[U-Boot] [PATCH 0/4] Add watchdog support for STM32MP1
This series: - sorts Kconfig entries in alphabetical order - enable watchdog support in SPL for STM32MP1 - adds watchdog support to STM32MP1 boards
Patrice Chotard (4): watchdog: Kconfig: Sort entry alphabetically ARM: dts: stm32mp: Add iwdg2 support for stm32mp157c watchdog: stm32mp: Add watchdog driver configs: stm32mp15: Enable WDT flags
MAINTAINERS | 1 + arch/arm/dts/stm32mp157-u-boot.dtsi | 4 ++ arch/arm/mach-stm32mp/Kconfig | 1 + configs/stm32mp15_basic_defconfig | 2 + configs/stm32mp15_trusted_defconfig | 2 + drivers/watchdog/Kconfig | 91 +++++++++++++----------- drivers/watchdog/Makefile | 1 + drivers/watchdog/stm32mp_wdt.c | 135 ++++++++++++++++++++++++++++++++++++ 8 files changed, 196 insertions(+), 41 deletions(-) create mode 100644 drivers/watchdog/stm32mp_wdt.c
To make adding new entry easier, sort Kconfig entries in alphabetical order.
Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
drivers/watchdog/Kconfig | 87 ++++++++++++++++++++++++------------------------ 1 file changed, 44 insertions(+), 43 deletions(-)
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 3bce0aa..4a3ff7a 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -26,6 +26,13 @@ config BCM2835_WDT This provides basic infrastructure to support BCM2835/2836 watchdog hardware, with a max timeout of ~15secs.
+config IMX_WATCHDOG + bool "Enable Watchdog Timer support for IMX and LSCH2 of NXP" + select HW_WATCHDOG + help + Select this to enable the IMX and LSCH2 of Layerscape watchdog + driver. + config OMAP_WATCHDOG bool "TI OMAP watchdog driver" depends on ARCH_OMAP2PLUS @@ -59,14 +66,6 @@ config WDT What exactly happens when the timer expires is up to a particular device/driver.
-config WDT_SANDBOX - bool "Enable Watchdog Timer support for Sandbox" - depends on SANDBOX && WDT - help - Enable Watchdog Timer support in Sandbox. This is a dummy device that - can be probed and supports all of the methods of WDT, but does not - really do anything. - config WDT_ARMADA_37XX bool "Marvell Armada 37xx watchdog timer support" depends on WDT && ARMADA_3700 @@ -87,6 +86,13 @@ config WDT_ASPEED It currently does not support Boot Flash Addressing Mode Detection or Second Boot.
+config WDT_AT91 + bool "AT91 watchdog timer support" + depends on WDT + help + Select this to enable Microchip watchdog timer, which can be found on + some AT91 devices. + config WDT_BCM6345 bool "BCM6345 watchdog timer support" depends on WDT && (ARCH_BMIPS || ARCH_BCM6858 || ARCH_BCM63158) @@ -95,14 +101,6 @@ config WDT_BCM6345 The watchdog timer is stopped when initialized. It performs full SoC reset.
-config WDT_ORION - bool "Orion watchdog timer support" - depends on WDT - select CLK - help - Select this to enable Orion watchdog timer, which can be found on some - Marvell Armada chips. - config WDT_CDNS bool "Cadence watchdog timer support" depends on WDT @@ -111,6 +109,20 @@ config WDT_CDNS Select this to enable Cadence watchdog timer, which can be found on some Xilinx Microzed Platform.
+config WDT_MPC8xx + bool "MPC8xx watchdog timer support" + depends on WDT && MPC8xx + select CONFIG_MPC8xx_WATCHDOG + help + Select this to enable mpc8xx watchdog timer + +config WDT_MT7621 + bool "MediaTek MT7621 watchdog timer support" + depends on WDT && ARCH_MT7620 + help + Select this to enable Ralink / Mediatek watchdog timer, + which can be found on some MediaTek chips. + config WDT_MTK bool "MediaTek watchdog timer support" depends on WDT && ARCH_MEDIATEK @@ -119,39 +131,28 @@ config WDT_MTK The watchdog timer is stopped when initialized. It performs full SoC reset.
-config XILINX_TB_WATCHDOG - bool "Xilinx Axi watchdog timer support" +config WDT_ORION + bool "Orion watchdog timer support" depends on WDT - imply WATCHDOG + select CLK help - Select this to enable Xilinx Axi watchdog timer, which can be found on some - Xilinx Microblaze Platforms. + Select this to enable Orion watchdog timer, which can be found on some + Marvell Armada chips.
-config IMX_WATCHDOG - bool "Enable Watchdog Timer support for IMX and LSCH2 of NXP" - select HW_WATCHDOG +config WDT_SANDBOX + bool "Enable Watchdog Timer support for Sandbox" + depends on SANDBOX && WDT help - Select this to enable the IMX and LSCH2 of Layerscape watchdog - driver. + Enable Watchdog Timer support in Sandbox. This is a dummy device that + can be probed and supports all of the methods of WDT, but does not + really do anything.
-config WDT_AT91 - bool "AT91 watchdog timer support" +config XILINX_TB_WATCHDOG + bool "Xilinx Axi watchdog timer support" depends on WDT + imply WATCHDOG help - Select this to enable Microchip watchdog timer, which can be found on - some AT91 devices. - -config WDT_MT7621 - bool "MediaTek MT7621 watchdog timer support" - depends on WDT && ARCH_MT7620 - help - Select this to enable Ralink / Mediatek watchdog timer, - which can be found on some MediaTek chips. - -config WDT_MPC8xx - bool "MPC8xx watchdog timer support" - depends on WDT && MPC8xx - help - Select this to enable mpc8xx watchdog timer + Select this to enable Xilinx Axi watchdog timer, which can be found on some + Xilinx Microblaze Platforms.
endmenu
- help
driver.
- config OMAP_WATCHDOG bool "TI OMAP watchdog driver" depends on ARCH_OMAP2PLUS
-config WDT_SANDBOX
- help
really do anything.
+config WDT_AT91
- depends on WDT
- help
some AT91 devices.
- config WDT_BCM6345 bool "BCM6345 watchdog timer support" depends on WDT && (ARCH_BMIPS || ARCH_BCM6858 || ARCH_BCM63158)
-config WDT_ORION
- depends on WDT
- select CLK
- help
+config WDT_MPC8xx
- select CONFIG_MPC8xx_WATCHDOG
- help
+config WDT_MT7621
- help
- config WDT_MTK bool "MediaTek watchdog timer support" depends on WDT && ARCH_MEDIATEK
+config WDT_ORION
- bool "Orion watchdog timer support" depends on WDT
- imply WATCHDOG
- select CLK help
+config WDT_SANDBOX
- depends on SANDBOX && WDT help
driver.
really do anything.
-config WDT_AT91
- bool "Xilinx Axi watchdog timer support" depends on WDT
- imply WATCHDOG help
some AT91 devices.
-config WDT_MT7621
- help
-config WDT_MPC8xx
- help
endmenu
Thanks, Stefan
This patch adds independent watchdog support for stm32mp157c in SPL.
arch/arm/dts/stm32mp157-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/stm32mp157-u-boot.dtsi b/arch/arm/dts/stm32mp157-u-boot.dtsi index ab6f673..09560e2 100644 --- a/arch/arm/dts/stm32mp157-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157-u-boot.dtsi @@ -140,3 +140,7 @@ compatible = "st,stm32-gpio"; u-boot,dm-pre-reloc; }; + +&iwdg2 { + u-boot,dm-pre-reloc; +};
This patch adds IWDG (Independent WatchDoG) support for STM32MP platform.
Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
MAINTAINERS | 1 + arch/arm/mach-stm32mp/Kconfig | 1 + drivers/watchdog/Kconfig | 8 +++ drivers/watchdog/Makefile | 1 + drivers/watchdog/stm32mp_wdt.c | 135 +++++++++++++++++++++++++++++++++++++++++ 5 files changed, 146 insertions(+) create mode 100644 drivers/watchdog/stm32mp_wdt.c
diff --git a/MAINTAINERS b/MAINTAINERS index 09f31cd..eec2603 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -311,6 +311,7 @@ F: drivers/ram/stm32mp1/ F: drivers/misc/stm32_rcc.c F: drivers/reset/stm32-reset.c F: drivers/spi/stm32_qspi.c +F: drivers/watchdog/stm32mp_wdt.c
ARM STM STV0991 M: Vikas Manocha vikas.manocha@st.com diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 73aa382..4e7cc2e 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -17,6 +17,7 @@ config SPL select SPL_DM_RESET select SPL_SERIAL_SUPPORT select SPL_SYSCON + select SPL_WATCHDOG_SUPPORT imply SPL_DISPLAY_PRINT imply SPL_LIBDISK_SUPPORT
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 4a3ff7a..d582abe 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -147,6 +147,14 @@ config WDT_SANDBOX can be probed and supports all of the methods of WDT, but does not really do anything.
+config WDT_STM32MP + bool "IWDG watchdog driver for STM32 MP's family" + depends on WDT + imply WATCHDOG + help + Enable the STM32 watchdog (IWDG) driver. Enable support to + configure STM32's on-SoC watchdog. + config XILINX_TB_WATCHDOG bool "Xilinx Axi watchdog timer support" depends on WDT diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 40b2f4b..a3ebff8 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -27,3 +27,4 @@ obj-$(CONFIG_WDT_CDNS) += cdns_wdt.o obj-$(CONFIG_WDT_MPC8xx) += mpc8xx_wdt.o obj-$(CONFIG_WDT_MT7621) += mt7621_wdt.o obj-$(CONFIG_WDT_MTK) += mtk_wdt.o +obj-$(CONFIG_WDT_STM32MP) += stm32mp_wdt.o diff --git a/drivers/watchdog/stm32mp_wdt.c b/drivers/watchdog/stm32mp_wdt.c new file mode 100644 index 0000000..82db2c6 --- /dev/null +++ b/drivers/watchdog/stm32mp_wdt.c @@ -0,0 +1,135 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2019, STMicroelectronics - All Rights Reserved + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <syscon.h> +#include <wdt.h> +#include <asm/io.h> +#include <linux/iopoll.h> + +/* IWDG registers */ +#define IWDG_KR 0x00 /* Key register */ +#define IWDG_PR 0x04 /* Prescaler Register */ +#define IWDG_RLR 0x08 /* ReLoad Register */ +#define IWDG_SR 0x0C /* Status Register */ + +/* IWDG_KR register bit mask */ +#define KR_KEY_RELOAD 0xAAAA /* Reload counter enable */ +#define KR_KEY_ENABLE 0xCCCC /* Peripheral enable */ +#define KR_KEY_EWA 0x5555 /* Write access enable */ + +/* IWDG_PR register bit values */ +#define PR_256 0x06 /* Prescaler set to 256 */ + +/* IWDG_RLR register values */ +#define RLR_MAX 0xFFF /* Max value supported by reload register */ + +/* IWDG_SR register bit values */ +#define SR_PVU BIT(0) /* Watchdog prescaler value update */ +#define SR_RVU BIT(1) /* Watchdog counter reload value update */ + +struct stm32mp_wdt_priv { + fdt_addr_t base; /* registers addr in physical memory */ + unsigned long wdt_clk_rate; /* Watchdog dedicated clock rate */ +}; + +static int stm32mp_wdt_reset(struct udevice *dev) +{ + struct stm32mp_wdt_priv *priv = dev_get_priv(dev); + + writel(KR_KEY_RELOAD, priv->base + IWDG_KR); + + return 0; +} + +static int stm32mp_wdt_start(struct udevice *dev, u64 timeout, ulong flags) +{ + struct stm32mp_wdt_priv *priv = dev_get_priv(dev); + int reload; + u32 val; + int ret; + + /* Prescaler fixed to 256 */ + reload = timeout * priv->wdt_clk_rate / 256; + if (reload > RLR_MAX + 1) + /* Force to max watchdog counter reload value */ + reload = RLR_MAX + 1; + else if (!reload) + /* Force to min watchdog counter reload value */ + reload = priv->wdt_clk_rate / 256; + + /* Set prescaler & reload registers */ + writel(KR_KEY_EWA, priv->base + IWDG_KR); + writel(PR_256, priv->base + IWDG_PR); + writel(reload - 1, priv->base + IWDG_RLR); + + /* Enable watchdog */ + writel(KR_KEY_ENABLE, priv->base + IWDG_KR); + + /* Wait for the registers to be updated */ + ret = readl_poll_timeout(priv->base + IWDG_SR, val, + val & (SR_PVU | SR_RVU), CONFIG_SYS_HZ); + + if (ret < 0) { + pr_err("Updating IWDG registers timeout"); + return -ETIMEDOUT; + } + + return 0; +} + +static int stm32mp_wdt_probe(struct udevice *dev) +{ + struct stm32mp_wdt_priv *priv = dev_get_priv(dev); + struct clk clk; + int ret; + + debug("IWDG init\n"); + + priv->base = devfdt_get_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) + return -EINVAL; + + /* Enable clock */ + ret = clk_get_by_name(dev, "pclk", &clk); + if (ret) + return ret; + + ret = clk_enable(&clk); + if (ret) + return ret; + + /* Get LSI clock */ + ret = clk_get_by_name(dev, "lsi", &clk); + if (ret) + return ret; + + priv->wdt_clk_rate = clk_get_rate(&clk); + + debug("IWDG init done\n"); + + return 0; +} + +static const struct wdt_ops stm32mp_wdt_ops = { + .start = stm32mp_wdt_start, + .reset = stm32mp_wdt_reset, +}; + +static const struct udevice_id stm32mp_wdt_match[] = { + { .compatible = "st,stm32mp1-iwdg" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(stm32mp_wdt) = { + .name = "stm32mp-wdt", + .id = UCLASS_WDT, + .of_match = stm32mp_wdt_match, + .priv_auto_alloc_size = sizeof(struct stm32mp_wdt_priv), + .probe = stm32mp_wdt_probe, + .ops = &stm32mp_wdt_ops, +};
- select SPL_WATCHDOG_SUPPORT imply SPL_DISPLAY_PRINT imply SPL_LIBDISK_SUPPORT
+config WDT_STM32MP
- bool "IWDG watchdog driver for STM32 MP's family"
- depends on WDT
- imply WATCHDOG
- help
- config XILINX_TB_WATCHDOG bool "Xilinx Axi watchdog timer support" depends on WDT
- Copyright (C) 2019, STMicroelectronics - All Rights Reserved
- fdt_addr_t base; /* registers addr in physical memory */
- unsigned long wdt_clk_rate; /* Watchdog dedicated clock rate */
- struct stm32mp_wdt_priv *priv = dev_get_priv(dev);
- writel(KR_KEY_RELOAD, priv->base + IWDG_KR);
s/timeout/timeout_ms (see below).
- int reload;
- u32 val;
- int ret;
- /* Prescaler fixed to 256 */
- reload = timeout * priv->wdt_clk_rate / 256;
Just checking, if this takes into account that timeout is passed in ms (milli-seconds) to the DM wdt_start() function. That's why I prefer to see timeout explicitly named to "timeout_ms" instead.
Thanks, Stefan
- if (reload > RLR_MAX + 1)
- else if (!reload)
- /* Set prescaler & reload registers */
- writel(KR_KEY_EWA, priv->base + IWDG_KR);
- writel(PR_256, priv->base + IWDG_PR);
- writel(reload - 1, priv->base + IWDG_RLR);
- /* Enable watchdog */
- writel(KR_KEY_ENABLE, priv->base + IWDG_KR);
- /* Wait for the registers to be updated */
- ret = readl_poll_timeout(priv->base + IWDG_SR, val,
- if (ret < 0) {
return -ETIMEDOUT;
- struct clk clk;
- int ret;
- debug("IWDG init\n");
- priv->base = devfdt_get_addr(dev);
- if (priv->base == FDT_ADDR_T_NONE)
return -EINVAL;
- /* Enable clock */
- ret = clk_get_by_name(dev, "pclk", &clk);
- if (ret)
return ret;
- ret = clk_enable(&clk);
- if (ret)
return ret;
- /* Get LSI clock */
- ret = clk_get_by_name(dev, "lsi", &clk);
- if (ret)
return ret;
- priv->wdt_clk_rate = clk_get_rate(&clk);
- debug("IWDG init done\n");
- .start = stm32mp_wdt_start,
- .reset = stm32mp_wdt_reset,
- { .compatible = "st,stm32mp1-iwdg" },
- { /* sentinel */ }
- .name = "stm32mp-wdt",
- .id = UCLASS_WDT,
- .of_match = stm32mp_wdt_match,
- .priv_auto_alloc_size = sizeof(struct stm32mp_wdt_priv),
- .probe = stm32mp_wdt_probe,
- .ops = &stm32mp_wdt_ops,
Viele Grüße, Stefan
Hi Stefan
diff --git a/MAINTAINERS b/MAINTAINERS index 09f31cd..eec2603 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -311,6 +311,7 @@ F: drivers/ram/stm32mp1/ F: drivers/misc/stm32_rcc.c F: drivers/reset/stm32-reset.c F: drivers/spi/stm32_qspi.c +F: drivers/watchdog/stm32mp_wdt.c ARM STM STV0991 M: Vikas Manocha vikas.manocha@st.com diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 73aa382..4e7cc2e 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -17,6 +17,7 @@ config SPL select SPL_DM_RESET select SPL_SERIAL_SUPPORT select SPL_SYSCON + select SPL_WATCHDOG_SUPPORT imply SPL_DISPLAY_PRINT imply SPL_LIBDISK_SUPPORT diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 4a3ff7a..d582abe 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -147,6 +147,14 @@ config WDT_SANDBOX can be probed and supports all of the methods of WDT, but does not really do anything. +config WDT_STM32MP + bool "IWDG watchdog driver for STM32 MP's family" + depends on WDT + imply WATCHDOG + help + Enable the STM32 watchdog (IWDG) driver. Enable support to + configure STM32's on-SoC watchdog.
+ return 0; +}
Ok, no problem, i will update and re-spin this series.
Thanks
Thanks, Stefan
+ return 0; +}
+ return 0; +}
Viele Grüße, Stefan
This allows to enable WATCHDOG and WDT flags to be able to reset the watchdog and to support watchdog driver model.
configs/stm32mp15_basic_defconfig | 2 ++ configs/stm32mp15_trusted_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index fd164fa..7252c14 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -77,3 +77,5 @@ CONFIG_USB_GADGET_MANUFACTURER="STMicroelectronics" CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_WDT=y +CONFIG_WDT_STM32MP=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index f82b770..52ee280 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -68,3 +68,5 @@ CONFIG_USB_GADGET_MANUFACTURER="STMicroelectronics" CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_WDT=y +CONFIG_WDT_STM32MP=y
Patrice CHOTARD
Patrice Chotard
Stefan Roese
