[U-Boot] [PATCH] AT91: fix at91cap9 SoC files
Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de --- arch/arm/cpu/arm926ejs/at91/at91cap9_devices.c | 88 +++++----- arch/arm/include/asm/arch-at91/at91cap9.h | 214 +++++++++++----------- arch/arm/include/asm/arch-at91/at91cap9_matrix.h | 147 +++++----------- 3 files changed, 191 insertions(+), 258 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/at91/at91cap9_devices.c b/arch/arm/cpu/arm926ejs/at91/at91cap9_devices.c index 2d878fd..2a0d7a3 100644 --- a/arch/arm/cpu/arm926ejs/at91/at91cap9_devices.c +++ b/arch/arm/cpu/arm926ejs/at91/at91cap9_devices.c @@ -27,77 +27,73 @@ */
#include <common.h> +#include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/gpio.h> -#include <asm/arch/io.h> + +/* + * if CONFIG_AT91_GPIO_PULLUP ist set, keep pullups on on all + * peripheral pins. Good to have if hardware is soldered optionally + * or in case of SPI no slave is selected. Avoid lines to float + * needlessly. Use a short local PUP define. + * + * Due to errata "TXD floats when CTS is inactive" pullups are always + * on for TXD pins. + */ +#ifdef CONFIG_AT91_GPIO_PULLUP +# define PUP CONFIG_AT91_GPIO_PULLUP +#else +# define PUP 0 +#endif
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTA, 22, 1); /* TXD0 */ - at91_set_a_periph(AT91_PIO_PORTA, 23, 0); /* RXD0 */ - writel(1 << AT91CAP9_ID_US0, &pmc->pcer); + at91_set_a_periph(AT91_PIO_PORTA, 23, PUP); /* RXD0 */ + writel(1 << ATMEL_ID_USART0, &pmc->pcer); }
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTD, 0, 1); /* TXD1 */ - at91_set_a_periph(AT91_PIO_PORTD, 1, 0); /* RXD1 */ - writel(1 << AT91CAP9_ID_US1, &pmc->pcer); + at91_set_a_periph(AT91_PIO_PORTD, 1, PUP); /* RXD1 */ + writel(1 << ATMEL_ID_USART1, &pmc->pcer); }
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTD, 2, 1); /* TXD2 */ - at91_set_a_periph(AT91_PIO_PORTD, 3, 0); /* RXD2 */ - writel(1 << AT91CAP9_ID_US2, &pmc->pcer); + at91_set_a_periph(AT91_PIO_PORTD, 3, PUP); /* RXD2 */ + writel(1 << ATMEL_ID_USART2, &pmc->pcer); }
-void at91_serial3_hw_init(void) +void at91_seriald_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
- at91_set_a_periph(AT91_PIO_PORTC, 30, 0); /* DRXD */ + at91_set_a_periph(AT91_PIO_PORTC, 30, PUP); /* DRXD */ at91_set_a_periph(AT91_PIO_PORTC, 31, 1); /* DTXD */ - writel(1 << AT91_ID_SYS, &pmc->pcer); -} - -void at91_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_serial0_hw_init(); -#endif - -#ifdef CONFIG_USART1 - at91_serial1_hw_init(); -#endif - -#ifdef CONFIG_USART2 - at91_serial2_hw_init(); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_serial3_hw_init(); -#endif + writel(1 << ATMEL_ID_SYS, &pmc->pcer); }
-#ifdef CONFIG_HAS_DATAFLASH +#if defined(CONFIG_HAS_DATAFLASH) || defined(CONFIG_ATMEL_SPI) void at91_spi0_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
- at91_set_b_periph(AT91_PIO_PORTA, 0, 0); /* SPI0_MISO */ - at91_set_b_periph(AT91_PIO_PORTA, 1, 0); /* SPI0_MOSI */ - at91_set_b_periph(AT91_PIO_PORTA, 2, 0); /* SPI0_SPCK */ + at91_set_b_periph(AT91_PIO_PORTA, 0, PUP); /* SPI0_MISO */ + at91_set_b_periph(AT91_PIO_PORTA, 1, PUP); /* SPI0_MOSI */ + at91_set_b_periph(AT91_PIO_PORTA, 2, PUP); /* SPI0_SPCK */
/* Enable clock */ - writel(1 << AT91CAP9_ID_SPI0, &pmc->pcer); + writel(1 << ATMEL_ID_SPI0, &pmc->pcer);
if (cs_mask & (1 << 0)) { at91_set_b_periph(AT91_PIO_PORTA, 5, 1); @@ -127,14 +123,14 @@ void at91_spi0_hw_init(unsigned long cs_mask)
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
- at91_set_a_periph(AT91_PIO_PORTB, 12, 0); /* SPI1_MISO */ - at91_set_a_periph(AT91_PIO_PORTB, 13, 0); /* SPI1_MOSI */ - at91_set_a_periph(AT91_PIO_PORTB, 14, 0); /* SPI1_SPCK */ + at91_set_a_periph(AT91_PIO_PORTB, 12, PUP); /* SPI1_MISO */ + at91_set_a_periph(AT91_PIO_PORTB, 13, PUP); /* SPI1_MOSI */ + at91_set_a_periph(AT91_PIO_PORTB, 14, PUP); /* SPI1_SPCK */
/* Enable clock */ - writel(1 << AT91CAP9_ID_SPI1, &pmc->pcer); + writel(1 << ATMEL_ID_SPI1, &pmc->pcer);
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 15, 1); @@ -194,12 +190,12 @@ void at91_macb_hw_init(void) #ifdef CONFIG_AT91_CAN void at91_can_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* CAN_TX */ at91_set_a_periph(AT91_PIO_PORTA, 13, 1); /* CAN_RX */
/* Enable clock */ - writel(1 << AT91CAP9_ID_CAN, &pmc->pcer); + writel(1 << ATMEL_ID_CAN, &pmc->pcer); } #endif diff --git a/arch/arm/include/asm/arch-at91/at91cap9.h b/arch/arm/include/asm/arch-at91/at91cap9.h index 5af6fdc..a41f755 100644 --- a/arch/arm/include/asm/arch-at91/at91cap9.h +++ b/arch/arm/include/asm/arch-at91/at91cap9.h @@ -18,133 +18,133 @@ #define AT91CAP9_H
/* - * Peripheral identifiers/interrupts. + * defines to be used in other places */ -#define AT91_ID_FIQ 0 /* Advanced Interrupt Controller (FIQ) */ -#define AT91_ID_SYS 1 /* System Peripherals */ -#define AT91CAP9_ID_PIOABCD 2 /* Parallel IO Controller A, B, C and D */ -#define AT91CAP9_ID_MPB0 3 /* MP Block Peripheral 0 */ -#define AT91CAP9_ID_MPB1 4 /* MP Block Peripheral 1 */ -#define AT91CAP9_ID_MPB2 5 /* MP Block Peripheral 2 */ -#define AT91CAP9_ID_MPB3 6 /* MP Block Peripheral 3 */ -#define AT91CAP9_ID_MPB4 7 /* MP Block Peripheral 4 */ -#define AT91CAP9_ID_US0 8 /* USART 0 */ -#define AT91CAP9_ID_US1 9 /* USART 1 */ -#define AT91CAP9_ID_US2 10 /* USART 2 */ -#define AT91CAP9_ID_MCI0 11 /* Multimedia Card Interface 0 */ -#define AT91CAP9_ID_MCI1 12 /* Multimedia Card Interface 1 */ -#define AT91CAP9_ID_CAN 13 /* CAN */ -#define AT91CAP9_ID_TWI 14 /* Two-Wire Interface */ -#define AT91CAP9_ID_SPI0 15 /* Serial Peripheral Interface 0 */ -#define AT91CAP9_ID_SPI1 16 /* Serial Peripheral Interface 0 */ -#define AT91CAP9_ID_SSC0 17 /* Serial Synchronous Controller 0 */ -#define AT91CAP9_ID_SSC1 18 /* Serial Synchronous Controller 1 */ -#define AT91CAP9_ID_AC97C 19 /* AC97 Controller */ -#define AT91CAP9_ID_TCB 20 /* Timer Counter 0, 1 and 2 */ -#define AT91CAP9_ID_PWMC 21 /* Pulse Width Modulation Controller */ -#define AT91CAP9_ID_EMAC 22 /* Ethernet */ -#define AT91CAP9_ID_AESTDES 23 /* Advanced Encryption Standard, Triple DES */ -#define AT91CAP9_ID_ADC 24 /* Analog-to-Digital Converter */ -#define AT91CAP9_ID_ISI 25 /* Image Sensor Interface */ -#define AT91CAP9_ID_LCDC 26 /* LCD Controller */ -#define AT91CAP9_ID_DMA 27 /* DMA Controller */ -#define AT91CAP9_ID_UDPHS 28 /* USB High Speed Device Port */ -#define AT91CAP9_ID_UHP 29 /* USB Host Port */ -#define AT91CAP9_ID_IRQ0 30 /* Advanced Interrupt Controller (IRQ0) */ -#define AT91CAP9_ID_IRQ1 31 /* Advanced Interrupt Controller (IRQ1) */ - -#define AT91_PIO_BASE 0xfffff200 -#define AT91_PMC_BASE 0xfffffc00 -#define AT91_RSTC_BASE 0xfffffd00 -#define AT91_PIT_BASE 0xfffffd30 - -#ifdef CONFIG_AT91_LEGACY +#define CONFIG_ARM926EJS /* ARM926EJS Core */ +#define CONFIG_AT91FAMILY /* it's a member of AT91 */
/* - * User Peripheral physical base addresses. + * Peripheral identifiers/interrupts. */ -#define AT91CAP9_BASE_UDPHS 0xfff78000 -#define AT91CAP9_BASE_TCB0 0xfff7c000 -#define AT91CAP9_BASE_TC0 0xfff7c000 -#define AT91CAP9_BASE_TC1 0xfff7c040 -#define AT91CAP9_BASE_TC2 0xfff7c080 -#define AT91CAP9_BASE_MCI0 0xfff80000 -#define AT91CAP9_BASE_MCI1 0xfff84000 -#define AT91CAP9_BASE_TWI 0xfff88000 -#define AT91CAP9_BASE_US0 0xfff8c000 -#define AT91CAP9_BASE_US1 0xfff90000 -#define AT91CAP9_BASE_US2 0xfff94000 -#define AT91CAP9_BASE_SSC0 0xfff98000 -#define AT91CAP9_BASE_SSC1 0xfff9c000 -#define AT91CAP9_BASE_AC97C 0xfffa0000 -#define AT91CAP9_BASE_SPI0 0xfffa4000 -#define AT91CAP9_BASE_SPI1 0xfffa8000 -#define AT91CAP9_BASE_CAN 0xfffac000 -#define AT91CAP9_BASE_PWMC 0xfffb8000 -#define AT91CAP9_BASE_EMAC 0xfffbc000 -#define AT91CAP9_BASE_ADC 0xfffc0000 -#define AT91CAP9_BASE_ISI 0xfffc4000 -#define AT91_BASE_SYS 0xffffe200 +#define ATMEL_ID_FIQ 0 /* Advanced Interrupt Controller (FIQ) */ +#define ATMEL_ID_SYS 1 /* System Peripherals */ +#define ATMEL_ID_PIOABCD 2 /* Parallel IO Controller A, B, C and D */ +#define ATMEL_ID_MPB0 3 /* MP Block Peripheral 0 */ +#define ATMEL_ID_MPB1 4 /* MP Block Peripheral 1 */ +#define ATMEL_ID_MPB2 5 /* MP Block Peripheral 2 */ +#define ATMEL_ID_MPB3 6 /* MP Block Peripheral 3 */ +#define ATMEL_ID_MPB4 7 /* MP Block Peripheral 4 */ +#define ATMEL_ID_USART0 8 /* USART 0 */ +#define ATMEL_ID_USART1 9 /* USART 1 */ +#define ATMEL_ID_USART2 10 /* USART 2 */ +#define ATMEL_ID_MCI0 11 /* Multimedia Card Interface 0 */ +#define ATMEL_ID_MCI1 12 /* Multimedia Card Interface 1 */ +#define ATMEL_ID_CAN 13 /* CAN */ +#define ATMEL_ID_TWI 14 /* Two-Wire Interface */ +#define ATMEL_ID_SPI0 15 /* Serial Peripheral Interface 0 */ +#define ATMEL_ID_SPI1 16 /* Serial Peripheral Interface 0 */ +#define ATMEL_ID_SSC0 17 /* Serial Synchronous Controller 0 */ +#define ATMEL_ID_SSC1 18 /* Serial Synchronous Controller 1 */ +#define ATMEL_ID_AC97C 19 /* AC97 Controller */ +#define ATMEL_ID_TCB 20 /* Timer Counter 0, 1 and 2 */ +#define ATMEL_ID_PWMC 21 /* Pulse Width Modulation Controller */ +#define ATMEL_ID_EMAC 22 /* Ethernet */ +#define ATMEL_ID_AESTDES 23 /* Advanced Encryption Standard, Triple DES */ +#define ATMEL_ID_ADC 24 /* Analog-to-Digital Converter */ +#define ATMEL_ID_ISI 25 /* Image Sensor Interface */ +#define ATMEL_ID_LCDC 26 /* LCD Controller */ +#define ATMEL_ID_DMA 27 /* DMA Controller */ +#define ATMEL_ID_UDPHS 28 /* USB High Speed Device Port */ +#define ATMEL_ID_UHP 29 /* USB Host Port */ +#define ATMEL_ID_IRQ0 30 /* Advanced Interrupt Controller (IRQ0) */ +#define ATMEL_ID_IRQ1 31 /* Advanced Interrupt Controller (IRQ1) */
/* - * System Peripherals (offset from AT91_BASE_SYS) + * User Peripheral physical base addresses. */ -#define AT91_ECC (0xffffe200 - AT91_BASE_SYS) -#define AT91_BCRAMC (0xffffe400 - AT91_BASE_SYS) -#define AT91_DDRSDRC (0xffffe600 - AT91_BASE_SYS) -#define AT91_SMC (0xffffe800 - AT91_BASE_SYS) -#define AT91_MATRIX (0xffffea00 - AT91_BASE_SYS) -#define AT91_CCFG (0xffffeb10 - AT91_BASE_SYS) -#define AT91_DMA (0xffffec00 - AT91_BASE_SYS) -#define AT91_DBGU (0xffffee00 - AT91_BASE_SYS) -#define AT91_AIC (0xfffff000 - AT91_BASE_SYS) -#define AT91_PIOA (0xfffff200 - AT91_BASE_SYS) -#define AT91_PIOB (0xfffff400 - AT91_BASE_SYS) -#define AT91_PIOC (0xfffff600 - AT91_BASE_SYS) -#define AT91_PIOD (0xfffff800 - AT91_BASE_SYS) -#define AT91_PMC (0xfffffc00 - AT91_BASE_SYS) -#define AT91_RSTC (0xfffffd00 - AT91_BASE_SYS) -#define AT91_SHDWC (0xfffffd10 - AT91_BASE_SYS) -#define AT91_RTT (0xfffffd20 - AT91_BASE_SYS) -#define AT91_PIT (0xfffffd30 - AT91_BASE_SYS) -#define AT91_WDT (0xfffffd40 - AT91_BASE_SYS) -#define AT91_SCKCR (0xfffffd50 - AT91_BASE_SYS) -#define AT91_GPBR_REVB (0xfffffd50 - AT91_BASE_SYS) -#define AT91_GPBR_REVC (0xfffffd60 - AT91_BASE_SYS) - -#define AT91_USART0 AT91CAP9_BASE_US0 -#define AT91_USART1 AT91CAP9_BASE_US1 -#define AT91_USART2 AT91CAP9_BASE_US2 +#define ATMEL_BASE_UDPHS 0xfff78000 +#define ATMEL_BASE_TCB0 0xfff7c000 +#define ATMEL_BASE_TC0 0xfff7c000 +#define ATMEL_BASE_TC1 0xfff7c040 +#define ATMEL_BASE_TC2 0xfff7c080 +#define ATMEL_BASE_MCI0 0xfff80000 +#define ATMEL_BASE_MCI1 0xfff84000 +#define ATMEL_BASE_TWI 0xfff88000 +#define ATMEL_BASE_USART0 0xfff8c000 +#define ATMEL_BASE_USART1 0xfff90000 +#define ATMEL_BASE_USART2 0xfff94000 +#define ATMEL_BASE_SSC0 0xfff98000 +#define ATMEL_BASE_SSC1 0xfff9c000 +#define ATMEL_BASE_AC97C 0xfffa0000 +#define ATMEL_BASE_SPI0 0xfffa4000 +#define ATMEL_BASE_SPI1 0xfffa8000 +#define ATMEL_BASE_CAN 0xfffac000 +#define ATMEL_BASE_PWMC 0xfffb8000 +#define ATMEL_BASE_EMAC 0xfffbc000 +#define ATMEL_BASE_ADC 0xfffc0000 +#define ATMEL_BASE_ISI 0xfffc4000
/* - * SCKCR flags + * System Peripherals physical base addresses. */ -#define AT91CAP9_SCKCR_RCEN (1 << 0) /* RC Oscillator Enable */ -#define AT91CAP9_SCKCR_OSC32EN (1 << 1) /* 32kHz Oscillator Enable */ -#define AT91CAP9_SCKCR_OSC32BYP (1 << 2) /* 32kHz Oscillator Bypass */ -#define AT91CAP9_SCKCR_OSCSEL (1 << 3) /* Slow Clock Selector */ -#define AT91CAP9_SCKCR_OSCSEL_RC (0 << 3) -#define AT91CAP9_SCKCR_OSCSEL_32 (1 << 3) +#define ATMEL_BASE_ECC 0xffffe200 +#define ATMEL_BASE_BCRAMC 0xffffe400 +#define ATMEL_BASE_DDRSDRC 0xffffe600 +#define ATMEL_BASE_SMC 0xffffe800 +#define ATMEL_BASE_MATRIX 0xffffea00 +#define ATMEL_BASE_CCFG 0xffffeb10 +#define ATMEL_BASE_DMA 0xffffec00 +#define ATMEL_BASE_DBGU 0xffffee00 +#define ATMEL_BASE_AIC 0xfffff000 +#define ATMEL_BASE_PIOA 0xfffff200 +#define ATMEL_BASE_PIOB 0xfffff400 +#define ATMEL_BASE_PIOC 0xfffff600 +#define ATMEL_BASE_PIOD 0xfffff800 +#define ATMEL_BASE_PMC 0xfffffc00 +#define ATMEL_BASE_RSTC 0xfffffd00 +#define ATMEL_BASE_SHDWC 0xfffffd10 +#define ATMEL_BASE_RTT 0xfffffd20 +#define ATMEL_BASE_PIT 0xfffffd30 +#define ATMEL_BASE_WDT 0xfffffd40 +#define ATMEL_BASE_SCKCR 0xfffffd50 +#define ATMEL_BASE_GPBR_REVB 0xfffffd50 +#define ATMEL_BASE_GPBR_REVC 0xfffffd60
-#endif /* CONFIG_AT91_LEGACY */ /* * Internal Memory. */ -#define AT91CAP9_SRAM_BASE 0x00100000 /* Internal SRAM base address */ -#define AT91CAP9_SRAM_SIZE (32 * SZ_1K) /* Internal SRAM size (32Kb) */ +#define ATMEL_BASE_SRAM 0x00100000 /* Internal SRAM */
-#define AT91CAP9_ROM_BASE 0x00400000 /* Internal ROM base address */ -#define AT91CAP9_ROM_SIZE (32 * SZ_1K) /* Internal ROM size (32Kb) */ +#define ATMEL_BASE_ROM 0x00400000 /* Internal ROM */
-#define AT91CAP9_LCDC_BASE 0x00500000 /* LCD Controller */ -#define AT91CAP9_UDPHS_BASE 0x00600000 /* USB High Speed Device Port */ -#define AT91CAP9_UHP_BASE 0x00700000 /* USB Host controller */ +#define ATMEL_BASE_LCDC 0x00500000 /* LCD Controller */ +#define ATMEL_BASE_UHPHS 0x00600000 /* USB High Speed Device */ +#define ATMEL_BASE_UHP 0x00700000 /* USB Host controller */
-#define CONFIG_DRAM_BASE AT91_CHIPSELECT_6 +/* + * External memory + */ +#define ATMEL_BASE_CS0 0x10000000 +#define ATMEL_BASE_CS1 0x20000000 +#define ATMEL_BASE_CS2 0x30000000 +#define ATMEL_BASE_CS3 0x40000000 +#define ATMEL_BASE_CS4 0x50000000 +#define ATMEL_BASE_CS5 0x60000000 +#define ATMEL_BASE_CS6 0x70000000 +#define ATMEL_BASE_CS7 0x80000000 + +#define CONFIG_DRAM_BASE ATMEL_BASE_CS6 + +/* + * Other misc defines + */ +#define ATMEL_PIO_PORTS 4 /* this SoCs has 4 PIO */ +#define ATMEL_BASE_PIO ATMEL_BASE_PIOA +#define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP
/* * Cpu Name */ -#define CONFIG_SYS_AT91_CPU_NAME "AT91CAP9" +#define ATMEL_CPU_NAME "AT91CAP9"
#endif diff --git a/arch/arm/include/asm/arch-at91/at91cap9_matrix.h b/arch/arm/include/asm/arch-at91/at91cap9_matrix.h index 22b7e9b..3088287 100644 --- a/arch/arm/include/asm/arch-at91/at91cap9_matrix.h +++ b/arch/arm/include/asm/arch-at91/at91cap9_matrix.h @@ -17,116 +17,53 @@ #ifndef AT91CAP9_MATRIX_H #define AT91CAP9_MATRIX_H
-#define AT91_MATRIX_MCFG0 (AT91_MATRIX + 0x00) /* Master Configuration Register 0 */ -#define AT91_MATRIX_MCFG1 (AT91_MATRIX + 0x04) /* Master Configuration Register 1 */ -#define AT91_MATRIX_MCFG2 (AT91_MATRIX + 0x08) /* Master Configuration Register 2 */ -#define AT91_MATRIX_MCFG3 (AT91_MATRIX + 0x0C) /* Master Configuration Register 3 */ -#define AT91_MATRIX_MCFG4 (AT91_MATRIX + 0x10) /* Master Configuration Register 4 */ -#define AT91_MATRIX_MCFG5 (AT91_MATRIX + 0x14) /* Master Configuration Register 5 */ -#define AT91_MATRIX_MCFG6 (AT91_MATRIX + 0x18) /* Master Configuration Register 6 */ -#define AT91_MATRIX_MCFG7 (AT91_MATRIX + 0x1C) /* Master Configuration Register 7 */ -#define AT91_MATRIX_MCFG8 (AT91_MATRIX + 0x20) /* Master Configuration Register 8 */ -#define AT91_MATRIX_MCFG9 (AT91_MATRIX + 0x24) /* Master Configuration Register 9 */ -#define AT91_MATRIX_MCFG10 (AT91_MATRIX + 0x28) /* Master Configuration Register 10 */ -#define AT91_MATRIX_MCFG11 (AT91_MATRIX + 0x2C) /* Master Configuration Register 11 */ -#define AT91_MATRIX_ULBT (7 << 0) /* Undefined Length Burst Type */ -#define AT91_MATRIX_ULBT_INFINITE (0 << 0) -#define AT91_MATRIX_ULBT_SINGLE (1 << 0) -#define AT91_MATRIX_ULBT_FOUR (2 << 0) -#define AT91_MATRIX_ULBT_EIGHT (3 << 0) -#define AT91_MATRIX_ULBT_SIXTEEN (4 << 0) +#ifndef __ASSEMBLY__
-#define AT91_MATRIX_SCFG0 (AT91_MATRIX + 0x40) /* Slave Configuration Register 0 */ -#define AT91_MATRIX_SCFG1 (AT91_MATRIX + 0x44) /* Slave Configuration Register 1 */ -#define AT91_MATRIX_SCFG2 (AT91_MATRIX + 0x48) /* Slave Configuration Register 2 */ -#define AT91_MATRIX_SCFG3 (AT91_MATRIX + 0x4C) /* Slave Configuration Register 3 */ -#define AT91_MATRIX_SCFG4 (AT91_MATRIX + 0x50) /* Slave Configuration Register 4 */ -#define AT91_MATRIX_SCFG5 (AT91_MATRIX + 0x54) /* Slave Configuration Register 5 */ -#define AT91_MATRIX_SCFG6 (AT91_MATRIX + 0x58) /* Slave Configuration Register 6 */ -#define AT91_MATRIX_SCFG7 (AT91_MATRIX + 0x5C) /* Slave Configuration Register 7 */ -#define AT91_MATRIX_SCFG8 (AT91_MATRIX + 0x60) /* Slave Configuration Register 8 */ -#define AT91_MATRIX_SCFG9 (AT91_MATRIX + 0x64) /* Slave Configuration Register 9 */ -#define AT91_MATRIX_SLOT_CYCLE (0xff << 0) /* Maximum Number of Allowed Cycles for a Burst */ -#define AT91_MATRIX_DEFMSTR_TYPE (3 << 16) /* Default Master Type */ -#define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) -#define AT91_MATRIX_DEFMSTR_TYPE_LAST (1 << 16) -#define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) -#define AT91_MATRIX_FIXED_DEFMSTR (0xf << 18) /* Fixed Index of Default Master */ -#define AT91_MATRIX_ARBT (3 << 24) /* Arbitration Type */ -#define AT91_MATRIX_ARBT_ROUND_ROBIN (0 << 24) -#define AT91_MATRIX_ARBT_FIXED_PRIORITY (1 << 24) +/* + * This struct defines access to the matrix' maximum of + * 16 masters and 16 slaves. + * Note: not all masters/slaves are available + */ +struct at91_matrix { + u32 mcfg[16]; /* Master Configuration Registers */ + u32 scfg[16]; /* Slave Configuration Registers */ + u32 pras[16][2]; /* Priority Assignment Slave Registers */ + u32 mrcr; /* Master Remap Control Register */ + u32 filler[0x06]; + u32 ebicsa; /* EBI Chip Select Assignment Register */ +}; + +#endif /* __ASSEMBLY__ */
-#define AT91_MATRIX_PRAS0 (AT91_MATRIX + 0x80) /* Priority Register A for Slave 0 */ -#define AT91_MATRIX_PRBS0 (AT91_MATRIX + 0x84) /* Priority Register B for Slave 0 */ -#define AT91_MATRIX_PRAS1 (AT91_MATRIX + 0x88) /* Priority Register A for Slave 1 */ -#define AT91_MATRIX_PRBS1 (AT91_MATRIX + 0x8C) /* Priority Register B for Slave 1 */ -#define AT91_MATRIX_PRAS2 (AT91_MATRIX + 0x90) /* Priority Register A for Slave 2 */ -#define AT91_MATRIX_PRBS2 (AT91_MATRIX + 0x94) /* Priority Register B for Slave 2 */ -#define AT91_MATRIX_PRAS3 (AT91_MATRIX + 0x98) /* Priority Register A for Slave 3 */ -#define AT91_MATRIX_PRBS3 (AT91_MATRIX + 0x9C) /* Priority Register B for Slave 3 */ -#define AT91_MATRIX_PRAS4 (AT91_MATRIX + 0xA0) /* Priority Register A for Slave 4 */ -#define AT91_MATRIX_PRBS4 (AT91_MATRIX + 0xA4) /* Priority Register B for Slave 4 */ -#define AT91_MATRIX_PRAS5 (AT91_MATRIX + 0xA8) /* Priority Register A for Slave 5 */ -#define AT91_MATRIX_PRBS5 (AT91_MATRIX + 0xAC) /* Priority Register B for Slave 5 */ -#define AT91_MATRIX_PRAS6 (AT91_MATRIX + 0xB0) /* Priority Register A for Slave 6 */ -#define AT91_MATRIX_PRBS6 (AT91_MATRIX + 0xB4) /* Priority Register B for Slave 6 */ -#define AT91_MATRIX_PRAS7 (AT91_MATRIX + 0xB8) /* Priority Register A for Slave 7 */ -#define AT91_MATRIX_PRBS7 (AT91_MATRIX + 0xBC) /* Priority Register B for Slave 7 */ -#define AT91_MATRIX_PRAS8 (AT91_MATRIX + 0xC0) /* Priority Register A for Slave 8 */ -#define AT91_MATRIX_PRBS8 (AT91_MATRIX + 0xC4) /* Priority Register B for Slave 8 */ -#define AT91_MATRIX_PRAS9 (AT91_MATRIX + 0xC8) /* Priority Register A for Slave 9 */ -#define AT91_MATRIX_PRBS9 (AT91_MATRIX + 0xCC) /* Priority Register B for Slave 9 */ -#define AT91_MATRIX_M0PR (3 << 0) /* Master 0 Priority */ -#define AT91_MATRIX_M1PR (3 << 4) /* Master 1 Priority */ -#define AT91_MATRIX_M2PR (3 << 8) /* Master 2 Priority */ -#define AT91_MATRIX_M3PR (3 << 12) /* Master 3 Priority */ -#define AT91_MATRIX_M4PR (3 << 16) /* Master 4 Priority */ -#define AT91_MATRIX_M5PR (3 << 20) /* Master 5 Priority */ -#define AT91_MATRIX_M6PR (3 << 24) /* Master 6 Priority */ -#define AT91_MATRIX_M7PR (3 << 28) /* Master 7 Priority */ -#define AT91_MATRIX_M8PR (3 << 0) /* Master 8 Priority (in Register B) */ -#define AT91_MATRIX_M9PR (3 << 4) /* Master 9 Priority (in Register B) */ -#define AT91_MATRIX_M10PR (3 << 8) /* Master 10 Priority (in Register B) */ -#define AT91_MATRIX_M11PR (3 << 12) /* Master 11 Priority (in Register B) */ +#define AT91_MATRIX_ULBT_INFINITE (0 << 0) +#define AT91_MATRIX_ULBT_SINGLE (1 << 0) +#define AT91_MATRIX_ULBT_FOUR (2 << 0) +#define AT91_MATRIX_ULBT_EIGHT (3 << 0) +#define AT91_MATRIX_ULBT_SIXTEEN (4 << 0)
-#define AT91_MATRIX_MRCR (AT91_MATRIX + 0x100) /* Master Remap Control Register */ -#define AT91_MATRIX_RCB0 (1 << 0) /* Remap Command for AHB Master 0 (ARM926EJ-S Instruction Master) */ -#define AT91_MATRIX_RCB1 (1 << 1) /* Remap Command for AHB Master 1 (ARM926EJ-S Data Master) */ -#define AT91_MATRIX_RCB2 (1 << 2) -#define AT91_MATRIX_RCB3 (1 << 3) -#define AT91_MATRIX_RCB4 (1 << 4) -#define AT91_MATRIX_RCB5 (1 << 5) -#define AT91_MATRIX_RCB6 (1 << 6) -#define AT91_MATRIX_RCB7 (1 << 7) -#define AT91_MATRIX_RCB8 (1 << 8) -#define AT91_MATRIX_RCB9 (1 << 9) -#define AT91_MATRIX_RCB10 (1 << 10) -#define AT91_MATRIX_RCB11 (1 << 11) +#define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_LAST (1 << 16) +#define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) +#define AT91_MATRIX_FIXED_DEFMSTR_SHIFT 18 +#define AT91_MATRIX_ARBT_ROUND_ROBIN (0 << 24) +#define AT91_MATRIX_ARBT_FIXED_PRIORITY (1 << 24)
-#define AT91_MPBS0_SFR (AT91_MATRIX + 0x114) /* MPBlock Slave 0 Special Function Register */ -#define AT91_MPBS1_SFR (AT91_MATRIX + 0x11C) /* MPBlock Slave 1 Special Function Register */ +#define AT91_MATRIX_M0PR_SHIFT 0 +#define AT91_MATRIX_M1PR_SHIFT 4 +#define AT91_MATRIX_M2PR_SHIFT 8 +#define AT91_MATRIX_M3PR_SHIFT 12 +#define AT91_MATRIX_M4PR_SHIFT 16 +#define AT91_MATRIX_M5PR_SHIFT 20
-#define AT91_MATRIX_EBICSA (AT91_MATRIX + 0x120) /* EBI Chip Select Assignment Register */ -#define AT91_MATRIX_EBI_CS1A (1 << 1) /* Chip Select 1 Assignment */ -#define AT91_MATRIX_EBI_CS1A_SMC (0 << 1) -#define AT91_MATRIX_EBI_CS1A_BCRAMC (1 << 1) -#define AT91_MATRIX_EBI_CS3A (1 << 3) /* Chip Select 3 Assignment */ -#define AT91_MATRIX_EBI_CS3A_SMC (0 << 3) -#define AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA (1 << 3) -#define AT91_MATRIX_EBI_CS4A (1 << 4) /* Chip Select 4 Assignment */ -#define AT91_MATRIX_EBI_CS4A_SMC (0 << 4) -#define AT91_MATRIX_EBI_CS4A_SMC_CF1 (1 << 4) -#define AT91_MATRIX_EBI_CS5A (1 << 5) /* Chip Select 5 Assignment */ -#define AT91_MATRIX_EBI_CS5A_SMC (0 << 5) -#define AT91_MATRIX_EBI_CS5A_SMC_CF2 (1 << 5) -#define AT91_MATRIX_EBI_DBPUC (1 << 8) /* Data Bus Pull-up Configuration */ -#define AT91_MATRIX_EBI_DQSPDC (1 << 9) /* Data Qualifier Strobe Pull-Down Configuration */ -#define AT91_MATRIX_EBI_VDDIOMSEL (1 << 16) /* Memory voltage selection */ -#define AT91_MATRIX_EBI_VDDIOMSEL_1_8V (0 << 16) -#define AT91_MATRIX_EBI_VDDIOMSEL_3_3V (1 << 16) +#define AT91_MATRIX_RCB0 (1 << 0) +#define AT91_MATRIX_RCB1 (1 << 1)
-#define AT91_MPBS2_SFR (AT91_MATRIX + 0x12C) /* MPBlock Slave 2 Special Function Register */ -#define AT91_MPBS3_SFR (AT91_MATRIX + 0x130) /* MPBlock Slave 3 Special Function Register */ -#define AT91_APB_SFR (AT91_MATRIX + 0x134) /* APB Bridge Special Function Register */ +#define AT91_MATRIX_CS1A_SDRAMC (1 << 1) +#define AT91_MATRIX_CS3A_SMC_SMARTMEDIA (1 << 3) +#define AT91_MATRIX_CS4A_SMC_CF1 (1 << 4) +#define AT91_MATRIX_CS5A_SMC_CF2 (1 << 5) +#define AT91_MATRIX_DBPUC (1 << 8) +#define AT91_MATRIX_VDDIOMSEL_1_8V (0 << 16) +#define AT91_MATRIX_VDDIOMSEL_3_3V (1 << 16)
#endif
Hi Reinhard,
On 03/08/2011 10:39, Reinhard Meyer wrote:
Signed-off-by: Reinhard Meyeru-boot@emk-elektronik.de
FYI, there are two consecutive commits in your u-boot-atmel/fix-at91cap9 branch with this same exact title of "AT91: fix at91cap9 SoC files".
Somehow this can't be correct: either both patches contribute to the same atomic change and should be merged under their common title, or they do different things and their titles do not reflex what they each do.
Amicalement,
Dear Albert,
I tried to provide a fix myself, but that is imcomplete. I am waiting on SOMEONE ELSE to continue this fix effort, or to provide a complete new one...
At the end *ALL* would be merged into one patch, of course.
Best Regards, Reinhard
Albert ARIBAUD
Reinhard Meyer
