[PATCH] arm: allwinner: r40: update R40 DT files from linux 5.12-rc1
Update R40 .dts{,i} and dt-binding headers to current version from kernel.
Files taken from Linux 5.12-rc1 release (commit fe07bfda2fb9cdef8a4d4008a409bb02f35f1bd8)
Signed-off-by: Ivan Uvarov i.uvarov@cognitivepilot.com --- arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 23 +- arch/arm/dts/sun8i-r40.dtsi | 375 ++++++++++++++++-- arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts | 12 +- include/dt-bindings/clock/sun8i-r40-ccu.h | 6 +- .../interrupt-controller/arm-gic.h | 5 +- include/dt-bindings/thermal/thermal.h | 3 +- 6 files changed, 375 insertions(+), 49 deletions(-)
diff --git a/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts index c488aaacbd..a6a1087a0c 100644 --- a/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts +++ b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts @@ -129,7 +129,7 @@ pinctrl-names = "default"; pinctrl-0 = <&gmac_rgmii_pins>; phy-handle = <&phy1>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-supply = <®_dc1sw>; status = "okay"; }; @@ -164,6 +164,10 @@
#include "axp22x.dtsi"
+&ir0 { + status = "okay"; +}; + &mmc0 { vmmc-supply = <®_dcdc1>; bus-width = <4>; @@ -201,10 +205,15 @@ &pio { pinctrl-names = "default"; pinctrl-0 = <&clk_out_a_pin>; + vcc-pa-supply = <®_aldo2>; + vcc-pc-supply = <®_dcdc1>; + vcc-pd-supply = <®_dcdc1>; + vcc-pe-supply = <®_eldo1>; + vcc-pf-supply = <®_dcdc1>; + vcc-pg-supply = <®_dldo1>; };
®_aldo2 { - regulator-always-on; regulator-min-microvolt = <2500000>; regulator-max-microvolt = <2500000>; regulator-name = "vcc-pa"; @@ -218,16 +227,16 @@ };
®_dc1sw { - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; regulator-name = "vcc-gmac-phy"; };
®_dcdc1 { regulator-always-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-name = "vcc-3v0"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; };
®_dcdc2 { diff --git a/arch/arm/dts/sun8i-r40.dtsi b/arch/arm/dts/sun8i-r40.dtsi index 06b685869f..d5ad3b9efd 100644 --- a/arch/arm/dts/sun8i-r40.dtsi +++ b/arch/arm/dts/sun8i-r40.dtsi @@ -44,8 +44,10 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/clock/sun8i-de2.h> #include <dt-bindings/clock/sun8i-r40-ccu.h> +#include <dt-bindings/clock/sun8i-tcon-top.h> #include <dt-bindings/reset/sun8i-r40-ccu.h> #include <dt-bindings/reset/sun8i-de2.h> +#include <dt-bindings/thermal/thermal.h>
/ { #address-cells = <1>; @@ -78,25 +80,25 @@ #address-cells = <1>; #size-cells = <0>;
- cpu@0 { + cpu0: cpu@0 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0>; };
- cpu@1 { + cpu1: cpu@1 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <1>; };
- cpu@2 { + cpu2: cpu@2 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <2>; };
- cpu@3 { + cpu3: cpu@3 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <3>; @@ -109,6 +111,22 @@ status = "disabled"; };
+ thermal-zones { + cpu_thermal: cpu0-thermal { + /* milliseconds */ + polling-delay-passive = <0>; + polling-delay = <0>; + thermal-sensors = <&ths 0>; + }; + + gpu_thermal: gpu-thermal { + /* milliseconds */ + polling-delay-passive = <0>; + polling-delay = <0>; + thermal-sensors = <&ths 1>; + }; + }; + soc { compatible = "simple-bus"; #address-cells = <1>; @@ -118,11 +136,11 @@ display_clocks: clock@1000000 { compatible = "allwinner,sun8i-r40-de2-clk", "allwinner,sun8i-h3-de2-clk"; - reg = <0x01000000 0x100000>; - clocks = <&ccu CLK_DE>, - <&ccu CLK_BUS_DE>; - clock-names = "mod", - "bus"; + reg = <0x01000000 0x10000>; + clocks = <&ccu CLK_BUS_DE>, + <&ccu CLK_DE>; + clock-names = "bus", + "mod"; resets = <&ccu RST_BUS_DE>; #clock-cells = <1>; #reset-cells = <1>; @@ -172,6 +190,48 @@ }; };
+ deinterlace: deinterlace@1400000 { + compatible = "allwinner,sun8i-r40-deinterlace", + "allwinner,sun8i-h3-deinterlace"; + reg = <0x01400000 0x20000>; + clocks = <&ccu CLK_BUS_DEINTERLACE>, + <&ccu CLK_DEINTERLACE>, + /* + * NOTE: Contrary to what datasheet claims, + * DRAM deinterlace gate doesn't exist and + * it's shared with CSI1. + */ + <&ccu CLK_DRAM_CSI1>; + clock-names = "bus", "mod", "ram"; + resets = <&ccu RST_BUS_DEINTERLACE>; + interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; + interconnects = <&mbus 9>; + interconnect-names = "dma-mem"; + }; + + syscon: system-control@1c00000 { + compatible = "allwinner,sun8i-r40-system-control", + "allwinner,sun4i-a10-system-control"; + reg = <0x01c00000 0x30>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + sram_c: sram@1d00000 { + compatible = "mmio-sram"; + reg = <0x01d00000 0xd0000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x01d00000 0xd0000>; + + ve_sram: sram-section@0 { + compatible = "allwinner,sun8i-r40-sram-c1", + "allwinner,sun4i-a10-sram-c1"; + reg = <0x000000 0x80000>; + }; + }; + }; + nmi_intc: interrupt-controller@1c00030 { compatible = "allwinner,sun7i-a20-sc-nmi"; interrupt-controller; @@ -180,6 +240,69 @@ interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; };
+ dma: dma-controller@1c02000 { + compatible = "allwinner,sun8i-r40-dma", + "allwinner,sun50i-a64-dma"; + reg = <0x01c02000 0x1000>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_DMA>; + dma-channels = <16>; + dma-requests = <31>; + resets = <&ccu RST_BUS_DMA>; + #dma-cells = <1>; + }; + + spi0: spi@1c05000 { + compatible = "allwinner,sun8i-r40-spi", + "allwinner,sun8i-h3-spi"; + reg = <0x01c05000 0x1000>; + interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>; + clock-names = "ahb", "mod"; + resets = <&ccu RST_BUS_SPI0>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + spi1: spi@1c06000 { + compatible = "allwinner,sun8i-r40-spi", + "allwinner,sun8i-h3-spi"; + reg = <0x01c06000 0x1000>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_SPI1>; + clock-names = "ahb", "mod"; + resets = <&ccu RST_BUS_SPI1>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + csi0: csi@1c09000 { + compatible = "allwinner,sun8i-r40-csi0", + "allwinner,sun7i-a20-csi0"; + reg = <0x01c09000 0x1000>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_CSI0>, <&ccu CLK_CSI_SCLK>, + <&ccu CLK_DRAM_CSI0>; + clock-names = "bus", "isp", "ram"; + resets = <&ccu RST_BUS_CSI0>; + interconnects = <&mbus 5>; + interconnect-names = "dma-mem"; + status = "disabled"; + }; + + video-codec@1c0e000 { + compatible = "allwinner,sun8i-r40-video-engine"; + reg = <0x01c0e000 0x1000>; + clocks = <&ccu CLK_BUS_VE>, <&ccu CLK_VE>, + <&ccu CLK_DRAM_VE>; + clock-names = "ahb", "mod", "ram"; + resets = <&ccu RST_BUS_VE>; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + allwinner,sram = <&ve_sram 1>; + }; + mmc0: mmc@1c0f000 { compatible = "allwinner,sun8i-r40-mmc", "allwinner,sun50i-a64-mmc"; @@ -266,6 +389,38 @@ #phy-cells = <1>; };
+ crypto: crypto@1c15000 { + compatible = "allwinner,sun8i-r40-crypto"; + reg = <0x01c15000 0x1000>; + interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_CE>, <&ccu CLK_CE>; + clock-names = "bus", "mod"; + resets = <&ccu RST_BUS_CE>; + }; + + spi2: spi@1c17000 { + compatible = "allwinner,sun8i-r40-spi", + "allwinner,sun8i-h3-spi"; + reg = <0x01c17000 0x1000>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI2>, <&ccu CLK_SPI2>; + clock-names = "ahb", "mod"; + resets = <&ccu RST_BUS_SPI2>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + ahci: sata@1c18000 { + compatible = "allwinner,sun8i-r40-ahci"; + reg = <0x01c18000 0x1000>; + interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SATA>, <&ccu CLK_SATA>; + resets = <&ccu RST_BUS_SATA>; + reset-names = "ahci"; + status = "disabled"; + }; + ehci1: usb@1c19000 { compatible = "allwinner,sun8i-r40-ehci", "generic-ehci"; reg = <0x01c19000 0x100>; @@ -312,6 +467,19 @@ status = "disabled"; };
+ spi3: spi@1c1f000 { + compatible = "allwinner,sun8i-r40-spi", + "allwinner,sun8i-h3-spi"; + reg = <0x01c1f000 0x1000>; + interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI3>, <&ccu CLK_SPI3>; + clock-names = "ahb", "mod"; + resets = <&ccu RST_BUS_SPI3>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + ccu: clock@1c20000 { compatible = "allwinner,sun8i-r40-ccu"; reg = <0x01c20000 0x400>; @@ -322,8 +490,7 @@ };
rtc: rtc@1c20400 { - compatible = "allwinner,sun8i-r40-rtc", - "allwinner,sun8i-h3-rtc"; + compatible = "allwinner,sun8i-r40-rtc"; reg = <0x01c20400 0x400>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; clock-output-names = "osc32k", "osc32k-out"; @@ -347,6 +514,20 @@ function = "clk_out_a"; };
+ /omit-if-no-ref/ + csi0_8bits_pins: csi0-8bits-pins { + pins = "PE0", "PE2", "PE3", "PE4", "PE5", + "PE6", "PE7", "PE8", "PE9", "PE10", + "PE11"; + function = "csi0"; + }; + + /omit-if-no-ref/ + csi0_mclk_pin: csi0-mclk-pin { + pins = "PE1"; + function = "csi0"; + }; + gmac_rgmii_pins: gmac-rgmii-pins { pins = "PA0", "PA1", "PA2", "PA3", "PA4", "PA5", "PA6", "PA7", @@ -365,6 +546,36 @@ function = "i2c0"; };
+ i2c1_pins: i2c1-pins { + pins = "PB18", "PB19"; + function = "i2c1"; + }; + + i2c2_pins: i2c2-pins { + pins = "PB20", "PB21"; + function = "i2c2"; + }; + + i2c3_pins: i2c3-pins { + pins = "PI0", "PI1"; + function = "i2c3"; + }; + + i2c4_pins: i2c4-pins { + pins = "PI2", "PI3"; + function = "i2c4"; + }; + + ir0_pins: ir0-pins { + pins = "PB4"; + function = "ir0"; + }; + + ir1_pins: ir1-pins { + pins = "PB23"; + function = "ir1"; + }; + mmc0_pins: mmc0-pins { pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; @@ -390,6 +601,36 @@ bias-pull-up; };
+ /omit-if-no-ref/ + spi0_pc_pins: spi0-pc-pins { + pins = "PC0", "PC1", "PC2"; + function = "spi0"; + }; + + /omit-if-no-ref/ + spi0_cs0_pc_pin: spi0-cs0-pc-pin { + pins = "PC23"; + function = "spi0"; + }; + + /omit-if-no-ref/ + spi1_pi_pins: spi1-pi-pins { + pins = "PI17", "PI18", "PI19"; + function = "spi1"; + }; + + /omit-if-no-ref/ + spi1_cs0_pi_pin: spi1-cs0-pi-pin { + pins = "PI16"; + function = "spi1"; + }; + + /omit-if-no-ref/ + spi1_cs1_pi_pin: spi1-cs1-pi-pin { + pins = "PI15"; + function = "spi1"; + }; + uart0_pb_pins: uart0-pb-pins { pins = "PB22", "PB23"; function = "uart0"; @@ -409,6 +650,45 @@ wdt: watchdog@1c20c90 { compatible = "allwinner,sun4i-a10-wdt"; reg = <0x01c20c90 0x10>; + interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc24M>; + }; + + ir0: ir@1c21800 { + compatible = "allwinner,sun8i-r40-ir", + "allwinner,sun6i-a31-ir"; + reg = <0x01c21800 0x400>; + pinctrl-0 = <&ir0_pins>; + pinctrl-names = "default"; + clocks = <&ccu CLK_BUS_IR0>, <&ccu CLK_IR0>; + clock-names = "apb", "ir"; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + resets = <&ccu RST_BUS_IR0>; + status = "disabled"; + }; + + ir1: ir@1c21c00 { + compatible = "allwinner,sun8i-r40-ir", + "allwinner,sun6i-a31-ir"; + reg = <0x01c21c00 0x400>; + pinctrl-0 = <&ir1_pins>; + pinctrl-names = "default"; + clocks = <&ccu CLK_BUS_IR1>, <&ccu CLK_IR1>; + clock-names = "apb", "ir"; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + resets = <&ccu RST_BUS_IR1>; + status = "disabled"; + }; + + ths: thermal-sensor@1c24c00 { + compatible = "allwinner,sun8i-r40-ths"; + reg = <0x01c24c00 0x100>; + clocks = <&ccu CLK_BUS_THS>, <&ccu CLK_THS>; + clock-names = "bus", "mod"; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + resets = <&ccu RST_BUS_THS>; + /* TODO: add nvmem-cells for calibration */ + #thermal-sensor-cells = <1>; };
uart0: serial@1c28000 { @@ -518,6 +798,8 @@ interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C1>; resets = <&ccu RST_BUS_I2C1>; + pinctrl-0 = <&i2c1_pins>; + pinctrl-names = "default"; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -529,6 +811,8 @@ interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C2>; resets = <&ccu RST_BUS_I2C2>; + pinctrl-0 = <&i2c2_pins>; + pinctrl-names = "default"; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -540,6 +824,8 @@ interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C3>; resets = <&ccu RST_BUS_I2C3>; + pinctrl-0 = <&i2c3_pins>; + pinctrl-names = "default"; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -551,22 +837,33 @@ interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C4>; resets = <&ccu RST_BUS_I2C4>; + pinctrl-0 = <&i2c4_pins>; + pinctrl-names = "default"; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
- ahci: sata@1c18000 { - compatible = "allwinner,sun8i-r40-ahci"; - reg = <0x01c18000 0x1000>; - interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_SATA>, <&ccu CLK_SATA>; - resets = <&ccu RST_BUS_SATA>; - resets-name = "ahci"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - + mali: gpu@1c40000 { + compatible = "allwinner,sun8i-r40-mali", "arm,mali-400"; + reg = <0x01c40000 0x10000>; + interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gp", + "gpmmu", + "pp0", + "ppmmu0", + "pp1", + "ppmmu1", + "pmu"; + clocks = <&ccu CLK_BUS_GPU>, <&ccu CLK_GPU>; + clock-names = "bus", "core"; + resets = <&ccu RST_BUS_GPU>; };
gmac: ethernet@1c50000 { @@ -588,6 +885,16 @@ }; };
+ mbus: dram-controller@1c62000 { + compatible = "allwinner,sun8i-r40-mbus"; + reg = <0x01c62000 0x1000>; + clocks = <&ccu 155>; + #address-cells = <1>; + #size-cells = <1>; + dma-ranges = <0x00000000 0x40000000 0x80000000>; + #interconnect-cells = <1>; + }; + tcon_top: tcon-top@1c70000 { compatible = "allwinner,sun8i-r40-tcon-top"; reg = <0x01c70000 0x1000>; @@ -614,12 +921,9 @@ #size-cells = <0>;
tcon_top_mixer0_in: port@0 { - #address-cells = <1>; - #size-cells = <0>; reg = <0>;
- tcon_top_mixer0_in_mixer0: endpoint@0 { - reg = <0>; + tcon_top_mixer0_in_mixer0: endpoint { remote-endpoint = <&mixer0_out_tcon_top>; }; }; @@ -713,7 +1017,7 @@ compatible = "allwinner,sun8i-r40-tcon-tv"; reg = <0x01c73000 0x1000>; interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_TCON_TV0>, <&tcon_top 0>; + clocks = <&ccu CLK_BUS_TCON_TV0>, <&tcon_top CLK_TCON_TOP_TV0>; clock-names = "ahb", "tcon-ch1"; resets = <&ccu RST_BUS_TCON_TV0>; reset-names = "lcd"; @@ -756,7 +1060,7 @@ compatible = "allwinner,sun8i-r40-tcon-tv"; reg = <0x01c74000 0x1000>; interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_TCON_TV1>, <&tcon_top 1>; + clocks = <&ccu CLK_BUS_TCON_TV1>, <&tcon_top CLK_TCON_TOP_TV1>; clock-names = "ahb", "tcon-ch1"; resets = <&ccu RST_BUS_TCON_TV1>; reset-names = "lcd"; @@ -798,7 +1102,7 @@ gic: interrupt-controller@1c81000 { compatible = "arm,gic-400"; reg = <0x01c81000 0x1000>, - <0x01c82000 0x1000>, + <0x01c82000 0x2000>, <0x01c84000 0x2000>, <0x01c86000 0x2000>; interrupt-controller; @@ -818,7 +1122,7 @@ resets = <&ccu RST_BUS_HDMI1>; reset-names = "ctrl"; phys = <&hdmi_phy>; - phy-names = "hdmi-phy"; + phy-names = "phy"; status = "disabled";
ports { @@ -843,7 +1147,7 @@ compatible = "allwinner,sun8i-r40-hdmi-phy"; reg = <0x01ef0000 0x10000>; clocks = <&ccu CLK_BUS_HDMI1>, <&ccu CLK_HDMI_SLOW>, - <&ccu 7>, <&ccu 16>; + <&ccu CLK_PLL_VIDEO0>, <&ccu CLK_PLL_VIDEO1>; clock-names = "bus", "mod", "pll-0", "pll-1"; resets = <&ccu RST_BUS_HDMI0>; reset-names = "phy"; @@ -851,6 +1155,15 @@ }; };
+ pmu { + compatible = "arm,cortex-a7-pmu"; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; + }; + timer { compatible = "arm,armv7-timer"; interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, diff --git a/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts b/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts index 15c22b06fc..47954551f5 100644 --- a/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts +++ b/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts @@ -120,7 +120,7 @@ pinctrl-names = "default"; pinctrl-0 = <&gmac_rgmii_pins>; phy-handle = <&phy1>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-supply = <®_dc1sw>; status = "okay"; }; @@ -198,16 +198,16 @@ };
®_dcdc2 { diff --git a/include/dt-bindings/clock/sun8i-r40-ccu.h b/include/dt-bindings/clock/sun8i-r40-ccu.h index 4fa5f69fc2..d7337b55a4 100644 --- a/include/dt-bindings/clock/sun8i-r40-ccu.h +++ b/include/dt-bindings/clock/sun8i-r40-ccu.h @@ -43,6 +43,10 @@ #ifndef _DT_BINDINGS_CLK_SUN8I_R40_H_ #define _DT_BINDINGS_CLK_SUN8I_R40_H_
+#define CLK_PLL_VIDEO0 7 + +#define CLK_PLL_VIDEO1 16 + #define CLK_CPU 24
#define CLK_BUS_MIPI_DSI 29 @@ -172,7 +176,7 @@ #define CLK_AVS 152 #define CLK_HDMI 153 #define CLK_HDMI_SLOW 154 - +#define CLK_MBUS 155 #define CLK_DSI_DPHY 156 #define CLK_TVE0 157 #define CLK_TVE1 158 diff --git a/include/dt-bindings/interrupt-controller/arm-gic.h b/include/dt-bindings/interrupt-controller/arm-gic.h index 1ea1b702fe..35b6f69b7d 100644 --- a/include/dt-bindings/interrupt-controller/arm-gic.h +++ b/include/dt-bindings/interrupt-controller/arm-gic.h @@ -1,3 +1,4 @@ +/* SPDX-License-Identifier: GPL-2.0 OR MIT */ /* * This header provides constants for the ARM GIC. */ @@ -7,14 +8,14 @@
#include <dt-bindings/interrupt-controller/irq.h>
-/* interrupt specific cell 0 */ +/* interrupt specifier cell 0 */
#define GIC_SPI 0 #define GIC_PPI 1
/* * Interrupt specifier cell 2. - * The flaggs in irq.h are valid, plus those below. + * The flags in irq.h are valid, plus those below. */ #define GIC_CPU_MASK_RAW(x) ((x) << 8) #define GIC_CPU_MASK_SIMPLE(num) GIC_CPU_MASK_RAW((1 << (num)) - 1) diff --git a/include/dt-bindings/thermal/thermal.h b/include/dt-bindings/thermal/thermal.h index b5e6b0069a..bc7babb1a6 100644 --- a/include/dt-bindings/thermal/thermal.h +++ b/include/dt-bindings/thermal/thermal.h @@ -1,10 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* * This header provides constants for most thermal bindings. * * Copyright (C) 2013 Texas Instruments * Eduardo Valentin eduardo.valentin@ti.com - * - * GPLv2 only */
#ifndef _DT_BINDINGS_THERMAL_THERMAL_H
On Mon, 19 Apr 2021 12:30:57 +0300 Ivan Uvarov i.uvarov@cognitivepilot.com wrote:
Looks good to me, thanks for the work! Can confirm the files are identical to the one from the latest kernel (5.12-rc8). Also boot tested my BananaPi M2 Berry and briefly tested SD card, SATA, USB and network, both in U-Boot and Linux (using that DT).
Reviewed-by: Andre Przywara andre.przywara@arm.com
Thanks, Andre
- phy-mode = "rgmii-id"; phy-supply = <®_dc1sw>; status = "okay";
+&ir0 {
- status = "okay";
- vcc-pa-supply = <®_aldo2>;
- vcc-pc-supply = <®_dcdc1>;
- vcc-pd-supply = <®_dcdc1>;
- vcc-pe-supply = <®_eldo1>;
- vcc-pf-supply = <®_dcdc1>;
- vcc-pg-supply = <®_dldo1>;
®_aldo2 {
®_dc1sw {
- regulator-min-microvolt = <3300000>;
- regulator-max-microvolt = <3300000>; regulator-name = "vcc-gmac-phy";
- regulator-name = "vcc-3v3";
cpu@0 {
};cpu0: cpu@0 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0>;
cpu@1 {
};cpu1: cpu@1 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <1>;
cpu@2 {
};cpu2: cpu@2 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <2>;
cpu@3 {
- thermal-zones {
/* milliseconds */
/* milliseconds */
- soc { compatible = "simple-bus"; #address-cells = <1>;
<&ccu CLK_BUS_DE>;
"bus";
<&ccu CLK_DE>;
compatible =
claims,
exist and
compatible =
#size-cells = <1>;
ranges;
#size-cells = <1>;
compatible =
- nmi_intc: interrupt-controller@1c00030 { compatible = "allwinner,sun7i-a20-sc-nmi"; interrupt-controller;
#dma-cells = <1>;
spi0: spi@1c05000 {
CLK_SPI0>;
#size-cells = <0>;
spi1: spi@1c06000 {
CLK_SPI1>;
#size-cells = <0>;
csi0: csi@1c09000 {
CLK_CSI_SCLK>,
compatible =
<&ccu CLK_DRAM_VE>;
- mmc0: mmc@1c0f000 { compatible = "allwinner,sun8i-r40-mmc", "allwinner,sun50i-a64-mmc";
spi2: spi@1c17000 {
CLK_SPI2>;
#size-cells = <0>;
CLK_SATA>;
- ehci1: usb@1c19000 { compatible = "allwinner,sun8i-r40-ehci",
spi3: spi@1c1f000 {
CLK_SPI3>;
#size-cells = <0>;
- ccu: clock@1c20000 { compatible = "allwinner,sun8i-r40-ccu"; reg = <0x01c20000 0x400>;
rtc: rtc@1c20400 {
/omit-if-no-ref/
"PE5",
"PE10",
"PE11";
function = "csi0";
/omit-if-no-ref/
pins = "PE1";
function = "csi0";
function = "i2c1";
function = "i2c2";
function = "i2c3";
function = "i2c4";
pins = "PB4";
function = "ir0";
pins = "PB23";
function = "ir1";
/omit-if-no-ref/
function = "spi0";
/omit-if-no-ref/
pins = "PC23";
function = "spi0";
/omit-if-no-ref/
function = "spi1";
/omit-if-no-ref/
pins = "PI16";
function = "spi1";
/omit-if-no-ref/
pins = "PI15";
function = "spi1";
clocks = <&osc24M>;
ir0: ir@1c21800 {
ir1: ir@1c21c00 {
};pinctrl-names = "default"; status = "disabled"; #address-cells = <1>; #size-cells = <0>;
CLK_SATA>;
#size-cells = <0>;
mali: gpu@1c40000 {
"arm,mali-400";
<GIC_SPI 70
<GIC_SPI 71
<GIC_SPI 72
<GIC_SPI 74
<GIC_SPI 75
<GIC_SPI 73
"gpmmu",
"pp0",
"ppmmu0",
"pp1",
"ppmmu1",
"pmu";
#size-cells = <1>;
0x80000000>;
- tcon_top: tcon-top@1c70000 { compatible = "allwinner,sun8i-r40-tcon-top"; reg = <0x01c70000 0x1000>;
endpoint@0 {
reg = <0>;
0>;
1>;
phy-names = "phy"; status = "disabled"; ports {
- pmu {
<&cpu3>;
- timer { compatible = "arm,armv7-timer"; interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) |
®_dc1sw {
#define CLK_CPU 24
- This header provides constants for the ARM GIC.
- Interrupt specifier cell 2.
- The flaggs in irq.h are valid, plus those below.
- The flags in irq.h are valid, plus those below.
- This header provides constants for most thermal bindings.
- Copyright (C) 2013 Texas Instruments
- Eduardo Valentin eduardo.valentin@ti.com
- GPLv2 only
Andre Przywara
Ivan Uvarov
