[U-Boot] [PATCH] clk: rmobile: Assure SD-IF clock are configured correctly
The SD driver calls clk_set_rate() before clk_enable(), yet clk_set_rate() implementation in the clock driver does not set the SD-IF divider. Fix it.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/clk/renesas/clk-rcar-gen3.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/clk/renesas/clk-rcar-gen3.c b/drivers/clk/renesas/clk-rcar-gen3.c index b26bbcc59f..44d6ba5797 100644 --- a/drivers/clk/renesas/clk-rcar-gen3.c +++ b/drivers/clk/renesas/clk-rcar-gen3.c @@ -1216,6 +1216,8 @@ static ulong gen3_clk_get_rate(struct clk *clk)
static ulong gen3_clk_set_rate(struct clk *clk, ulong rate) { + /* Force correct SD-IF divider configuration if applicable */ + gen3_clk_setup_sdif_div(clk); return gen3_clk_get_rate(clk); }
