[U-Boot] [PATCH] fsl_i2c: Add write-then-read transaction interface for I2C slave
Most of the I2C slaves support accesses in the typical style viz.read/write series of bytes at particular address offset. These transactions are currently supportd in the i2c driver using i2c_read and i2c_write APIs. I2C EEPROMs, RTC, etc fall in this category. The transactions look like:" START:Address:Tx:Offset:RESTART:Address[0..4]:Tx/Rx:data[0..n]:STOP"
However there are certain devices which support accesses in terms of the transactions as follows: "START:Address:Tx:Txdata[0..n1]:Clock_stretching: RESTART:Address:Rx:data[0..n2]"
The Txdata is typically a command and some associated data, similarly Rxdata could be command status plus some data received as a response to the command sent. i2c_write_read() function provides support for such transactions (multiple bytes write followed by read)
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Shaveta Leekha shaveta@freescale.com --- drivers/i2c/fsl_i2c.c | 64 ++++++++++++++++++++++++++++++++++++++++++----- drivers/i2c/i2c_core.c | 7 +++++ include/i2c.h | 19 ++++++++++--- 3 files changed, 78 insertions(+), 12 deletions(-)
diff --git a/drivers/i2c/fsl_i2c.c b/drivers/i2c/fsl_i2c.c index 291ad94..838c1b1 100644 --- a/drivers/i2c/fsl_i2c.c +++ b/drivers/i2c/fsl_i2c.c @@ -472,6 +472,56 @@ fsl_i2c_write(struct i2c_adapter *adap, u8 dev, uint addr, int alen,
return -1; } +/* To perform any generic transaction on a I2C slave which involves + + START: Address: Write bytes(cmd + data): clock extension: + RESTART: Address: Read bytes (data + status): STOP + + This is different from standard I2C devices which are supported + in existing i2c_read and i2c_write functions. + */ +int +fsl_i2c_write_read(struct i2c_adapter *adap, u8 dev, u8 *wdata, int wlength, + u8 *rdata, int rlength) +{ + struct fsl_i2c *device = (struct fsl_i2c *)i2c_dev[adap->hwadapnr]; + + int i = -1; /* signal error */ + + if (i2c_wait4bus(adap)) + return -1; + +/* Generate a START and send the Address and the Tx Bytes to the slave. + * "START: Address: Write bytes wdata[wlength]" + */ + if (i2c_write_addr(adap, dev, I2C_WRITE_BIT, 0) != 0) + i = __i2c_write(adap, wdata, wlength); + + if (i != wlength) + return -1; + +/* Now issue a READ by generating a RESTART condition + * "RESTART: Address: Read bytes rdata[rlength]" + * Some slaves may also do clock stretching and keep the SCL low until + * they finish some command processing at their end. The I2C controller + * will wait for the clock stretching period to get over before generating + * the RESTART condition on the bus. + */ + if (rlength + && i2c_write_addr(adap, dev, I2C_READ_BIT, 1) != 0) + i = __i2c_read(adap, rdata, rlength); + +/* Generate STOP */ + writeb(I2C_CR_MEN, &device->cr); + + if (i2c_wait4bus(adap)) /* Wait until STOP */ + debug("i2c_write_read: wait4bus timed out\n"); + + if (i != rlength) + return -1; + + return 0; +}
static int fsl_i2c_probe(struct i2c_adapter *adap, uchar chip) @@ -503,12 +553,12 @@ static unsigned int fsl_i2c_set_bus_speed(struct i2c_adapter *adap, * Register fsl i2c adapters */ U_BOOT_I2C_ADAP_COMPLETE(fsl_0, fsl_i2c_init, fsl_i2c_probe, fsl_i2c_read, - fsl_i2c_write, fsl_i2c_set_bus_speed, - CONFIG_SYS_FSL_I2C_SPEED, CONFIG_SYS_FSL_I2C_SLAVE, - 0) -#ifdef CONFIG_SYS_FSL_I2C2_OFFSET + fsl_i2c_write, fsl_i2c_write_read, + fsl_i2c_set_bus_speed, CONFIG_SYS_FSL_I2C_SPEED, + CONFIG_SYS_FSL_I2C_SLAVE, 0); +#ifdef CONFIG_SYS_I2C2_OFFSET U_BOOT_I2C_ADAP_COMPLETE(fsl_1, fsl_i2c_init, fsl_i2c_probe, fsl_i2c_read, - fsl_i2c_write, fsl_i2c_set_bus_speed, - CONFIG_SYS_FSL_I2C2_SPEED, CONFIG_SYS_FSL_I2C2_SLAVE, - 1) + fsl_i2c_write, fsl_i2c_write_read, + fsl_i2c_set_bus_speed, CONFIG_SYS_FSL_I2C2_SPEED, + CONFIG_SYS_FSL_I2C2_SLAVE, 1); #endif diff --git a/drivers/i2c/i2c_core.c b/drivers/i2c/i2c_core.c index 18d6736..6647856 100644 --- a/drivers/i2c/i2c_core.c +++ b/drivers/i2c/i2c_core.c @@ -341,6 +341,13 @@ int i2c_write(uint8_t chip, unsigned int addr, int alen, return I2C_ADAP->write(I2C_ADAP, chip, addr, alen, buffer, len); }
+int i2c_write_read(uchar chip, uint8_t *wbuffer, int wlen, uint8_t *rbuffer, + int rlen) +{ + return I2C_ADAP->write_read(I2C_ADAP, chip, wbuffer, wlen, + rbuffer, rlen); +} + unsigned int i2c_set_bus_speed(unsigned int speed) { unsigned int ret; diff --git a/include/i2c.h b/include/i2c.h index 1b4078e..7bac20a 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -65,6 +65,9 @@ struct i2c_adapter { int (*write)(struct i2c_adapter *adap, uint8_t chip, uint addr, int alen, uint8_t *buffer, int len); + int (*write_read)(struct i2c_adapter *adap, uint8_t chip, + uint8_t *wbuffer, int wlength, uint8_t *rbuffer, + int rlength); uint (*set_bus_speed)(struct i2c_adapter *adap, uint speed); int speed; @@ -75,13 +78,14 @@ struct i2c_adapter { char *name; };
-#define U_BOOT_I2C_MKENT_COMPLETE(_init, _probe, _read, _write, \ +#define U_BOOT_I2C_MKENT_COMPLETE(_init, _probe, _read, _write, _write_read, \ _set_speed, _speed, _slaveaddr, _hwadapnr, _name) \ { \ .init = _init, \ .probe = _probe, \ .read = _read, \ .write = _write, \ + .write_read = _write_read, \ .set_bus_speed = _set_speed, \ .speed = _speed, \ .slaveaddr = _slaveaddr, \ @@ -90,10 +94,11 @@ struct i2c_adapter { .name = #_name \ };
-#define U_BOOT_I2C_ADAP_COMPLETE(_name, _init, _probe, _read, _write, \ - _set_speed, _speed, _slaveaddr, _hwadapnr) \ - ll_entry_declare(struct i2c_adapter, _name, i2c) = \ - U_BOOT_I2C_MKENT_COMPLETE(_init, _probe, _read, _write, \ +#define U_BOOT_I2C_ADAP_COMPLETE(_name, _init, _probe, _read, _write, \ + _write_read, _set_speed, _speed, _slaveaddr, \ + _hwadapnr) \ + ll_entry_declare(struct i2c_adapter, _name, i2c) = \ + U_BOOT_I2C_MKENT_COMPLETE(_init, _probe, _read, _write, _write_read, \ _set_speed, _speed, _slaveaddr, _hwadapnr, _name);
struct i2c_adapter *i2c_get_adapter(int index); @@ -237,6 +242,8 @@ int i2c_read(uint8_t chip, unsigned int addr, int alen,
int i2c_write(uint8_t chip, unsigned int addr, int alen, uint8_t *buffer, int len); +int i2c_write_read(uint8_t chip, uchar *wbuffer, int wlen, uchar *rbuffer, + int rlen);
/* * Utility routines to read/write registers. @@ -302,6 +309,8 @@ int i2c_probe(uchar chip); */ int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len); int i2c_write(uchar chip, uint addr, int alen, uchar *buffer, int len); +int i2c_write_read(uchar chip, uchar *wbuffer, int wlen, uchar *rbuffer, + int rlen);
<snip>
- int (*write_read)(struct i2c_adapter *adap, uint8_t chip,
uint (*set_bus_speed)(struct i2c_adapter *adap, uint speed); int speed;int rlength);
.set_bus_speed = _set_speed, \ .speed = _speed, \ .slaveaddr = _slaveaddr, \.write_read = _write_read, \
_hwadapnr) \
- U_BOOT_I2C_MKENT_COMPLETE(_init, _probe, _read, _write, _write_read, \ _set_speed, _speed, _slaveaddr, _hwadapnr, _name);
int rlen);
- Utility routines to read/write registers.
int rlen);
You need to be careful when changing the header file. If you compile other platforms, you will see the error. Try ./MAKEALL -a powerpc. I don't know how bad you broke other architectures.
York
-----Original Message----- From: Sun York-R58495 Sent: Saturday, March 08, 2014 3:10 AM To: Leekha Shaveta-B20052; u-boot@lists.denx.de Cc: Aggrwal Poonam-B10812; Aggrwal Poonam-B10812 Subject: Re: [PATCH] fsl_i2c: Add write-then-read transaction interface for I2C slave
<snip>
-#define U_BOOT_I2C_MKENT_COMPLETE(_init, _probe, _read, _write, \ +#define U_BOOT_I2C_MKENT_COMPLETE(_init, _probe, _read, _write, +_write_read, \ _set_speed, _speed, _slaveaddr, _hwadapnr, _name) \ { \ .init = _init, \ .probe = _probe, \ .read = _read, \ .write = _write, \
_hwadapnr) \
+_write_read, \ _set_speed, _speed, _slaveaddr, _hwadapnr, _name);
int rlen);
int rlen);
[Leekha Shaveta-B20052] Agree. This may break i2c driver code for other architectures. For one of the I2C device for B4 platform, the read/write transaction cycle is little different from Other conventional I2C devices like EEPROM, PCA etc. As its not right to change the header file for i2c as the same is being shared by other architectures/drivers also. So should we write a separate header file for FSL I2C driver fsl_i2c.h that support this New write_read API for I2C?
What do you suggest here?
York
<snip>
_hwadapnr) \
int rlen);
int rlen);
You are adding a new operation to i2c adapters. There are different ways.
1) Update all code to support this new operation 2) Use ifdef to activate this operation only on selected platforms 3) Look for other examples to do this safely. There may be some better ways to do so.
York
Shaveta Leekha
shavetaï¼ freescale.com
York Sun
