[PATCH] mmc: Fix comment typo
%s/occured/occurred/
Signed-off-by: Naoki Hayama naoki.hayama@lineo.co.jp ---
drivers/mmc/mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index d79cdef62e..106bf6d4d3 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -2184,7 +2184,7 @@ static int mmc_select_mode_and_width(struct mmc *mmc, uint card_caps) return 0; error: mmc_set_signal_voltage(mmc, old_voltage); - /* if an error occured, revert to a safer bus mode */ + /* if an error occurred, revert to a safer bus mode */ mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_BUS_WIDTH, EXT_CSD_BUS_WIDTH_1); mmc_select_mode(mmc, MMC_LEGACY);
Naoki Hayama
