 4, + PAD_CTL_HYS_SCHMITZ = 0x1 << 4, + PAD_CTL_ODE_CMOS = 0x0 << 3, + PAD_CTL_ODE_OpenDrain = 0x1 << 3, + PAD_CTL_DRV_NORMAL = 0x0 << 1, + PAD_CTL_DRV_HIGH = 0x1 << 1, + PAD_CTL_DRV_MAX = 0x2 << 1, + PAD_CTL_SRE_SLOW = 0x0 << 0, + PAD_CTL_SRE_FAST = 0x1 << 0 +}; + +/* + * This enumeration is constructed based on the Section + * "sw_pad_ctl & sw_mux_ctl details" of the MX31 IC Spec. Each enumerated + * value is constructed based on the rules described above. + */ + +enum iomux_pins { + MX31_PIN_TTM_PAD = IOMUX_PIN(0xff, 0), + MX31_PIN_CSPI3_SPI_RDY = IOMUX_PIN(0xff, 1), + MX31_PIN_CSPI3_SCLK = IOMUX_PIN(0xff, 2), + MX31_PIN_CSPI3_MISO = IOMUX_PIN(0xff, 3), + MX31_PIN_CSPI3_MOSI = IOMUX_PIN(0xff, 4), + MX31_PIN_CLKSS = IOMUX_PIN(0xff, 5), + MX31_PIN_CE_CONTROL = IOMUX_PIN(0xff, 6), + MX31_PIN_ATA_RESET_B = IOMUX_PIN(95, 7), + MX31_PIN_ATA_DMACK = IOMUX_PIN(94, 8), + MX31_PIN_ATA_DIOW = IOMUX_PIN(93, 9), + MX31_PIN_ATA_DIOR = IOMUX_PIN(92, 10), + MX31_PIN_ATA_CS1 = IOMUX_PIN(91, 11), + MX31_PIN_ATA_CS0 = IOMUX_PIN(90, 12), + MX31_PIN_SD1_DATA3 = IOMUX_PIN(63, 13), + MX31_PIN_SD1_DATA2 = IOMUX_PIN(62, 14), + MX31_PIN_SD1_DATA1 = IOMUX_PIN(61, 15), + MX31_PIN_SD1_DATA0 = IOMUX_PIN(60, 16), + MX31_PIN_SD1_CLK = IOMUX_PIN(59, 17), + MX31_PIN_SD1_CMD = IOMUX_PIN(58, 18), + MX31_PIN_D3_SPL = IOMUX_PIN(0xff, 19), + MX31_PIN_D3_CLS = IOMUX_PIN(0xff, 20), + MX31_PIN_D3_REV = IOMUX_PIN(0xff, 21), + MX31_PIN_CONTRAST = IOMUX_PIN(0xff, 22), + MX31_PIN_VSYNC3 = IOMUX_PIN(0xff, 23), + MX31_PIN_READ = IOMUX_PIN(0xff, 24), + MX31_PIN_WRITE = IOMUX_PIN(0xff, 25), + MX31_PIN_PAR_RS = IOMUX_PIN(0xff, 26), + MX31_PIN_SER_RS = IOMUX_PIN(89, 27), + MX31_PIN_LCS1 = IOMUX_PIN(88, 28), + MX31_PIN_LCS0 = IOMUX_PIN(87, 29), + MX31_PIN_SD_D_CLK = IOMUX_PIN(86, 30), + MX31_PIN_SD_D_IO = IOMUX_PIN(85, 31), + MX31_PIN_SD_D_I = IOMUX_PIN(84, 32), + MX31_PIN_DRDY0 = IOMUX_PIN(0xff, 33), + MX31_PIN_FPSHIFT = IOMUX_PIN(0xff, 34), + MX31_PIN_HSYNC = IOMUX_PIN(0xff, 35), + MX31_PIN_VSYNC0 = IOMUX_PIN(0xff, 36), + MX31_PIN_LD17 = IOMUX_PIN(0xff, 37), + MX31_PIN_LD16 = IOMUX_PIN(0xff, 38), + MX31_PIN_LD15 = IOMUX_PIN(0xff, 39), + MX31_PIN_LD14 = IOMUX_PIN(0xff, 40), + MX31_PIN_LD13 = IOMUX_PIN(0xff, 41), + MX31_PIN_LD12 = IOMUX_PIN(0xff, 42), + MX31_PIN_LD11 = IOMUX_PIN(0xff, 43), + MX31_PIN_LD10 = IOMUX_PIN(0xff, 44), + MX31_PIN_LD9 = IOMUX_PIN(0xff, 45), + MX31_PIN_LD8 = IOMUX_PIN(0xff, 46), + MX31_PIN_LD7 = IOMUX_PIN(0xff, 47), + MX31_PIN_LD6 = IOMUX_PIN(0xff, 48), + MX31_PIN_LD5 = IOMUX_PIN(0xff, 49), + MX31_PIN_LD4 = IOMUX_PIN(0xff, 50), + MX31_PIN_LD3 = IOMUX_PIN(0xff, 51), + MX31_PIN_LD2 = IOMUX_PIN(0xff, 52), + MX31_PIN_LD1 = IOMUX_PIN(0xff, 53), + MX31_PIN_LD0 = IOMUX_PIN(0xff, 54), + MX31_PIN_USBH2_DATA1 = IOMUX_PIN(0xff, 55), + MX31_PIN_USBH2_DATA0 = IOMUX_PIN(0xff, 56), + MX31_PIN_USBH2_NXT = IOMUX_PIN(0xff, 57), + MX31_PIN_USBH2_STP = IOMUX_PIN(0xff, 58), + MX31_PIN_USBH2_DIR = IOMUX_PIN(0xff, 59), + MX31_PIN_USBH2_CLK = IOMUX_PIN(0xff, 60), + MX31_PIN_USBOTG_DATA7 = IOMUX_PIN(0xff, 61), + MX31_PIN_USBOTG_DATA6 = IOMUX_PIN(0xff, 62), + MX31_PIN_USBOTG_DATA5 = IOMUX_PIN(0xff, 63), + MX31_PIN_USBOTG_DATA4 = IOMUX_PIN(0xff, 64), + MX31_PIN_USBOTG_DATA3 = IOMUX_PIN(0xff, 65), + MX31_PIN_USBOTG_DATA2 = IOMUX_PIN(0xff, 66), + MX31_PIN_USBOTG_DATA1 = IOMUX_PIN(0xff, 67), + MX31_PIN_USBOTG_DATA0 = IOMUX_PIN(0xff, 68), + MX31_PIN_USBOTG_NXT = IOMUX_PIN(0xff, 69), + MX31_PIN_USBOTG_STP = IOMUX_PIN(0xff, 70), + MX31_PIN_USBOTG_DIR = IOMUX_PIN(0xff, 71), + MX31_PIN_USBOTG_CLK = IOMUX_PIN(0xff, 72), + MX31_PIN_USB_BYP = IOMUX_PIN(31, 73), + MX31_PIN_USB_OC = IOMUX_PIN(30, 74), + MX31_PIN_USB_PWR = IOMUX_PIN(29, 75), + MX31_PIN_SJC_MOD = IOMUX_PIN(0xff, 76), + MX31_PIN_DE_B = IOMUX_PIN(0xff, 77), + MX31_PIN_TRSTB = IOMUX_PIN(0xff, 78), + MX31_PIN_TDO = IOMUX_PIN(0xff, 79), + MX31_PIN_TDI = IOMUX_PIN(0xff, 80), + MX31_PIN_TMS = IOMUX_PIN(0xff, 81), + MX31_PIN_TCK = IOMUX_PIN(0xff, 82), + MX31_PIN_RTCK = IOMUX_PIN(0xff, 83), + MX31_PIN_KEY_COL7 = IOMUX_PIN(57, 84), + MX31_PIN_KEY_COL6 = IOMUX_PIN(56, 85), + MX31_PIN_KEY_COL5 = IOMUX_PIN(55, 86), + MX31_PIN_KEY_COL4 = IOMUX_PIN(54, 87), + MX31_PIN_KEY_COL3 = IOMUX_PIN(0xff, 88), + MX31_PIN_KEY_COL2 = IOMUX_PIN(0xff, 89), + MX31_PIN_KEY_COL1 = IOMUX_PIN(0xff, 90), + MX31_PIN_KEY_COL0 = IOMUX_PIN(0xff, 91), + MX31_PIN_KEY_ROW7 = IOMUX_PIN(53, 92), + MX31_PIN_KEY_ROW6 = IOMUX_PIN(52, 93), + MX31_PIN_KEY_ROW5 = IOMUX_PIN(51, 94), + MX31_PIN_KEY_ROW4 = IOMUX_PIN(50, 95), + MX31_PIN_KEY_ROW3 = IOMUX_PIN(0xff, 96), + MX31_PIN_KEY_ROW2 = IOMUX_PIN(0xff, 97), + MX31_PIN_KEY_ROW1 = IOMUX_PIN(0xff, 98), + MX31_PIN_KEY_ROW0 = IOMUX_PIN(0xff, 99), + MX31_PIN_BATT_LINE = IOMUX_PIN(49, 100), + MX31_PIN_CTS2 = IOMUX_PIN(0xff, 101), + MX31_PIN_RTS2 = IOMUX_PIN(0xff, 102), + MX31_PIN_TXD2 = IOMUX_PIN(28, 103), + MX31_PIN_RXD2 = IOMUX_PIN(27, 104), + MX31_PIN_DTR_DCE2 = IOMUX_PIN(48, 105), + MX31_PIN_DCD_DTE1 = IOMUX_PIN(47, 106), + MX31_PIN_RI_DTE1 = IOMUX_PIN(46, 107), + MX31_PIN_DSR_DTE1 = IOMUX_PIN(45, 108), + MX31_PIN_DTR_DTE1 = IOMUX_PIN(44, 109), + MX31_PIN_DCD_DCE1 = IOMUX_PIN(43, 110), + MX31_PIN_RI_DCE1 = IOMUX_PIN(42, 111), + MX31_PIN_DSR_DCE1 = IOMUX_PIN(41, 112), + MX31_PIN_DTR_DCE1 = IOMUX_PIN(40, 113), + MX31_PIN_CTS1 = IOMUX_PIN(39, 114), + MX31_PIN_RTS1 = IOMUX_PIN(38, 115), + MX31_PIN_TXD1 = IOMUX_PIN(37, 116), + MX31_PIN_RXD1 = IOMUX_PIN(36, 117), + MX31_PIN_CSPI2_SPI_RDY = IOMUX_PIN(0xff, 118), + MX31_PIN_CSPI2_SCLK = IOMUX_PIN(0xff, 119), + MX31_PIN_CSPI2_SS2 = IOMUX_PIN(0xff, 120), + MX31_PIN_CSPI2_SS1 = IOMUX_PIN(0xff, 121), + MX31_PIN_CSPI2_SS0 = IOMUX_PIN(0xff, 122), + MX31_PIN_CSPI2_MISO = IOMUX_PIN(0xff, 123), + MX31_PIN_CSPI2_MOSI = IOMUX_PIN(0xff, 124), + MX31_PIN_CSPI1_SPI_RDY = IOMUX_PIN(0xff, 125), + MX31_PIN_CSPI1_SCLK = IOMUX_PIN(0xff, 126), + MX31_PIN_CSPI1_SS2 = IOMUX_PIN(0xff, 127), + MX31_PIN_CSPI1_SS1 = IOMUX_PIN(0xff, 128), + MX31_PIN_CSPI1_SS0 = IOMUX_PIN(0xff, 129), + MX31_PIN_CSPI1_MISO = IOMUX_PIN(0xff, 130), + MX31_PIN_CSPI1_MOSI = IOMUX_PIN(0xff, 131), + MX31_PIN_SFS6 = IOMUX_PIN(26, 132), + MX31_PIN_SCK6 = IOMUX_PIN(25, 133), + MX31_PIN_SRXD6 = IOMUX_PIN(24, 134), + MX31_PIN_STXD6 = IOMUX_PIN(23, 135), + MX31_PIN_SFS5 = IOMUX_PIN(0xff, 136), + MX31_PIN_SCK5 = IOMUX_PIN(0xff, 137), + MX31_PIN_SRXD5 = IOMUX_PIN(22, 138), + MX31_PIN_STXD5 = IOMUX_PIN(21, 139), + MX31_PIN_SFS4 = IOMUX_PIN(0xff, 140), + MX31_PIN_SCK4 = IOMUX_PIN(0xff, 141), + MX31_PIN_SRXD4 = IOMUX_PIN(20, 142), + MX31_PIN_STXD4 = IOMUX_PIN(19, 143), + MX31_PIN_SFS3 = IOMUX_PIN(0xff, 144), + MX31_PIN_SCK3 = IOMUX_PIN(0xff, 145), + MX31_PIN_SRXD3 = IOMUX_PIN(18, 146), + MX31_PIN_STXD3 = IOMUX_PIN(17, 147), + MX31_PIN_I2C_DAT = IOMUX_PIN(0xff, 148), + MX31_PIN_I2C_CLK = IOMUX_PIN(0xff, 149), + MX31_PIN_CSI_PIXCLK = IOMUX_PIN(83, 150), + MX31_PIN_CSI_HSYNC = IOMUX_PIN(82, 151), + MX31_PIN_CSI_VSYNC = IOMUX_PIN(81, 152), + MX31_PIN_CSI_MCLK = IOMUX_PIN(80, 153), + MX31_PIN_CSI_D15 = IOMUX_PIN(79, 154), + MX31_PIN_CSI_D14 = IOMUX_PIN(78, 155), + MX31_PIN_CSI_D13 = IOMUX_PIN(77, 156), + MX31_PIN_CSI_D12 = IOMUX_PIN(76, 157), + MX31_PIN_CSI_D11 = IOMUX_PIN(75, 158), + MX31_PIN_CSI_D10 = IOMUX_PIN(74, 159), + MX31_PIN_CSI_D9 = IOMUX_PIN(73, 160), + MX31_PIN_CSI_D8 = IOMUX_PIN(72, 161), + MX31_PIN_CSI_D7 = IOMUX_PIN(71, 162), + MX31_PIN_CSI_D6 = IOMUX_PIN(70, 163), + MX31_PIN_CSI_D5 = IOMUX_PIN(69, 164), + MX31_PIN_CSI_D4 = IOMUX_PIN(68, 165), + MX31_PIN_M_GRANT = IOMUX_PIN(0xff, 166), + MX31_PIN_M_REQUEST = IOMUX_PIN(0xff, 167), + MX31_PIN_PC_POE = IOMUX_PIN(0xff, 168), + MX31_PIN_PC_RW_B = IOMUX_PIN(0xff, 169), + MX31_PIN_IOIS16 = IOMUX_PIN(0xff, 170), + MX31_PIN_PC_RST = IOMUX_PIN(0xff, 171), + MX31_PIN_PC_BVD2 = IOMUX_PIN(0xff, 172), + MX31_PIN_PC_BVD1 = IOMUX_PIN(0xff, 173), + MX31_PIN_PC_VS2 = IOMUX_PIN(0xff, 174), + MX31_PIN_PC_VS1 = IOMUX_PIN(0xff, 175), + MX31_PIN_PC_PWRON = IOMUX_PIN(0xff, 176), + MX31_PIN_PC_READY = IOMUX_PIN(0xff, 177), + MX31_PIN_PC_WAIT_B = IOMUX_PIN(0xff, 178), + MX31_PIN_PC_CD2_B = IOMUX_PIN(0xff, 179), + MX31_PIN_PC_CD1_B = IOMUX_PIN(0xff, 180), + MX31_PIN_D0 = IOMUX_PIN(0xff, 181), + MX31_PIN_D1 = IOMUX_PIN(0xff, 182), + MX31_PIN_D2 = IOMUX_PIN(0xff, 183), + MX31_PIN_D3 = IOMUX_PIN(0xff, 184), + MX31_PIN_D4 = IOMUX_PIN(0xff, 185), + MX31_PIN_D5 = IOMUX_PIN(0xff, 186), + MX31_PIN_D6 = IOMUX_PIN(0xff, 187), + MX31_PIN_D7 = IOMUX_PIN(0xff, 188), + MX31_PIN_D8 = IOMUX_PIN(0xff, 189), + MX31_PIN_D9 = IOMUX_PIN(0xff, 190), + MX31_PIN_D10 = IOMUX_PIN(0xff, 191), + MX31_PIN_D11 = IOMUX_PIN(0xff, 192), + MX31_PIN_D12 = IOMUX_PIN(0xff, 193), + MX31_PIN_D13 = IOMUX_PIN(0xff, 194), + MX31_PIN_D14 = IOMUX_PIN(0xff, 195), + MX31_PIN_D15 = IOMUX_PIN(0xff, 196), + MX31_PIN_NFRB = IOMUX_PIN(16, 197), + MX31_PIN_NFCE_B = IOMUX_PIN(15, 198), + MX31_PIN_NFWP_B = IOMUX_PIN(14, 199), + MX31_PIN_NFCLE = IOMUX_PIN(13, 200), + MX31_PIN_NFALE = IOMUX_PIN(12, 201), + MX31_PIN_NFRE_B = IOMUX_PIN(11, 202), + MX31_PIN_NFWE_B = IOMUX_PIN(10, 203), + MX31_PIN_SDQS3 = IOMUX_PIN(0xff, 204), + MX31_PIN_SDQS2 = IOMUX_PIN(0xff, 205), + MX31_PIN_SDQS1 = IOMUX_PIN(0xff, 206), + MX31_PIN_SDQS0 = IOMUX_PIN(0xff, 207), + MX31_PIN_SDCLK_B = IOMUX_PIN(0xff, 208), + MX31_PIN_SDCLK = IOMUX_PIN(0xff, 209), + MX31_PIN_SDCKE1 = IOMUX_PIN(0xff, 210), + MX31_PIN_SDCKE0 = IOMUX_PIN(0xff, 211), + MX31_PIN_SDWE = IOMUX_PIN(0xff, 212), + MX31_PIN_CAS = IOMUX_PIN(0xff, 213), + MX31_PIN_RAS = IOMUX_PIN(0xff, 214), + MX31_PIN_RW = IOMUX_PIN(0xff, 215), + MX31_PIN_BCLK = IOMUX_PIN(0xff, 216), + MX31_PIN_LBA = IOMUX_PIN(0xff, 217), + MX31_PIN_ECB = IOMUX_PIN(0xff, 218), + MX31_PIN_CS5 = IOMUX_PIN(0xff, 219), + MX31_PIN_CS4 = IOMUX_PIN(0xff, 220), + MX31_PIN_CS3 = IOMUX_PIN(0xff, 221), + MX31_PIN_CS2 = IOMUX_PIN(0xff, 222), + MX31_PIN_CS1 = IOMUX_PIN(0xff, 223), + MX31_PIN_CS0 = IOMUX_PIN(0xff, 224), + MX31_PIN_OE = IOMUX_PIN(0xff, 225), + MX31_PIN_EB1 = IOMUX_PIN(0xff, 226), + MX31_PIN_EB0 = IOMUX_PIN(0xff, 227), + MX31_PIN_DQM3 = IOMUX_PIN(0xff, 228), + MX31_PIN_DQM2 = IOMUX_PIN(0xff, 229), + MX31_PIN_DQM1 = IOMUX_PIN(0xff, 230), + MX31_PIN_DQM0 = IOMUX_PIN(0xff, 231), + MX31_PIN_SD31 = IOMUX_PIN(0xff, 232), + MX31_PIN_SD30 = IOMUX_PIN(0xff, 233), + MX31_PIN_SD29 = IOMUX_PIN(0xff, 234), + MX31_PIN_SD28 = IOMUX_PIN(0xff, 235), + MX31_PIN_SD27 = IOMUX_PIN(0xff, 236), + MX31_PIN_SD26 = IOMUX_PIN(0xff, 237), + MX31_PIN_SD25 = IOMUX_PIN(0xff, 238), + MX31_PIN_SD24 = IOMUX_PIN(0xff, 239), + MX31_PIN_SD23 = IOMUX_PIN(0xff, 240), + MX31_PIN_SD22 = IOMUX_PIN(0xff, 241), + MX31_PIN_SD21 = IOMUX_PIN(0xff, 242), + MX31_PIN_SD20 = IOMUX_PIN(0xff, 243), + MX31_PIN_SD19 = IOMUX_PIN(0xff, 244), + MX31_PIN_SD18 = IOMUX_PIN(0xff, 245), + MX31_PIN_SD17 = IOMUX_PIN(0xff, 246), + MX31_PIN_SD16 = IOMUX_PIN(0xff, 247), + MX31_PIN_SD15 = IOMUX_PIN(0xff, 248), + MX31_PIN_SD14 = IOMUX_PIN(0xff, 249), + MX31_PIN_SD13 = IOMUX_PIN(0xff, 250), + MX31_PIN_SD12 = IOMUX_PIN(0xff, 251), + MX31_PIN_SD11 = IOMUX_PIN(0xff, 252), + MX31_PIN_SD10 = IOMUX_PIN(0xff, 253), + MX31_PIN_SD9 = IOMUX_PIN(0xff, 254), + MX31_PIN_SD8 = IOMUX_PIN(0xff, 255), + MX31_PIN_SD7 = IOMUX_PIN(0xff, 256), + MX31_PIN_SD6 = IOMUX_PIN(0xff, 257), + MX31_PIN_SD5 = IOMUX_PIN(0xff, 258), + MX31_PIN_SD4 = IOMUX_PIN(0xff, 259), + MX31_PIN_SD3 = IOMUX_PIN(0xff, 260), + MX31_PIN_SD2 = IOMUX_PIN(0xff, 261), + MX31_PIN_SD1 = IOMUX_PIN(0xff, 262), + MX31_PIN_SD0 = IOMUX_PIN(0xff, 263), + MX31_PIN_SDBA0 = IOMUX_PIN(0xff, 264), + MX31_PIN_SDBA1 = IOMUX_PIN(0xff, 265), + MX31_PIN_A25 = IOMUX_PIN(0xff, 266), + MX31_PIN_A24 = IOMUX_PIN(0xff, 267), + MX31_PIN_A23 = IOMUX_PIN(0xff, 268), + MX31_PIN_A22 = IOMUX_PIN(0xff, 269), + MX31_PIN_A21 = IOMUX_PIN(0xff, 270), + MX31_PIN_A20 = IOMUX_PIN(0xff, 271), + MX31_PIN_A19 = IOMUX_PIN(0xff, 272), + MX31_PIN_A18 = IOMUX_PIN(0xff, 273), + MX31_PIN_A17 = IOMUX_PIN(0xff, 274), + MX31_PIN_A16 = IOMUX_PIN(0xff, 275), + MX31_PIN_A14 = IOMUX_PIN(0xff, 276), + MX31_PIN_A15 = IOMUX_PIN(0xff, 277), + MX31_PIN_A13 = IOMUX_PIN(0xff, 278), + MX31_PIN_A12 = IOMUX_PIN(0xff, 279), + MX31_PIN_A11 = IOMUX_PIN(0xff, 280), + MX31_PIN_MA10 = IOMUX_PIN(0xff, 281), + MX31_PIN_A10 = IOMUX_PIN(0xff, 282), + MX31_PIN_A9 = IOMUX_PIN(0xff, 283), + MX31_PIN_A8 = IOMUX_PIN(0xff, 284), + MX31_PIN_A7 = IOMUX_PIN(0xff, 285), + MX31_PIN_A6 = IOMUX_PIN(0xff, 286), + MX31_PIN_A5 = IOMUX_PIN(0xff, 287), + MX31_PIN_A4 = IOMUX_PIN(0xff, 288), + MX31_PIN_A3 = IOMUX_PIN(0xff, 289), + MX31_PIN_A2 = IOMUX_PIN(0xff, 290), + MX31_PIN_A1 = IOMUX_PIN(0xff, 291), + MX31_PIN_A0 = IOMUX_PIN(0xff, 292), + MX31_PIN_VPG1 = IOMUX_PIN(0xff, 293), + MX31_PIN_VPG0 = IOMUX_PIN(0xff, 294), + MX31_PIN_DVFS1 = IOMUX_PIN(0xff, 295), + MX31_PIN_DVFS0 = IOMUX_PIN(0xff, 296), + MX31_PIN_VSTBY = IOMUX_PIN(0xff, 297), + MX31_PIN_POWER_FAIL = IOMUX_PIN(0xff, 298), + MX31_PIN_CKIL = IOMUX_PIN(0xff, 299), + MX31_PIN_BOOT_MODE4 = IOMUX_PIN(0xff, 300), + MX31_PIN_BOOT_MODE3 = IOMUX_PIN(0xff, 301), + MX31_PIN_BOOT_MODE2 = IOMUX_PIN(0xff, 302), + MX31_PIN_BOOT_MODE1 = IOMUX_PIN(0xff, 303), + MX31_PIN_BOOT_MODE0 = IOMUX_PIN(0xff, 304), + MX31_PIN_CLKO = IOMUX_PIN(0xff, 305), + MX31_PIN_POR_B = IOMUX_PIN(0xff, 306), + MX31_PIN_RESET_IN_B = IOMUX_PIN(0xff, 307), + MX31_PIN_CKIH = IOMUX_PIN(0xff, 308), + MX31_PIN_SIMPD0 = IOMUX_PIN(35, 309), + MX31_PIN_SRX0 = IOMUX_PIN(34, 310), + MX31_PIN_STX0 = IOMUX_PIN(33, 311), + MX31_PIN_SVEN0 = IOMUX_PIN(32, 312), + MX31_PIN_SRST0 = IOMUX_PIN(67, 313), + MX31_PIN_SCLK0 = IOMUX_PIN(66, 314), + MX31_PIN_GPIO3_1 = IOMUX_PIN(65, 315), + MX31_PIN_GPIO3_0 = IOMUX_PIN(64, 316), + MX31_PIN_GPIO1_6 = IOMUX_PIN(6, 317), + MX31_PIN_GPIO1_5 = IOMUX_PIN(5, 318), + MX31_PIN_GPIO1_4 = IOMUX_PIN(4, 319), + MX31_PIN_GPIO1_3 = IOMUX_PIN(3, 320), + MX31_PIN_GPIO1_2 = IOMUX_PIN(2, 321), + MX31_PIN_GPIO1_1 = IOMUX_PIN(1, 322), + MX31_PIN_GPIO1_0 = IOMUX_PIN(0, 323), + MX31_PIN_PWMO = IOMUX_PIN(9, 324), + MX31_PIN_WATCHDOG_RST = IOMUX_PIN(0xff, 325), + MX31_PIN_COMPARE = IOMUX_PIN(8, 326), + MX31_PIN_CAPTURE = IOMUX_PIN(7, 327), +};
/* Bit definitions for RCSR register in CCM */ #define CCM_RCSR_NF16B (1 << 31) @@ -194,6 +558,12 @@ struct gpio_regs {
/* Register offsets based on IOMUXC_BASE */ /* 0x00 .. 0x7b */ +#define MUX_CTL_USBH2_DATA1 0x40 +#define MUX_CTL_USBH2_DIR 0x44 +#define MUX_CTL_USBH2_STP 0x45 +#define MUX_CTL_USBH2_NXT 0x46 +#define MUX_CTL_USBH2_DATA0 0x47 +#define MUX_CTL_USBH2_CLK 0x4B #define MUX_CTL_RTS1 0x7c #define MUX_CTL_CTS1 0x7d #define MUX_CTL_DTR_DCE1 0x7e @@ -219,6 +589,11 @@ struct gpio_regs { #define MUX_CTL_SCK6 0x92 #define MUX_CTL_SFS6 0x93
+#define MUX_CTL_STXD3 0x9C +#define MUX_CTL_SRXD3 0x9D +#define MUX_CTL_SCK3 0x9E +#define MUX_CTL_SFS3 0x9F + #define MUX_CTL_NFC_WP 0xD0 #define MUX_CTL_NFC_CE 0xD1 #define MUX_CTL_NFC_RB 0xD2 @@ -324,4 +699,33 @@ struct gpio_regs { #define IRAM_BASE_ADDR 0x1FFFC000 #define IRAM_SIZE (16 * 1024)
+#define MX31_AIPS1_BASE_ADDR 0x43f00000 +#define MX31_OTG_BASE_ADDR (MX31_AIPS1_BASE_ADDR + 0x88000) + +/* USB portsc */ +/* values for portsc field */ +#define MXC_EHCI_PHY_LOW_POWER_SUSPEND (1 << 23) +#define MXC_EHCI_FORCE_FS (1 << 24) +#define MXC_EHCI_UTMI_8BIT (0 << 28) +#define MXC_EHCI_UTMI_16BIT (1 << 28) +#define MXC_EHCI_SERIAL (1 << 29) +#define MXC_EHCI_MODE_UTMI (0 << 30) +#define MXC_EHCI_MODE_PHILIPS (1 << 30) +#define MXC_EHCI_MODE_ULPI (2 << 30) +#define MXC_EHCI_MODE_SERIAL (3 << 30) + +/* values for flags field */ +#define MXC_EHCI_INTERFACE_DIFF_UNI (0 << 0) +#define MXC_EHCI_INTERFACE_DIFF_BI (1 << 0) +#define MXC_EHCI_INTERFACE_SINGLE_UNI (2 << 0) +#define MXC_EHCI_INTERFACE_SINGLE_BI (3 << 0) +#define MXC_EHCI_INTERFACE_MASK (0xf) + +#define MXC_EHCI_POWER_PINS_ENABLED (1 << 5) +#define MXC_EHCI_TTL_ENABLED (1 << 6) + +#define MXC_EHCI_INTERNAL_PHY (1 << 7) +#define MXC_EHCI_IPPUE_DOWN (1 << 8) +#define MXC_EHCI_IPPUE_UP (1 << 9) + #endif /* __ASM_ARCH_MX31_REGS_H */ diff --git a/drivers/video/mx3fb.c b/drivers/video/mx3fb.c index 7f04b49..51831f0 100644 --- a/drivers/video/mx3fb.c +++ b/drivers/video/mx3fb.c @@ -334,37 +334,6 @@ enum ipu_panel {
#define IOMUX_MODE_L(pin, mode) IOMUX_MODE(((pin) + 0xc) ^ 3, mode)
-enum lcd_pin { - MX31_PIN_D3_SPL = IOMUX_PIN(0xff, 19), - MX31_PIN_D3_CLS = IOMUX_PIN(0xff, 20), - MX31_PIN_D3_REV = IOMUX_PIN(0xff, 21), - MX31_PIN_CONTRAST = IOMUX_PIN(0xff, 22), - MX31_PIN_VSYNC3 = IOMUX_PIN(0xff, 23), - - MX31_PIN_DRDY0 = IOMUX_PIN(0xff, 33), - MX31_PIN_FPSHIFT = IOMUX_PIN(0xff, 34), - MX31_PIN_HSYNC = IOMUX_PIN(0xff, 35), - - MX31_PIN_LD17 = IOMUX_PIN(0xff, 37), - MX31_PIN_LD16 = IOMUX_PIN(0xff, 38), - MX31_PIN_LD15 = IOMUX_PIN(0xff, 39), - MX31_PIN_LD14 = IOMUX_PIN(0xff, 40), - MX31_PIN_LD13 = IOMUX_PIN(0xff, 41), - MX31_PIN_LD12 = IOMUX_PIN(0xff, 42), - MX31_PIN_LD11 = IOMUX_PIN(0xff, 43), - MX31_PIN_LD10 = IOMUX_PIN(0xff, 44), - MX31_PIN_LD9 = IOMUX_PIN(0xff, 45), - MX31_PIN_LD8 = IOMUX_PIN(0xff, 46), - MX31_PIN_LD7 = IOMUX_PIN(0xff, 47), - MX31_PIN_LD6 = IOMUX_PIN(0xff, 48), - MX31_PIN_LD5 = IOMUX_PIN(0xff, 49), - MX31_PIN_LD4 = IOMUX_PIN(0xff, 50), - MX31_PIN_LD3 = IOMUX_PIN(0xff, 51), - MX31_PIN_LD2 = IOMUX_PIN(0xff, 52), - MX31_PIN_LD1 = IOMUX_PIN(0xff, 53), - MX31_PIN_LD0 = IOMUX_PIN(0xff, 54), -}; - struct chan_param_mem_planar { /* Word 0 */ u32 xv:10;
The patch adds the EHCI controller for the i.MX31 Soc.
Signed-off-by: Stefano Babic sbabic@denx.de --- drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-mxc.c | 130 +++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 131 insertions(+), 0 deletions(-) create mode 100644 drivers/usb/host/ehci-mxc.c
diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 255679a..399520e 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -36,6 +36,7 @@ COBJS-$(CONFIG_USB_SL811HS) += sl811-hcd.o # echi COBJS-$(CONFIG_USB_EHCI) += ehci-hcd.o COBJS-$(CONFIG_USB_EHCI_FSL) += ehci-fsl.o +COBJS-$(CONFIG_USB_EHCI_MXC) += ehci-mxc.o COBJS-$(CONFIG_USB_EHCI_PPC4XX) += ehci-ppc4xx.o COBJS-$(CONFIG_USB_EHCI_IXP4XX) += ehci-ixp.o COBJS-$(CONFIG_USB_EHCI_KIRKWOOD) += ehci-kirkwood.o diff --git a/drivers/usb/host/ehci-mxc.c b/drivers/usb/host/ehci-mxc.c new file mode 100644 index 0000000..af8ee90 --- /dev/null +++ b/drivers/usb/host/ehci-mxc.c @@ -0,0 +1,130 @@ +/* + * Copyright (c) 2009 Daniel Mack daniel@caiaq.de + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY + * or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License + * for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software Foundation, + * Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + + +#include <common.h> +#include <usb.h> +#include <asm/io.h> +#include <asm/arch/mx31-regs.h> +#include <usb/ehci-fsl.h> +#include <errno.h> + +#include "ehci.h" +#include "ehci-core.h" + +#define USBCTRL_OTGBASE_OFFSET 0x600 + +#define MX31_OTG_SIC_SHIFT 29 +#define MX31_OTG_SIC_MASK (0x3 << MX31_OTG_SIC_SHIFT) +#define MX31_OTG_PM_BIT (1 << 24) + +#define MX31_H2_SIC_SHIFT 21 +#define MX31_H2_SIC_MASK (0x3 << MX31_H2_SIC_SHIFT) +#define MX31_H2_PM_BIT (1 << 16) +#define MX31_H2_DT_BIT (1 << 5) + +#define MX31_H1_SIC_SHIFT 13 +#define MX31_H1_SIC_MASK (0x3 << MX31_H1_SIC_SHIFT) +#define MX31_H1_PM_BIT (1 << 8) +#define MX31_H1_DT_BIT (1 << 4) + +static int mxc_set_usbcontrol(int port, unsigned int flags) +{ + unsigned int v; +#ifdef CONFIG_MX31 + v = readl(MX31_OTG_BASE_ADDR + USBCTRL_OTGBASE_OFFSET); + + switch (port) { + case 0: /* OTG port */ + v &= ~(MX31_OTG_SIC_MASK | MX31_OTG_PM_BIT); + v |= (flags & MXC_EHCI_INTERFACE_MASK) + << MX31_OTG_SIC_SHIFT; + if (!(flags & MXC_EHCI_POWER_PINS_ENABLED)) + v |= MX31_OTG_PM_BIT; + + break; + case 1: /* H1 port */ + v &= ~(MX31_H1_SIC_MASK | MX31_H1_PM_BIT | + MX31_H1_DT_BIT); + v |= (flags & MXC_EHCI_INTERFACE_MASK) + << MX31_H1_SIC_SHIFT; + if (!(flags & MXC_EHCI_POWER_PINS_ENABLED)) + v |= MX31_H1_PM_BIT; + + if (!(flags & MXC_EHCI_TTL_ENABLED)) + v |= MX31_H1_DT_BIT; + + break; + case 2: /* H2 port */ + v &= ~(MX31_H2_SIC_MASK | MX31_H2_PM_BIT | + MX31_H2_DT_BIT); + v |= (flags & MXC_EHCI_INTERFACE_MASK) + << MX31_H2_SIC_SHIFT; + if (!(flags & MXC_EHCI_POWER_PINS_ENABLED)) + v |= MX31_H2_PM_BIT; + + if (!(flags & MXC_EHCI_TTL_ENABLED)) + v |= MX31_H2_DT_BIT; + + break; + default: + return -EINVAL; + } + + writel(v, MX31_OTG_BASE_ADDR + + USBCTRL_OTGBASE_OFFSET); +#endif + return 0; +} + +int ehci_hcd_init(void) +{ + u32 tmp; + struct usb_ehci *ehci; + struct clock_control_regs *sc_regs = + (struct clock_control_regs *)CCM_BASE; + + tmp = __raw_readl(&sc_regs->ccmr); + __raw_writel(__raw_readl(&sc_regs->ccmr) | (1 << 9), &sc_regs->ccmr) ; + + udelay(80); + + /* Take USB2 */ + ehci = (struct usb_ehci *)(MX31_OTG_BASE_ADDR + + (0x200 * CONFIG_MXC_USB_PORT)); + hccr = (struct ehci_hccr *)((uint32_t)&ehci->caplength); + hcor = (struct ehci_hcor *)((uint32_t) hccr + + HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + setbits_le32(&ehci->usbmode, CM_HOST); + setbits_le32(&ehci->control, USB_EN); + + __raw_writel(CONFIG_MXC_USB_PORTSC, &ehci->portsc); + + mxc_set_usbcontrol(CONFIG_MXC_USB_PORT, CONFIG_MXC_USB_FLAGS); + + return 0; +} + +/* + * Destroy the appropriate control structures corresponding + * the the EHCI host controller. + */ +int ehci_hcd_stop(void) +{ + return 0; +}
Signed-off-by: Stefano Babic sbabic@denx.de --- board/davedenx/qong/qong.c | 33 +++++++++++++++++++++++++++++++++ include/configs/qong.h | 18 +++++++++++++++++- 2 files changed, 50 insertions(+), 1 deletions(-)
diff --git a/board/davedenx/qong/qong.c b/board/davedenx/qong/qong.c index efeb0bb..8a81cfc 100644 --- a/board/davedenx/qong/qong.c +++ b/board/davedenx/qong/qong.c @@ -25,6 +25,7 @@ #include <netdev.h> #include <asm/arch/mx31.h> #include <asm/arch/mx31-regs.h> +#include <asm/io.h> #include <nand.h> #include <fsl_pmic.h> #include <mxc_gpio.h> @@ -97,6 +98,38 @@ int board_early_init_f (void) mx31_gpio_mux(MUX_CSPI2_SCLK__CSPI2_CLK); mx31_gpio_mux(MUX_CSPI2_SPI_RDY__CSPI2_DATAREADY_B);
+ /* Setup pins for USB2 Host */ + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_USBH2_CLK, MUX_CTL_FUNC)); + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_USBH2_DIR, MUX_CTL_FUNC)); + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_USBH2_NXT, MUX_CTL_FUNC)); + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_USBH2_STP, MUX_CTL_FUNC)); + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_USBH2_DATA0, MUX_CTL_FUNC)); + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_USBH2_DATA1, MUX_CTL_FUNC)); + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_STXD3, MUX_CTL_FUNC)); + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_SRXD3, MUX_CTL_FUNC)); + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_SCK3, MUX_CTL_FUNC)); + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_SFS3, MUX_CTL_FUNC)); + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_STXD6, MUX_CTL_FUNC)); + mx31_gpio_mux(IOMUX_MODE(MUX_CTL_SRXD6, MUX_CTL_FUNC)); + +#define H2_PAD_CFG (PAD_CTL_DRV_MAX | PAD_CTL_SRE_FAST | PAD_CTL_HYS_CMOS | \ + PAD_CTL_ODE_CMOS | PAD_CTL_100K_PU) + + mx31_set_pad(MX31_PIN_USBH2_CLK, H2_PAD_CFG); + mx31_set_pad(MX31_PIN_USBH2_DIR, H2_PAD_CFG); + mx31_set_pad(MX31_PIN_USBH2_NXT, H2_PAD_CFG); + mx31_set_pad(MX31_PIN_USBH2_STP, H2_PAD_CFG); + mx31_set_pad(MX31_PIN_USBH2_DATA0, H2_PAD_CFG); /* USBH2_DATA0 */ + mx31_set_pad(MX31_PIN_USBH2_DATA1, H2_PAD_CFG); /* USBH2_DATA1 */ + mx31_set_pad(MX31_PIN_SRXD6, H2_PAD_CFG); /* USBH2_DATA2 */ + mx31_set_pad(MX31_PIN_STXD6, H2_PAD_CFG); /* USBH2_DATA3 */ + mx31_set_pad(MX31_PIN_SFS3, H2_PAD_CFG); /* USBH2_DATA4 */ + mx31_set_pad(MX31_PIN_SCK3, H2_PAD_CFG); /* USBH2_DATA5 */ + mx31_set_pad(MX31_PIN_SRXD3, H2_PAD_CFG); /* USBH2_DATA6 */ + mx31_set_pad(MX31_PIN_STXD3, H2_PAD_CFG); /* USBH2_DATA7 */ + + writel(readl((IOMUXC_BASE + 0x8)) | (1 << 11), IOMUXC_BASE + 0x8); + return 0;
} diff --git a/include/configs/qong.h b/include/configs/qong.h index 2d124ea..fef8094 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -89,6 +89,22 @@ #define CONFIG_BMP_16BPP #define CONFIG_DISPLAY_COM57H5M10XRC
+/* USB */ +#define CONFIG_CMD_USB +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_EHCI /* Enable EHCI USB support */ +#define CONFIG_USB_EHCI_MXC +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_MXC_USB_PORT 2 +#define CONFIG_MXC_USB_PORTSC (MXC_EHCI_MODE_ULPI | MXC_EHCI_UTMI_8BIT) +#define CONFIG_MXC_USB_FLAGS MXC_EHCI_POWER_PINS_ENABLED +#define CONFIG_EHCI_IS_TDI +#define CONFIG_USB_STORAGE +#define CONFIG_DOS_PARTITION +#define CONFIG_SUPPORT_VFAT +#define CONFIG_CMD_FAT +#endif /* CONFIG_CMD_USB */ + /* * Reducing the ARP timeout from default 5 seconds to 200ms we speed up the * initial TFTP transfer, should the user wish one, significantly. @@ -250,7 +266,7 @@ extern int qong_nand_rdy(void *chip); #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x60000) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x80000)
/* Address and size of Redundant Environment Sector */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
Dear Remy,
even though USB related, this looks like a board specific patch to me. Is it OK with you that Stefano pulls this through the iMX repository?
2010/10/11 Wolfgang Denk wd@denx.de:
Dear Remy,
OK with me.
Remy
OK with me.
Hi Remy,
thanks - I will merge in u-boot-imx and sent the pull request to Wolfgang
Stefano
Remy Bohmer
Stefano Babic
