[PATCH] env: Add H_DEFAULT flag
Add another internal environment flag which indicates that the operation is resetting the environment to the default one. This allows the env code to discern between import of external environment and reset to default.
Signed-off-by: Marek Vasut marex@denx.de --- env/common.c | 3 ++- include/search.h | 1 + 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/env/common.c b/env/common.c index 088b2aebb4..0db56e610a 100644 --- a/env/common.c +++ b/env/common.c @@ -81,6 +81,7 @@ void env_set_default(const char *s, int flags) debug("Using default environment\n"); }
+ flags |= H_DEFAULT; if (himport_r(&env_htab, (char *)default_environment, sizeof(default_environment), '\0', flags, 0, 0, NULL) == 0) @@ -99,7 +100,7 @@ int env_set_default_vars(int nvars, char * const vars[], int flags) * Special use-case: import from default environment * (and use \0 as a separator) */ - flags |= H_NOCLEAR; + flags |= H_NOCLEAR | H_DEFAULT; return himport_r(&env_htab, (const char *)default_environment, sizeof(default_environment), '\0', flags, 0, nvars, vars); diff --git a/include/search.h b/include/search.h index bca36d3abc..c4b50c9630 100644 --- a/include/search.h +++ b/include/search.h @@ -112,5 +112,6 @@ int hwalk_r(struct hsearch_data *htab, #define H_MATCH_METHOD (H_MATCH_IDENT | H_MATCH_SUBSTR | H_MATCH_REGEX) #define H_PROGRAMMATIC (1 << 9) /* indicate that an import is from env_set() */ #define H_ORIGIN_FLAGS (H_INTERACTIVE | H_PROGRAMMATIC) +#define H_DEFAULT (1 << 10) /* indicate that an import is default env */
#endif /* _SEARCH_H_ */
