[PATCH] RFC: x86: serial: ns16550: Allow the UART to be silently disabled
U-Boot normally requires a UART. When booting from coreboot it is sometimes just not available, e.g. when no sysinfo or DBG2 information is provided.
In this case we need to continue running, since the display can be used. Add a flag to disable serial for this case.
This allows U-Boot to start up and operation from the display, instead of hanging on start-up.
This could perhaps be hidden behind a Kconfig option to reduce code size.
drivers/serial/ns16550.c | 17 +++++++++++++++-- drivers/serial/serial_coreboot.c | 1 + include/ns16550.h | 1 + 3 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index eab9537fbae..6bb84f8c5bc 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -384,6 +384,8 @@ static int ns16550_serial_putc(struct udevice *dev, const char ch) { struct ns16550 *const com_port = dev_get_priv(dev);
+ if (com_port->plat->flags & NS16550_FLAG_DISABLE) + return 0; if (!(serial_in(&com_port->lsr) & UART_LSR_THRE)) return -EAGAIN; serial_out(ch, &com_port->thr); @@ -404,6 +406,9 @@ static int ns16550_serial_pending(struct udevice *dev, bool input) { struct ns16550 *const com_port = dev_get_priv(dev);
+ if (com_port->plat->flags & NS16550_FLAG_DISABLE) + return 0; + if (input) return (serial_in(&com_port->lsr) & UART_LSR_DR) ? 1 : 0; else @@ -414,6 +419,9 @@ static int ns16550_serial_getc(struct udevice *dev) { struct ns16550 *const com_port = dev_get_priv(dev);
+ if (com_port->plat->flags & NS16550_FLAG_DISABLE) + return 0; + if (!(serial_in(&com_port->lsr) & UART_LSR_DR)) return -EAGAIN;
@@ -428,7 +436,8 @@ static int ns16550_serial_setbrg(struct udevice *dev, int baudrate)
clock_divisor = ns16550_calc_divisor(com_port, plat->clock, baudrate);
- ns16550_setbrg(com_port, clock_divisor); + if (!(plat->flags & NS16550_FLAG_DISABLE)) + ns16550_setbrg(com_port, clock_divisor);
return 0; } @@ -441,6 +450,9 @@ static int ns16550_serial_setconfig(struct udevice *dev, uint serial_config) uint bits = SERIAL_GET_BITS(serial_config); uint stop = SERIAL_GET_STOP(serial_config);
+ if (com_port->plat->flags & NS16550_FLAG_DISABLE) + return 0; + /* * only parity config is implemented, check if other serial settings * are the default one. @@ -525,7 +537,8 @@ int ns16550_serial_probe(struct udevice *dev) reset_deassert_bulk(&reset_bulk);
com_port->plat = dev_get_plat(dev); - ns16550_init(com_port, -1); + if (!(plat->flags & NS16550_FLAG_DISABLE)) + ns16550_init(com_port, -1);
return 0; } diff --git a/drivers/serial/serial_coreboot.c b/drivers/serial/serial_coreboot.c index 23066e4d054..cdf9afc1739 100644 --- a/drivers/serial/serial_coreboot.c +++ b/drivers/serial/serial_coreboot.c @@ -120,6 +120,7 @@ static int coreboot_of_to_plat(struct udevice *dev) * there is no UART, which may panic. So stay silent and * pray that the video console will work. */ + plat->flags |= NS16550_FLAG_DISABLE; log_debug("Cannot detect UART\n"); }
diff --git a/include/ns16550.h b/include/ns16550.h index e7e68663d03..618bb4026b3 100644 --- a/include/ns16550.h +++ b/include/ns16550.h @@ -52,6 +52,7 @@ enum ns16550_flags { NS16550_FLAG_IO = 1 << 0, /* Use I/O access (else mem-mapped) */ NS16550_FLAG_ENDIAN = 1 << 1, /* Use out_le/be_32() */ NS16550_FLAG_BE = 1 << 2, /* Big-endian access (else little) */ + NS16550_FLAG_DISABLE = BIT(3), /* No output or input */ };
