[U-Boot] [PATCH] powerpc/inka4x0: Remove left-over ide reset code.
The pin which was used in preliminary versions of the board for ide reset is really connected to the rtc clock.
Signed-off-by: Detlev Zundel dzu@denx.de --- board/inka4x0/inka4x0.c | 33 --------------------------------- include/configs/inka4x0.h | 1 - 2 files changed, 0 insertions(+), 34 deletions(-)
diff --git a/board/inka4x0/inka4x0.c b/board/inka4x0/inka4x0.c index 7428b92..c645b05 100644 --- a/board/inka4x0/inka4x0.c +++ b/board/inka4x0/inka4x0.c @@ -274,36 +274,3 @@ void pci_init_board(void) pci_mpc5xxx_init(&hose); } #endif - -#if defined(CONFIG_CMD_IDE) && defined(CONFIG_IDE_RESET) - -void init_ide_reset (void) -{ - volatile struct mpc5xxx_wu_gpio *wu_gpio = - (struct mpc5xxx_wu_gpio *)MPC5XXX_WU_GPIO; - - debug ("init_ide_reset\n"); - - /* Configure PSC1_4 as GPIO output for ATA reset */ - setbits_8(&wu_gpio->enable, MPC5XXX_GPIO_WKUP_PSC1_4); - setbits_8(&wu_gpio->ddr, MPC5XXX_GPIO_WKUP_PSC1_4); - /* Deassert reset */ - setbits_8(&wu_gpio->dvo, MPC5XXX_GPIO_WKUP_PSC1_4); -} - -void ide_set_reset (int idereset) -{ - volatile struct mpc5xxx_wu_gpio *wu_gpio = - (struct mpc5xxx_wu_gpio *)MPC5XXX_WU_GPIO; - - debug ("ide_reset(%d)\n", idereset); - - if (idereset) { - clrbits_8(&wu_gpio->dvo, MPC5XXX_GPIO_WKUP_PSC1_4); - /* Make a delay. MPC5200 spec says 25 usec min */ - udelay(500000); - } else { - setbits_8(&wu_gpio->dvo, MPC5XXX_GPIO_WKUP_PSC1_4); - } -} -#endif diff --git a/include/configs/inka4x0.h b/include/configs/inka4x0.h index 5f06b09..46606ca 100644 --- a/include/configs/inka4x0.h +++ b/include/configs/inka4x0.h @@ -418,7 +418,6 @@ static inline void tws_data_config_output(unsigned output) #undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ #undef CONFIG_IDE_LED /* LED for ide not supported */
-#define CONFIG_IDE_RESET /* reset for ide supported */ #define CONFIG_IDE_PREINIT
#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */
Hi Grant,
realizing that I forgot to CC you on the original mail[1], I now formally ask you to pull the patch into your repo as it fixes a real bug.
Thanks Detlev
[1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/59148
- if (idereset) {
udelay(500000);
- } else {
On Wed, May 13, 2009 at 3:30 AM, Detlev Zundel dzu@denx.de wrote:
Hi Grant,
Hi Detlev,
I'm not the u-boot mpc5xxx maintainer anymore. I didn't have time to keep up with it. John Rigby is the current maintainer.
g.
Hi Grant,
Argh, my fault, I should have known better. Sorry for the noise.
Cheers Detlev
Dear Detlev Zundel,
Applied, thanks.
Detlev Zundel
Grant Likely
