[U-Boot-Users] [PATCH 18/18] Clear up confusion over the CMD_POST and POST_DIAG mess.
For some reason, CONFIG_POST permeated as CONFIG_CMD_POST_DIAG when it really means just CONFIG_CMD_DIAG. There is no CMD_POST. Clear this mess up some.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/BC3450.h | 8 ++++---- include/configs/GEN860T.h | 10 +++------- include/configs/KUP4K.h | 10 +++------- include/configs/KUP4X.h | 10 +++------- include/configs/TB5200.h | 16 ++++++++-------- include/configs/TQM5200.h | 8 ++++---- include/configs/aev.h | 8 ++++---- include/configs/bf537-stamp.h | 8 ++++---- include/configs/lwmon.h | 11 ++++------- include/configs/smmaco4.h | 8 ++++---- include/configs/spieval.h | 30 +++++++++++++++--------------- include/configs/uc100.h | 11 ++++------- 12 files changed, 60 insertions(+), 78 deletions(-)
diff --git a/include/configs/BC3450.h b/include/configs/BC3450.h index 00b656e..aec4d83 100644 --- a/include/configs/BC3450.h +++ b/include/configs/BC3450.h @@ -138,11 +138,8 @@ CFG_POST_I2C)
#ifdef CONFIG_POST -# define CFG_CMD_POST_DIAG CFG_CMD_DIAG /* preserve space for the post_word at end of on-chip SRAM */ # define MPC5XXX_SRAM_POST_SIZE MPC5XXX_SRAM_SIZE-4 -#else -# define CFG_CMD_POST_DIAG 0 #endif /* CONFIG_POST */
@@ -161,7 +158,6 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_NFS #define CONFIG_CMD_PING -#define CONFIG_CMD_POST_DIAG #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SNTP #define CONFIG_CMD_BSP @@ -192,6 +188,10 @@ #define CONFIG_CMD_PCI #endif
+#ifdef CONFIG_POST + #define CONFIG_CMD_DIAG +#endif +
#define CONFIG_TIMESTAMP /* display image timestamps */
diff --git a/include/configs/GEN860T.h b/include/configs/GEN860T.h index 612b661..2b2d15a 100644 --- a/include/configs/GEN860T.h +++ b/include/configs/GEN860T.h @@ -222,12 +222,6 @@ CFG_POST_UART | \ CFG_POST_SPR )
-#ifdef CONFIG_POST -#define CFG_CMD_POST_DIAG CFG_CMD_DIAG -#else -#define CFG_CMD_POST_DIAG 0 -#endif -
/* * Command line configuration. @@ -245,12 +239,14 @@ #define CONFIG_CMD_FPGA #define CONFIG_CMD_MII #define CONFIG_CMD_BEDBUG -#define CONFIG_CMD_POST_DIAG
#if !defined(CONFIG_SC) #define CONFIG_CMD_DOC #endif
+#ifdef CONFIG_POST +u #define CONFIG_CMD_DIAG +#endif
/* * There is no IDE/PCMCIA hardware support on the board. diff --git a/include/configs/KUP4K.h b/include/configs/KUP4K.h index 2422201..2f05605 100644 --- a/include/configs/KUP4K.h +++ b/include/configs/KUP4K.h @@ -156,12 +156,6 @@ #define CONFIG_POST (CFG_POST_CPU | \ CFG_POST_RTC | \ CFG_POST_I2C) - -#ifdef CONFIG_POST -#define CFG_CMD_POST_DIAG CFG_CMD_DIAG -#else -#define CFG_CMD_POST_DIAG 0 -#endif #endif
@@ -175,9 +169,11 @@ #define CONFIG_CMD_I2C #define CONFIG_CMD_IDE #define CONFIG_CMD_NFS -#define CONFIG_CMD_POST_DIAG #define CONFIG_CMD_SNTP
/* * Miscellaneous configurable options diff --git a/include/configs/KUP4X.h b/include/configs/KUP4X.h index 184338b..c59b70f 100644 --- a/include/configs/KUP4X.h +++ b/include/configs/KUP4X.h @@ -167,12 +167,6 @@ #define CONFIG_POST (CFG_POST_CPU | \ CFG_POST_RTC | \ CFG_POST_I2C) - -#ifdef CONFIG_POST -#define CFG_CMD_POST_DIAG CFG_CMD_DIAG -#else -#define CFG_CMD_POST_DIAG 0 -#endif #endif
@@ -187,10 +181,12 @@ #define CONFIG_CMD_I2C #define CONFIG_CMD_IDE #define CONFIG_CMD_NFS -#define CONFIG_CMD_POST_DIAG #define CONFIG_CMD_SNTP #define CONFIG_CMD_USB
/* * Miscellaneous configurable options diff --git a/include/configs/TB5200.h b/include/configs/TB5200.h index f64c522..3d90efb 100644 --- a/include/configs/TB5200.h +++ b/include/configs/TB5200.h @@ -82,11 +82,8 @@ CFG_POST_I2C)
#ifdef CONFIG_POST -#define CFG_CMD_POST_DIAG CFG_CMD_DIAG /* preserve space for the post_word at end of on-chip SRAM */ #define MPC5XXX_SRAM_POST_SIZE MPC5XXX_SRAM_SIZE-4 -#else -#define CFG_CMD_POST_DIAG 0 #endif
@@ -95,10 +92,6 @@ */ #include <config_cmd_default.h>
-#ifdef CONFIG_VIDEO -#define CONFIG_CMD_BMP -#endif - #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE #define CONFIG_CMD_DHCP @@ -112,12 +105,19 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_NFS #define CONFIG_CMD_PING -#define CONFIG_CMD_POST_DIAG #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SNTP #define CONFIG_CMD_BSP #define CONFIG_CMD_USB
+#ifdef CONFIG_VIDEO +#define CONFIG_CMD_BMP +#endif + +#ifdef CONFIG_POST +#define CONFIG__CMD_DIAG +#endif +
diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 24114b8..598c1c6 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -142,11 +142,8 @@ #endif
@@ -164,7 +161,6 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_NFS #define CONFIG_CMD_PING -#define CONFIG_CMD_POST_DIAG #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SNTP #define CONFIG_CMD_BSP @@ -188,6 +184,10 @@ #define CONFIG_CFG_FAT #endif
diff --git a/include/configs/aev.h b/include/configs/aev.h index ecd84d3..93b20db 100644 --- a/include/configs/aev.h +++ b/include/configs/aev.h @@ -86,11 +86,8 @@ CFG_POST_I2C)
@@ -109,10 +106,13 @@ #define CONFIG_CMD_NFS #define CONFIG_CMD_PCI #define CONFIG_CMD_PING -#define CONFIG_CMD_POST #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SNTP
+#ifdef CONFIG_POST +#define CONFIG_CMD_DIAG +#endif +
diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index 36f55d1..bea157a 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -144,11 +144,8 @@ #endif
#ifdef CONFIG_POST -#define CFG_CMD_POST_DIAG CFG_CMD_DIAG #define FLASH_START_POST_BLOCK 11 /* Should > = 11 */ #define FLASH_END_POST_BLOCK 71 /* Should < = 71 */ -#else -#define CFG_CMD_POST_DIAG 0 #endif
/* CF-CARD IDE-HDD Support */ @@ -197,7 +194,10 @@ #if (BFIN_BOOT_MODE == BF537_BYPASS_BOOT)
#define CONFIG_CMD_DHCP -#define CONFIG_CMD_POST_DIAG + +#if defined(CONFIG_POST) +#define CONFIG_CMD_DIAG +#endif
#ifdef CONFIG_BF537_NAND #define CONFIG_CMD_NAND diff --git a/include/configs/lwmon.h b/include/configs/lwmon.h index 3dc7a8e..1db5e90 100644 --- a/include/configs/lwmon.h +++ b/include/configs/lwmon.h @@ -170,12 +170,6 @@
#define CONFIG_RTC_PCF8563 /* use Philips PCF8563 RTC */
/* * Command line configuration. @@ -192,9 +186,12 @@ #define CONFIG_CMD_I2C #define CONFIG_CMD_IDE #define CONFIG_CMD_NFS -#define CONFIG_CMD_POST #define CONFIG_CMD_SNTP
#define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION diff --git a/include/configs/smmaco4.h b/include/configs/smmaco4.h index 8d09857..a965e8a 100644 --- a/include/configs/smmaco4.h +++ b/include/configs/smmaco4.h @@ -60,11 +60,8 @@ CFG_POST_I2C)
@@ -82,10 +79,13 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_NFS #define CONFIG_CMD_PING -#define CONFIG_CMD_POST #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SNTP
diff --git a/include/configs/spieval.h b/include/configs/spieval.h index e480df5..ccfcf1c 100644 --- a/include/configs/spieval.h +++ b/include/configs/spieval.h @@ -116,11 +116,8 @@ CFG_POST_I2C)
@@ -129,6 +126,18 @@ */ #include <config_cmd_default.h>
+#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SNTP + #if defined(CONFIG_MINIFAP) || defined(CONFIG_STK52XX) #define CONFIG_CMD_IDE #define CONFIG_CMD_FAT @@ -148,18 +157,9 @@ #define CONFIG_CMD_PCI #endif
-#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_ECHO -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MII -#define CONFIG_CMD_NFS -#define CONFIG_CMD_PING -#define CONFIG_CMD_POST -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SNTP +#ifdef CONFIG_POST +#define CONFIG_CMD_DIAG +#endif
#define CONFIG_TIMESTAMP /* display image timestamps */ diff --git a/include/configs/uc100.h b/include/configs/uc100.h index 2bdc55b..d223c58 100644 --- a/include/configs/uc100.h +++ b/include/configs/uc100.h @@ -117,12 +117,6 @@ CFG_POST_SPR ) #undef CONFIG_POST
/* * Command line configuration. @@ -140,9 +134,12 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_NFS #define CONFIG_CMD_PING -#define CONFIG_CMD_POST #define CONFIG_CMD_SNTP
#define CONFIG_NETCONSOLE
Jon Loeliger
