[U-Boot] [PATCH 1/4] EHCI: fix root hub device descriptor
On little endian machines, EHCI root hub's USB revision is reported as 0.2 -- cpu_to_le16() was missed in the initializer for the 'bcdUSB' descriptor field. The same should be done for the 'bcdDevice' field.
Signed-off-by: Sergei Shtylyov sshtylyov@mvista.com
--- drivers/usb/host/ehci-hcd.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
Index: u-boot/drivers/usb/host/ehci-hcd.c =================================================================== --- u-boot.orig/drivers/usb/host/ehci-hcd.c +++ u-boot/drivers/usb/host/ehci-hcd.c @@ -55,14 +55,14 @@ static struct descriptor { { 0x12, /* bLength */ 1, /* bDescriptorType: UDESC_DEVICE */ - 0x0002, /* bcdUSB: v2.0 */ + cpu_to_le16(0x0200), /* bcdUSB: v2.0 */ 9, /* bDeviceClass: UDCLASS_HUB */ 0, /* bDeviceSubClass: UDSUBCLASS_HUB */ 1, /* bDeviceProtocol: UDPROTO_HSHUBSTT */ 64, /* bMaxPacketSize: 64 bytes */ 0x0000, /* idVendor */ 0x0000, /* idProduct */ - 0x0001, /* bcdDevice */ + cpu_to_le16(0x0100), /* bcdDevice */ 1, /* iManufacturer */ 2, /* iProduct */ 0, /* iSerialNumber */
2010/2/27 Sergei Shtylyov sshtylyov@ru.mvista.com:
Applied to u-boot-usb Thanks!
Remy
- cpu_to_le16(0x0200), /* bcdUSB: v2.0 */
- cpu_to_le16(0x0100), /* bcdDevice */
1, /* iManufacturer */ 2, /* iProduct */ 0, /* iSerialNumber */ _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Remy Bohmer
Sergei Shtylyov
