[U-Boot] [PATCH] imx7: SPI: add suport for SPI flash in mikroBUS slot
Enable the escpi3 nets attached to the mikroBUS slot on the i.MX7 Sabre evalution board. Also enble the SPI flash commands to work with the "flash click" board.
This is V2 of this patch with changes recommended by the maintainer
CC: Jagan Teki jteki@openedev.com --- board/freescale/mx7dsabresd/mx7dsabresd.c | 24 ++++++++++++++++++++++++ configs/mx7dsabresd_secure_defconfig | 3 +++ include/configs/mx7dsabresd.h | 3 +++ 3 files changed, 30 insertions(+)
diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index b936544..6ccdd4b 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -50,6 +50,9 @@ DECLARE_GLOBAL_DATA_PTR;
#define NAND_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_SRE_SLOW | PAD_CTL_HYS)
+#define SPI_PAD_CTRL \ + (PAD_CTL_HYS | PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_SRE_FAST) + #define NAND_PAD_READY0_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_PUS_PU5KOHM) #ifdef CONFIG_SYS_I2C_MXC #define PC MUX_PAD_CTRL(I2C_PAD_CTRL) @@ -68,6 +71,23 @@ static struct i2c_pads_info i2c_pad_info1 = { }; #endif
+static iomux_v3_cfg_t const ecspi3_pads[] = { + MX7D_PAD_SAI2_RX_DATA__ECSPI3_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX7D_PAD_SAI2_TX_SYNC__ECSPI3_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX7D_PAD_SAI2_TX_BCLK__ECSPI3_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX7D_PAD_SAI2_TX_DATA__GPIO6_IO22 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +int board_spi_cs_gpio(unsigned bus, unsigned cs) +{ + return (bus == 2 && cs == 0) ? (IMX_GPIO_NR(6, 22)) : -1; +} + +static void setup_spi(void) +{ + imx_iomux_v3_setup_multiple_pads(ecspi3_pads, ARRAY_SIZE(ecspi3_pads)); +} + int dram_init(void) { gd->ram_size = PHYS_SDRAM_SIZE; @@ -553,6 +573,10 @@ int board_init(void) board_qspi_init(); #endif
+#ifdef CONFIG_MXC_SPI + setup_spi(); +#endif + return 0; }
diff --git a/configs/mx7dsabresd_secure_defconfig b/configs/mx7dsabresd_secure_defconfig index 126ce31..ef93522 100644 --- a/configs/mx7dsabresd_secure_defconfig +++ b/configs/mx7dsabresd_secure_defconfig @@ -45,3 +45,6 @@ CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_OF_LIBFDT=y +CONFIG_SPI_FLASH=y +CONFIG_CMD_SF=y +CONFIG_SPI_FLASH_EON=y diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 360a5e0..7f468b2 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -201,6 +201,9 @@ #define CONFIG_ENV_SIZE SZ_8K #define CONFIG_ENV_IS_IN_MMC
+/* SPI flash support */ +#define CONFIG_MXC_SPI + /* * If want to use nand, define CONFIG_NAND_MXS and rework board * to support nand, since emmc has pin conflicts with nand
Patch subject doesn’t show as V2 fix it.
- (PAD_CTL_HYS | PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_SRE_FAST)
- MX7D_PAD_SAI2_RX_DATA__ECSPI3_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX7D_PAD_SAI2_TX_SYNC__ECSPI3_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX7D_PAD_SAI2_TX_BCLK__ECSPI3_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX7D_PAD_SAI2_TX_DATA__GPIO6_IO22 | MUX_PAD_CTRL(NO_PAD_CTRL),
setup_spi();
This is not SPI flash it's SPI driver.
thanks!
Angus Ainslie
Jagan Teki
